Debootstrap, segmentation fault
J’ai besoin d’une [mono]Squeeze[/mono] sous [mono]chroot[/mono] et cela fait deux heures que je m’échine avec [mono]debootstrap[/mono].
[code][14:40:57] ~ # debootstrap --include=linux-image-amd64,grub-pc,locales,ntpdate,console-data --arch amd64 squeeze /srv/chroot/squeeze http://ftp.us.debian.org/debian
I: Retrieving Release
I: Retrieving Release.gpg
I: Checking Release signature
I: Valid Release signature (key id 0E4EDE2C7F3E1FC0D033800E64481591B98321F9)
I: Installing core packages…
W: Failure trying to run: chroot /srv/chroot/squeeze dpkg --force-depends --install /var/cache/apt/archives/base-passwd_3.5.22_amd64.deb
W: See /srv/chroot/squeeze/debootstrap/debootstrap.log for details
[14:55:19] ~ # [/code]
[14:56:41] ~ # cat /srv/chroot/squeeze/debootstrap/debootstrap.log gpgv: Signature made Sat Apr 25 13:01:30 2015 CEST using RSA key ID 473041FA gpgv: Good signature from "Debian Archive Automatic Signing Key (6.0/squeeze) <ftpmaster@debian.org>" gpgv: Signature made Sat Apr 25 13:05:42 2015 CEST using RSA key ID B98321F9 gpgv: Good signature from "Squeeze Stable Release Key <debian-release@lists.debian.org>" warning, in file '/var/lib/dpkg/status' near line 4 package 'dpkg': missing description Segmentation fault [14:56:45] ~ #
[code][14:58:19] ~ # cat /srv/chroot/squeeze/var/lib/dpkg/status
Package: dpkg
Status: install ok installed
Maintainer: unknown
Version: 1.15.11
[14:58:24] ~ #[/code]
[15:01:40] ~ # ll /srv/chroot/squeeze/var/cache/apt/archives/base-passwd_3.5.22_amd64.deb -rw-r--r-- 1 root root 41K 2009-09-07 05:47 /srv/chroot/squeeze/var/cache/apt/archives/base-passwd_3.5.22_amd64.deb [15:02:02] ~ #
À la base, j’avais essayé ces deux miroirs, sans succès.
http://http.debian.net/debian/
http://httpredir.debian.org/debian
J’ai tenté aussi avec [mono]Lenny[/mono] et [mono]Wheezy[/mono], toujours les mêmes erreurs.
[15:21:52] ~ # chroot /srv/chroot/squeeze Erreur de segmentation [15:21:55] ~ #
[15:32:13]:~/tmp$ apt-listbugs list debootstrap Récupération des rapports de bogue… Fait Analyse des informations Trouvé/Corrigé… Fait [15:32:55]:~/tmp$
J’ai également rétrogradé [mono]debootstrap[/mono] en version [mono]Stable[/mono] ([mono]Installé : 1.0.67[/mono]).
Rien sur la toile, pour bien faire, une idée ?
[code][16:53:59] ~ # debootstrap --include=linux-image-amd64,grub-pc,locales,ntpdate,console-data --components=main,contrib,non-free --arch amd64 squeeze /srv/chroot/squeeze64 http://httpredir.debian.org/debian
I: Retrieving Packages
I: Validating Packages
I: Resolving dependencies of required packages…
I: Resolving dependencies of base packages…
I: Found additional required dependencies: insserv libbz2-1.0 libdb4.8 libslang2
I: Found additional base dependencies: dmsetup gettext-base grub-common initramfs-tools klibc-utils libcap2 libdevmapper1.02.1 libfreetype6 libklibc libnfnetlink0 libsqlite3-0 libuuid-perl linux-base linux-image-2.6.32-5-amd64 ucf
I: Checking component main on http://httpredir.debian.org/debian…
I: Retrieving libacl1
I: Configuring gnupg…
I: Configuring debian-archive-keyring…
I: Configuring apt…
I: Configuring libept1…
I: Configuring apt-utils…
I: Configuring aptitude…
I: Configuring tasksel-data…
I: Configuring libdevmapper1.02.1…
I: Configuring dmsetup…
I: Configuring grub-common…
I: Configuring tasksel…
I: Configuring grub-pc…
I: Configuring initramfs-tools…
I: Base system installed successfully.
[17:02:45] ~ # [/code]
[17:06:41] ~ # ls /srv/chroot/squeeze64 bin boot dev etc home initrd.img lib lib64 media mnt opt proc root sbin selinux srv sys tmp usr var vmlinuz [17:06:49] ~ #
Ci-dessus, j’ai réussi depuis une Wheezy, hier.
Je suis repassé sous mon AptoSid ce matin, nouvelle tentative [mono]debootstrap[/mono] >>> [mono]wheezy, squeeze et lenny[/mono] en échec (les mêmes erreurs).
J’avais d’abord pensé qu’il s’agissait de ma variable [mono]PATH[/mono], ce n’est pas le cas.
[10:17:33] ~ # echo $PATH /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/root/.bin [10:17:35] ~ #
Bizarrement, l’installation d’une [mono]Jessie[/mono] via [mono]debootstrap[/mono] est un succès.
[code][11:18:32] ~ # debootstrap --verbose --variant=buildd --arch amd64 jessie /srv/chroot/jessie64 http://httpredir.debian.org/debian
I: Valid Release signature (key id 75DDC3C4A499F1A18CB5F3C8CBF8D6FD518E17E1)
I: Found additional required dependencies: acl adduser dmsetup insserv libaudit-common libaudit1 libbz2-1.0 libcap2 libcap2-bin libcryptsetup4 libdb5.3 libdebconfclient0 libdevmapper1.02.1 libgcrypt20 libgpg-error0 libkmod2 libncursesw5 libprocps3 libsemanage-common libsemanage1 libslang2 libsystemd0 libudev1 libustr-1.0-1 procps systemd systemd-sysv udev
I: Found additional base dependencies: binutils bzip2 cpp cpp-4.9 debian-archive-keyring dpkg-dev g++ g+±4.9 gcc gcc-4.9 gnupg gpgv libapt-pkg4.12 libasan1 libatomic1 libc-dev-bin libc6-dev libcilkrts5 libcloog-isl4 libdpkg-perl libgcc-4.9-dev libgdbm3 libgmp10 libgomp1 libisl10 libitm1 liblsan0 libmpc3 libmpfr4 libquadmath0 libreadline6 libstdc+±4.9-dev libstdc++6 libtimedate-perl libtsan0 libubsan0 libusb-0.1-4 linux-libc-dev make patch perl perl-modules readline-common xz-utils
I: Retrieving acl 2.2.52-2
I: Validating acl 2.2.52-2
I: Retrieving libacl1 2.2.52-2
I: Validating libacl1 2.2.52-2
I: Retrieving adduser 3.113+nmu3
I: Validating adduser 3.113+nmu3
I: Retrieving apt 1.0.9.8.1
I: Validating apt 1.0.9.8.1
I: Configuring apt…
I: Configuring libstdc+±4.9-dev:amd64…
I: Configuring cpp…
I: Configuring gcc-4.9…
I: Configuring gcc…
I: Configuring g+±4.9…
I: Configuring g++…
I: Configuring build-essential…
I: Configuring libc-bin…
[11:25:04] ~ #
J’aimerai comprendre le pourquoi du comment …
