bonjour a toutes & a tous ,
j’aimerais avoir une petite precision afin d’obtenir les couleurs totales dans Konsole
j’ai suivi et bien lu les threads sur le forum mais voila :
dans mon fichier /etc/bashrc j’ai ceci :
#/etc/bashrc
umask 022
PATH="/sbin:/bin:/usr/sbin:/usr/bin:/opt/kde2/bin:/usr/X11R6/bin:/usr/games:/usr/local/sbin:/usr/local/bin:."
export PATH
# LOCALE
[ -f /etc/sysconfig/i18n ] && . /etc/sysconfig/i18n && [ -n "$LANG" ] && export LANG
[ -n "$TTY" ] && PS1="\[e[1;34m\]knoppix@$TTY[\W]#\[e[0;39m\] " || PS1="\[e[1;34m\][\W]#\[e[0;39m\] "
alias which="type -path"
alias ll="ls -l --color=auto"
alias la="ls -la --color=auto"
alias ls="ls --color=auto"
dans mon ~/.bashrc j’ai :
# /etc/bash.bashrc
[ -f /etc/profile ] && . /etc/profile
et le dernier dans /etc/bash.bashrc :
# System-wide .bashrc file for interactive bash(1) shells.
# To enable the settings / commands in this file for login shells as well,
# this file has to be sourced in /etc/profile.
# If not running interactively, don't do anything
[ -z "$PS1" ] && return
# check the window size after each command and, if necessary,
# update the values of LINES and COLUMNS.
shopt -s checkwinsize
# set variable identifying the chroot you work in (used in the prompt below)
if [ -z "$debian_chroot" ] && [ -r /etc/debian_chroot ]; then
debian_chroot=$(cat /etc/debian_chroot)
fi
# set a fancy prompt (non-color, overwrite the one in /etc/profile)
PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
# Commented out, don't overwrite xterm -T "title" -n "icontitle" by default.
# If this is an xterm set the title to user@host:dir
#case "$TERM" in
#xterm*|rxvt*)
# PROMPT_COMMAND='echo -ne "\033]0;${USER}@${HOSTNAME}: ${PWD}\007"'
#esac
# enable bash completion in interactive shells
#if [ -f /etc/bash_completion ]; then
# . /etc/bash_completion
#fi
# if the command-not-found package is installed, use it
if [ -x /usr/lib/command-not-found ]; then
function command_not_found_handle {
# check because c-n-f could've been removed in the meantime
/usr/bin/python /usr/lib/command-not-found -- $1
return $?
else
return 127
fi
fi
ma question est : quel fichier bashrc dois-je copier dans ~/.bashrc afin d’avoir toute les couleurs dans ma konsole
excuser si cette question est un peu bete , j’essais de comprendre les difference de fichiers du meme noms
merci & bonnes fetes
