1-
[code]bene:/home/benedicte# iwlist scanning
lo Interface doesn’t support scanning.
eth0 Interface doesn’t support scanning.
wmaster0 Interface doesn’t support scanning.
wlan0 Interface doesn’t support scanning : Network is down
-2
[code]bene:/home/benedicte# dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.26-2-686 (Debian 2.6.26-24) (dannf@debian.org) (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-25)) #1 SMP Mon Jun 21 05:58:44 UTC 2010
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000000fef0000 (usable)
[ 0.000000] BIOS-e820: 000000000fef0000 - 000000000fef3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000000fef3000 - 000000000ff00000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 254MB LOWMEM available.
[ 0.000000] Entering add_active_range(0, 0, 65264) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 65264
[ 0.000000] HighMem 65264 -> 65264
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 65264
[ 0.000000] On node 0 totalpages: 65264
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 478 pages used for memmap
[ 0.000000] Normal zone: 60690 pages, LIFO batch:15
[ 0.000000] HighMem zone: 0 pages used for memmap
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] DMI 2.2 present.
[ 0.000000] ACPI: RSDP 000F6F80, 0014 (r0 000000)
[ 0.000000] ACPI: RSDT 0FEF3000, 0028 (r1 000000 AWRDACPI 42302E31 AWRD 0)
[ 0.000000] ACPI: FACP 0FEF3040, 0074 (r1 000000 AWRDACPI 42302E31 AWRD 0)
[ 0.000000] ACPI: DSDT 0FEF30C0, 2D6C (r1 000000 AWRDACPI 1000 MSFT 100000C)
[ 0.000000] ACPI: FACS 0FEF0000, 0040
[ 0.000000] ACPI: PM-Timer IO Port: 0x4008
[ 0.000000] Allocating PCI resources starting at 10000000 (gap: 0ff00000:efc00000)
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] SMP: Allowing 0 CPUs, 0 hotplug CPUs
[ 0.000000] PERCPU: Allocating 37992 bytes of per cpu data
[ 0.000000] NR_CPUS: 8, nr_cpu_ids: 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64754
[ 0.000000] Kernel command line: root=/dev/hda1 ro quiet
[ 0.000000] Local APIC disabled by BIOS – you can enable it with “lapic”
[ 0.000000] mapped APIC to ffffb000 (0120c000)
[ 0.000000] Enabling fast FPU save and restore… done.
[ 0.000000] Enabling unmasked SIMD FPU exception support… done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 1024 (order: 10, 4096 bytes)
[ 0.000000] Detected 634.798 MHz processor.
[ 0.004000] Console: colour VGA+ 80x25
[ 0.004000] console [tty0] enabled
[ 0.004000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.004000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.004000] Memory: 248900k/261056k available (1771k kernel code, 11628k reserved, 750k data, 244k init, 0k highmem)
[ 0.004000] virtual kernel memory layout:
[ 0.004000] fixmap : 0xfff4c000 - 0xfffff000 ( 716 kB)
[ 0.004000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.004000] vmalloc : 0xd0800000 - 0xff7fe000 ( 751 MB)
[ 0.004000] lowmem : 0xc0000000 - 0xcfef0000 ( 254 MB)
[ 0.004000] .init : 0xc037f000 - 0xc03bc000 ( 244 kB)
[ 0.004000] .data : 0xc02badcd - 0xc0376620 ( 750 kB)
[ 0.004000] .text : 0xc0100000 - 0xc02badcd (1771 kB)
[ 0.004000] Checking if this processor honours the WP bit even in supervisor mode…Ok.
[ 0.004000] CPA: page pool initialized 1 of 1 pages preallocated
[ 0.084502] Calibrating delay using timer specific routine… 1271.57 BogoMIPS (lpj=2543142)
[ 0.084657] Security Framework initialized
[ 0.084688] SELinux: Disabled at boot.
[ 0.084703] Capability LSM initialized
[ 0.084768] Mount-cache hash table entries: 512
[ 0.085387] Initializing cgroup subsys ns
[ 0.085407] Initializing cgroup subsys cpuacct
[ 0.085417] Initializing cgroup subsys devices
[ 0.085512] CPU: L1 I cache: 16K, L1 D cache: 16K
[ 0.085525] CPU: L2 cache: 128K
[ 0.085545] Intel machine check architecture supported.
[ 0.085558] Intel machine check reporting enabled on CPU#0.
[ 0.085620] Checking ‘hlt’ instruction… OK.
[ 0.101114] SMP alternatives: switching to UP code
[ 0.115649] Freeing SMP alternatives: 16k freed
[ 0.115677] ACPI: Core revision 20080321
[ 0.127199] ACPI: setting ELCR to 0200 (from 0a28)
[ 0.132008] weird, boot CPU (#0) not listedby the BIOS.
[ 0.132008] SMP motherboard not detected.
[ 0.132008] Local APIC not detected. Using dummy APIC emulation.
[ 0.132008] SMP disabled
[ 0.132008] Brought up 1 CPUs
[ 0.132008] Total of 1 processors activated (1271.57 BogoMIPS).
[ 0.132008] CPU0 attaching sched-domain:
[ 0.132008] domain 0: span 0
[ 0.132008] groups: 0
[ 0.132008] net_namespace: 660 bytes
[ 0.132008] Booting paravirtualized kernel on bare hardware
[ 0.132008] NET: Registered protocol family 16
[ 0.132723] ACPI: bus type pci registered
[ 0.159685] PCI: PCI BIOS revision 2.10 entry at 0xfb0f0, last bus=1
[ 0.159701] PCI: Using configuration type 1 for base access
[ 0.159736] Setting up standard PCI resources
[ 0.166655] ACPI: EC: Look up EC in DSDT
[ 0.178933] ACPI: Interpreter enabled
[ 0.178958] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.179030] ACPI: Using PIC for interrupt routing
[ 0.200980] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.201637] pci 0000:00:1f.0: quirk: region 4000-407f claimed by ICH4 ACPI/GPIO/TCO
[ 0.201656] pci 0000:00:1f.0: quirk: region 4080-40bf claimed by ICH4 GPIO
[ 0.202472] PCI: Transparent bridge - 0000:00:1e.0
[ 0.202566] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PRT]
[ 0.203036] ACPI: PCI Interrupt Routing Table [_SB.PCI0.HUB0._PRT]
[ 0.210082] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.210455] ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.210796] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 11 12 14 15) *9
[ 0.211135] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.211963] Linux Plug and Play Support v0.97 © Adam Belay
[ 0.212262] pnp: PnP ACPI init
[ 0.212346] ACPI: bus type pnp registered
[ 0.230028] pnp: PnP ACPI: found 15 devices
[ 0.230045] ACPI: ACPI bus type pnp unregistered
[ 0.230061] PnPBIOS: Disabled by ACPI PNP
[ 0.231841] PCI: Using ACPI for IRQ routing
[ 0.232939] system 00:00: iomem range 0xca000-0xcffff has been reserved
[ 0.232960] system 00:00: iomem range 0xf0000-0xf7fff could not be reserved
[ 0.232971] system 00:00: iomem range 0xf8000-0xfbfff could not be reserved
[ 0.232982] system 00:00: iomem range 0xfc000-0xfffff could not be reserved
[ 0.232994] system 00:00: iomem range 0xfef0000-0xfefffff could not be reserved
[ 0.233005] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 0.233017] system 00:00: iomem range 0x100000-0xfeeffff could not be reserved
[ 0.233030] system 00:00: iomem range 0xffb00000-0xffb7ffff could not be reserved
[ 0.233042] system 00:00: iomem range 0xfff00000-0xffffffff could not be reserved
[ 0.233053] system 00:00: iomem range 0xe0000-0xeffff has been reserved
[ 0.233092] system 00:03: ioport range 0x290-0x297 has been reserved
[ 0.233103] system 00:03: ioport range 0x3f0-0x3f1 has been reserved
[ 0.233114] system 00:03: ioport range 0x4d0-0x4d1 has been reserved
[ 0.233125] system 00:03: ioport range 0x800-0x805 has been reserved
[ 0.265912] PCI: Bridge: 0000:00:1e.0
[ 0.265930] IO window: b000-cfff
[ 0.265944] MEM window: 0xd4000000-0xd40fffff
[ 0.265955] PREFETCH window: disabled.
[ 0.265987] PCI: Setting latency timer of device 0000:00:1e.0 to 64
[ 0.266112] NET: Registered protocol family 2
[ 0.266553] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.267440] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.267752] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.268207] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.268225] TCP reno registered
[ 0.268872] NET: Registered protocol family 1
[ 0.269373] checking if image is initramfs…<7>Switched to high resolution mode on CPU 0
[ 1.171654] it is
[ 2.343985] Freeing initrd memory: 6071k freed
[ 2.347134] audit: initializing netlink socket (disabled)
[ 2.347197] type=2000 audit(1280106869.344:1): initialized
[ 2.347685] Total HugeTLB memory allocated, 0
[ 2.348139] VFS: Disk quotas dquot_6.5.1
[ 2.348271] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.348448] msgmni has been set to 498
[ 2.349142] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 2.349166] io scheduler noop registered
[ 2.349174] io scheduler anticipatory registered
[ 2.349181] io scheduler deadline registered
[ 2.349253] io scheduler cfq registered (default)
[ 2.349309] pci 0000:00:01.0: Boot video device
[ 2.351426] isapnp: Scanning for PnP cards…
[ 2.706199] isapnp: No Plug & Play device found
[ 2.724000] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 2.724600] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.726762] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.736857] brd: module loaded
[ 2.737464] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 2.740912] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.740939] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 2.741871] mice: PS/2 mouse device common for all mice
[ 2.742656] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 2.742895] rtc0: alarms up to one month
[ 2.743150] cpuidle: using governor ladder
[ 2.743163] cpuidle: using governor menu
[ 2.743188] No iBFT detected.
[ 2.745179] TCP cubic registered
[ 2.745193] NET: Registered protocol family 17
[ 2.745220] Using IPI No-Shortcut mode
[ 2.746126] registered taskstats version 1
[ 2.747000] rtc_cmos 00:05: setting system clock to 2010-07-26 01:14:31 UTC (1280106871)
[ 2.748045] Freeing unused kernel memory: 244k freed
[ 2.770538] input: AT Translated Set 2 keyboard as /class/input/input0
[ 3.169832] ACPI: PNP0C0B:00 is registered as cooling_device0
[ 3.169861] ACPI: Fan [FAN] (on)
[ 3.200598] ACPI: CPU0 (power states: C1[C1] C2[C2])
[ 3.200876] ACPI: ACPI0007:00 is registered as cooling_device1
[ 3.200899] ACPI: Processor [CPU0] (supports 2 throttling states)
[ 3.210285] ACPI: LNXTHERM:01 is registered as thermal_zone0
[ 3.210863] ACPI: Thermal Zone [THRM] (31 C)
[ 4.956697] No dock devices found.
[ 5.490981] SCSI subsystem initialized
[ 5.619299] usbcore: registered new interface driver usbfs
[ 5.619416] usbcore: registered new interface driver hub
[ 5.619628] usbcore: registered new device driver usb
[ 6.046675] USB Universal Host Controller Interface driver v3.0
[ 6.047468] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 5
[ 6.047484] PCI: setting IRQ 5 as level-triggered
[ 6.047494] ACPI: PCI Interrupt 0000:00:1f.2[D] -> Link [LNKD] -> GSI 5 (level, low) -> IRQ 5
[ 6.047533] PCI: Setting latency timer of device 0000:00:1f.2 to 64
[ 6.047546] uhci_hcd 0000:00:1f.2: UHCI Host Controller
[ 6.047973] uhci_hcd 0000:00:1f.2: new USB bus registered, assigned bus number 1
[ 6.048127] uhci_hcd 0000:00:1f.2: irq 5, io base 0x0000d000
[ 6.048549] usb usb1: configuration #1 chosen from 1 choice
[ 6.048668] hub 1-0:1.0: USB hub found
[ 6.048718] hub 1-0:1.0: 2 ports detected
[ 6.049001] libata version 3.00 loaded.
[ 6.152641] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 6.152660] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.152671] usb usb1: Product: UHCI Host Controller
[ 6.152679] usb usb1: Manufacturer: Linux 2.6.26-2-686 uhci_hcd
[ 6.152687] usb usb1: SerialNumber: 0000:00:1f.2
[ 6.153431] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 3
[ 6.153447] PCI: setting IRQ 3 as level-triggered
[ 6.153456] ACPI: PCI Interrupt 0000:01:05.0[A] -> Link [LNKB] -> GSI 3 (level, low) -> IRQ 3
[ 6.153494] uhci_hcd 0000:01:05.0: UHCI Host Controller
[ 6.153654] uhci_hcd 0000:01:05.0: new USB bus registered, assigned bus number 2
[ 6.153716] uhci_hcd 0000:01:05.0: irq 3, io base 0x0000b400
[ 6.154117] usb usb2: configuration #1 chosen from 1 choice
[ 6.154240] hub 2-0:1.0: USB hub found
[ 6.154291] hub 2-0:1.0: 2 ports detected
[ 6.256640] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 6.256659] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.256670] usb usb2: Product: UHCI Host Controller
[ 6.256678] usb usb2: Manufacturer: Linux 2.6.26-2-686 uhci_hcd
[ 6.256686] usb usb2: SerialNumber: 0000:01:05.0
[ 6.257591] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
[ 6.257611] PCI: setting IRQ 11 as level-triggered
[ 6.257621] ACPI: PCI Interrupt 0000:01:05.1[B] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 6.257662] uhci_hcd 0000:01:05.1: UHCI Host Controller
[ 6.257832] uhci_hcd 0000:01:05.1: new USB bus registered, assigned bus number 3
[ 6.257896] uhci_hcd 0000:01:05.1: irq 11, io base 0x0000b800
[ 6.258344] usb usb3: configuration #1 chosen from 1 choice
[ 6.258472] hub 3-0:1.0: USB hub found
[ 6.258517] hub 3-0:1.0: 2 ports detected
[ 6.360547] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 6.360567] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.360577] usb usb3: Product: UHCI Host Controller
[ 6.360586] usb usb3: Manufacturer: Linux 2.6.26-2-686 uhci_hcd
[ 6.360594] usb usb3: SerialNumber: 0000:01:05.1
[ 6.384584] via-rhine.c:v1.10-LK1.4.3 2007-03-06 Written by Donald Becker
[ 6.384608] via-rhine: Broken BIOS detected, avoid_D3 enabled.
[ 6.385332] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
[ 6.385348] ACPI: PCI Interrupt 0000:01:04.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 6.391718] eth0: VIA Rhine III at 0x1b000, 00:40:f4:8b:ea:7d, IRQ 11.
[ 6.395123] eth0: MII PHY found at address 1, status 0x786d advertising 05e1 Link 45e1.
[ 6.507300] Uniform Multi-Platform E-IDE driver
[ 6.507324] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 6.545601] ACPI: PCI Interrupt 0000:01:05.2[C] -> Link [LNKD] -> GSI 5 (level, low) -> IRQ 5
[ 6.545669] ehci_hcd 0000:01:05.2: EHCI Host Controller
[ 6.545808] ehci_hcd 0000:01:05.2: new USB bus registered, assigned bus number 4
[ 6.545961] ehci_hcd 0000:01:05.2: irq 5, io mem 0xd4001000
[ 6.636207] usb 2-2: new full speed USB device using uhci_hcd and address 2
[ 6.648150] ehci_hcd 0000:01:05.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 6.648515] usb usb4: configuration #1 chosen from 1 choice
[ 6.648652] hub 4-0:1.0: USB hub found
[ 6.648699] hub 4-0:1.0: 4 ports detected
[ 6.704246] hub 2-0:1.0: unable to enumerate USB device on port 2
[ 6.752586] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.752604] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.752615] usb usb4: Product: EHCI Host Controller
[ 6.752623] usb usb4: Manufacturer: Linux 2.6.26-2-686 ehci_hcd
[ 6.752632] usb usb4: SerialNumber: 0000:01:05.2
[ 6.763499] ICH0: IDE controller (0x8086:0x2421 rev 0x01) at PCI slot 0000:00:1f.1
[ 6.763554] ICH0: not 100% native mode: will probe irqs later
[ 6.763590] ide0: BM-DMA at 0xf000-0xf007
[ 6.763614] ide1: BM-DMA at 0xf008-0xf00f
[ 6.763631] Probing IDE interface ide0…
[ 6.867832] Floppy drive(s): fd0 is 1.44M
[ 6.888681] FDC 0 is a post-1991 82077
[ 7.052369] hda: Maxtor 6K040L0, ATA DISK drive
[ 7.204196] usb 4-2: new high speed USB device using ehci_hcd and address 2
[ 7.332320] hdb: ST310212A, ATA DISK drive
[ 7.337920] usb 4-2: configuration #1 chosen from 1 choice
[ 7.338780] usb 4-2: New USB device found, idVendor=079b, idProduct=0062
[ 7.338797] usb 4-2: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[ 7.338808] usb 4-2: Product: 802.11b/g USB WLAN
[ 7.338815] usb 4-2: Manufacturer: ZyDAS
[ 7.388409] hda: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 7.388535] hda: UDMA/33 mode selected
[ 7.388656] hdb: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 7.388918] hdb: UDMA/33 mode selected
[ 7.389240] Probing IDE interface ide1…
[ 7.576186] usb 4-3: new high speed USB device using ehci_hcd and address 3
[ 7.737190] usb 4-3: configuration #1 chosen from 1 choice
[ 7.738298] usb 4-3: New USB device found, idVendor=07c4, idProduct=0601
[ 7.738315] usb 4-3: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[ 7.738326] usb 4-3: Product: MULTI READER
[ 7.738333] usb 4-3: Manufacturer: Datafab
[ 7.738340] usb 4-3: SerialNumber: 090410000404
[ 8.103865] Initializing USB Mass Storage driver…
[ 8.104448] scsi0 : SCSI emulation for USB Mass Storage devices
[ 8.104977] usbcore: registered new interface driver usb-storage
[ 8.104996] USB Mass Storage support registered.
[ 8.110479] usb-storage: device found at 3
[ 8.110496] usb-storage: waiting for device to settle before scanning
[ 8.346251] Marking TSC unstable due to: TSC halts in idle.
[ 8.404242] hdd: 40X12X48 CD-RW 1.00 20020412, ATAPI CD/DVD-ROM drive
[ 8.460268] hdd: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 8.460464] hdd: UDMA/33 mode selected
[ 8.460937] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 8.461054] ide1 at 0x170-0x177,0x376 on irq 15
[ 8.645850] hda: max request size: 128KiB
[ 10.765619] hda: 80293248 sectors (41110 MB) w/2048KiB Cache, CHS=65535/16/63
[ 10.765830] hda: cache flushes supported
[ 10.766035] hda: hda1 hda2 < hda5 hda6 >
[ 10.808605] hdb: max request size: 128KiB
[ 10.809821] hdb: 20005650 sectors (10242 MB) w/512KiB Cache, CHS=19846/16/63
[ 10.809843] hdb: cache flushes not supported
[ 10.810020] hdb: hdb1
[ 10.848104] hdd: ATAPI 48X CD-ROM CD-R/RW drive, 2048kB Cache
[ 10.848129] Uniform CD-ROM driver Revision: 3.20
[ 11.731228] PM: Starting manual resume from disk
[ 11.855806] kjournald starting. Commit interval 5 seconds
[ 11.855875] EXT3-fs: mounted filesystem with ordered data mode.
[ 13.108956] usb-storage: device scan complete
[ 13.117529] scsi 0:0:0:0: Direct-Access Datafab MULTI READER 9732 PQ: 0 ANSI: 0
[ 13.125661] scsi 0:0:0:1: Direct-Access Datafab MULTI READER 9732 PQ: 0 ANSI: 0
[ 13.134213] scsi 0:0:0:2: Direct-Access Datafab MULTI READER 9732 PQ: 0 ANSI: 0
[ 14.505686] udevd version 125 started
[ 17.096912] Driver ‘sd’ needs updating - please use bus_type methods
[ 17.098878] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 17.100687] sd 0:0:0:1: [sdb] Attached SCSI removable disk
[ 17.102457] sd 0:0:0:2: [sdc] Attached SCSI removable disk
[ 19.728993] input: PC Speaker as /class/input/input1
[ 20.684378] Linux agpgart interface v0.103
[ 20.824838] agpgart: Detected an Intel i810 Chipset.
[ 20.842400] agpgart: AGP aperture is 64M @ 0xd0000000
[ 20.858841] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 20.886740] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 21.100240] Intel 82802 RNG detected
[ 22.004561] input: ImPS/2 Generic Wheel Mouse as /class/input/input2
[ 22.710203] input: Power Button (FF) as /class/input/input3
[ 22.739316] ACPI: Power Button (FF) [PWRF]
[ 22.739575] input: Power Button (CM) as /class/input/input4
[ 22.764430] ACPI: Power Button (CM) [PWRB]
[ 22.764701] input: Sleep Button (CM) as /class/input/input5
[ 22.792289] ACPI: Sleep Button (CM) [SLPB]
[ 22.869830] parport_pc 00:0a: reported by Plug and Play ACPI
[ 22.869937] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 26.546611] gameport: NS558 PnP Gameport is pnp00:0e/gameport0, io 0x201, speed 784kHz
[ 30.100267] usb 4-2: reset high speed USB device using ehci_hcd and address 2
[ 30.234627] phy0: Selected rate control algorithm ‘pid’
[ 31.060568] zd1211rw 4-2:1.0: phy0
[ 31.060674] usbcore: registered new interface driver zd1211rw
[ 32.032767] ACPI: PCI Interrupt 0000:01:0a.0[A] -> Link [LNKD] -> GSI 5 (level, low) -> IRQ 5
[ 33.696498] Adding 746980k swap on /dev/hda5. Priority:-1 extents:1 across:746980k
[ 34.041536] EXT3 FS on hda1, internal journal
[ 34.743966] loop: module loaded
[ 35.709364] kjournald starting. Commit interval 5 seconds
[ 35.712477] EXT3 FS on hda6, internal journal
[ 35.712500] EXT3-fs: mounted filesystem with ordered data mode.
[ 38.655766] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 43.326978] NET: Registered protocol family 10
[ 43.329068] lo: Disabled Privacy Extensions
[ 43.923893] lp0: using parport0 (interrupt-driven).
[ 44.035045] ppdev: user-space parallel port driver
[ 48.055052] RPC: Registered udp transport module.
[ 48.055070] RPC: Registered tcp transport module.
[ 48.192177] Installing knfsd (copyright © 1996 okir@monad.swb.de).
[ 48.337759] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[ 48.358038] NFSD: starting 90-second grace period
[ 53.672083] eth0: no IPv6 routers present
[ 57.910104] NET: Registered protocol family 5
[ 61.226266] [drm] Initialized drm 1.1.0 20060810
[ 61.246634] ACPI: PCI Interrupt 0000:00:01.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 61.246668] PCI: Setting latency timer of device 0000:00:01.0 to 64
[ 61.247212] [drm] Initialized i810 1.4.0 20030605 on minor 0
[ 61.249122] mtrr: base(0xd0000000) is not aligned on a size(0x180000) boundary
[ 61.872732] [drm] Using v1.4 init.
[ 65.060044] [drm:drm_release] ERROR reclaim_buffers_locked() deadlock. Please rework this
[ 65.060057] driver to use reclaim_buffers_idlelocked() instead.
[ 65.060062] I will go on reclaiming the buffers anyway.
[ 6308.814830] usb 4-2: USB disconnect, address 2
[ 6318.548170] usb 4-2: new high speed USB device using ehci_hcd and address 4
[ 6318.681896] usb 4-2: configuration #1 chosen from 1 choice
[ 6318.796268] usb 4-2: reset high speed USB device using ehci_hcd and address 4
[ 6318.936517] phy1: Selected rate control algorithm ‘pid’
[ 6318.939371] zd1211rw 4-2:1.0: phy1
[ 6318.939727] usb 4-2: New USB device found, idVendor=079b, idProduct=0062
[ 6318.939741] usb 4-2: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[ 6318.939751] usb 4-2: Product: 802.11b/g USB WLAN
[ 6318.939759] usb 4-2: Manufacturer: ZyDAS
mais c’est de l’hebreux pour moi…
