Debian Wheezy 7.2 sur un vieux PC
je viens de m’inscrire sur le forum car je n’arrive pas à installer/configurer correctement mon vieux PC avec ma Debian Wheezy 7.2
Voici quelques informations sur mon installation:
utilisateur@Ordinateur:~$ uname -a Linux Ordinateur 3.2.0-4-686-pae #1 SMP Debian 3.2.51-1 i686 GNU/Linux
[code]utilisateur@Ordinateur:~$lspci -vv
00:00.0 Host bridge: Intel Corporation 82845G/GL[Brookdale-G]/GE/PE DRAM Controller/Host-Hub Interface (rev 01)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Latency: 0
Region 0: Memory at d0000000 (32-bit, prefetchable) [size=256M]
Capabilities:
Kernel driver in use: agpgart-intel
00:01.0 PCI bridge: Intel Corporation 82845G/GL[Brookdale-G]/GE/PE Host-to-AGP Bridge (rev 01) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap- 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 96
Bus: primary=00, secondary=01, subordinate=01, sec-latency=64
Memory behind bridge: c0100000-c0ffffff
Prefetchable memory behind bridge: e0000000-e1ffffff
Secondary status: 66MHz+ FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA+ VGA+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
00:1d.0 USB controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #1 (rev 01) (prog-if 00 [UHCI])
Subsystem: IBM NetVista A30p
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 16
Region 4: I/O ports at 1800 [size=32]
Kernel driver in use: uhci_hcd
00:1d.1 USB controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #2 (rev 01) (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin B routed to IRQ 19
Region 4: I/O ports at 1820 [size=32]
00:1d.2 USB controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #3 (rev 01) (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin C routed to IRQ 18
Region 4: I/O ports at 1840 [size=32]
00:1d.7 USB controller: Intel Corporation 82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Controller (rev 01) (prog-if 20 [EHCI])
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin D routed to IRQ 23
Region 0: Memory at c0000000 (32-bit, non-prefetchable) [size=1K]
Capabilities:
Kernel driver in use: ehci_hcd
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 81) (prog-if 00 [Normal decode])
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR+ INTx-
Latency: 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=32
I/O behind bridge: 00002000-00002fff
Memory behind bridge: c1000000-c10fffff
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA+ VGA- MAbort- >Reset- FastB2B-
00:1f.0 ISA bridge: Intel Corporation 82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge (rev 01)
Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Latency: 0
00:1f.1 IDE interface: Intel Corporation 82801DB (ICH4) IDE Controller (rev 01) (prog-if 8a [Master SecP PriP])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
Interrupt: pin A routed to IRQ 18
Region 0: I/O ports at 01f0 [size=8]
Region 1: I/O ports at 03f4 [size=1]
Region 2: I/O ports at 0170 [size=8]
Region 3: I/O ports at 0374 [size=1]
Region 4: I/O ports at 1860 [size=16]
Region 5: Memory at 40000000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ata_piix
00:1f.3 SMBus: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) SMBus Controller (rev 01)
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin B routed to IRQ 17
Region 4: I/O ports at 1880 [size=32]
00:1f.5 Multimedia audio controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC’97 Audio Controller (rev 01)
Latency: 0
Region 0: I/O ports at 1c00 [size=256]
Region 1: I/O ports at 18c0 [size=64]
Region 2: Memory at c0000c00 (32-bit, non-prefetchable) [size=512]
Region 3: Memory at c0000800 (32-bit, non-prefetchable) [size=256]
Capabilities:
Kernel driver in use: snd_intel8x0
01:00.0 VGA compatible controller: Matrox Electronics Systems Ltd. MGA G400/G450 (rev 85) (prog-if 00 [VGA controller])
Subsystem: Matrox Electronics Systems Ltd. Millennium G450 Dual Head
Latency: 128 (4000ns min, 8000ns max), Cache Line Size: 32 bytes
Region 0: Memory at e0000000 (32-bit, prefetchable) [size=32M]
Region 1: Memory at c0100000 (32-bit, non-prefetchable) [size=16K]
Region 2: Memory at c0800000 (32-bit, non-prefetchable) [size=8M]
[virtual] Expansion ROM at c0120000 [disabled] [size=128K]
Capabilities:
Kernel driver in use: matrox_w1
02:08.0 Ethernet controller: Intel Corporation 82801DB PRO/100 VE (LOM) Ethernet Controller (rev 81)
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Latency: 66 (2000ns min, 14000ns max), Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 20
Region 0: Memory at c1000000 (32-bit, non-prefetchable) [size=4K]
Region 1: I/O ports at 2000 [size=64]
Capabilities:
Kernel driver in use: e100
J’ai installé LXDE par souci de fluidité sur ce vieux PC.
Sauf erreur de ma part, la distribution fonctionne de façon stable.
Mais je n’arrive pas à configurer correctement ma carte vidéo ni ma carte son.
Auriez-vous des conseils à me donner afin d’installer correctement ces deux cartes ?
Sachant que la carte vidéo est en AGP et la carte son est sur la carte-mère.
Par avance, merci.
Pour ta carte graphique, une Matrox.
Joli…
Selon: projects.tuxx-home.at/?id=matrox_drivers
Ta carte correspond à la G-Series.
Je pense que les drivers sont déjà gérés et que tu n’as aucune opération spécifique à faire.
Que voudrais-tu faire ?
Question: ça gère la 3D ces cartes-là ? :stuck_out_tongue:
Résultat chez moi:
$ glxinfo | grep direct direct rendering: Yes
Idem pour la carte son, c’est un chipset intel.
Donc tu n’as rien de spécial à faire, les drivers sont certainement déjà dans ALSA/le noyau.
Tu peux faire un petit…
… et lancer un “alsamixer”, pour voir si tu peux gérer les volumes.
J’oubliais que tu as ptet pulseaudio d’installé, si tu peux vérifier…
  • Pour la carte graphique Matrox:
root@Ordinateur:~# glxinfo | grep direct direct rendering: Yes
Je pense effectivement qu’elle est gérée par le Noyau.
J’aimerai juste savoir si il existe une sorte de “PowerDesk” pour mon LXDE afin de la configurer au mieux, mais pour de la 2D ça suffira amplement à mon avis.
  • Pour la carte son:
root@Ordinateur:~# cat /proc/asound/cards 0 [I82801DBICH4 ]: ICH4 - Intel 82801DB-ICH4 Intel 82801DB-ICH4 with AD1981B at irq 17
root@Ordinateur:~# cat /proc/asound/devices 2: [ 0- 4]: digital audio playback 3: [ 0- 3]: digital audio capture 4: [ 0- 2]: digital audio capture 5: [ 0- 1]: digital audio capture 6: [ 0- 0]: digital audio playback 7: [ 0- 0]: digital audio capture 8: [ 0] : control 33: : timer
Hormis par le haut-parleur de la carte-mère, je n’ai aucun son.
Même en réglant tout à fond avec le “alsamixer”
Et après vérification, “pulseaudio” n’est pas installé.
Dois-je l’installer ?
D’acc,
Comme outils pour la carte graphique,
Pour la gestion des écrans, xrandr ainsi que ses interfaces graphiques (grandr…).
Et pour la 3D, driconf, mais c’est des options rarement utiles et l’outil n’est pas hyper clair.
Pour le son,
Hormis le volume, veiller à ce qu’aucun ne soit sur “mute”.
Eventuellement, voir si pour l’une des barres de alsamixer, il propose différents modes de sortie, et tenter l’un ou l’autre…
Si aucun son ne sort, scruter /var/log/syslog (ou dmesg) en quête d’anomalies. (tu peux coller le log sur ce forum)
Et faire des recherches pour voir s’il y a des antécédents sur le chipset précis que tu utilises. Car il arrive quand même que certaines cartes sons aient du mal.
Pour pulseaudio, je ne te le recommande pas, c’est une surcouche “évoluée” qui ajoute entre autre la gestion réseau et la gestion des volumes sonores au niveau applicatif, mais ça fout sa petite dose de bordel également. C’était au cas où si tu l’avais, pour débugger, ça aurait été plus simple de la désactiver.
Sur le net, on trouve des topics du genre:
forum.tinycorelinux.net/index.php?topic=15735.0
forums.debian.net/viewtopic.php?f=5&t=57847
… mais pas de vraie solution.
Si tu as des LiveCDs d’autres distribs (Ubuntu, …) ça peut être intéressant de tester.
Après ce sera selon ta motiv’, tu peux essayer de recouper ce qui se dit dans les témoignages et tenter des trucs, fouiner sur le site d’ALSA ce qui se dit sur ton chipset spécifique, voir s’il y a qqch dans leur bugtracker, et éventuellement suivre la procédure de rapport de bug. Mais avant ça il faut s’assurer que ça ne vient pas de ta configuration.
Je viens de regarder les logs sans rien comprendre.
C’est trop long de tout copier-coller, je laisse tomber.
Tant pis je n’aurais pas de son sur cette vieille bouse.
Merci quand même.
Fais le tour complet d’Alsamixer. Il y a peut-être une option à activer quelque part.
Je n’ai pas relu tout ton post, mais tu risques quoi à installer pulseaudio ?
Je pense surtout que mon vieux “IBM NetVista” d’avant 2007 n’en peut plus…
Dans le doute, peux-tu poster ici une capture d’écran de ton alsamixer ?
Ton ordinateur est une bête de course comparé à certains ordinosaures que j’ai vu tourner sous Debian avec du son :wink:
Je n’y arrive pas avec mon pauvre LXDE…
Je laisse tomber.
Capture d’écran ?
Voir ce post: a-lire-avant-de-poster-t4657.html
Ou installer “scrot”.
Quant aux logs, tu fais un:
cp /var/log/cequetuveux /home/toncompteutilisateur/Desktop/
Puis ensuite tu l’uploades sur ce forum. C’est pas la mort …
Et si tu veux copier le résultat d’une commande, imagineons, dmesg, tu peux faire:
Pour créer le fichier texte dans ton répertoire utilisateur, qui contiendra le résultat de la commande.
L’opérateur ‘>’ servant à faire une redirection de flux.
Je laisse tomber.[/quote]
Si tu as un autre PC, tu peux essayer d’installer Debian dessus, ce serait dommage de rester sur un échec.
Je n’ai pas d’autre PC au bureau.
J’attends que l’on me change mon vieux bouzin, mais on m’imposera un W7 à la place :frowning: :frowning: :frowning:
Je verrai si ma Debian chez moi fonctionne nickel.
Bon, après un retour de vacances d’été, j’ai réussi à me trouver un autre PC plus récent…
Je vais voir ce que ça donne avec celui-ci…
[code]root@Debian:~# lspci -vv
00:00.0 Host bridge: Intel Corporation 82915G/P/GV/GL/PL/910GL Memory Controller Hub (rev 04)
Subsystem: IBM Device 02d9
Latency: 0
Capabilities: [e0] Vendor Specific Information: Len=09 <?>
00:02.0 VGA compatible controller: Intel Corporation 82915G/GV/910GL Integrated Graphics Controller (rev 04) (prog-if 00 [VGA controller])
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Region 0: Memory at d0100000 (32-bit, non-prefetchable) [size=512K]
Region 1: I/O ports at 3800 [size=8]
Region 2: Memory at c0000000 (32-bit, prefetchable) [size=256M]
Region 3: Memory at d0180000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at [disabled]
Capabilities: [d0] Power Management version 2
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Kernel driver in use: i915
00:1d.0 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1 (rev 04) (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin A routed to IRQ 23
Region 4: I/O ports at 3440 [size=32]
00:1d.1 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2 (rev 04) (prog-if 00 [UHCI])
Latency: 0
Region 4: I/O ports at 3460 [size=32]
00:1d.2 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #3 (rev 04) (prog-if 00 [UHCI])
Latency: 0
Region 4: I/O ports at 3480 [size=32]
00:1d.3 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #4 (rev 04) (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin D routed to IRQ 16
Region 4: I/O ports at 34a0 [size=32]
00:1d.7 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller (rev 04) (prog-if 20 [EHCI])
Latency: 0
Region 0: Memory at d03c0000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [50] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME+
Capabilities: [58] Debug port: BAR=1 offset=00a0
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev d4) (prog-if 01 [Subtractive decode])
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Bus: primary=00, secondary=0a, subordinate=0a, sec-latency=32
Memory behind bridge: d0000000-d00fffff
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
Capabilities: [50] Subsystem: IBM Device 02d9
00:1e.2 Multimedia audio controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) AC’97 Audio Controller (rev 04)
Latency: 0
Interrupt: pin A routed to IRQ 17
Region 0: I/O ports at 3000 [size=256]
Region 1: I/O ports at 3400 [size=64]
Region 2: Memory at d03c0800 (32-bit, non-prefetchable) [size=512]
Region 3: Memory at d03c0400 (32-bit, non-prefetchable) [size=256]
00:1f.0 ISA bridge: Intel Corporation 82801FB/FR (ICH6/ICH6R) LPC Interface Bridge (rev 04)
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
00:1f.2 IDE interface: Intel Corporation 82801FB/FW (ICH6/ICH6W) SATA Controller (rev 04) (prog-if 80 [Master])
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Region 4: I/O ports at 34f0 [size=16]
Capabilities: [70] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
00:1f.3 SMBus: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller (rev 04)
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Region 4: I/O ports at 34c0 [size=32]
0a:0b.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5705_2 Gigabit Ethernet (rev 03)
Latency: 32 (16000ns min), Cache Line Size: 32 bytes
Region 0: Memory at d0000000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [48] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] Vital Product Data
pcilib: sysfs_read_vpd: read failed: Connection timed out
Not readable
Capabilities: [58] MSI: Enable- Count=1/8 Maskable- 64bit+
Address: 6defed2bffdfffa8 Data: fef7
Kernel driver in use: tg3[/code]
Je sens que je vais m’amuser… :wink:
