Debian/sid et gnome 2.18.0
hello la communauté,
j’essaye de compiler sur une debian sid noyau 2.6.18-4 avec garnome le nouveau bureau gnome pour voir ce que ca donne…
seulement voila plantage dans la compilation et je sais pas trop ca tourne autour de glx je pense
voici le log enfin la fin de log
[quote]cc -DHAVE_CONFIG_H -I. -I. -I…/… -I…/…/src -I…/…/src -I/home/guigus/garnome/include -I/home/guigus/garnome/include -L/home/guigus/garnome/lib -O2 -pipe -Wall -Wpointer-arith -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wnested-externs -fno-strict-aliasing -MT glitz_glx_drawable.lo -MD -MP -MF .deps/glitz_glx_drawable.Tpo -c glitz_glx_drawable.c -fPIC -DPIC -o .libs/glitz_glx_drawable.o
In file included from glitz_glx_drawable.c:30:
glitz_glxint.h:34:19: error: GL/gl.h: No such file or directory
glitz_glxint.h:35:20: error: GL/glx.h: No such file or directory
In file included from glitz_glxint.h:37,
glitz_glxext.h:110: error: expected declaration specifiers or ‘…’ before 'GLXDrawable’
glitz_glxext.h:113: error: expected declaration specifiers or ‘…’ before 'GLXDrawable’
glitz_glxext.h:113: error: expected declaration specifiers or ‘…’ before 'GLXContext’
glitz_glxext.h:114: error: expected declaration specifiers or ‘…’ before ‘*’ token
glitz_glxext.h:116: error: expected declaration specifiers or ‘…’ before 'GLXContext’
glitz_glxext.h:116: warning: type defaults to ‘int’ in declaration of 'GLXContext’
glitz_glxext.h:116: error: ‘GLXContext’ declared as function returning a function
glitz_glxext.h:116: warning: function declaration isn’t a prototype
glitz_glxext.h:124: error: expected declaration specifiers or ‘…’ before 'GLXDrawable’
glitz_glxint.h:61: error: expected specifier-qualifier-list before 'glitz_glx_create_new_context_t’
glitz_glxint.h:88: error: field ‘context’ declared as a function
glitz_glxint.h:105: error: field ‘root_context’ declared as a function
glitz_glxint.h:117: error: expected specifier-qualifier-list before 'GLXDrawable’
glitz_glx_drawable.c:36: error: expected declaration specifiers or ‘…’ before 'GLXDrawable’
glitz_glx_drawable.c: In function ‘_glitz_glx_create_drawable’:
glitz_glx_drawable.c:49: error: ‘glitz_glx_drawable_t’ has no member named 'drawable’
glitz_glx_drawable.c:49: error: ‘glx_drawable’ undeclared (first use in this function)
glitz_glx_drawable.c:49: error: (Each undeclared identifier is reported only once
glitz_glx_drawable.c:49: error: for each function it appears in.)
glitz_glx_drawable.c:50: error: ‘glitz_glx_drawable_t’ has no member named 'pbuffer’
glitz_glx_drawable.c:51: error: ‘glitz_glx_drawable_t’ has no member named 'width’
glitz_glx_drawable.c:52: error: ‘glitz_glx_drawable_t’ has no member named 'height’
glitz_glx_drawable.c: In function ‘_glitz_glx_drawable_update_size’:
glitz_glx_drawable.c:80: error: ‘glitz_glx_drawable_t’ has no member named 'pbuffer’
glitz_glx_drawable.c:82: error: ‘glitz_glx_drawable_t’ has no member named 'pbuffer’
glitz_glx_drawable.c:83: error: ‘glitz_glx_drawable_t’ has no member named 'drawable’
glitz_glx_drawable.c:83: error: ‘glitz_glx_drawable_t’ has no member named 'pbuffer’
glitz_glx_drawable.c:87: error: ‘glitz_glx_drawable_t’ has no member named 'pbuffer’
glitz_glx_drawable.c:91: error: ‘glitz_glx_drawable_t’ has no member named 'width’
glitz_glx_drawable.c:92: error: ‘glitz_glx_drawable_t’ has no member named 'height’
glitz_glx_drawable.c: In function ‘_glitz_glx_create_pbuffer_drawable’:
glitz_glx_drawable.c:118: error: too many arguments to function '_glitz_glx_create_drawable’
glitz_glx_drawable.c: In function ‘glitz_glx_create_drawable_for_window’:
glitz_glx_drawable.c:169: error: too many arguments to function '_glitz_glx_create_drawable’
glitz_glx_drawable.c: In function ‘glitz_glx_destroy’:
glitz_glx_drawable.c:223: warning: implicit declaration of function 'glXGetCurrentDrawable’
glitz_glx_drawable.c:223: warning: nested extern declaration of 'glXGetCurrentDrawable’
glitz_glx_drawable.c:223: error: ‘glitz_glx_drawable_t’ has no member named 'drawable’
glitz_glx_drawable.c:224: warning: implicit declaration of function 'glXMakeCurrent’
glitz_glx_drawable.c:224: warning: nested extern declaration of 'glXMakeCurrent’
glitz_glx_drawable.c:227: error: ‘glitz_glx_drawable_t’ has no member named 'pbuffer’
glitz_glx_drawable.c:228: error: ‘glitz_glx_drawable_t’ has no member named 'pbuffer’
glitz_glx_drawable.c: In function ‘glitz_glx_swap_buffers’:
glitz_glx_drawable.c:239: warning: implicit declaration of function 'glXSwapBuffers’
glitz_glx_drawable.c:239: warning: nested extern declaration of 'glXSwapBuffers’
glitz_glx_drawable.c:240: error: ‘glitz_glx_drawable_t’ has no member named 'drawable’
glitz_glx_drawable.c: In function ‘glitz_glx_copy_sub_buffer’:
glitz_glx_drawable.c:258: error: ‘glitz_glx_static_proc_address_list_t’ has no member named 'copy_sub_buffer’
glitz_glx_drawable.c:259: error: ‘glitz_glx_drawable_t’ has no member named 'drawable’
make[9]: *** [glitz_glx_drawable.lo] Erreur 1
make[9]: quittant le répertoire « /home/guigus/garnome-2.18.0/freedesktop/glitz/work/main.d/glitz-0.5.6/src/glx »
make[8]: *** [all-recursive] Erreur 1
make[8]: quittant le répertoire « /home/guigus/garnome-2.18.0/freedesktop/glitz/work/main.d/glitz-0.5.6/src »
make[7]: *** [all-recursive] Erreur 1
make[7]: quittant le répertoire « /home/guigus/garnome-2.18.0/freedesktop/glitz/work/main.d/glitz-0.5.6 »
make[6]: *** [all] Erreur 2
make[6]: quittant le répertoire « /home/guigus/garnome-2.18.0/freedesktop/glitz/work/main.d/glitz-0.5.6 »
make[5]: *** [build-work/main.d/glitz-0.5.6/Makefile] Erreur 2
make[5]: quittant le répertoire « /home/guigus/garnome-2.18.0/freedesktop/glitz »
make[4]: *** […/…/freedesktop/glitz/cookies/main.d/install] Erreur 2
make[4]: quittant le répertoire « /home/guigus/garnome-2.18.0/freedesktop/cairo »
make[3]: *** […/…/freedesktop/cairo/cookies/main.d/install] Erreur 2
make[3]: quittant le répertoire « /home/guigus/garnome-2.18.0/platform/gtk+ »
make[2]: *** […/…/platform/gtk+/cookies/main.d/install] Erreur 2
make[2]: quittant le répertoire « /home/guigus/garnome-2.18.0/bindings/pygtk »
make[1]: *** […/…/bindings/pygtk/cookies/main.d/install] Erreur 2
make[1]: quittant le répertoire « /home/guigus/garnome-2.18.0/desktop/alacarte »
make: *** [paranoid-install] Erreur 2
guigus@debian-Sid:~/garnome-2.18.0/desktop$[/quote]
si quelqu’un a une idée pour me depatouiller bon pour le moment gnome 2.14.3 et xfce 4 marche bien mais je suis curieux de voir gnome 2.18 voilou…
a pluch
apt-cache search opengl dev
si c’est pour tester gnome 2.18 il y a gnome live 2.18
rpath.org/rbuilder/project/f … se?id=5451
