Alors, reboot effectué, extrait du dmesg, ça bronche toujours.
Je vais vérifier que c’est vraiment pas possible d’enlever ce fichu disque, ça me gonfle, faut ouvrir la bécane en entier, pas juste la petit trappe…
[EDIT] les 4go de SSD qui sont en /dev/sda sont soudés à la carte mère, pas moyen de s’en débarrasser donc! aaaaaaaargh!
[ 1.629058] ACPI: Thermal Zone [TZ00] (58 C)
[ 1.650941] SCSI subsystem initialized
[ 1.707976] libata version 3.00 loaded.
[ 1.709870] ahci 0000:00:1f.2: version 3.0
[ 1.709920] ahci: probe of 0000:00:1f.2 failed with error -22
[ 1.710968] ata_piix 0000:00:1f.2: version 2.13
[ 1.710997] ata_piix 0000:00:1f.2: MAP [ P0 P2 IDE IDE ]
[ 1.711073] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.722699] scsi0 : ata_piix
[ 1.727675] scsi1 : ata_piix
[ 1.730945] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 1.730953] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 1.898985] usb 2-1: new full-speed USB device number 2 using uhci_hcd
[ 1.912309] Refined TSC clocksource calibration: 900.092 MHz.
[ 1.912321] Switching to clocksource tsc
[ 1.912342] ata2.00: CFA: ASUS-PHISON OB SSD, TST2.04P, max UDMA/66
[ 1.912349] ata2.00: 7880544 sectors, multi 0: LBA
[ 1.912362] ata2.01: CFA: ASUS-PHISON SSD, TST2.04P, max UDMA/66
[ 1.912369] ata2.01: 15761088 sectors, multi 0: LBA
[ 1.920194] ata2.00: configured for UDMA/66
[ 1.928191] ata2.01: configured for UDMA/66
[ 1.928408] scsi 1:0:0:0: Direct-Access ATA ASUS-PHISON OB S TST2 PQ: 0 ANSI: 5
[ 1.929202] scsi 1:0:1:0: Direct-Access ATA ASUS-PHISON SSD TST2 PQ: 0 ANSI: 5
[ 1.947094] sd 1:0:0:0: [sda] 7880544 512-byte logical blocks: (4.03 GB/3.75 GiB)
[ 1.947209] sd 1:0:0:0: [sda] Write Protect is off
[ 1.947216] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.947265] sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 1.950292] sd 1:0:1:0: [sdb] 15761088 512-byte logical blocks: (8.06 GB/7.51 GiB)
[ 1.950714] sda: unknown partition table
[ 1.951193] sd 1:0:1:0: [sdb] Write Protect is off
[ 1.951202] sd 1:0:1:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.951253] sd 1:0:1:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 1.952417] sd 1:0:0:0: [sda] Attached SCSI disk
[ 1.953831] sdb: sdb1
[ 1.954584] sd 1:0:1:0: [sdb] Attached SCSI disk
[ 1.957581] sd 1:0:0:0: Attached scsi generic sg0 type 0
[ 1.964390] sd 1:0:1:0: Attached scsi generic sg1 type 0
[ 1.996666] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 1.996734] ata2.00: BMDMA stat 0x5
[ 1.996788] ata2.00: failed command: READ DMA
[ 1.996852] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 1.996855] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 1.996976] ata2.00: status: { DRDY ERR }
[ 1.997029] ata2.00: error: { UNC ABRT }
[ 2.012230] ata2.00: configured for UDMA/66
[ 2.028192] ata2.01: configured for UDMA/66
[ 2.028208] ata2: EH complete
[ 2.029433] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.029496] ata2.00: BMDMA stat 0x5
[ 2.029548] ata2.00: failed command: READ DMA
[ 2.029612] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.029615] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.029737] ata2.00: status: { DRDY ERR }
[ 2.029790] ata2.00: error: { UNC ABRT }
[ 2.044199] ata2.00: configured for UDMA/66
[ 2.052198] ata2.01: configured for UDMA/66
[ 2.052210] ata2: EH complete
[ 2.053428] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.053489] ata2.00: BMDMA stat 0x5
[ 2.053541] ata2.00: failed command: READ DMA
[ 2.053605] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.053608] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.053780] ata2.00: status: { DRDY ERR }
[ 2.053853] ata2.00: error: { UNC ABRT }
[ 2.063618] usb 2-1: New USB device found, idVendor=0781, idProduct=5571
[ 2.063625] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.063631] usb 2-1: Product: Cruzer Fit
[ 2.063636] usb 2-1: Manufacturer: SanDisk
[ 2.063640] usb 2-1: SerialNumber: 4C532000000911116344
[ 2.068291] ata2.00: configured for UDMA/66
[ 2.073499] Initializing USB Mass Storage driver...
[ 2.073696] scsi2 : usb-storage 2-1:1.0
[ 2.073894] usbcore: registered new interface driver usb-storage
[ 2.073900] USB Mass Storage support registered.
[ 2.076258] ata2.01: configured for UDMA/66
[ 2.076283] ata2: EH complete
[ 2.077528] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.077616] ata2.00: BMDMA stat 0x5
[ 2.077689] ata2.00: failed command: READ DMA
[ 2.077772] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.077775] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.077975] ata2.00: status: { DRDY ERR }
[ 2.078048] ata2.00: error: { UNC ABRT }
[ 2.092193] ata2.00: configured for UDMA/66
[ 2.100192] ata2.01: configured for UDMA/66
[ 2.100203] ata2: EH complete
[ 2.101420] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.101501] ata2.00: BMDMA stat 0x5
[ 2.101573] ata2.00: failed command: READ DMA
[ 2.101657] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.101660] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.101860] ata2.00: status: { DRDY ERR }
[ 2.101933] ata2.00: error: { UNC ABRT }
[ 2.116192] ata2.00: configured for UDMA/66
[ 2.124195] ata2.01: configured for UDMA/66
[ 2.124206] ata2: EH complete
[ 2.125424] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.125505] ata2.00: BMDMA stat 0x5
[ 2.125577] ata2.00: failed command: READ DMA
[ 2.125660] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.125663] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.125864] ata2.00: status: { DRDY ERR }
[ 2.125936] ata2.00: error: { UNC ABRT }
[ 2.140194] ata2.00: configured for UDMA/66
[ 2.148193] ata2.01: configured for UDMA/66
[ 2.148212] sd 1:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 2.148222] sd 1:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[ 2.148231] Descriptor sense data with sense descriptors (in hex):
[ 2.148236] 72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
[ 2.148252] 00 00 08 00
[ 2.148260] sd 1:0:0:0: [sda] Add. Sense: No additional sense information
[ 2.148272] sd 1:0:0:0: [sda] CDB: Read(10): 28 00 00 00 08 00 00 00 08 00
[ 2.148289] end_request: I/O error, dev sda, sector 2048
[ 2.148368] Buffer I/O error on device sda, logical block 256
[ 2.148467] ata2: EH complete
[ 2.150917] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.151000] ata2.00: BMDMA stat 0x5
[ 2.151072] ata2.00: failed command: READ DMA
[ 2.151155] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.151159] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.151359] ata2.00: status: { DRDY ERR }
[ 2.151432] ata2.00: error: { UNC ABRT }
[ 2.164194] ata2.00: configured for UDMA/66
[ 2.176025] usb 4-2: new full-speed USB device number 2 using uhci_hcd
[ 2.180197] ata2.01: configured for UDMA/66
[ 2.180210] ata2: EH complete
[ 2.181429] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.181512] ata2.00: BMDMA stat 0x5
[ 2.181584] ata2.00: failed command: READ DMA
[ 2.181667] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.181670] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.181871] ata2.00: status: { DRDY ERR }
[ 2.181943] ata2.00: error: { UNC ABRT }
[ 2.196193] ata2.00: configured for UDMA/66
[ 2.204192] ata2.01: configured for UDMA/66
[ 2.204203] ata2: EH complete
[ 2.205419] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.205500] ata2.00: BMDMA stat 0x5
[ 2.205572] ata2.00: failed command: READ DMA
[ 2.205657] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.205660] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.205860] ata2.00: status: { DRDY ERR }
[ 2.205933] ata2.00: error: { UNC ABRT }
[ 2.220192] ata2.00: configured for UDMA/66
[ 2.228192] ata2.01: configured for UDMA/66
[ 2.228202] ata2: EH complete
[ 2.229419] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.229499] ata2.00: BMDMA stat 0x5
[ 2.229571] ata2.00: failed command: READ DMA
[ 2.229655] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.229658] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.229858] ata2.00: status: { DRDY ERR }
[ 2.229930] ata2.00: error: { UNC ABRT }
[ 2.244192] ata2.00: configured for UDMA/66
[ 2.252192] ata2.01: configured for UDMA/66
[ 2.252202] ata2: EH complete
[ 2.253420] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.253501] ata2.00: BMDMA stat 0x5
[ 2.253573] ata2.00: failed command: READ DMA
[ 2.253656] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.253659] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.253859] ata2.00: status: { DRDY ERR }
[ 2.253931] ata2.00: error: { UNC ABRT }
[ 2.268192] ata2.00: configured for UDMA/66
[ 2.276193] ata2.01: configured for UDMA/66
[ 2.276204] ata2: EH complete
[ 2.277421] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.277501] ata2.00: BMDMA stat 0x5
[ 2.277573] ata2.00: failed command: READ DMA
[ 2.277657] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.277660] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.277860] ata2.00: status: { DRDY ERR }
[ 2.277933] ata2.00: error: { UNC ABRT }
[ 2.292207] ata2.00: configured for UDMA/66
[ 2.300197] ata2.01: configured for UDMA/66
[ 2.300214] sd 1:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 2.300222] sd 1:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[ 2.300231] Descriptor sense data with sense descriptors (in hex):
[ 2.300235] 72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
[ 2.300252] 00 00 08 00
[ 2.300260] sd 1:0:0:0: [sda] Add. Sense: No additional sense information
[ 2.300270] sd 1:0:0:0: [sda] CDB: Read(10): 28 00 00 00 08 00 00 00 08 00
[ 2.300286] end_request: I/O error, dev sda, sector 2048
[ 2.300364] Buffer I/O error on device sda, logical block 256
[ 2.300462] ata2: EH complete
[ 2.442276] usb 4-2: New USB device found, idVendor=04f2, idProduct=b071
[ 2.442284] usb 4-2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[ 2.442290] usb 4-2: Product: CNF7129
[ 2.442295] usb 4-2: Manufacturer: Chicony Electronics Co., Ltd.
[ 2.442301] usb 4-2: SerialNumber: SN0001
[ 3.076681] scsi 2:0:0:0: Direct-Access SanDisk Cruzer Fit 1.26 PQ: 0 ANSI: 5
[ 3.079273] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 3.084625] sd 2:0:0:0: [sdc] 7821312 512-byte logical blocks: (4.00 GB/3.72 GiB)
[ 3.089654] sd 2:0:0:0: [sdc] Write Protect is off
[ 3.089663] sd 2:0:0:0: [sdc] Mode Sense: 43 00 00 00
[ 3.094637] sd 2:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 3.130644] sdc: sdc1 sdc2 < sdc5 >
[ 3.156644] sd 2:0:0:0: [sdc] Attached SCSI removable disk
[ 4.984911] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[ 13.909350] udevd[342]: starting version 175
[ 17.715423] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 17.718048] Marking TSC unstable due to TSC halts in idle
[ 17.718078] ACPI: acpi_idle registered with cpuidle
[ 17.723339] ACPI: Lid Switch [LID]
[ 17.723513] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 17.723526] ACPI: Sleep Button [SLPB]
[ 17.723675] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 17.723684] ACPI: Power Button [PWRB]
[ 17.723818] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 17.723826] ACPI: Power Button [PWRF]
[ 17.751141] Switching to clocksource hpet
[ 18.145687] ACPI: Battery Slot [BAT0] (battery present)
[ 18.145888] ACPI: AC Adapter [AC0] (on-line)
[ 18.198888] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5
[ 18.198903] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 18.377139] intel_rng: FWH not detected
[ 18.413033] iTCO_vendor_support: vendor-support=0
[ 18.447348] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 18.447546] iTCO_wdt: Found a ICH6-M TCO device (Version=2, TCOBASE=0x0860)
[ 18.449569] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 18.697824] psmouse serio1: hgpk: ID: 10 00 64
[ 18.890463] psmouse serio1: elantech: assuming hardware version 2 (with firmware version 0x020030)
[ 18.963997] psmouse serio1: elantech: Synaptics capabilities query result 0x00, 0x02, 0x64.
[ 19.178617] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio1/input/input6
[ 19.389918] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 19.390027] ata2.00: BMDMA stat 0x5
[ 19.390103] ata2.00: failed command: READ DMA
[ 19.390187] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 19.390191] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 19.390394] ata2.00: status: { DRDY ERR }
[ 19.390467] ata2.00: error: { UNC ABRT }
[ 19.404221] ata2.00: configured for UDMA/66
[ 19.420217] ata2.01: configured for UDMA/66
[ 19.420241] ata2: EH complete
[ 19.421476] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 19.421563] ata2.00: BMDMA stat 0x5
[ 19.421636] ata2.00: failed command: READ DMA
[ 19.421720] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 19.421724] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 19.421926] ata2.00: status: { DRDY ERR }
[ 19.422000] ata2.00: error: { UNC ABRT }
[ 19.436208] ata2.00: configured for UDMA/66
[ 19.444199] ata2.01: configured for UDMA/66
[ 19.444218] ata2: EH complete
[ 19.445451] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 19.445538] ata2.00: BMDMA stat 0x5
[ 19.445611] ata2.00: failed command: READ DMA
[ 19.445695] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 19.445699] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 19.445901] ata2.00: status: { DRDY ERR }
[ 19.445975] ata2.00: error: { UNC ABRT }
[ 19.460200] ata2.00: configured for UDMA/66
[ 19.468204] ata2.01: configured for UDMA/66
[ 19.468218] ata2: EH complete
[ 19.469440] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 19.469523] ata2.00: BMDMA stat 0x5
[ 19.469596] ata2.00: failed command: READ DMA
[ 19.469680] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 19.469683] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 19.469885] ata2.00: status: { DRDY ERR }
[ 19.469959] ata2.00: error: { UNC ABRT }
[ 19.484205] ata2.00: configured for UDMA/66
[ 19.492198] ata2.01: configured for UDMA/66
[ 19.492210] ata2: EH complete
[ 19.493431] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 19.493514] ata2.00: BMDMA stat 0x5
[ 19.493586] ata2.00: failed command: READ DMA
[ 19.493670] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 19.493673] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 19.493875] ata2.00: status: { DRDY ERR }
[ 19.493949] ata2.00: error: { UNC ABRT }
[ 19.508267] ata2.00: configured for UDMA/66
[ 19.516208] ata2.01: configured for UDMA/66
[ 19.516229] ata2: EH complete
[ 19.517466] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 19.517554] ata2.00: BMDMA stat 0x5
[ 19.517627] ata2.00: failed command: READ DMA
[ 19.517711] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 19.517714] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 19.517917] ata2.00: status: { DRDY ERR }
[ 19.517990] ata2.00: error: { UNC ABRT }
[ 19.532205] ata2.00: configured for UDMA/66
[ 19.540205] ata2.01: configured for UDMA/66
[ 19.540227] sd 1:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 19.540235] sd 1:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[ 19.540244] Descriptor sense data with sense descriptors (in hex):
[ 19.540248] 72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
[ 19.540265] 00 00 08 00
[ 19.540273] sd 1:0:0:0: [sda] Add. Sense: No additional sense information
[ 19.540283] sd 1:0:0:0: [sda] CDB: Read(10): 28 00 00 00 08 00 00 00 08 00
[ 19.540300] end_request: I/O error, dev sda, sector 2048
[ 19.540381] Buffer I/O error on device sda, logical block 256
[ 19.540478] ata2: EH complete
[ 19.542910] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 19.542997] ata2.00: BMDMA stat 0x5
[ 19.543072] ata2.00: failed command: READ DMA
[ 19.543159] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 19.543162] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 19.543369] ata2.00: status: { DRDY ERR }
[ 19.543445] ata2.00: error: { UNC ABRT }
[ 19.556241] ata2.00: configured for UDMA/66
[ 19.572215] ata2.01: configured for UDMA/66
[ 19.572237] ata2: EH complete
[ 19.573468] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 19.573555] ata2.00: BMDMA stat 0x5
[ 19.573628] ata2.00: failed command: READ DMA
[ 19.573712] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 19.573715] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 19.573918] ata2.00: status: { DRDY ERR }
[ 19.573991] ata2.00: error: { UNC ABRT }
[ 19.588207] ata2.00: configured for UDMA/66
[ 19.596215] ata2.01: configured for UDMA/66
[ 19.596233] ata2: EH complete
[ 19.597458] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 19.597541] ata2.00: BMDMA stat 0x5
[ 19.597614] ata2.00: failed command: READ DMA
[ 19.597698] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 19.597701] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 19.597903] ata2.00: status: { DRDY ERR }
[ 19.597976] ata2.00: error: { UNC ABRT }
[ 19.612205] ata2.00: configured for UDMA/66
[ 19.620205] ata2.01: configured for UDMA/66
[ 19.620216] ata2: EH complete
[ 19.621435] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 19.621517] ata2.00: BMDMA stat 0x5
[ 19.621590] ata2.00: failed command: READ DMA
[ 19.625297] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 19.625300] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 19.625502] ata2.00: status: { DRDY ERR }
[ 19.625576] ata2.00: error: { UNC ABRT }
[ 19.640206] ata2.00: configured for UDMA/66
[ 19.648203] ata2.01: configured for UDMA/66
[ 19.648214] ata2: EH complete
[ 19.649435] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 19.649516] ata2.00: BMDMA stat 0x5
[ 19.649589] ata2.00: failed command: READ DMA
[ 19.649672] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 19.649675] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 19.649877] ata2.00: status: { DRDY ERR }
[ 19.649951] ata2.00: error: { UNC ABRT }
[ 19.664271] ata2.00: configured for UDMA/66
[ 19.672203] ata2.01: configured for UDMA/66
[ 19.672225] ata2: EH complete
[ 19.673459] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 19.673546] ata2.00: BMDMA stat 0x5
[ 19.673620] ata2.00: failed command: READ DMA
[ 19.673704] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 19.673707] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 19.673910] ata2.00: status: { DRDY ERR }
[ 19.673983] ata2.00: error: { UNC ABRT }
[ 19.688217] ata2.00: configured for UDMA/66
[ 19.696225] ata2.01: configured for UDMA/66
[ 19.696248] sd 1:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 19.696256] sd 1:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[ 19.696265] Descriptor sense data with sense descriptors (in hex):
[ 19.696270] 72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
[ 19.696287] 00 00 08 00
[ 19.696295] sd 1:0:0:0: [sda] Add. Sense: No additional sense information
[ 19.696305] sd 1:0:0:0: [sda] CDB: Read(10): 28 00 00 00 08 00 00 00 08 00
[ 19.696322] end_request: I/O error, dev sda, sector 2048
[ 19.696404] Buffer I/O error on device sda, logical block 256
[ 19.696501] ata2: EH complete
