Je tente d’utiliser un scanner en réseau, j’ai suis vi ce wiki clx.anet.fr/spip/article.php3?id_article=215
Seulement impossible de l’utiliser en réseau (en local il fonctionne).
Un saned en mode debug donne :
:/# /usr/sbin/saned -d128
[saned] main: starting debug mode (level 128)
[saned] main: trying to get port for service `sane-port' (getaddrinfo)
[saned] main: [0] socket () using IPv6
[saned] main: [0] setsockopt ()
[saned] main: [0] bind () to port 6566
[saned] main: [0] bind failed: Address already in use
[saned] main: [1] socket () using IPv4
[saned] main: [1] setsockopt ()
[saned] main: [1] bind () to port 6566
[saned] main: [1] bind failed: Address already in use
[saned] main: couldn't bind an address. Exiting.
Dans syslog j’ai :
Sep 18 16:04:24 serveur saned[6990]: saned (AF-indep+IPv6) from sane-backends 1.0.18 ready
Sep 18 16:04:24 serveur saned[6990]: check_host: getpeername failed: Socket operation on non-socket
Sep 18 16:04:24 serveur saned[6990]: init: access by host [error] denied
Sep 18 16:04:24 serveur saned[6990]: quit: exiting
Une idée ?
Merci.
