Merci beaucoup!!!
J’ai installé une debian sarge PPC… marche bien sauf… Xfree (comme d’ab). J’ai un carte Nvidia qui marchait très bien sous YellowDog (1024x768/24b). J’ai d’ailleur sauvegarder le fichier de conf qui j’avais sous YDL et l’ai mis sur ma debian. J’utilise les drivers “nv”.
Seulement voila. kan je démarre Xfree j’ai droit a un écran noir
Se n’est pas un plantage de la machine puisque je peux me connecter via ssh a celle ci.
Quelqu’un vois la soluce???
[quote]# XFree86 4 configuration created by redhat-config-xfree86
Section “ServerLayout”
Identifier "Anaconda Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section “Files”
The location of the RGB database. Note, this is the name of the
file minus the extension (like “.txt” or “.db”). There is normally
no need to change the default.
Multiple FontPath entries are allowed (they are concatenated together)
By default, Red Hat 6.0 and later now use a font server independent of
the X server to render fonts.
RgbPath "/usr/X11R6/lib/X11/rgb"
FontPath "unix/:7100"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load “fbdevhw”
#Load "dri"
Load "glx"
Load "record"
Load "freetype"
Load "type1"
EndSection
Section “InputDevice”
Option “AutoRepeat” “500 5”
when using XQUEUE, comment out the above line, and uncomment the
following line
Option “Protocol” “Xqueue”
Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
Option “Xleds” “1 2 3”
To disable the XKEYBOARD extension, uncomment XkbDisable.
Option “XkbDisable”
To customise the XKB settings to suit your keyboard, modify the
lines below (which are the defaults). For example, for a non-U.S.
keyboard, you will probably want to use:
Option “XkbModel” “pc102”
If you have a US Microsoft Natural keyboard, you can use:
Option “XkbModel” “microsoft”
Then to change the language, change the Layout setting.
For example, a german layout can be obtained with:
Option “XkbLayout” “de”
or:
Option “XkbVariant” “nodeadkeys”
If you’d like to switch the positions of your capslock and
control keys, use:
Option “XkbOptions” “ctrl:swapcaps”
#Option "XkbOptions" ""
Identifier "Keyboard0"
Driver "keyboard"
Option "XkbRules" "xfree86"
Option "XkbModel" "macintosh"
Option "XkbLayout" "fr_CH"
#Option "XkbVariant" ""
EndSection
Section "InputDevice"
Identifier "Mouse0"
Driver "mouse"
Option “Protocol” "IMPS/2"
Option “Device” "/dev/input/mice"
Option “ZAxisMapping” "4 5"
Option “Emulate3Buttons” "no"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
HorizSync 30.0 - 70.0
VertRefresh 60.0 - 60.0
Option "dpms"
EndSection
Section “Device”
# no known options
#BusID
Identifier "Generic OF compatible"
Driver "nv"
VendorName "Generic OF compatible"
BoardName "NVIDIA GeForce"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Generic OF compatible"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes “1024x768” “800x600” "640x480"
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
Je songe serieusement a revendre mon PowerBook… c t une mauvaise idée a première vue
