depuis hier soir ma passerelle ne fonctionne plus
je manipule un peu ipv6
[code]
root@alpha30:/etc/network# pg interfaces
This file describes the network interfaces available on your system
auto lo
iface lo inet loopback
iface enp0s7 inet auto
address 192.168.1.30
netmask 255.255.255.0
gateway 192.168.1.1
#dns-domain example.com
dns-nameservers 193.252.19.3
iface enp0s8 inet auto
address 10.0.0.30
gateway 192.168.1.1
root@alpha30:/etc/network# ifconfig -a
enp7s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.30 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::1e6f:65ff:fe3d:3516 prefixlen 64 scopeid 0x20
ether 1c:6f:65:3d:35:16 txqueuelen 1000 (Ethernet)
RX packets 160716 bytes 163593641 (156.0 MiB)
RX errors 0 dropped 10572 overruns 0 frame 0
TX packets 90742 bytes 8711970 (8.3 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp8s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.0.0.30 netmask 255.0.0.0 broadcast 10.255.255.255
inet6 fe80::20c:76ff:feae:b556 prefixlen 64 scopeid 0x20
ether 00:0c:76:ae:b5:56 txqueuelen 1000 (Ethernet)
RX packets 17593 bytes 2077786 (1.9 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 21349 bytes 21016210 (20.0 MiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Boucle locale)
RX packets 140 bytes 436207 (425.9 KiB)
TX packets 140 bytes 436207 (425.9 KiB)
root@alpha30:/etc/network# ip6tables -L
Chain INPUT (policy DROP)
target prot opt source destination
ACCEPT all anywhere anywhere
ACCEPT all anywhere anywhere state RELATED,ESTABLISHED
LOG icmp anywhere anywhere LOG level warning
DROP icmp anywhere anywhere
ACCEPT tcp anywhere anywhere tcp dpt:http
ACCEPT tcp anywhere anywhere tcp dpt:https
ACCEPT tcp anywhere anywhere tcp dpt:mysql
ACCEPT tcp anywhere anywhere tcp dpt:netbios-ns
ACCEPT tcp anywhere anywhere tcp dpt:netbios-dgm
ACCEPT tcp anywhere anywhere tcp dpt:netbios-ssn
ACCEPT tcp anywhere anywhere tcp dpt:microsoft-ds
ACCEPT tcp anywhere anywhere tcp dpt:ipp
ACCEPT udp anywhere anywhere udp dpt:80
ACCEPT udp anywhere anywhere udp dpt:443
ACCEPT udp anywhere anywhere udp dpt:mysql
ACCEPT udp anywhere anywhere udp dpt:netbios-ns
ACCEPT udp anywhere anywhere udp dpt:netbios-dgm
ACCEPT udp anywhere anywhere udp dpt:netbios-ssn
ACCEPT udp anywhere anywhere udp dpt:microsoft-ds
ACCEPT udp anywhere anywhere udp dpt:ipp
ACCEPT icmp anywhere anywhere
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmp router-solicitation HL match HL == 255
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmp neighbour-solicitation HL match HL == 255
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmp neighbour-advertisement HL match HL == 255
LOG all anywhere anywhere LOG level warning
Chain FORWARD (policy DROP)
Chain OUTPUT (policy ACCEPT)
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmp router-advertisement
root@alpha30:/etc/network# cd /home/jb1
root@alpha30:/home/jb1# ./res*
- /sbin/ifconfig enp7s0 192.168.1.30
- /sbin/ifconfig enp8s0 10.0.0.30
- /sbin/route add default gw 192.168.1.1 dev enp7s0
SIOCADDRT: Le fichier existe - /home/jb1/fw.sh restart
- . /lib/lsb/init-functions
- run-parts --lsbsysinit --list /lib/lsb/init-functions.d
- [ -r /lib/lsb/init-functions.d/20-left-info-blocks ]
- . /lib/lsb/init-functions.d/20-left-info-blocks
- [ -r /lib/lsb/init-functions.d/40-systemd ]
- . /lib/lsb/init-functions.d/40-systemd
- _use_systemctl=0
- [ -d /run/systemd/system ]
- prog=fw.sh
- service=fw.service
- systemctl -p LoadState --value show fw.service
- state=not-found
- [ not-found = masked ]
- [ 2495 -ne 1 ]
- [ -z ]
- readlink -f /home/jb1/fw.sh
- [ 0 = 1 ]
- FANCYTTY=
- [ -e /etc/lsb-base-logging.sh ]
- true
- IPV6=1
- TCP_SERVICES=80 443 3306 137 138 139 445 631
- UDP_SERVICES=80 443 3306 137 138 139 445 631
- REMOTE_TCP_SERVICES=
- REMOTE_UDP_SERVICES=
- ISROUTERNAT=true
- ethx=enp8s0
- ethy=enp7s0
- readonly IPTABLES=/sbin/iptables
- readonly IP6TABLES=/sbin/ip6tables
- [ -x /sbin/iptables ]
- [ 1 -eq 1 ]
- [ -x /sbin/ip6tables ]
- log_daemon_msg Starting firewall…
- [ -z Starting firewall… ]
- log_daemon_msg_pre Starting firewall…
- log_use_fancy_output
- TPUT=/usr/bin/tput
- EXPR=/usr/bin/expr
- [ -t 1 ]
- [ xxterm != x ]
- [ xxterm != xdumb ]
- [ -x /usr/bin/tput ]
- [ -x /usr/bin/expr ]
- /usr/bin/tput hpa 60
- /usr/bin/tput setaf 1
- [ -z ]
- FANCYTTY=1
- true
- echo -n […]
[…] + [ -z ] - echo -n Starting firewall…:
Starting firewall…:+ return - fw_start
- fw_clear
- /sbin/iptables -t filter -F
- /sbin/iptables -t nat -F
- /sbin/iptables -t mangle -F
- /sbin/iptables -t raw -F
- /sbin/iptables -t filter -P INPUT ACCEPT
- /sbin/iptables -t filter -P OUTPUT ACCEPT
- /sbin/iptables -t filter -P FORWARD ACCEPT
- /sbin/iptables -t nat -P PREROUTING ACCEPT
- /sbin/iptables -t nat -P POSTROUTING ACCEPT
- /sbin/iptables -t nat -P OUTPUT ACCEPT
- /sbin/iptables -t mangle -P PREROUTING ACCEPT
- /sbin/iptables -t mangle -P OUTPUT ACCEPT
- /sbin/iptables -t mangle -P POSTROUTING ACCEPT
- /sbin/iptables -t mangle -P FORWARD ACCEPT
- /sbin/iptables -t mangle -P INPUT ACCEPT
- /sbin/iptables -t raw -P OUTPUT ACCEPT
- /sbin/iptables -t raw -P PREROUTING ACCEPT
- /sbin/iptables -F
- [ 1 -eq 1 ]
- /sbin/ip6tables -t filter -F
- /sbin/ip6tables -t nat -F
- /sbin/ip6tables -t mangle -F
- /sbin/ip6tables -t raw -F
- /sbin/ip6tables -t filter -P INPUT ACCEPT
- /sbin/ip6tables -t filter -P OUTPUT ACCEPT
- /sbin/ip6tables -t filter -P FORWARD ACCEPT
- /sbin/ip6tables -t nat -P PREROUTING ACCEPT
- /sbin/ip6tables -t nat -P POSTROUTING ACCEPT
- /sbin/ip6tables -t nat -P OUTPUT ACCEPT
- /sbin/ip6tables -t mangle -P PREROUTING ACCEPT
- /sbin/ip6tables -t mangle -P OUTPUT ACCEPT
- /sbin/ip6tables -t mangle -P POSTROUTING ACCEPT
- /sbin/ip6tables -t mangle -P FORWARD ACCEPT
- /sbin/ip6tables -t mangle -P INPUT ACCEPT
- /sbin/ip6tables -t raw -P OUTPUT ACCEPT
- /sbin/ip6tables -t raw -P PREROUTING ACCEPT
- /sbin/ip6tables -F
- /sbin/iptables -t filter -P INPUT DROP
- /sbin/iptables -t filter -P FORWARD DROP
- /sbin/iptables -t filter -P OUTPUT DROP
- /sbin/iptables -t filter -A INPUT -i lo -j ACCEPT
- /sbin/iptables -t filter -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
- [ -z ]
- [ -z ]
- /sbin/iptables -A INPUT -p tcp --dport 80 -j ACCEPT
- /sbin/iptables -A INPUT -p tcp --dport 443 -j ACCEPT
- /sbin/iptables -A INPUT -p tcp --dport 3306 -j ACCEPT
- /sbin/iptables -A INPUT -p tcp --dport 137 -j ACCEPT
- /sbin/iptables -A INPUT -p tcp --dport 138 -j ACCEPT
- /sbin/iptables -A INPUT -p tcp --dport 139 -j ACCEPT
- /sbin/iptables -A INPUT -p tcp --dport 445 -j ACCEPT
- /sbin/iptables -A INPUT -p tcp --dport 631 -j ACCEPT
- /sbin/iptables -A INPUT -p udp --dport 80 -j ACCEPT
- /sbin/iptables -A INPUT -p udp --dport 443 -j ACCEPT
- /sbin/iptables -A INPUT -p udp --dport 3306 -j ACCEPT
- /sbin/iptables -A INPUT -p udp --dport 137 -j ACCEPT
- /sbin/iptables -A INPUT -p udp --dport 138 -j ACCEPT
- /sbin/iptables -A INPUT -p udp --dport 139 -j ACCEPT
- /sbin/iptables -A INPUT -p udp --dport 445 -j ACCEPT
- /sbin/iptables -A INPUT -p udp --dport 631 -j ACCEPT
- true
- /sbin/iptables -A INPUT -i enp8s0 -j ACCEPT
- /sbin/iptables -A INPUT -p icmp -j ACCEPT
- /sbin/iptables -A FORWARD -i enp7s0 -o enp8s0 -m state --state RELATED,ESTABLISHED -j ACCEPT
- /sbin/iptables -A FORWARD -o enp7s0 -j ACCEPT
- /sbin/iptables -t nat -A POSTROUTING -o enp7s0 -j MASQUERADE
- /sbin/iptables -t filter -A INPUT -j LOG --log-level=4
- [ 1 -eq 1 ]
- /sbin/ip6tables -t filter -P INPUT DROP
- /sbin/ip6tables -t filter -P FORWARD DROP
- /sbin/ip6tables -t filter -P OUTPUT DROP
- /sbin/ip6tables -t filter -A INPUT -i lo -j ACCEPT
- /sbin/ip6tables -t filter -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
- /sbin/ip6tables -t filter -A INPUT -p icmp -j LOG
- /sbin/ip6tables -t filter -A INPUT -p icmp -j DROP
- [ -z ]
- [ -z ]
- /sbin/ip6tables -A INPUT -p tcp --dport 80 -j ACCEPT
- /sbin/ip6tables -A INPUT -p tcp --dport 443 -j ACCEPT
- /sbin/ip6tables -A INPUT -p tcp --dport 3306 -j ACCEPT
- /sbin/ip6tables -A INPUT -p tcp --dport 137 -j ACCEPT
- /sbin/ip6tables -A INPUT -p tcp --dport 138 -j ACCEPT
- /sbin/ip6tables -A INPUT -p tcp --dport 139 -j ACCEPT
- /sbin/ip6tables -A INPUT -p tcp --dport 445 -j ACCEPT
- /sbin/ip6tables -A INPUT -p tcp --dport 631 -j ACCEPT
- /sbin/ip6tables -A INPUT -p udp --dport 80 -j ACCEPT
- /sbin/ip6tables -A INPUT -p udp --dport 443 -j ACCEPT
- /sbin/ip6tables -A INPUT -p udp --dport 3306 -j ACCEPT
- /sbin/ip6tables -A INPUT -p udp --dport 137 -j ACCEPT
- /sbin/ip6tables -A INPUT -p udp --dport 138 -j ACCEPT
- /sbin/ip6tables -A INPUT -p udp --dport 139 -j ACCEPT
- /sbin/ip6tables -A INPUT -p udp --dport 445 -j ACCEPT
- /sbin/ip6tables -A INPUT -p udp --dport 631 -j ACCEPT
- true
- /sbin/ip6tables -A INPUT -i enp8s0 -j ACCEPT
- /sbin/ip6tables -A INPUT -p icmp -j ACCEPT
- /sbin/ip6tables -A FORWARD -i enp7s0 -o enp8s0 -m state --state RELATED,ESTABLISHED -j ACCEPT
- /sbin/ip6tables -A FORWARD -o enp7s0 -j ACCEPT
- /sbin/ip6tables -t nat -A POSTROUTING -o enp7s0 -j MASQUERADE
- /sbin/ip6tables -A INPUT -p icmpv6 --icmpv6-type router-solicitation -m hl --hl-eq 255 -j ACCEPT
- /sbin/ip6tables -A OUTPUT -p icmpv6 --icmpv6-type router-advertisement -j ACCEPT
- /sbin/ip6tables -A INPUT -p icmpv6 --icmpv6-type neighbour-solicitation -m hl --hl-eq 255 -j ACCEPT
- /sbin/ip6tables -A INPUT -p icmpv6 --icmpv6-type neighbour-advertisement -m hl --hl-eq 255 -j ACCEPT
- /sbin/ip6tables -A OUTPUT -p icmpv6 --icmpv6-type neighbour-solicitation -j ACCEPT
- /sbin/ip6tables -A OUTPUT -p icmpv6 --icmpv6-type neighbour-advertisement -j ACCEPT
- /sbin/ip6tables -t filter -A INPUT -j LOG --log-level=4
- log_end_msg 0
- [ -z 0 ]
- local retval
- retval=0
- log_end_msg_pre 0
- [ -t 1 ]
- [ xxterm != x ]
- [ -z 1 ]
- true
- true
- RED=
- /usr/bin/tput setaf 2
- GREEN=
- /usr/bin/tput setaf 3
- YELLOW=
- /usr/bin/tput op
- NORMAL=
- /usr/bin/tput civis
- /usr/bin/tput sc
- /usr/bin/tput hpa 0
- [ 0 -eq 0 ]
- /bin/echo -ne [ ok
[ ok + /usr/bin/tput rc - /usr/bin/tput cnorm
- [ -t 1 ]
- [ xxterm != x ]
- [ -z 1 ]
- true
- true
- RED=
- YELLOW=
- /usr/bin/tput op
- NORMAL=
- [ 0 -eq 0 ]
- echo .
. - log_end_msg_post 0
- return 0
- exit 0
- /sbin/ifconfig -a
RX packets 164653 bytes 166445972 (158.7 MiB)
RX errors 0 dropped 10633 overruns 0 frame 0
TX packets 94269 bytes 9226643 (8.7 MiB)
RX packets 17597 bytes 2078086 (1.9 MiB)
TX packets 21389 bytes 21041548 (20.0 MiB)
- /sbin/route -n
Table de routage IP du noyau
Destination Passerelle Genmask Indic Metric Ref Use Iface
0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 enp7s0
10.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 enp8s0
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 enp7s0
[|/code]
aprés le boot, je lance le reseau à la maiin sans networkmanager
A+
JB1
