Je cherche des renseignements concernant ce bout de log qui est récurrent afin de pouvoir agir si c’est nécessaire.
[quote]Aug 19 20:48:23 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:49:01 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:49:01 vpsxxxxx postfix/smtpd[31734]: lost connection after CONNECT from localhost.localdomain[127.0.0.1]
Aug 19 20:49:01 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:49:01 vpsxxxxx dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<Zkbn8P8AHQB/AAAB>
Aug 19 20:49:01 vpsxxxxx dovecot: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<4Efn8P8AMgB/AAAB>
Aug 19 20:49:25 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:49:25 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:50:02 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:50:02 vpsxxxxx postfix/smtpd[31734]: lost connection after CONNECT from localhost.localdomain[127.0.0.1]
Aug 19 20:50:02 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:50:02 vpsxxxxx dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<Mn599P8AKgB/AAAB>
Aug 19 20:50:02 vpsxxxxx dovecot: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<SH599P8APwB/AAAB>
Aug 19 20:50:02 vpsxxxxx dovecot: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<2Q9/9P8ARQB/AAAB>
Aug 19 20:50:02 vpsxxxxx dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<xBF/9P8AMAB/AAAB>
Aug 19 20:50:08 vpsxxxxx postfix/smtpd[31734]: connect from unknown[unknown]
Aug 19 20:50:08 vpsxxxxx postfix/smtpd[31734]: lost connection after CONNECT from unknown[unknown]
Aug 19 20:50:08 vpsxxxxx postfix/smtpd[31734]: disconnect from unknown[unknown]
Aug 19 20:50:27 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:50:27 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:51:01 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:51:01 vpsxxxxx postfix/smtpd[31734]: lost connection after CONNECT from localhost.localdomain[127.0.0.1]
Aug 19 20:51:01 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:51:01 vpsxxxxx dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<lo0P+P8AQQB/AAAB>
Aug 19 20:51:01 vpsxxxxx dovecot: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<KpEP+P8AVgB/AAAB>
Aug 19 20:51:29 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:51:29 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:52:01 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:52:01 vpsxxxxx postfix/smtpd[31734]: lost connection after CONNECT from localhost.localdomain[127.0.0.1]
Aug 19 20:52:01 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:52:01 vpsxxxxx dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<6PeV+/8ATgB/AAAB>
Aug 19 20:52:01 vpsxxxxx dovecot: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<sviV+/8AYwB/AAAB>
Aug 19 20:52:31 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:52:31 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:53:01 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:53:01 vpsxxxxx postfix/smtpd[31734]: lost connection after CONNECT from localhost.localdomain[127.0.0.1]
Aug 19 20:53:01 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:53:01 vpsxxxxx dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<OZAr//8AWwB/AAAB>
Aug 19 20:53:01 vpsxxxxx dovecot: imap-login: Disconnected (disconnected before greeting, waited 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<SJIr//8AcAB/AAAB>
Aug 19 20:53:33 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:53:33 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:54:01 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:54:01 vpsxxxxx postfix/smtpd[31734]: lost connection after CONNECT from localhost.localdomain[127.0.0.1]
Aug 19 20:54:01 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:54:01 vpsxxxxx dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<DS7BAgABaAB/AAAB>
Aug 19 20:54:01 vpsxxxxx dovecot: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<Fy7BAgABfQB/AAAB>
Aug 19 20:54:35 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:54:35 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:55:01 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:55:01 vpsxxxxx postfix/smtpd[31734]: lost connection after CONNECT from localhost.localdomain[127.0.0.1]
Aug 19 20:55:01 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:55:01 vpsxxxxx dovecot: imap-login: Disconnected (disconnected before greeting, waited 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<329XBgABigB/AAAB>
Aug 19 20:55:01 vpsxxxxx dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<0nNXBgABdQB/AAAB>
Aug 19 20:55:01 vpsxxxxx dovecot: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<mS1ZBgABkAB/AAAB>
Aug 19 20:55:01 vpsxxxxx dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<my1ZBgABewB/AAAB>
Aug 19 20:55:07 vpsxxxxx postfix/anvil[32292]: statistics: max connection rate 1/60s for (smtp:37.187.236.250) at Aug 19 20:45:07
Aug 19 20:55:07 vpsxxxxx postfix/anvil[32292]: statistics: max connection count 1 for (smtp:37.187.236.250) at Aug 19 20:45:07
Aug 19 20:55:07 vpsxxxxx postfix/anvil[32292]: statistics: max cache size 1 at Aug 19 20:45:07
Aug 19 20:55:11 vpsxxxxx postfix/smtpd[31734]: connect from 250.ip-37-187-236.eu[37.187.236.250]
Aug 19 20:55:11 vpsxxxxx postfix/smtpd[31734]: lost connection after CONNECT from 250.ip-37-187-236.eu[37.187.236.250]
Aug 19 20:55:11 vpsxxxxx postfix/smtpd[31734]: disconnect from 250.ip-37-187-236.eu[37.187.236.250]
Aug 19 20:55:37 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:55:37 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:56:01 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:56:01 vpsxxxxx postfix/smtpd[31734]: lost connection after CONNECT from localhost.localdomain[127.0.0.1]
Aug 19 20:56:01 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:56:01 vpsxxxxx dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<GKrqCQABjAB/AAAB>
Aug 19 20:56:01 vpsxxxxx dovecot: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<ZKrqCQABoQB/AAAB>
Aug 19 20:56:39 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:56:39 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:57:01 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:57:01 vpsxxxxx postfix/smtpd[31734]: lost connection after CONNECT from localhost.localdomain[127.0.0.1]
Aug 19 20:57:01 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:57:01 vpsxxxxx dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<pouADQABpgB/AAAB>
Aug 19 20:57:01 vpsxxxxx dovecot: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<24yADQABuwB/AAAB>
Aug 19 20:57:41 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:57:41 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:58:01 vpsxxxxx postfix/smtpd[31734]: connect from localhost.localdomain[127.0.0.1]
Aug 19 20:58:01 vpsxxxxx postfix/smtpd[31734]: lost connection after CONNECT from localhost.localdomain[127.0.0.1]
Aug 19 20:58:01 vpsxxxxx postfix/smtpd[31734]: disconnect from localhost.localdomain[127.0.0.1]
Aug 19 20:58:01 vpsxxxxx dovecot: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<DCUWEQAB0gB/AAAB>
Aug 19 20:58:01 vpsxxxxx dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<jycWEQABvQB/AAAB>[/quote]
Ma config est basé sur debian 7 avec ispconfig-roundcube-postix-dovecot
Merci de votre aide et éclaircissement.
Seb
