Hello …
Et c’est parti mon kiki … Deux jours d’installation et déjà des interrogations sur ma sid toute fraîche.
après un apt-get update et apt-get upgrade j’ai :
root@new-host-2:/home/sorodje# apt-get upgrade
Les paquets suivants ont été conservés :
libavcodec52 libavformat52
firmware-linux-nonfree sudo
2 mis à jour, 0 nouvellement installés, 0 à enlever et 2 non mis à jour.
1 partiellement installés ou enlevés.
Il est nécessaire de prendre 0o/601ko dans les archives.
Après cette opération, 8 192o d'espace disque seront libérés.
Souhaitez-vous continuer [O/n] ? O
Lecture des fichiers de modifications (« changelog »)... Terminé
Paramétrage de initscripts (2.88dsf-8) ...
insserv: There is a loop at service gdm3 if started
insserv: There is a loop between service bootlogs and mountnfs if started
insserv: loop involving service mountnfs at depth 6
insserv: loop involving service nfs-common at depth 5
insserv: There is a loop between service gdm3 and bootlogs if started
insserv: loop involving service bootlogs at depth 10
insserv: loop involving service gdm3 at depth 9
insserv: loop involving service urandom at depth 10
insserv: There is a loop between service bootlogs and mountoverflowtmp if started
insserv: loop involving service mountoverflowtmp at depth 7
insserv: loop involving service mountall-bootclean at depth 6
insserv: There is a loop between service bootlogs and checkfs if started
insserv: loop involving service checkfs at depth 4
insserv: loop involving service checkroot at depth 3
insserv: loop involving service networking at depth 9
insserv: loop involving service mountall at depth 6
insserv: loop involving service mtab at depth 4
insserv: There is a loop between service gdm3 and bootlogd if started
insserv: loop involving service bootlogd at depth 3
insserv: loop involving service mountdevsubfs at depth 2
insserv: There is a loop between service bootlogs and mountall if started
insserv: loop involving service rsyslog at depth 15
insserv: loop involving service kbd at depth 15
insserv: loop involving service mountnfs-bootclean at depth 15
insserv: loop involving service hostname at depth 5
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg : erreur de traitement de initscripts (--configure) :
le sous-processus script post-installation installé a retourné une erreur de sortie d'état 1
initscripts
donne :
Les paquets suivants sont à demi configurés, probablement à cause de
problèmes survenus lors de la première configuration. Il faudrait réessayer
de les configurer en utilisant dpkg --configure <paquet> ou l'option
configure du menu de dselect :
initscripts scripts for initializing and shutting down the system
et un dpkg --configure initscripts redonne évidemment le message du dessus
Problème à la configuration de initscripts je suppose ?
Débutant sur sid , je dois faire quoi ? passer mon chemin en attendant des jours meilleurs ou m’attendre à des anomalies graves et dangereuses pour ma santé ou celle de mon système ?
j’ai rebooté sans souci et sans message d’erreur visible lors de la phase de démarrage et d’arrêt .
