Debian SID ni clavier ni souris sous X
Après mise à jour de ma debian SID, je n’ai plus ni clavier ni souris dès que je lance X (sous xfce comme dwm) avec startx.
Voici ce que me donne dmesg :
[   45.731314] iwlwifi 0000:0c:00.0: Radio type=0x0-0x2-0x0
[   45.776086] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   50.352346] systemd-logind[2867]: New seat seat0.
[   50.365877] systemd-logind[2867]: Watching system buttons on /dev/input/event5 (Video Bus)
[   50.365960] systemd-logind[2867]: Watching system buttons on /dev/input/event7 (Power Button)
[   50.366033] systemd-logind[2867]: Watching system buttons on /dev/input/event6 (Lid Switch)
[   50.366111] systemd-logind[2867]: Watching system buttons on /dev/input/event8 (Sleep Button)
[   50.367532] systemd-logind[2867]: Failed to start user service, ignoring: Unknown unit: user@1000.service
[   50.374448] systemd-logind[2867]: New session 1 of user fred.
[   51.224240] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   57.534040] iwlwifi 0000:0c:00.0: L1 Enabled - LTR Disabled
[   57.537112] iwlwifi 0000:0c:00.0: L1 Enabled - LTR Disabled
[   57.537198] iwlwifi 0000:0c:00.0: Radio type=0x0-0x2-0x0
[   57.685371] iwlwifi 0000:0c:00.0: L1 Enabled - LTR Disabled
[   57.688405] iwlwifi 0000:0c:00.0: L1 Enabled - LTR Disabled
[   57.688491] iwlwifi 0000:0c:00.0: Radio type=0x0-0x2-0x0
[   57.721270] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   58.120280] e1000e: eth0 NIC Link is Down
[   58.324243] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   58.520072] iwlwifi 0000:0c:00.0: L1 Enabled - LTR Disabled
[   58.523101] iwlwifi 0000:0c:00.0: L1 Enabled - LTR Disabled
[   58.523187] iwlwifi 0000:0c:00.0: Radio type=0x0-0x2-0x0
[   58.669843] iwlwifi 0000:0c:00.0: L1 Enabled - LTR Disabled
[   58.672908] iwlwifi 0000:0c:00.0: L1 Enabled - LTR Disabled
[   58.673005] iwlwifi 0000:0c:00.0: Radio type=0x0-0x2-0x0
[   58.706011] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   63.980868] wlan0: authenticate with f4:ca:e5:9f:5e:94
[   63.986170] wlan0: send auth to f4:ca:e5:9f:5e:94 (try 1/3)
[   63.988765] wlan0: authenticated
[   63.992031] wlan0: associate with f4:ca:e5:9f:5e:94 (try 1/3)
[   63.995450] wlan0: RX AssocResp from f4:ca:e5:9f:5e:94 (capab=0x411 status=0 aid=3)
[   64.004960] wlan0: associated
[   64.004995] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   71.781413] systemd-logind[2867]: New session 2 of user fred.
[   77.068773] systemd-logind[2867]: Existing logind session ID 2 used by new audit session, ignoring
[   77.069838] systemd-logind[2867]: Failed to start user service, ignoring: Unknown unit: user@0.service
Quels sont les paquets qui ont été installés/mis à jour dernièrement ?
Un énorme paquet, je ne sais pas comment récupérer la liste exacte.
Ça doit être un problème de droits, car si je lance startx en tant que root (je sais c’est déconseillé) ça marche.
Par exemple
tail /var/log/apt/history.log
Merci :slight_smile:
La mise à jour d’hier (je fais un pastebin c’est très long) :
http://pastebin.com/LTG63iQ6
La mise à jour d’aujourd’hui : (le problème était déjà existant)
Start-Date: 2016-12-18  09:51:03
Upgrade: xserver-xorg-input-synaptics:amd64 (1.8.3-2, 1.9.0-1+b1), xserver-xorg-video-nouveau:amd64 (1:1.0.13-1, 1:1.0.13-1+b1), xserver-xorg-core:amd64 (2:1.18.4-2, 2:1.19.0-3), xserver-xorg-input-libinput:amd64 (0.20.0-1, 0.23.0-1), xserver-xorg-input-wacom:amd64 (0.33.0-1, 0.33.0-1+b1), xserver-xorg-input-evdev:amd64 (1:2.10.3-1, 1:2.10.4-1+b1), xserver-xorg-input-mouse:amd64 (1:1.9.1-1+b1, 1:1.9.2-1+b1)
Remove: xserver-xorg-input-vmmouse:amd64 (1:13.1.0-1+b1)
Il y a eu une erreur le 17.
Que donne ?
dpkg --configure -a
Rien, mais l’erreur était avec nginx, donc à priori ça n’a rien à voir. Je l’ai fixé depuis.
Ok.
J’aurais bien accusé xserver-xorg-input-libinput mais si le problème existait déjà le 17…
Je ne serais pas surpris que ce soit un problème de droits, vu qu’en root tout marche.
Mais je ne sais pas ou regarder.
J’ai suivi ça qui semble similaire :
https://bbs.archlinux.org/viewtopic.php?id=186946
Mais avec allowed_users=console comme avec allowed_users=anybody ça ne change rien.
Je vais essayer de reconfigurer xserver-xorg-input.libinput.
S’ils ne sont plus nécessaires, supprimer les paquets input suivants
  • xserver-xorg-input-evdev
  • xserver-xorg-input-mouse
  • xserver-xorg-input-synaptics
  • xserver-xorg-input-vmmouse
En principe, seuls libinput et wacom (éventuellement) suffisent.
J’ai fait le ménage mais ça ne change rien à mon problème :confused:
Il y a ces deux lignes qui m’inquiètent qd je fais un dmeg:
[  110.972925] systemd-logind[2858]: Failed to start user service, ignoring: Unknown unit: user@1000.service
[  571.521208] systemd-logind[2858]: Existing logind session ID 2 used by new audit session, ignoring
[  571.522210] systemd-logind[2858]: Failed to start user service, ignoring: Unknown unit: user@0.service
L’upgrade avait supprimé mes users standards du groupe “input”.
C’est résolu :slight_smile:
Merci pour votre aide :slight_smile:
Pas sûr que ce groupe contienne des utilisateurs…
Ça a pourtant résolu le problème
avec une sid ou testing il est vivement recommandé d’installer le paquet apt-listbugs qui signale les paquets buggés au moment de l’upgrade; ça évite bien des désagréments.
