J’ai utilisé fdisk depuis une autre machine en ssh, lorsque j’ai quitté fdisk (“write table to disk and exit”) j’ai eu un message d’erreur dans le tty1 du eeepc:
Durant le reboot, il y a nettement moins de lignes de messages d’erreurs mais il y en a encore…
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-4-686-pae (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-15) ) #1 SMP Debian 3.2.41-2
[ 0.000000] Disabled fast string operations
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003f780000 (usable)
[ 0.000000] BIOS-e820: 000000003f780000 - 000000003f790000 (ACPI data)
[ 0.000000] BIOS-e820: 000000003f790000 - 000000003f7d0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003f7d0000 - 000000003f7de000 (reserved)
[ 0.000000] BIOS-e820: 000000003f7e0000 - 000000003f800000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: ASUSTeK Computer INC. 900/900, BIOS 0802 07/07/2008
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x3f780 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-DFFFF uncachable
[ 0.000000] E0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 03F800000 mask FFF800000 uncachable
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT not supported by CPU.
[ 0.000000] found SMP MP-table at [c00ff780] ff780
[ 0.000000] initial memory mapped : 0 - 01a00000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000379fe000
[ 0.000000] 0000000000 - 0000200000 page 4k
[ 0.000000] 0000200000 - 0037800000 page 2M
[ 0.000000] 0037800000 - 00379fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 379fe000 @ 19f9000-1a00000
[ 0.000000] RAMDISK: 36984000 - 374ba000
[ 0.000000] ACPI: RSDP 000fbe60 00014 (v00 ACPIAM)
[ 0.000000] ACPI: RSDT 3f780000 00034 (v01 A M I OEMRSDT 07000807 MSFT 00000097)
[ 0.000000] ACPI: FACP 3f780200 00081 (v01 A M I OEMFACP 07000807 MSFT 00000097)
[ 0.000000] ACPI: DSDT 3f780400 06105 (v01 A0979 A0979029 00000029 INTL 20060113)
[ 0.000000] ACPI: FACS 3f790000 00040
[ 0.000000] ACPI: APIC 3f780390 00068 (v01 A M I OEMAPIC 07000807 MSFT 00000097)
[ 0.000000] ACPI: OEMB 3f790040 00046 (v01 A M I AMI_OEM 07000807 MSFT 00000097)
[ 0.000000] ACPI: MCFG 3f786510 0003C (v01 A M I OEMMCFG 07000807 MSFT 00000097)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 125MB HIGHMEM available.
[ 0.000000] 889MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 379fe000
[ 0.000000] low ram: 0 - 379fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000379fe
[ 0.000000] HighMem 0x000379fe -> 0x0003f780
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0003f780
[ 0.000000] On node 0 totalpages: 259855
[ 0.000000] free_area_init_node: node 0, pgdat c1412600, node_mem_map f6194200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1748 pages used for memmap
[ 0.000000] Normal zone: 221994 pages, LIFO batch:31
[ 0.000000] HighMem zone: 252 pages used for memmap
[ 0.000000] HighMem zone: 31878 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
[ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 3f800000 (gap: 3f800000:bf600000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 14 pages/cpu @f79e9000 s33280 r0 d24064 u57344
[ 0.000000] pcpu-alloc: s33280 r0 d24064 u57344 alloc=14*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 257823
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-686-pae root=UUID=6196c50e-51db-4dc6-974f-c001f8c4f4b1 ro initrd=/install/initrd.gz quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000379fe:0003f780)
[ 0.000000] Memory: 1013704k/1039872k available (2847k kernel code, 25716k reserved, 1352k data, 416k init, 128520k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xffd36000 - 0xfffff000 (2852 kB)
[ 0.000000] pkmap : 0xffa00000 - 0xffc00000 (2048 kB)
[ 0.000000] vmalloc : 0xf81fe000 - 0xff9fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf79fe000 ( 889 MB)
[ 0.000000] .init : 0xc141a000 - 0xc1482000 ( 416 kB)
[ 0.000000] .data : 0xc12c7e00 - 0xc1419f40 (1352 kB)
[ 0.000000] .text : 0xc1000000 - 0xc12c7e00 (2847 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:256 16
[ 0.000000] CPU 0 irqstacks, hard=f5c06000 soft=f5c08000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 900.093 MHz processor.
[ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 1800.18 BogoMIPS (lpj=3600372)
[ 0.004015] pid_max: default: 32768 minimum: 301
[ 0.004110] Security Framework initialized
[ 0.004124] AppArmor: AppArmor disabled by boot time parameter
[ 0.004156] Mount-cache hash table entries: 512
[ 0.004443] Initializing cgroup subsys cpuacct
[ 0.004458] Initializing cgroup subsys memory
[ 0.004480] Initializing cgroup subsys devices
[ 0.004486] Initializing cgroup subsys freezer
[ 0.004491] Initializing cgroup subsys net_cls
[ 0.004497] Initializing cgroup subsys blkio
[ 0.004514] Initializing cgroup subsys perf_event
[ 0.004572] Disabled fast string operations
[ 0.004589] mce: CPU supports 5 MCE banks
[ 0.004609] CPU0: Thermal monitoring enabled (TM1)
[ 0.004713] SMP alternatives: switching to UP code
[ 0.013646] Freeing SMP alternatives: 8k freed
[ 0.013658] ACPI: Core revision 20110623
[ 0.024116] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.024533] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.065013] CPU0: Intel(R) Celeron(R) M processor 900MHz stepping 08
[ 0.068003] Performance Events: p6 PMU driver.
[ 0.068003] ... version: 0
[ 0.068003] ... bit width: 32
[ 0.068003] ... generic registers: 2
[ 0.068003] ... value mask: 00000000ffffffff
[ 0.068003] ... max period: 000000007fffffff
[ 0.068003] ... fixed-purpose events: 0
[ 0.068003] ... event mask: 0000000000000003
[ 0.068003] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.068003] Brought up 1 CPUs
[ 0.068003] Total of 1 processors activated (1800.18 BogoMIPS).
[ 0.068003] devtmpfs: initialized
[ 0.068003] PM: Registering ACPI NVS region at 3f790000 (262144 bytes)
[ 0.068003] print_constraints: dummy:
[ 0.068003] NET: Registered protocol family 16
[ 0.068003] ACPI: bus type pci registered
[ 0.068003] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.068003] PCI: not using MMCONFIG
[ 0.068003] PCI : PCI BIOS aera is rw and x. Use pci=nobios if you want it NX.
[ 0.068003] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=5
[ 0.068003] PCI: Using configuration type 1 for base access
[ 0.068858] bio: create slab <bio-0> at 0
[ 0.069038] ACPI: Added _OSI(Module Device)
[ 0.069045] ACPI: Added _OSI(Processor Device)
[ 0.069051] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.069057] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.071137] ACPI: EC: Look up EC in DSDT
[ 0.073420] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.088822] ACPI: Interpreter enabled
[ 0.088860] ACPI: (supports S0 S3 S4 S5)
[ 0.088912] ACPI: Using IOAPIC for interrupt routing
[ 0.088971] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.090178] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.090185] PCI: Using MMCONFIG for extended config space
[ 0.100352] ACPI: EC: GPE = 0x18, I/O: command/status = 0x66, data = 0x62
[ 0.100651] ACPI: No dock devices found.
[ 0.100656] HEST: Table not found.
[ 0.100669] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.100878] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.101326] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.101334] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.101341] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.101348] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000dffff]
[ 0.101356] pci_root PNP0A08:00: host bridge window [mem 0x3f810000-0xffffffff]
[ 0.101386] pci 0000:00:00.0: [8086:2590] type 0 class 0x000600
[ 0.101467] pci 0000:00:02.0: [8086:2592] type 0 class 0x000300
[ 0.101486] pci 0000:00:02.0: reg 10: [mem 0xf7f00000-0xf7f7ffff]
[ 0.101498] pci 0000:00:02.0: reg 14: [io 0xec00-0xec07]
[ 0.101511] pci 0000:00:02.0: reg 18: [mem 0xd0000000-0xdfffffff pref]
[ 0.101523] pci 0000:00:02.0: reg 1c: [mem 0xf7ec0000-0xf7efffff]
[ 0.101580] pci 0000:00:02.1: [8086:2792] type 0 class 0x000380
[ 0.101597] pci 0000:00:02.1: reg 10: [mem 0xf7f80000-0xf7ffffff]
[ 0.101714] pci 0000:00:1b.0: [8086:2668] type 0 class 0x000403
[ 0.101739] pci 0000:00:1b.0: reg 10: [mem 0xf7eb8000-0xf7ebbfff 64bit]
[ 0.101831] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.101867] pci 0000:00:1c.0: [8086:2660] type 1 class 0x000604
[ 0.101963] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.102003] pci 0000:00:1c.1: [8086:2662] type 1 class 0x000604
[ 0.102097] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.102134] pci 0000:00:1c.2: [8086:2664] type 1 class 0x000604
[ 0.102228] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.102268] pci 0000:00:1d.0: [8086:2658] type 0 class 0x000c03
[ 0.102324] pci 0000:00:1d.0: reg 20: [io 0xe400-0xe41f]
[ 0.102370] pci 0000:00:1d.1: [8086:2659] type 0 class 0x000c03
[ 0.102424] pci 0000:00:1d.1: reg 20: [io 0xe480-0xe49f]
[ 0.102472] pci 0000:00:1d.2: [8086:265a] type 0 class 0x000c03
[ 0.102526] pci 0000:00:1d.2: reg 20: [io 0xe800-0xe81f]
[ 0.102572] pci 0000:00:1d.3: [8086:265b] type 0 class 0x000c03
[ 0.102626] pci 0000:00:1d.3: reg 20: [io 0xe880-0xe89f]
[ 0.102681] pci 0000:00:1e.0: [8086:2448] type 1 class 0x000604
[ 0.102764] pci 0000:00:1f.0: [8086:2641] type 0 class 0x000601
[ 0.102867] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[ 0.102886] pci 0000:00:1f.0: LPC Generic IO decode 1 PIO at 0380-03ff
[ 0.102920] pci 0000:00:1f.2: [8086:2653] type 0 class 0x000101
[ 0.102942] pci 0000:00:1f.2: reg 10: [io 0x0000-0x0007]
[ 0.102956] pci 0000:00:1f.2: reg 14: [io 0x0000-0x0003]
[ 0.102970] pci 0000:00:1f.2: reg 18: [io 0x0000-0x0007]
[ 0.102984] pci 0000:00:1f.2: reg 1c: [io 0x0000-0x0003]
[ 0.102999] pci 0000:00:1f.2: reg 20: [io 0xffa0-0xffaf]
[ 0.103049] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.103074] pci 0000:00:1f.3: [8086:266a] type 0 class 0x000c05
[ 0.103139] pci 0000:00:1f.3: reg 20: [io 0x0400-0x041f]
[ 0.103236] pci 0000:00:1c.0: PCI bridge to [bus 04-04]
[ 0.103330] pci 0000:03:00.0: [1969:2048] type 0 class 0x000200
[ 0.103362] pci 0000:03:00.0: reg 10: [mem 0xfbfc0000-0xfbffffff 64bit]
[ 0.103429] pci 0000:03:00.0: reg 30: [mem 0xfbfa0000-0xfbfbffff pref]
[ 0.103506] pci 0000:03:00.0: PME# supported from D3hot D3cold
[ 0.103538] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.103556] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.103567] pci 0000:00:1c.1: bridge window [mem 0xfbf00000-0xfbffffff]
[ 0.103652] pci 0000:01:00.0: [168c:001c] type 0 class 0x000200
[ 0.103684] pci 0000:01:00.0: reg 10: [mem 0xfbef0000-0xfbefffff 64bit]
[ 0.103847] pci 0000:01:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.103864] pci 0000:00:1c.2: PCI bridge to [bus 01-02]
[ 0.103875] pci 0000:00:1c.2: bridge window [mem 0xf8000000-0xfbefffff]
[ 0.103886] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf6ffffff 64bit pref]
[ 0.103968] pci 0000:00:1e.0: PCI bridge to [bus 05-05] (subtractive decode)
[ 0.103984] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.103992] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.104018] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.104026] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode)
[ 0.104034] pci 0000:00:1e.0: bridge window [mem 0x3f810000-0xffffffff] (subtractive decode)
[ 0.104062] pci_bus 0000:00: on NUMA node 0
[ 0.104072] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.104399] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P3._PRT]
[ 0.104471] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P5._PRT]
[ 0.104530] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P6._PRT]
[ 0.104726] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.104735] pci0000:00: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d
[ 0.104741] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.114586] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.114711] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.114830] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.114948] ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.115067] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.115187] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.115309] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.115430] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[ 0.115725] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.115746] vgaarb: loaded
[ 0.115750] vgaarb: bridge control possible 0000:00:02.0
[ 0.115856] PCI: Using ACPI for IRQ routing
[ 0.115915] PCI: pci_cache_line_size set to 64 bytes
[ 0.116034] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.116041] reserve RAM buffer: 000000003f780000 - 000000003fffffff
[ 0.116571] hpet clockevent registered
[ 0.116579] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.116590] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.116601] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.120114] Switching to clocksource hpet
[ 0.124235] pnp: PnP ACPI init
[ 0.124280] ACPI: bus type pnp registered
[ 0.124561] pnp 00:00: [bus 00-ff]
[ 0.124569] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.124575] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.124582] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.124589] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.124595] pnp 00:00: [mem 0x000d0000-0x000dffff window]
[ 0.124602] pnp 00:00: [mem 0x3f810000-0xffffffff window]
[ 0.124744] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.124772] pnp 00:01: [mem 0xfed13000-0xfed19fff]
[ 0.124889] system 00:01: [mem 0xfed13000-0xfed19fff] has been reserved
[ 0.124898] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.124959] pnp 00:02: [dma 4]
[ 0.124965] pnp 00:02: [io 0x0000-0x000f]
[ 0.124971] pnp 00:02: [io 0x0081-0x0083]
[ 0.124977] pnp 00:02: [io 0x0087]
[ 0.124982] pnp 00:02: [io 0x0089-0x008b]
[ 0.124988] pnp 00:02: [io 0x008f]
[ 0.124993] pnp 00:02: [io 0x00c0-0x00df]
[ 0.125059] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.125092] pnp 00:03: [io 0x0070-0x0071]
[ 0.125114] pnp 00:03: [irq 8]
[ 0.125188] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.125278] pnp 00:04: [io 0x0060]
[ 0.125284] pnp 00:04: [io 0x0064]
[ 0.125296] pnp 00:04: [irq 1]
[ 0.125370] pnp 00:04: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.125498] pnp 00:05: [irq 12]
[ 0.125582] pnp 00:05: Plug and Play ACPI device, IDs SYN0a00 SYN0a01 SYN0a04 SYN0002 PNP0f13 (active)
[ 0.125608] pnp 00:06: [io 0x0061]
[ 0.125676] pnp 00:06: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.125701] pnp 00:07: [io 0x00f0-0x00ff]
[ 0.125714] pnp 00:07: [irq 13]
[ 0.125783] pnp 00:07: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.126019] pnp 00:08: [io 0x0010-0x001f]
[ 0.126026] pnp 00:08: [io 0x0022-0x003f]
[ 0.126032] pnp 00:08: [io 0x0044-0x005f]
[ 0.126037] pnp 00:08: [io 0x0063]
[ 0.126043] pnp 00:08: [io 0x0067-0x006f]
[ 0.126049] pnp 00:08: [io 0x0072-0x007f]
[ 0.126054] pnp 00:08: [io 0x0080]
[ 0.126060] pnp 00:08: [io 0x0084-0x0086]
[ 0.126065] pnp 00:08: [io 0x0088]
[ 0.126071] pnp 00:08: [io 0x008c-0x008e]
[ 0.126076] pnp 00:08: [io 0x0090-0x009f]
[ 0.126082] pnp 00:08: [io 0x00a2-0x00bf]
[ 0.126088] pnp 00:08: [io 0x00e0-0x00ef]
[ 0.126094] pnp 00:08: [io 0x0380-0x0383]
[ 0.126099] pnp 00:08: [io 0x04d0-0x04d1]
[ 0.126105] pnp 00:08: [io 0x0800-0x087f]
[ 0.126112] pnp 00:08: [io 0x0000-0xffffffffffffffff disabled]
[ 0.126118] pnp 00:08: [io 0x0480-0x04bf]
[ 0.126124] pnp 00:08: [mem 0xfed1c000-0xfed1ffff]
[ 0.126130] pnp 00:08: [mem 0xfed20000-0xfed8ffff]
[ 0.126136] pnp 00:08: [mem 0xfff00000-0xffffffff]
[ 0.126280] system 00:08: [io 0x0380-0x0383] has been reserved
[ 0.126288] system 00:08: [io 0x04d0-0x04d1] has been reserved
[ 0.126296] system 00:08: [io 0x0800-0x087f] has been reserved
[ 0.126304] system 00:08: [io 0x0480-0x04bf] has been reserved
[ 0.126313] system 00:08: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.126322] system 00:08: [mem 0xfed20000-0xfed8ffff] has been reserved
[ 0.126330] system 00:08: [mem 0xfff00000-0xffffffff] could not be reserved
[ 0.126339] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.126577] pnp 00:09: [mem 0xfec00000-0xfec00fff]
[ 0.126584] pnp 00:09: [mem 0xfee00000-0xfee00fff]
[ 0.126695] system 00:09: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.126704] system 00:09: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.126712] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.126801] pnp 00:0a: [mem 0xe0000000-0xefffffff]
[ 0.126917] system 00:0a: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.126926] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.127087] pnp 00:0b: [mem 0xe0000000-0xefffffff]
[ 0.127211] system 00:0b: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.127220] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.127432] pnp 00:0c: [mem 0x00000000-0x0009ffff]
[ 0.127439] pnp 00:0c: [mem 0x00000000-0xffffffffffffffff disabled]
[ 0.127446] pnp 00:0c: [mem 0x000e0000-0x000fffff]
[ 0.127452] pnp 00:0c: [mem 0x00100000-0x3f7fffff]
[ 0.127459] pnp 00:0c: [mem 0x00000000-0xffffffffffffffff disabled]
[ 0.127592] system 00:0c: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.127601] system 00:0c: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.127610] system 00:0c: [mem 0x00100000-0x3f7fffff] could not be reserved
[ 0.127618] system 00:0c: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.127968] pnp: PnP ACPI: found 13 devices
[ 0.127974] ACPI: ACPI bus type pnp unregistered
[ 0.127984] PnPBIOS: Disabled by ACPI PNP
[ 0.167413] PCI: max bus depth: 1 pci_try_num: 2
[ 0.167490] pci 0000:00:1c.2: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.167502] pci 0000:00:1c.1: BAR 15: assigned [mem 0x3f900000-0x3fafffff 64bit pref]
[ 0.167514] pci 0000:00:1c.1: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.167524] pci 0000:00:1c.0: BAR 14: assigned [mem 0x3fb00000-0x3fcfffff]
[ 0.167534] pci 0000:00:1c.0: BAR 15: assigned [mem 0x3fd00000-0x3fefffff 64bit pref]
[ 0.167546] pci 0000:00:1c.0: BAR 13: assigned [io 0x3000-0x3fff]
[ 0.167554] pci 0000:00:1c.0: PCI bridge to [bus 04-04]
[ 0.167562] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff]
[ 0.167572] pci 0000:00:1c.0: bridge window [mem 0x3fb00000-0x3fcfffff]
[ 0.167581] pci 0000:00:1c.0: bridge window [mem 0x3fd00000-0x3fefffff 64bit pref]
[ 0.167593] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.167601] pci 0000:00:1c.1: bridge window [io 0x2000-0x2fff]
[ 0.167611] pci 0000:00:1c.1: bridge window [mem 0xfbf00000-0xfbffffff]
[ 0.167620] pci 0000:00:1c.1: bridge window [mem 0x3f900000-0x3fafffff 64bit pref]
[ 0.167631] pci 0000:00:1c.2: PCI bridge to [bus 01-02]
[ 0.167639] pci 0000:00:1c.2: bridge window [io 0x1000-0x1fff]
[ 0.167649] pci 0000:00:1c.2: bridge window [mem 0xf8000000-0xfbefffff]
[ 0.167658] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf6ffffff 64bit pref]
[ 0.167670] pci 0000:00:1e.0: PCI bridge to [bus 05-05]
[ 0.167697] pci 0000:00:1c.0: enabling device (0104 -> 0107)
[ 0.167733] pci 0000:00:1c.0: setting latency timer to 64
[ 0.167744] pci 0000:00:1c.1: enabling device (0106 -> 0107)
[ 0.167760] pci 0000:00:1c.1: setting latency timer to 64
[ 0.167771] pci 0000:00:1c.2: enabling device (0106 -> 0107)
[ 0.167787] pci 0000:00:1c.2: setting latency timer to 64
[ 0.167799] pci 0000:00:1e.0: setting latency timer to 64
[ 0.167808] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.167814] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.167821] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.167828] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.167835] pci_bus 0000:00: resource 8 [mem 0x3f810000-0xffffffff]
[ 0.167842] pci_bus 0000:04: resource 0 [io 0x3000-0x3fff]
[ 0.167849] pci_bus 0000:04: resource 1 [mem 0x3fb00000-0x3fcfffff]
[ 0.167856] pci_bus 0000:04: resource 2 [mem 0x3fd00000-0x3fefffff 64bit pref]
[ 0.167863] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 0.167870] pci_bus 0000:03: resource 1 [mem 0xfbf00000-0xfbffffff]
[ 0.167877] pci_bus 0000:03: resource 2 [mem 0x3f900000-0x3fafffff 64bit pref]
[ 0.167884] pci_bus 0000:01: resource 0 [io 0x1000-0x1fff]
[ 0.167891] pci_bus 0000:01: resource 1 [mem 0xf8000000-0xfbefffff]
[ 0.167898] pci_bus 0000:01: resource 2 [mem 0xf0000000-0xf6ffffff 64bit pref]
[ 0.167906] pci_bus 0000:05: resource 4 [io 0x0000-0x0cf7]
[ 0.167912] pci_bus 0000:05: resource 5 [io 0x0d00-0xffff]
[ 0.167919] pci_bus 0000:05: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.167926] pci_bus 0000:05: resource 7 [mem 0x000d0000-0x000dffff]
[ 0.167933] pci_bus 0000:05: resource 8 [mem 0x3f810000-0xffffffff]
[ 0.168052] NET: Registered protocol family 2
[ 0.168197] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.168706] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.170356] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.171139] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.171147] TCP reno registered
[ 0.171158] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.171193] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.171458] NET: Registered protocol family 1
[ 0.171498] pci 0000:00:02.0: Boot video device
[ 0.171691] PCI: CLS 16 bytes, default 64
[ 0.171831] Unpacking initramfs...
[ 1.032662] Freeing initrd memory: 11480k freed
[ 1.047560] audit: initializing netlink socket (disabled)
[ 1.047586] type=2000 audit(1368650193.040:1): initialized
[ 1.079009] highmem bounce pool size: 64 pages
[ 1.079023] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.079651] VFS: Disk quotas dquot_6.5.2
[ 1.079724] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.079889] msgmni has been set to 1751
[ 1.080279] alg: No test for stdrng (krng)
[ 1.080343] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.080351] io scheduler noop registered
[ 1.080355] io scheduler deadline registered
[ 1.080376] io scheduler cfq registered (default)
[ 1.080546] pcieport 0000:00:1c.0: setting latency timer to 64
[ 1.080613] pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X
[ 1.080726] pcieport 0000:00:1c.1: setting latency timer to 64
[ 1.080780] pcieport 0000:00:1c.1: irq 41 for MSI/MSI-X
[ 1.080882] pcieport 0000:00:1c.2: setting latency timer to 64
[ 1.080935] pcieport 0000:00:1c.2: irq 42 for MSI/MSI-X
[ 1.081107] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.081163] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.081169] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 1.081823] intel_idle: does not run on family 6 model 13
[ 1.081880] ERST: Table is not found!
[ 1.081885] GHES: HEST is not enabled!
[ 1.081916] isapnp: Scanning for PnP cards...
[ 1.435539] isapnp: No Plug & Play device found
[ 1.435688] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.436783] Linux agpgart interface v0.103
[ 1.436990] agpgart-intel 0000:00:00.0: Intel 915GM Chipset
[ 1.437091] agpgart-intel 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[ 1.437270] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 1.437501] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 1.437894] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.464746] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.464767] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.465068] mousedev: PS/2 mouse device common for all mice
[ 1.466262] rtc_cmos 00:03: RTC can wake from S4
[ 1.466459] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 1.466496] rtc0: alarms up to one month, 114 bytes nvram, hpet irqs
[ 1.466529] cpuidle: using governor ladder
[ 1.466537] cpuidle: using governor menu
[ 1.467022] TCP cubic registered
[ 1.467076] NET: Registered protocol family 10
[ 1.468196] Mobile IPv6
[ 1.468205] NET: Registered protocol family 17
[ 1.468215] Registering the dns_resolver key type
[ 1.468258] Using IPI No-Shortcut mode
[ 1.468500] PM: Hibernation image not present or could not be loaded.
[ 1.468523] registered taskstats version 1
[ 1.469185] rtc_cmos 00:03: setting system clock to 2013-05-15 20:36:34 UTC (1368650194)
[ 1.469296] Initializing network drop monitor service
[ 1.469503] Freeing unused kernel memory: 416k freed
[ 1.469901] Write protecting the kernel text: 2848k
[ 1.469979] Write protecting the kernel read-only data: 1092k
[ 1.469984] NX-protecting the kernel data: 3296k
[ 1.492404] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.507690] udevd[44]: starting version 175
[ 1.620677] Atheros(R) L2 Ethernet Driver - version 2.2.3
[ 1.620685] Copyright (c) 2007 Atheros Corporation.
[ 1.620760] atl2 0000:03:00.0: setting latency timer to 64
[ 1.656781] usbcore: registered new interface driver usbfs
[ 1.656845] usbcore: registered new interface driver hub
[ 1.672161] usbcore: registered new device driver usb
[ 1.673260] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.674064] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.674161] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.674170] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.674225] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 1.674292] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000e400
[ 1.674374] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.674381] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.674388] usb usb1: Product: UHCI Host Controller
[ 1.674394] usb usb1: Manufacturer: Linux 3.2.0-4-686-pae uhci_hcd
[ 1.674400] usb usb1: SerialNumber: 0000:00:1d.0
[ 1.694369] hub 1-0:1.0: USB hub found
[ 1.694383] hub 1-0:1.0: 2 ports detected
[ 1.694579] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.694588] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.694608] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
[ 1.694678] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000e480
[ 1.694753] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.694761] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.694767] usb usb2: Product: UHCI Host Controller
[ 1.694773] usb usb2: Manufacturer: Linux 3.2.0-4-686-pae uhci_hcd
[ 1.694779] usb usb2: SerialNumber: 0000:00:1d.1
[ 1.698465] hub 2-0:1.0: USB hub found
[ 1.698479] hub 2-0:1.0: 2 ports detected
[ 1.698679] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.698687] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.698710] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
[ 1.698777] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000e800
[ 1.698854] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.698861] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.698868] usb usb3: Product: UHCI Host Controller
[ 1.698874] usb usb3: Manufacturer: Linux 3.2.0-4-686-pae uhci_hcd
[ 1.698880] usb usb3: SerialNumber: 0000:00:1d.2
[ 1.699349] hub 3-0:1.0: USB hub found
[ 1.699361] hub 3-0:1.0: 2 ports detected
[ 1.699528] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.699536] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.699555] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
[ 1.699615] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000e880
[ 1.699689] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.699697] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.699703] usb usb4: Product: UHCI Host Controller
[ 1.699709] usb usb4: Manufacturer: Linux 3.2.0-4-686-pae uhci_hcd
[ 1.699715] usb usb4: SerialNumber: 0000:00:1d.3
[ 1.701761] hub 4-0:1.0: USB hub found
[ 1.701775] hub 4-0:1.0: 2 ports detected
[ 1.784470] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.784478] ACPI: Thermal Zone [TZ00] (61 C)
[ 1.803657] SCSI subsystem initialized
[ 1.850206] libata version 3.00 loaded.
[ 1.852236] ahci 0000:00:1f.2: version 3.0
[ 1.852290] ahci: probe of 0000:00:1f.2 failed with error -22
[ 1.853389] ata_piix 0000:00:1f.2: version 2.13
[ 1.853419] ata_piix 0000:00:1f.2: MAP [ P0 P2 IDE IDE ]
[ 1.853500] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.864738] scsi0 : ata_piix
[ 1.870169] scsi1 : ata_piix
[ 1.873526] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 1.873535] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 2.008037] usb 2-1: new full-speed USB device number 2 using uhci_hcd
[ 2.044023] Refined TSC clocksource calibration: 900.092 MHz.
[ 2.044035] Switching to clocksource tsc
[ 2.056316] ata2.00: CFA: ASUS-PHISON OB SSD, TST2.04P, max UDMA/66
[ 2.056324] ata2.00: 7880544 sectors, multi 0: LBA
[ 2.056337] ata2.01: CFA: ASUS-PHISON SSD, TST2.04P, max UDMA/66
[ 2.056344] ata2.01: 15761088 sectors, multi 0: LBA
[ 2.064223] ata2.00: configured for UDMA/66
[ 2.072195] ata2.01: configured for UDMA/66
[ 2.072450] scsi 1:0:0:0: Direct-Access ATA ASUS-PHISON OB S TST2 PQ: 0 ANSI: 5
[ 2.073282] scsi 1:0:1:0: Direct-Access ATA ASUS-PHISON SSD TST2 PQ: 0 ANSI: 5
[ 2.092363] sd 1:0:0:0: [sda] 7880544 512-byte logical blocks: (4.03 GB/3.75 GiB)
[ 2.092487] sd 1:0:0:0: [sda] Write Protect is off
[ 2.092495] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.092548] sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 2.094819] sda:
[ 2.095236] sd 1:0:1:0: [sdb] 15761088 512-byte logical blocks: (8.06 GB/7.51 GiB)
[ 2.095371] sd 1:0:1:0: [sdb] Write Protect is off
[ 2.095379] sd 1:0:1:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.095432] sd 1:0:1:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 2.096675] sd 1:0:0:0: [sda] Attached SCSI disk
[ 2.098096] sdb: sdb1
[ 2.098917] sd 1:0:1:0: [sdb] Attached SCSI disk
[ 2.108836] sd 1:0:0:0: Attached scsi generic sg0 type 0
[ 2.110064] sd 1:0:1:0: Attached scsi generic sg1 type 0
[ 2.144686] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.144756] ata2.00: BMDMA stat 0x5
[ 2.144812] ata2.00: failed command: READ DMA
[ 2.144877] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.144881] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.145003] ata2.00: status: { DRDY ERR }
[ 2.145057] ata2.00: error: { UNC ABRT }
[ 2.160205] ata2.00: configured for UDMA/66
[ 2.171737] usb 2-1: New USB device found, idVendor=0781, idProduct=5571
[ 2.171744] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.171751] usb 2-1: Product: Cruzer Fit
[ 2.171756] usb 2-1: Manufacturer: SanDisk
[ 2.171762] usb 2-1: SerialNumber: 4C532000000911116344
[ 2.176452] ata2.01: configured for UDMA/66
[ 2.176477] ata2: EH complete
[ 2.177759] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.177827] ata2.00: BMDMA stat 0x5
[ 2.177881] ata2.00: failed command: READ DMA
[ 2.177948] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.177951] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.178073] ata2.00: status: { DRDY ERR }
[ 2.178129] ata2.00: error: { UNC ABRT }
[ 2.182467] Initializing USB Mass Storage driver...
[ 2.182661] scsi2 : usb-storage 2-1:1.0
[ 2.182858] usbcore: registered new interface driver usb-storage
[ 2.182866] USB Mass Storage support registered.
[ 2.192221] ata2.00: configured for UDMA/66
[ 2.200197] ata2.01: configured for UDMA/66
[ 2.200217] ata2: EH complete
[ 2.201459] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.201527] ata2.00: BMDMA stat 0x5
[ 2.201580] ata2.00: failed command: READ DMA
[ 2.201645] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.201649] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.201811] ata2.00: status: { DRDY ERR }
[ 2.201884] ata2.00: error: { UNC ABRT }
[ 2.216197] ata2.00: configured for UDMA/66
[ 2.224196] ata2.01: configured for UDMA/66
[ 2.224210] ata2: EH complete
[ 2.225431] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.225515] ata2.00: BMDMA stat 0x5
[ 2.225587] ata2.00: failed command: READ DMA
[ 2.225671] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.225675] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.225876] ata2.00: status: { DRDY ERR }
[ 2.225949] ata2.00: error: { UNC ABRT }
[ 2.240198] ata2.00: configured for UDMA/66
[ 2.248197] ata2.01: configured for UDMA/66
[ 2.248210] ata2: EH complete
[ 2.249431] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.249513] ata2.00: BMDMA stat 0x5
[ 2.249586] ata2.00: failed command: READ DMA
[ 2.249670] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.249673] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.249874] ata2.00: status: { DRDY ERR }
[ 2.249947] ata2.00: error: { UNC ABRT }
[ 2.264197] ata2.00: configured for UDMA/66
[ 2.272196] ata2.01: configured for UDMA/66
[ 2.272209] ata2: EH complete
[ 2.273430] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.273512] ata2.00: BMDMA stat 0x5
[ 2.273585] ata2.00: failed command: READ DMA
[ 2.273668] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.273672] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.273873] ata2.00: status: { DRDY ERR }
[ 2.273946] ata2.00: error: { UNC ABRT }
[ 2.284024] usb 4-2: new full-speed USB device number 2 using uhci_hcd
[ 2.288201] ata2.00: configured for UDMA/66
[ 2.296198] ata2.01: configured for UDMA/66
[ 2.296218] sd 1:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 2.296227] sd 1:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[ 2.296237] Descriptor sense data with sense descriptors (in hex):
[ 2.296243] 72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
[ 2.296263] 00 00 08 00
[ 2.296272] sd 1:0:0:0: [sda] Add. Sense: No additional sense information
[ 2.296283] sd 1:0:0:0: [sda] CDB: Read(10): 28 00 00 00 08 00 00 00 08 00
[ 2.296302] end_request: I/O error, dev sda, sector 2048
[ 2.296383] Buffer I/O error on device sda, logical block 256
[ 2.296486] ata2: EH complete
[ 2.298927] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.299011] ata2.00: BMDMA stat 0x5
[ 2.299085] ata2.00: failed command: READ DMA
[ 2.299170] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.299173] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.299375] ata2.00: status: { DRDY ERR }
[ 2.299449] ata2.00: error: { UNC ABRT }
[ 2.312200] ata2.00: configured for UDMA/66
[ 2.328196] ata2.01: configured for UDMA/66
[ 2.328209] ata2: EH complete
[ 2.329433] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.329514] ata2.00: BMDMA stat 0x5
[ 2.329587] ata2.00: failed command: READ DMA
[ 2.329671] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.329675] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.329875] ata2.00: status: { DRDY ERR }
[ 2.329949] ata2.00: error: { UNC ABRT }
[ 2.344227] ata2.00: configured for UDMA/66
[ 2.352197] ata2.01: configured for UDMA/66
[ 2.352209] ata2: EH complete
[ 2.353429] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.353510] ata2.00: BMDMA stat 0x5
[ 2.353583] ata2.00: failed command: READ DMA
[ 2.353667] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.353670] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.353871] ata2.00: status: { DRDY ERR }
[ 2.353945] ata2.00: error: { UNC ABRT }
[ 2.368197] ata2.00: configured for UDMA/66
[ 2.376197] ata2.01: configured for UDMA/66
[ 2.376209] ata2: EH complete
[ 2.377427] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.377509] ata2.00: BMDMA stat 0x5
[ 2.377581] ata2.00: failed command: READ DMA
[ 2.377665] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.377669] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.377870] ata2.00: status: { DRDY ERR }
[ 2.377943] ata2.00: error: { UNC ABRT }
[ 2.392197] ata2.00: configured for UDMA/66
[ 2.400212] ata2.01: configured for UDMA/66
[ 2.400224] ata2: EH complete
[ 2.401445] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.401527] ata2.00: BMDMA stat 0x5
[ 2.401600] ata2.00: failed command: READ DMA
[ 2.401684] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.401688] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.401888] ata2.00: status: { DRDY ERR }
[ 2.401962] ata2.00: error: { UNC ABRT }
[ 2.416198] ata2.00: configured for UDMA/66
[ 2.424200] ata2.01: configured for UDMA/66
[ 2.424213] ata2: EH complete
[ 2.425433] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 2.425515] ata2.00: BMDMA stat 0x5
[ 2.425588] ata2.00: failed command: READ DMA
[ 2.425684] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 2.425687] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 2.425888] ata2.00: status: { DRDY ERR }
[ 2.425961] ata2.00: error: { UNC ABRT }
[ 2.440198] ata2.00: configured for UDMA/66
[ 2.448198] ata2.01: configured for UDMA/66
[ 2.448213] sd 1:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 2.448222] sd 1:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[ 2.448232] Descriptor sense data with sense descriptors (in hex):
[ 2.448237] 72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
[ 2.448257] 00 00 08 00
[ 2.448266] sd 1:0:0:0: [sda] Add. Sense: No additional sense information
[ 2.448277] sd 1:0:0:0: [sda] CDB: Read(10): 28 00 00 00 08 00 00 00 08 00
[ 2.448295] end_request: I/O error, dev sda, sector 2048
[ 2.448376] Buffer I/O error on device sda, logical block 256
[ 2.448474] ata2: EH complete
[ 2.550699] usb 4-2: New USB device found, idVendor=04f2, idProduct=b071
[ 2.550708] usb 4-2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[ 2.550715] usb 4-2: Product: CNF7129
[ 2.550720] usb 4-2: Manufacturer: Chicony Electronics Co., Ltd.
[ 2.550726] usb 4-2: SerialNumber: SN0001
[ 3.184796] scsi 2:0:0:0: Direct-Access SanDisk Cruzer Fit 1.26 PQ: 0 ANSI: 5
[ 3.187868] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 3.193935] sd 2:0:0:0: [sdc] 7821312 512-byte logical blocks: (4.00 GB/3.72 GiB)
[ 3.198780] sd 2:0:0:0: [sdc] Write Protect is off
[ 3.198791] sd 2:0:0:0: [sdc] Mode Sense: 43 00 00 00
[ 3.203752] sd 2:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 3.239765] sdc: sdc1 sdc2 < sdc5 >
[ 3.266762] sd 2:0:0:0: [sdc] Attached SCSI removable disk
[ 5.050256] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[ 13.024643] udevd[349]: starting version 175
[ 16.620512] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 16.620624] ata2.00: BMDMA stat 0x5
[ 16.620699] ata2.00: failed command: READ DMA
[ 16.620805] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 16.620809] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 16.621015] ata2.00: status: { DRDY ERR }
[ 16.621091] ata2.00: error: { UNC ABRT }
[ 16.636213] ata2.00: configured for UDMA/66
[ 16.652212] ata2.01: configured for UDMA/66
[ 16.652232] ata2: EH complete
[ 16.653458] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 16.653541] ata2.00: BMDMA stat 0x5
[ 16.653615] ata2.00: failed command: READ DMA
[ 16.653700] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 16.653703] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 16.653916] ata2.00: status: { DRDY ERR }
[ 16.653989] ata2.00: error: { UNC ABRT }
[ 16.668220] ata2.00: configured for UDMA/66
[ 16.676210] ata2.01: configured for UDMA/66
[ 16.676227] ata2: EH complete
[ 16.677452] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 16.677535] ata2.00: BMDMA stat 0x5
[ 16.677609] ata2.00: failed command: READ DMA
[ 16.677694] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 16.677697] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 16.677910] ata2.00: status: { DRDY ERR }
[ 16.677984] ata2.00: error: { UNC ABRT }
[ 16.692220] ata2.00: configured for UDMA/66
[ 16.700209] ata2.01: configured for UDMA/66
[ 16.700225] ata2: EH complete
[ 16.701448] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 16.701531] ata2.00: BMDMA stat 0x5
[ 16.701605] ata2.00: failed command: READ DMA
[ 16.701690] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 16.701693] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 16.701904] ata2.00: status: { DRDY ERR }
[ 16.701978] ata2.00: error: { UNC ABRT }
[ 16.716218] ata2.00: configured for UDMA/66
[ 16.724209] ata2.01: configured for UDMA/66
[ 16.724226] ata2: EH complete
[ 16.725446] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 16.725530] ata2.00: BMDMA stat 0x5
[ 16.725603] ata2.00: failed command: READ DMA
[ 16.725688] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 16.725692] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 16.725903] ata2.00: status: { DRDY ERR }
[ 16.725977] ata2.00: error: { UNC ABRT }
[ 16.740219] ata2.00: configured for UDMA/66
[ 16.748210] ata2.01: configured for UDMA/66
[ 16.748227] ata2: EH complete
[ 16.749448] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 16.749531] ata2.00: BMDMA stat 0x5
[ 16.749604] ata2.00: failed command: READ DMA
[ 16.749688] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 16.749692] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 16.749903] ata2.00: status: { DRDY ERR }
[ 16.749978] ata2.00: error: { UNC ABRT }
[ 16.764218] ata2.00: configured for UDMA/66
[ 16.772210] ata2.01: configured for UDMA/66
[ 16.772230] sd 1:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 16.772239] sd 1:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[ 16.772249] Descriptor sense data with sense descriptors (in hex):
[ 16.772254] 72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
[ 16.772275] 00 00 08 00
[ 16.772284] sd 1:0:0:0: [sda] Add. Sense: No additional sense information
[ 16.772295] sd 1:0:0:0: [sda] CDB: Read(10): 28 00 00 00 08 00 00 00 08 00
[ 16.772314] end_request: I/O error, dev sda, sector 2048
[ 16.772398] Buffer I/O error on device sda, logical block 256
[ 16.772492] ata2: EH complete
[ 16.774938] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 16.775022] ata2.00: BMDMA stat 0x5
[ 16.775096] ata2.00: failed command: READ DMA
[ 16.775181] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 16.775184] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 16.775386] ata2.00: status: { DRDY ERR }
[ 16.775461] ata2.00: error: { UNC ABRT }
[ 16.788220] ata2.00: configured for UDMA/66
[ 16.804212] ata2.01: configured for UDMA/66
[ 16.804232] ata2: EH complete
[ 16.805458] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 16.805544] ata2.00: BMDMA stat 0x5
[ 16.805620] ata2.00: failed command: READ DMA
[ 16.805705] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 16.805709] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 16.805936] ata2.00: status: { DRDY ERR }
[ 16.806013] ata2.00: error: { UNC ABRT }
[ 16.820269] ata2.00: configured for UDMA/66
[ 16.828213] ata2.01: configured for UDMA/66
[ 16.828231] ata2: EH complete
[ 16.829455] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 16.829540] ata2.00: BMDMA stat 0x5
[ 16.829616] ata2.00: failed command: READ DMA
[ 16.829702] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 16.829705] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 16.829932] ata2.00: status: { DRDY ERR }
[ 16.830008] ata2.00: error: { UNC ABRT }
[ 16.844213] ata2.00: configured for UDMA/66
[ 16.852214] ata2.01: configured for UDMA/66
[ 16.852234] ata2: EH complete
[ 16.853459] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 16.853544] ata2.00: BMDMA stat 0x5
[ 16.853621] ata2.00: failed command: READ DMA
[ 16.857557] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 16.857561] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 16.857774] ata2.00: status: { DRDY ERR }
[ 16.857849] ata2.00: error: { UNC ABRT }
[ 16.872213] ata2.00: configured for UDMA/66
[ 16.880213] ata2.01: configured for UDMA/66
[ 16.880230] ata2: EH complete
[ 16.881456] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 16.881540] ata2.00: BMDMA stat 0x5
[ 16.881616] ata2.00: failed command: READ DMA
[ 16.881702] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 16.881705] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 16.881929] ata2.00: status: { DRDY ERR }
[ 16.882004] ata2.00: error: { UNC ABRT }
[ 16.896213] ata2.00: configured for UDMA/66
[ 16.904213] ata2.01: configured for UDMA/66
[ 16.904230] ata2: EH complete
[ 16.905455] ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 16.905539] ata2.00: BMDMA stat 0x5
[ 16.905615] ata2.00: failed command: READ DMA
[ 16.905701] ata2.00: cmd c8/00:08:00:08:00/00:00:00:00:00/e0 tag 0 dma 4096 in
[ 16.905705] res 51/44:08:00:08:00/00:00:00:00:00/e0 Emask 0x9 (media error)
[ 16.905929] ata2.00: status: { DRDY ERR }
[ 16.906005] ata2.00: error: { UNC ABRT }
[ 16.920212] ata2.00: configured for UDMA/66
[ 16.928216] ata2.01: configured for UDMA/66
[ 16.928234] sd 1:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 16.928243] sd 1:0:0:0: [sda] Sense Key : Aborted Command [current] [descriptor]
[ 16.928253] Descriptor sense data with sense descriptors (in hex):
[ 16.928258] 72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
[ 16.928278] 00 00 08 00
[ 16.928288] sd 1:0:0:0: [sda] Add. Sense: No additional sense information
[ 16.928299] sd 1:0:0:0: [sda] CDB: Read(10): 28 00 00 00 08 00 00 00 08 00
[ 16.928318] end_request: I/O error, dev sda, sector 2048
[ 16.928400] Buffer I/O error on device sda, logical block 256
[ 16.928495] ata2: EH complete
