j’ai réinstallé tout proprement debian 9 sur mon ordi (lenovo Z50)
Au démarrage, il est vraiment très lent et j’ai tout un tas de messages d’erreur.
la commande dmesg -l err me donne
[ 3.318836] bluetooth hci0: firmware: failed to load rtl_bt/rtl8723b_config.bin (-2)
[ 3.318849] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_config.bin
[ 3.318864] bluetooth hci0: firmware: failed to load rtl_bt/rtl8723b_fw.bin (-2)
[ 3.318870] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_fw.bin
[ 3.358856] rtl8723be 0000:02:00.0: firmware: failed to load rtlwifi/rtl8723befw.bin (-2)
[ 3.393471] kvm: disabled by bios
[ 3.418514] ACPI Error: [\_SB_.PCI0.GFX0.DD02._BCL] Namespace lookup failure, AE_NOT_FOUND (20160831/psargs-359)
[ 3.418531] ACPI Error: Method parse/execution failed [\_SB.PCI0.RP05.PEGP.DD02._BCL] (Node ffff8e0c4aa03780), AE_NOT_FOUND (20160831/psparse-543)
[ 3.568594] nouveau 0000:03:00.0: DRM: Pointer to TMDS table invalid
[ 3.568599] nouveau 0000:03:00.0: DRM: Pointer to flat panel table invalid
[ 5.048659] r8169 0000:01:00.0: firmware: failed to load rtl_nic/rtl8168g-3.fw (-2)
[ 26.069895] INFO: rcu_sched self-detected stall on CPU
[ 26.069904] 3-...: (5250 ticks this GP) idle=18f/140000000000001/0 softirq=1488/1488 fqs=2617
[ 26.069906] (t=5250 jiffies g=-37 c=-38 q=7266)
[ 56.570218] INFO: rcu_sched self-detected stall on CPU
[ 56.570227] 0-...: (5250 ticks this GP) idle=b8b/140000000000001/0 softirq=1857/1866 fqs=2625
[ 56.570229] (t=5251 jiffies g=-34 c=-35 q=4047)
[ 88.162553] INFO: rcu_sched self-detected stall on CPU
[ 88.162562] 2-...: (5250 ticks this GP) idle=755/140000000000001/0 softirq=2758/2758 fqs=2611
[ 88.162564] (t=5250 jiffies g=48 c=47 q=2886)
[ 138.563358] nouveau 0000:03:00.0: bus: MMIO write of 0000001f FAULT at 6013d4 [ IBUS ]
[ 146.033019] nouveau 0000:03:00.0: bus: MMIO write of 0000001f FAULT at 6013d4 [ IBUS ]
[ 146.033119] nouveau 0000:03:00.0: bus: MMIO write of badf1001 FAULT at 50405c [ IBUS ]
[ 457.201569] nouveau 0000:03:00.0: bus: MMIO write of 8000001f FAULT at 6013d4 [ IBUS ]
[ 819.820990] nouveau 0000:03:00.0: bus: MMIO write of 0000001f FAULT at 6013d4 [ IBUS ]
[ 1649.120174] nouveau 0000:03:00.0: bus: MMIO write of 0000001f FAULT at 6013d4 [ IBUS ]
la wifi galérait mais après un petit recovery mode, ça s’est mis à fonctionner, par contre pas de bluetooth…
merci d’avance pour votre aide!
