et:
Jul 9 19:45:53 SERVER kernel: [ 3.000625] ata5: SATA max UDMA/133 cmd 0x9e0 ctl 0xbe0 bmdma 0xcc00 irq 23
Jul 9 19:45:53 SERVER kernel: [ 3.000629] ata6: SATA max UDMA/133 cmd 0x960 ctl 0xb60 bmdma 0xcc08 irq 23
Jul 9 19:45:53 SERVER kernel: [ 3.001106] firewire_core: created device fw0: GUID 00016c20001f251c, S400
Jul 9 19:45:53 SERVER kernel: [ 3.309074] usb 2-1: new high speed USB device using ehci_hcd and address 2
Jul 9 19:45:53 SERVER kernel: [ 3.465032] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jul 9 19:45:53 SERVER kernel: [ 3.468039] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jul 9 19:45:53 SERVER kernel: [ 3.472314] ata1.00: ATA-7: WDC WD2500JS-22NCB1, 10.02E02, max UDMA/133
Jul 9 19:45:53 SERVER kernel: [ 3.472317] ata1.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 31/32)
Jul 9 19:45:53 SERVER kernel: [ 3.476477] ata1.00: configured for UDMA/133
Jul 9 19:45:53 SERVER kernel: [ 3.476640] scsi 0:0:0:0: Direct-Access ATA WDC WD2500JS-22N 10.0 PQ: 0 ANSI: 5
Jul 9 19:45:53 SERVER kernel: [ 3.486203] usb 2-1: New USB device found, idVendor=06f8, idProduct=300d
Jul 9 19:45:53 SERVER kernel: [ 3.486206] usb 2-1: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Jul 9 19:45:53 SERVER kernel: [ 3.486208] usb 2-1: Product: Deluxe Optical Glass
Jul 9 19:45:53 SERVER kernel: [ 3.486210] usb 2-1: Manufacturer: Guillemot Corporation
Jul 9 19:45:53 SERVER kernel: [ 3.486303] usb 2-1: configuration #1 chosen from 1 choice
Jul 9 19:45:53 SERVER kernel: [ 3.503616] ata5.00: ATA-8: ST31500341AS, CC1H, max UDMA/133
Jul 9 19:45:53 SERVER kernel: [ 3.503621] ata5.00: 2930277168 sectors, multi 16: LBA48 NCQ (depth 31/32)
Jul 9 19:45:53 SERVER kernel: [ 3.559624] ata5.00: configured for UDMA/133
Jul 9 19:45:53 SERVER kernel: [ 3.713022] usb 2-4: new high speed USB device using ehci_hcd and address 5
Jul 9 19:45:53 SERVER kernel: [ 3.934829] usb 2-4: New USB device found, idVendor=0bda, idProduct=0103
Jul 9 19:45:53 SERVER kernel: [ 3.934832] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 9 19:45:53 SERVER kernel: [ 3.934834] usb 2-4: Product: USB 2.0 Card Chip
Jul 9 19:45:53 SERVER kernel: [ 3.934836] usb 2-4: Manufacturer: Generic
Jul 9 19:45:53 SERVER kernel: [ 3.934838] usb 2-4: SerialNumber: 020208014271000001
Jul 9 19:45:53 SERVER kernel: [ 3.934934] usb 2-4: configuration #1 chosen from 1 choice
Jul 9 19:45:53 SERVER kernel: [ 3.943215] Initializing USB Mass Storage driver...
Jul 9 19:45:53 SERVER kernel: [ 3.943379] scsi6 : SCSI emulation for USB Mass Storage devices
Jul 9 19:45:53 SERVER kernel: [ 3.943510] usb-storage: device found at 5
Jul 9 19:45:53 SERVER kernel: [ 3.943512] usb-storage: waiting for device to settle before scanning
Jul 9 19:45:53 SERVER kernel: [ 3.943537] usbcore: registered new interface driver usb-storage
Jul 9 19:45:53 SERVER kernel: [ 3.943541] USB Mass Storage support registered.
Jul 9 19:45:53 SERVER kernel: [ 3.948036] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Jul 9 19:45:53 SERVER kernel: [ 3.956425] ata2.00: ATA-8: ST2000DL003-9VT166, CC3C, max UDMA/133
Jul 9 19:45:53 SERVER kernel: [ 3.956429] ata2.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32)
Jul 9 19:45:53 SERVER kernel: [ 3.968418] ata2.00: configured for UDMA/133
Jul 9 19:45:53 SERVER kernel: [ 3.968573] scsi 1:0:0:0: Direct-Access ATA ST2000DL003-9VT1 CC3C PQ: 0 ANSI: 5
Jul 9 19:45:53 SERVER kernel: [ 4.135170] scsi 4:0:0:0: Direct-Access ATA ST31500341AS CC1H PQ: 0 ANSI: 5
Jul 9 19:45:53 SERVER kernel: [ 4.244028] usb 1-2: new low speed USB device using ohci_hcd and address 2
Jul 9 19:45:53 SERVER kernel: [ 5.017035] ata6: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Jul 9 19:45:53 SERVER kernel: [ 5.024447] ata6.00: ATA-8: ST2000DL003-9VT166, CC32, max UDMA/133
Jul 9 19:45:53 SERVER kernel: [ 5.024450] ata6.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32)
Jul 9 19:45:53 SERVER kernel: [ 5.040436] ata6.00: configured for UDMA/133
Jul 9 19:45:53 SERVER kernel: [ 5.040550] scsi 5:0:0:0: Direct-Access ATA ST2000DL003-9VT1 CC32 PQ: 0 ANSI: 5
Jul 9 19:45:53 SERVER kernel: [ 5.047645] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
Jul 9 19:45:53 SERVER kernel: [ 5.047701] sd 0:0:0:0: [sda] Write Protect is off
Jul 9 19:45:53 SERVER kernel: [ 5.047704] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Jul 9 19:45:53 SERVER kernel: [ 5.047731] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 9 19:45:53 SERVER kernel: [ 5.047874] sda:
Jul 9 19:45:53 SERVER kernel: [ 5.048255] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
Jul 9 19:45:53 SERVER kernel: [ 5.048258] sd 1:0:0:0: [sdb] 4096-byte physical blocks
Jul 9 19:45:53 SERVER kernel: [ 5.048308] sd 1:0:0:0: [sdb] Write Protect is off
Jul 9 19:45:53 SERVER kernel: [ 5.048311] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Jul 9 19:45:53 SERVER kernel: [ 5.048332] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 9 19:45:53 SERVER kernel: [ 5.048470] sdb:
Jul 9 19:45:53 SERVER kernel: [ 5.048614] sd 4:0:0:0: [sdc] 2930277168 512-byte logical blocks: (1.50 TB/1.36 TiB)
Jul 9 19:45:53 SERVER kernel: [ 5.048664] sd 4:0:0:0: [sdc] Write Protect is off
Jul 9 19:45:53 SERVER kernel: [ 5.048667] sd 4:0:0:0: [sdc] Mode Sense: 00 3a 00 00
Jul 9 19:45:53 SERVER kernel: [ 5.048688] sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 9 19:45:53 SERVER kernel: [ 5.048804] sdc:
Jul 9 19:45:53 SERVER kernel: [ 5.049235] sd 5:0:0:0: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
Jul 9 19:45:53 SERVER kernel: [ 5.049282] sd 5:0:0:0: [sdd] Write Protect is off
Jul 9 19:45:53 SERVER kernel: [ 5.049285] sd 5:0:0:0: [sdd] Mode Sense: 00 3a 00 00
Jul 9 19:45:53 SERVER kernel: [ 5.049306] sd 5:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 9 19:45:53 SERVER kernel: [ 5.050027] sdd: sda1 sda2 sda3 sda4
Jul 9 19:45:53 SERVER kernel: [ 5.058758] sdc1
Jul 9 19:45:53 SERVER kernel: [ 5.059147] sd 4:0:0:0: [sdc] Attached SCSI disk
Jul 9 19:45:53 SERVER kernel: [ 5.062515] sd 0:0:0:0: [sda] Attached SCSI disk
Jul 9 19:45:53 SERVER kernel: [ 5.064438] sdd1
Jul 9 19:45:53 SERVER kernel: [ 5.064933] sd 5:0:0:0: [sdd] Attached SCSI disk
Jul 9 19:45:53 SERVER kernel: [ 5.067691] sdb1
Jul 9 19:45:53 SERVER kernel: [ 5.068339] sd 1:0:0:0: [sdb] Attached SCSI disk
Jul 9 19:45:53 SERVER kernel: [ 5.490150] PM: Starting manual resume from disk
Jul 9 19:45:53 SERVER kernel: [ 5.490155] PM: Resume from partition 8:2
Jul 9 19:45:53 SERVER kernel: [ 5.490157] PM: Checking hibernation image.
Jul 9 19:45:53 SERVER kernel: [ 5.490325] PM: Error -22 checking image file
Jul 9 19:45:53 SERVER kernel: [ 5.490327] PM: Resume from disk failed.
Jul 9 19:45:53 SERVER kernel: [ 5.538447] EXT4-fs (sda3): mounted filesystem with ordered data mode
Jul 9 19:45:53 SERVER kernel: [ 6.998914] udev[512]: starting version 164
Jul 9 19:45:53 SERVER kernel: [ 7.190828] processor LNXCPU:00: registered as cooling_device1
Jul 9 19:45:53 SERVER kernel: [ 7.190903] processor LNXCPU:01: registered as cooling_device2
Jul 9 19:45:53 SERVER kernel: [ 7.440864] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
Jul 9 19:45:53 SERVER kernel: [ 7.440872] ACPI: Power Button [PWRB]
Jul 9 19:45:53 SERVER kernel: [ 7.440975] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
Jul 9 19:45:53 SERVER kernel: [ 7.440979] ACPI: Power Button [PWRF]
Jul 9 19:45:53 SERVER kernel: [ 7.441427] input: PC Speaker as /devices/platform/pcspkr/input/input4
Jul 9 19:45:53 SERVER kernel: [ 7.474696] ACPI: WMI: Mapper loaded
Jul 9 19:45:53 SERVER kernel: [ 7.502442] parport_pc 00:0a: reported by Plug and Play ACPI
Jul 9 19:45:53 SERVER kernel: [ 7.502497] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
Jul 9 19:45:53 SERVER kernel: [ 7.642927] EDAC MC: Ver: 2.1.0 May 6 2012
Jul 9 19:45:53 SERVER kernel: [ 7.691756] i2c i2c-0: nForce2 SMBus adapter at 0x1c00
Jul 9 19:45:53 SERVER kernel: [ 7.691808] i2c i2c-1: nForce2 SMBus adapter at 0x1c40
Jul 9 19:45:53 SERVER kernel: [ 7.705574] EDAC amd64_edac: Ver: 3.2.0 May 6 2012
Jul 9 19:45:53 SERVER kernel: [ 7.705751] EDAC amd64: This node reports that Memory ECC is currently disabled, set F3x44[22] (0000:00:18.3).
Jul 9 19:45:53 SERVER kernel: [ 7.705765] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Jul 9 19:45:53 SERVER kernel: [ 7.705767] Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
Jul 9 19:45:53 SERVER kernel: [ 7.705768] (Note that use of the override may cause unknown side effects.)
Jul 9 19:45:53 SERVER kernel: [ 7.705788] amd64_edac: probe of 0000:00:18.2 failed with error -22
Jul 9 19:45:53 SERVER kernel: [ 7.731209] Linux video capture interface: v2.00
Jul 9 19:45:53 SERVER kernel: [ 7.754034] uvcvideo: Found UVC 1.00 device Deluxe Optical Glass (06f8:300d)
Jul 9 19:45:53 SERVER kernel: [ 7.758327] input: Deluxe Optical Glass as /devices/pci0000:00/0000:00:0b.1/usb2/2-1/2-1:1.0/input/input5
Jul 9 19:45:53 SERVER kernel: [ 7.758382] usbcore: registered new interface driver uvcvideo
Jul 9 19:45:53 SERVER kernel: [ 7.758385] USB Video Class driver (v0.1.0)
Jul 9 19:45:53 SERVER kernel: [ 7.853103] acer-wmi: Acer Laptop ACPI-WMI Extras
Jul 9 19:45:53 SERVER kernel: [ 7.853112] acer-wmi: No or unsupported WMI interface, unable to load
Jul 9 19:45:53 SERVER kernel: [ 8.041745] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input6
Jul 9 19:45:53 SERVER kernel: [ 8.398759] ACPI: PCI Interrupt Link [APC6] enabled at IRQ 16
Jul 9 19:45:53 SERVER kernel: [ 8.398766] alloc irq_desc for 16 on node 0
Jul 9 19:45:53 SERVER kernel: [ 8.398769] alloc kstat_irqs on node 0
Jul 9 19:45:53 SERVER kernel: [ 8.398781] HDA Intel 0000:02:00.1: PCI INT B -> Link[APC6] -> GSI 16 (level, low) -> IRQ 16
Jul 9 19:45:53 SERVER kernel: [ 8.398831] HDA Intel 0000:02:00.1: setting latency timer to 64
Jul 9 19:45:53 SERVER kernel: [ 8.504237] 2:3:1: cannot get freq at ep 0x84
Jul 9 19:45:53 SERVER kernel: [ 8.521642] usbcore: registered new interface driver snd-usb-audio
Jul 9 19:45:53 SERVER kernel: [ 8.941262] usb-storage: device scan complete
Jul 9 19:45:53 SERVER kernel: [ 8.972108] scsi 6:0:0:0: Direct-Access Generic 2.0 Reader-CF 1.00 PQ: 0 ANSI: 0 CCS
Jul 9 19:45:53 SERVER kernel: [ 9.003103] scsi 6:0:0:1: Direct-Access Generic 2.0 Reader-SM/xD 1.00 PQ: 0 ANSI: 0 CCS
Jul 9 19:45:53 SERVER kernel: [ 9.034111] scsi 6:0:0:2: Direct-Access Generic 2.0 Reader-SD 1.00 PQ: 0 ANSI: 0 CCS
Jul 9 19:45:53 SERVER kernel: [ 9.065105] scsi 6:0:0:3: Direct-Access Generic 2.0 Reader-MS 1.00 PQ: 0 ANSI: 0 CCS
Jul 9 19:45:53 SERVER kernel: [ 9.070856] sd 6:0:0:0: [sde] Attached SCSI removable disk
Jul 9 19:45:53 SERVER kernel: [ 9.074727] sd 6:0:0:1: [sdf] Attached SCSI removable disk
Jul 9 19:45:53 SERVER kernel: [ 9.078140] sd 6:0:0:2: [sdg] Attached SCSI removable disk
Jul 9 19:45:53 SERVER kernel: [ 9.079102] sd 6:0:0:3: [sdh] Attached SCSI removable disk
Jul 9 19:45:53 SERVER kernel: [ 187.515675] Adding 2096120k swap on /dev/sda2. Priority:-1 extents:1 across:2096120k
Jul 9 19:45:53 SERVER kernel: [ 187.518768] EXT4-fs (sda3): warning: maximal mount count reached, running e2fsck is recommended
Jul 9 19:45:53 SERVER kernel: [ 187.647392] loop: module loaded
Jul 9 19:45:53 SERVER kernel: [ 187.671877] it87: Found IT8712F chip at 0x290, revision 7
Jul 9 19:45:53 SERVER kernel: [ 187.671887] it87: in3 is VCC (+5V)
Jul 9 19:45:53 SERVER kernel: [ 187.671889] it87: in7 is VCCH (+5V Stand-By)
Jul 9 19:45:53 SERVER kernel: [ 187.671926] ACPI: I/O resource it87 [0x295-0x296] conflicts with ACPI region IP__ [0x295-0x296]
Jul 9 19:45:53 SERVER kernel: [ 187.671958] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Jul 9 19:45:53 SERVER kernel: [ 188.246639] EXT4-fs (sda4): mounted filesystem with ordered data mode
Jul 9 19:45:53 SERVER kernel: [ 188.318469] EXT4-fs (sdc1): warning: maximal mount count reached, running e2fsck is recommended
Jul 9 19:45:53 SERVER kernel: [ 188.369642] EXT4-fs (sdc1): mounted filesystem with ordered data mode
Jul 9 19:45:53 SERVER kernel: [ 188.439167] EXT4-fs (sdb1): warning: maximal mount count reached, running e2fsck is recommended
Jul 9 19:45:53 SERVER kernel: [ 188.506316] EXT4-fs (sdb1): mounted filesystem with ordered data mode
Jul 9 19:45:53 SERVER kernel: [ 188.581774] EXT4-fs (sdd1): warning: maximal mount count reached, running e2fsck is recommended
Jul 9 19:45:53 SERVER kernel: [ 188.640384] EXT4-fs (sdd1): mounted filesystem with ordered data mode
Jul 9 19:45:53 SERVER kernel: [ 188.673038] EXT4-fs (sda1): warning: maximal mount count reached, running e2fsck is recommended
Jul 9 19:45:53 SERVER kernel: [ 188.688827] EXT4-fs (sda1): mounted filesystem with ordered data mode
Jul 9 19:45:53 SERVER kernel: [ 189.570526] fuse init (API version 7.13)
Jul 9 19:45:53 SERVER kernel: [ 190.603251] vboxdrv: Trying to deactivate the NMI watchdog permanently...
Jul 9 19:45:53 SERVER kernel: [ 190.603254] vboxdrv: Successfully done.
Jul 9 19:45:53 SERVER kernel: [ 190.603256] vboxdrv: Found 2 processor cores.
Jul 9 19:45:53 SERVER kernel: [ 190.603376] VBoxDrv: dbg - g_abExecMemory=ffffffffa04066c0
Jul 9 19:45:53 SERVER kernel: [ 190.603397] vboxdrv: fAsync=1 offMin=0x1a7ab offMax=0x1a7ab
Jul 9 19:45:53 SERVER kernel: [ 190.603538] vboxdrv: TSC mode is 'asynchronous', kernel timer mode is 'normal'.
Jul 9 19:45:53 SERVER kernel: [ 190.603541] vboxdrv: Successfully loaded version 3.2.10_OSE (interface 0x00140001).
Jul 9 19:46:00 SERVER kernel: [ 197.422673] ip_tables: (C) 2000-2006 Netfilter Core Team
Jul 9 19:46:03 SERVER kernel: [ 200.593018] eth0: no IPv6 routers present
Jul 9 19:46:11 SERVER kernel: [ 208.194233] 2:3:1: cannot get freq at ep 0x84
Jul 9 19:46:11 SERVER kernel: [ 208.226234] 2:3:1: cannot get freq at ep 0x84
Jul 9 19:46:11 SERVER kernel: [ 208.338682] hda-intel: IRQ timing workaround is activated for card #0. Suggest a bigger bdl_pos_adj.
Jul 9 19:46:28 SERVER kernel: [ 224.766050] powernow-k8: Found 1 AMD Athlon(tm) 64 X2 Dual Core Processor 4200+ processors (2 cpu cores) (version 2.20.00)
Jul 9 19:46:28 SERVER kernel: [ 224.766113] powernow-k8: 0 : fid 0xe (2200 MHz), vid 0x8
Jul 9 19:46:28 SERVER kernel: [ 224.766116] powernow-k8: 1 : fid 0xc (2000 MHz), vid 0xa
Jul 9 19:46:28 SERVER kernel: [ 224.766118] powernow-k8: 2 : fid 0xa (1800 MHz), vid 0xc
Jul 9 19:46:28 SERVER kernel: [ 224.766121] powernow-k8: 3 : fid 0x2 (1000 MHz), vid 0x12
Jul 9 19:46:33 SERVER kernel: [ 230.652038] Clocksource tsc unstable (delta = -138112025 ns)
Jul 9 19:46:45 SERVER kernel: [ 242.217044] INFO: task usb_id:607 blocked for more than 120 seconds.
Jul 9 19:46:45 SERVER kernel: [ 242.217049] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jul 9 19:46:45 SERVER kernel: [ 242.217052] usb_id D ffff88000180fb30 0 607 1 0x00000000
Jul 9 19:46:45 SERVER kernel: [ 242.217058] ffffffff814891f0 0000000000000082 ffff88007d417d48 ffff88007d417d44
Jul 9 19:46:45 SERVER kernel: [ 242.217063] 0000000000011ac0 00000000810fe02e 000000000000f9e0 ffff88007d417fd8
Jul 9 19:46:45 SERVER kernel: [ 242.217067] 0000000000015780 0000000000015780 ffff88007d25cdb0 ffff88007d25d0a8
Jul 9 19:46:45 SERVER kernel: [ 242.217071] Call Trace:
Jul 9 19:46:45 SERVER kernel: [ 242.217081] [<ffffffff812fbe2d>] ? schedule_timeout+0x2e/0xdd
Jul 9 19:46:45 SERVER kernel: [ 242.217088] [<ffffffff810ba470>] ? __alloc_pages_nodemask+0x11c/0x5fc
Jul 9 19:46:45 SERVER kernel: [ 242.217092] [<ffffffff812fc711>] ? __down_common+0x8d/0xde
Jul 9 19:46:45 SERVER kernel: [ 242.217098] [<ffffffff8106885f>] ? down+0x27/0x38
Jul 9 19:46:45 SERVER kernel: [ 242.217128] [<ffffffffa0014434>] ? show_manufacturer+0x1e/0x4c [usbcore]
Jul 9 19:46:45 SERVER kernel: [ 242.217133] [<ffffffff8121e92e>] ? dev_attr_show+0x1f/0x42
Jul 9 19:46:45 SERVER kernel: [ 242.217138] [<ffffffff8113f8fa>] ? sysfs_read_file+0xa7/0x125
Jul 9 19:46:45 SERVER kernel: [ 242.217143] [<ffffffff810efa50>] ? vfs_read+0xa6/0xff
Jul 9 19:46:45 SERVER kernel: [ 242.217146] [<ffffffff810efb65>] ? sys_read+0x45/0x6e
Jul 9 19:46:45 SERVER kernel: [ 242.217150] [<ffffffff81010b42>] ? system_call_fastpath+0x16/0x1b
Jul 9 19:47:22 SERVER kernel: [ 279.005054] fuse exit
Jul 9 19:47:36 SERVER kernel: Kernel logging (proc) stopped.
Jul 9 19:51:25 SERVER kernel: imklog 4.6.4, log source = /proc/kmsg started.
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Initializing cgroup subsys cpuset
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Linux version 2.6.32-5-amd64 (Debian 2.6.32-45) (dannf@debian.org) (gcc version 4.3.5 (Debian 4.3.5-4) ) #1 SMP Sun May 6 04:00:17 UTC 2012
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=UUID=2e09c46f-9525-4d47-924f-115e9abbce92 ro quiet
Jul 9 19:51:25 SERVER kernel: [ 0.000000] KERNEL supported cpus:
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Intel GenuineIntel
Jul 9 19:51:25 SERVER kernel: [ 0.000000] AMD AuthenticAMD
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Centaur CentaurHauls
Jul 9 19:51:25 SERVER kernel: [ 0.000000] BIOS-provided physical RAM map:
Jul 9 19:51:25 SERVER kernel: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] BIOS-e820: 0000000000100000 - 000000007fef0000 (usable)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] BIOS-e820: 000000007fef0000 - 000000007fef3000 (ACPI NVS)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] BIOS-e820: 000000007fef3000 - 000000007ff00000 (ACPI data)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] DMI 2.2 present.
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Phoenix BIOS detected: BIOS may corrupt low RAM, working around it.
Jul 9 19:51:25 SERVER kernel: [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] last_pfn = 0x7fef0 max_arch_pfn = 0x400000000
Jul 9 19:51:25 SERVER kernel: [ 0.000000] MTRR default type: uncachable
Jul 9 19:51:25 SERVER kernel: [ 0.000000] MTRR fixed ranges enabled:
Jul 9 19:51:25 SERVER kernel: [ 0.000000] 00000-9FFFF write-back
Jul 9 19:51:25 SERVER kernel: [ 0.000000] A0000-BFFFF uncachable
Jul 9 19:51:25 SERVER kernel: [ 0.000000] C0000-C7FFF write-protect
Jul 9 19:51:25 SERVER kernel: [ 0.000000] C8000-FFFFF uncachable
Jul 9 19:51:25 SERVER kernel: [ 0.000000] MTRR variable ranges enabled:
Jul 9 19:51:25 SERVER kernel: [ 0.000000] 0 base 0000000000 mask FF80000000 write-back
Jul 9 19:51:25 SERVER kernel: [ 0.000000] 1 base 007FF00000 mask FFFFF00000 uncachable
Jul 9 19:51:25 SERVER kernel: [ 0.000000] 2 disabled
Jul 9 19:51:25 SERVER kernel: [ 0.000000] 3 disabled
Jul 9 19:51:25 SERVER kernel: [ 0.000000] 4 disabled
Jul 9 19:51:25 SERVER kernel: [ 0.000000] 5 disabled
Jul 9 19:51:25 SERVER kernel: [ 0.000000] 6 disabled
Jul 9 19:51:25 SERVER kernel: [ 0.000000] 7 disabled
Jul 9 19:51:25 SERVER kernel: [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
Jul 9 19:51:25 SERVER kernel: [ 0.000000] initial memory mapped : 0 - 20000000
Jul 9 19:51:25 SERVER kernel: [ 0.000000] init_memory_mapping: 0000000000000000-000000007fef0000
Jul 9 19:51:25 SERVER kernel: [ 0.000000] 0000000000 - 007fe00000 page 2M
Jul 9 19:51:25 SERVER kernel: [ 0.000000] 007fe00000 - 007fef0000 page 4k
Jul 9 19:51:25 SERVER kernel: [ 0.000000] kernel direct mapping tables up to 7fef0000 @ 10000-14000
Jul 9 19:51:25 SERVER kernel: [ 0.000000] RAMDISK: 3770e000 - 37feff1c
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: RSDP 00000000000f7b70 00014 (v00 Nvidia)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: RSDT 000000007fef3040 00034 (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: FACP 000000007fef30c0 00074 (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: DSDT 000000007fef3180 063F0 (v01 NVIDIA AWRDACPI 00001000 MSFT 0100000E)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: FACS 000000007fef0000 00040
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: SSDT 000000007fef9680 001CA (v01 PTLTD POWERNOW 00000001 LTP 00000001)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: MCFG 000000007fef98c0 0003C (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: APIC 000000007fef95c0 00072 (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: Local APIC address 0xfee00000
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Scanning NUMA topology in Northbridge 24
Jul 9 19:51:25 SERVER kernel: [ 0.000000] No NUMA configuration found
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Faking a node at 0000000000000000-000000007fef0000
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Bootmem setup node 0 0000000000000000-000000007fef0000
Jul 9 19:51:25 SERVER kernel: [ 0.000000] NODE_DATA [0000000000012000 - 0000000000019fff]
Jul 9 19:51:25 SERVER kernel: [ 0.000000] bootmap [000000000001a000 - 0000000000029fdf] pages 10
Jul 9 19:51:25 SERVER kernel: [ 0.000000] (7 early reservations) ==> bootmem [0000000000 - 007fef0000]
Jul 9 19:51:25 SERVER kernel: [ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
Jul 9 19:51:25 SERVER kernel: [ 0.000000] #1 [0000006000 - 0000008000] TRAMPOLINE ==> [0000006000 - 0000008000]
Jul 9 19:51:25 SERVER kernel: [ 0.000000] #2 [0001000000 - 00016d95c4] TEXT DATA BSS ==> [0001000000 - 00016d95c4]
Jul 9 19:51:25 SERVER kernel: [ 0.000000] #3 [003770e000 - 0037feff1c] RAMDISK ==> [003770e000 - 0037feff1c]
Jul 9 19:51:25 SERVER kernel: [ 0.000000] #4 [000009f000 - 0000100000] BIOS reserved ==> [000009f000 - 0000100000]
Jul 9 19:51:25 SERVER kernel: [ 0.000000] #5 [00016da000 - 00016da0ad] BRK ==> [00016da000 - 00016da0ad]
Jul 9 19:51:25 SERVER kernel: [ 0.000000] #6 [0000010000 - 0000012000] PGTABLE ==> [0000010000 - 0000012000]
Jul 9 19:51:25 SERVER kernel: [ 0.000000] found SMP MP-table at [ffff8800000f3a50] f3a50
Jul 9 19:51:25 SERVER kernel: [ 0.000000] [ffffea0000000000-ffffea0001bfffff] PMD -> [ffff880001c00000-ffff8800037fffff] on node 0
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Zone PFN ranges:
Jul 9 19:51:25 SERVER kernel: [ 0.000000] DMA 0x00000010 -> 0x00001000
Jul 9 19:51:25 SERVER kernel: [ 0.000000] DMA32 0x00001000 -> 0x00100000
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Normal 0x00100000 -> 0x00100000
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Movable zone start PFN for each node
Jul 9 19:51:25 SERVER kernel: [ 0.000000] early_node_map[2] active PFN ranges
Jul 9 19:51:25 SERVER kernel: [ 0.000000] 0: 0x00000010 -> 0x0000009f
Jul 9 19:51:25 SERVER kernel: [ 0.000000] 0: 0x00000100 -> 0x0007fef0
Jul 9 19:51:25 SERVER kernel: [ 0.000000] On node 0 totalpages: 523903
Jul 9 19:51:25 SERVER kernel: [ 0.000000] DMA zone: 56 pages used for memmap
Jul 9 19:51:25 SERVER kernel: [ 0.000000] DMA zone: 102 pages reserved
Jul 9 19:51:25 SERVER kernel: [ 0.000000] DMA zone: 3825 pages, LIFO batch:0
Jul 9 19:51:25 SERVER kernel: [ 0.000000] DMA32 zone: 7109 pages used for memmap
Jul 9 19:51:25 SERVER kernel: [ 0.000000] DMA32 zone: 512811 pages, LIFO batch:31
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Nvidia board detected. Ignoring ACPI timer override.
Jul 9 19:51:25 SERVER kernel: [ 0.000000] If you got timer trouble try acpi_use_timer_override
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: PM-Timer IO Port: 0x1008
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Jul 9 19:51:25 SERVER kernel: [ 0.000000] IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: IRQ9 used by override.
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: IRQ14 used by override.
Jul 9 19:51:25 SERVER kernel: [ 0.000000] ACPI: IRQ15 used by override.
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Using ACPI (MADT) for SMP configuration information
Jul 9 19:51:25 SERVER kernel: [ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
Jul 9 19:51:25 SERVER kernel: [ 0.000000] nr_irqs_gsi: 24
Jul 9 19:51:25 SERVER kernel: [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
Jul 9 19:51:25 SERVER kernel: [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
Jul 9 19:51:25 SERVER kernel: [ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Allocating PCI resources starting at 7ff00000 (gap: 7ff00000:60100000)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Booting paravirtualized kernel on bare hardware
Jul 9 19:51:25 SERVER kernel: [ 0.000000] NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:2 nr_node_ids:1
Jul 9 19:51:25 SERVER kernel: [ 0.000000] PERCPU: Embedded 30 pages/cpu @ffff880001800000 s90328 r8192 d24360 u1048576
Jul 9 19:51:25 SERVER kernel: [ 0.000000] pcpu-alloc: s90328 r8192 d24360 u1048576 alloc=1*2097152
Jul 9 19:51:25 SERVER kernel: [ 0.000000] pcpu-alloc: [0] 0 1
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 516636
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Policy zone: DMA32
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=UUID=2e09c46f-9525-4d47-924f-115e9abbce92 ro quiet
Jul 9 19:51:25 SERVER kernel: [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Initializing CPU#0
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Checking aperture...
Jul 9 19:51:25 SERVER kernel: [ 0.000000] No AGP bridge found
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Node 0: aperture @ 1d00000000 size 32 MB
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Aperture beyond 4GB. Ignoring.
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Memory: 2050268k/2096064k available (3083k kernel code, 452k absent, 45344k reserved, 2048k data, 592k init)
Jul 9 19:51:25 SERVER kernel: [ 0.000000] SLUB: Genslabs=14, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Hierarchical RCU implementation.
Jul 9 19:51:25 SERVER kernel: [ 0.000000] NR_IRQS:4352 nr_irqs:424
Jul 9 19:51:25 SERVER kernel: [ 0.000000] spurious 8259A interrupt: IRQ7.
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Console: colour VGA+ 80x25
Jul 9 19:51:25 SERVER kernel: [ 0.000000] console [tty0] enabled
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Fast TSC calibration using PIT
Jul 9 19:51:25 SERVER kernel: [ 0.000000] Detected 1004.653 MHz processor.
Jul 9 19:51:25 SERVER kernel: [ 0.004008] Calibrating delay loop (skipped), value calculated using timer frequency.. 2009.30 BogoMIPS (lpj=4018612)
Jul 9 19:51:25 SERVER kernel: [ 0.004048] Security Framework initialized
Jul 9 19:51:25 SERVER kernel: [ 0.004057] SELinux: Disabled at boot.
Jul 9 19:51:25 SERVER kernel: [ 0.004472] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
Jul 9 19:51:25 SERVER kernel: [ 0.009745] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
Jul 9 19:51:25 SERVER kernel: [ 0.010573] Mount-cache hash table entries: 256
Jul 9 19:51:25 SERVER kernel: [ 0.010849] Initializing cgroup subsys ns
Jul 9 19:51:25 SERVER kernel: [ 0.010855] Initializing cgroup subsys cpuacct
Jul 9 19:51:25 SERVER kernel: [ 0.010864] Initializing cgroup subsys devices
Jul 9 19:51:25 SERVER kernel: [ 0.010869] Initializing cgroup subsys freezer
Jul 9 19:51:25 SERVER kernel: [ 0.010874] Initializing cgroup subsys net_cls
Jul 9 19:51:25 SERVER kernel: [ 0.010919] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
Jul 9 19:51:25 SERVER kernel: [ 0.010924] CPU: L2 Cache: 512K (64 bytes/line)
Jul 9 19:51:25 SERVER kernel: [ 0.010929] CPU 0/0x0 -> Node 0
Jul 9 19:51:25 SERVER kernel: [ 0.010933] tseg: 007ff00000
Jul 9 19:51:25 SERVER kernel: [ 0.010937] CPU: Physical Processor ID: 0
Jul 9 19:51:25 SERVER kernel: [ 0.010941] CPU: Processor Core ID: 0
Jul 9 19:51:25 SERVER kernel: [ 0.010947] mce: CPU supports 5 MCE banks
Jul 9 19:51:25 SERVER kernel: [ 0.010967] Performance Events: AMD PMU driver.
Jul 9 19:51:25 SERVER kernel: [ 0.010977] ... version: 0
Jul 9 19:51:25 SERVER kernel: [ 0.010980] ... bit width: 48
Jul 9 19:51:25 SERVER kernel: [ 0.010984] ... generic registers: 4
Jul 9 19:51:25 SERVER kernel: [ 0.010988] ... value mask: 0000ffffffffffff
Jul 9 19:51:25 SERVER kernel: [ 0.010992] ... max period: 00007fffffffffff
Jul 9 19:51:25 SERVER kernel: [ 0.010996] ... fixed-purpose events: 0
Jul 9 19:51:25 SERVER kernel: [ 0.011000] ... event mask: 000000000000000f
Jul 9 19:51:25 SERVER kernel: [ 0.012429] ACPI: Core revision 20090903
Jul 9 19:51:25 SERVER kernel: [ 0.027327] Setting APIC routing to flat
Jul 9 19:51:25 SERVER kernel: [ 0.027888] ..TIMER: vector=0x30 apic1=0 pin1=0 apic2=-1 pin2=-1
Jul 9 19:51:25 SERVER kernel: [ 0.067597] CPU0: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+ stepping 01
Jul 9 19:51:25 SERVER kernel: [ 0.068001] Booting processor 1 APIC 0x1 ip 0x6000
Jul 9 19:51:25 SERVER kernel: [ 0.008000] Initializing CPU#1
Jul 9 19:51:25 SERVER kernel: [ 0.008000] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
Jul 9 19:51:25 SERVER kernel: [ 0.008000] CPU: L2 Cache: 512K (64 bytes/line)
Jul 9 19:51:25 SERVER kernel: [ 0.008000] CPU 1/0x1 -> Node 0
Jul 9 19:51:25 SERVER kernel: [ 0.008000] CPU: Physical Processor ID: 0
Jul 9 19:51:25 SERVER kernel: [ 0.008000] CPU: Processor Core ID: 1
Jul 9 19:51:25 SERVER kernel: [ 0.152094] CPU1: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+ stepping 01
Jul 9 19:51:25 SERVER kernel: [ 0.152137] Brought up 2 CPUs
Jul 9 19:51:25 SERVER kernel: [ 0.152142] Total of 2 processors activated (4018.59 BogoMIPS).
Jul 9 19:51:25 SERVER kernel: [ 0.152730] CPU0 attaching sched-domain:
Jul 9 19:51:25 SERVER kernel: [ 0.152739] domain 0: span 0-1 level MC
Jul 9 19:51:25 SERVER kernel: [ 0.152745] groups: group ffff88000180fbf0 cpus 0 group ffff88000190fbf0 cpus 1
Jul 9 19:51:25 SERVER kernel: [ 0.152760] CPU1 attaching sched-domain:
Jul 9 19:51:25 SERVER kernel: [ 0.152765] domain 0: span 0-1 level MC
Jul 9 19:51:25 SERVER kernel: [ 0.152770] groups: group ffff88000190fbf0 cpus 1 group ffff88000180fbf0 cpus 0
Jul 9 19:51:25 SERVER kernel: [ 0.152897] devtmpfs: initialized
Jul 9 19:51:25 SERVER kernel: [ 0.160459] regulator: core version 0.5
Jul 9 19:51:25 SERVER kernel: [ 0.160459] NET: Registered protocol family 16
Jul 9 19:51:25 SERVER kernel: [ 0.160459] node 0 link 0: io port [9000, ffff]
Jul 9 19:51:25 SERVER kernel: [ 0.160459] TOM: 0000000080000000 aka 2048M
Jul 9 19:51:25 SERVER kernel: [ 0.160459] node 0 link 0: mmio [a0000, bffff]
Jul 9 19:51:25 SERVER kernel: [ 0.160459] node 0 link 0: mmio [80000000, dfffffff]
Jul 9 19:51:25 SERVER kernel: [ 0.160459] node 0 link 0: mmio [f0000000, fe02ffff]
Jul 9 19:51:25 SERVER kernel: [ 0.160459] node 0 link 0: mmio [e0000000, e03fffff]
Jul 9 19:51:25 SERVER kernel: [ 0.160459] bus: [00,03] on node 0 link 0
Jul 9 19:51:25 SERVER kernel: [ 0.160459] bus: 00 index 0 io port: [0, ffff]
Jul 9 19:51:25 SERVER kernel: [ 0.160459] bus: 00 index 1 mmio: [a0000, bffff]
Jul 9 19:51:25 SERVER kernel: [ 0.160459] bus: 00 index 2 mmio: [80000000, efffffff]
Jul 9 19:51:25 SERVER kernel: [ 0.160459] bus: 00 index 3 mmio: [f0000000, fcffffffff]
Jul 9 19:51:25 SERVER kernel: [ 0.160459] ACPI: bus type pci registered
Jul 9 19:51:25 SERVER kernel: [ 0.160579] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
Jul 9 19:51:25 SERVER kernel: [ 0.160586] PCI: MCFG area at e0000000 reserved in E820
Jul 9 19:51:25 SERVER kernel: [ 0.175858] PCI: Using MMCONFIG at e0000000 - efffffff
Jul 9 19:51:25 SERVER kernel: [ 0.175863] PCI: Using configuration type 1 for base access
Jul 9 19:51:25 SERVER kernel: [ 0.176702] bio: create slab <bio-0> at 0
Jul 9 19:51:25 SERVER kernel: [ 0.177372] ACPI: EC: Look up EC in DSDT
Jul 9 19:51:25 SERVER kernel: [ 0.194464] ACPI: Interpreter enabled
Jul 9 19:51:25 SERVER kernel: [ 0.194470] ACPI: (supports S0 S3 S4 S5)
Jul 9 19:51:25 SERVER kernel: [ 0.194522] ACPI: Using IOAPIC for interrupt routing
Jul 9 19:51:25 SERVER kernel: [ 0.215921] ACPI: No dock devices found.
Jul 9 19:51:25 SERVER kernel: [ 0.217860] ACPI: PCI Root Bridge [PCI0] (0000:00)
Jul 9 19:51:25 SERVER kernel: [ 0.218342] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
Jul 9 19:51:25 SERVER kernel: [ 0.218349] pci 0000:00:02.0: PME# disabled
Jul 9 19:51:25 SERVER kernel: [ 0.218423] pci 0000:00:04.0: PME# supported from D0 D1 D2 D3hot D3cold
Jul 9 19:51:25 SERVER kernel: [ 0.218429] pci 0000:00:04.0: PME# disabled
Jul 9 19:51:25 SERVER kernel: [ 0.218687] HPET not enabled in BIOS. You might try hpet=force boot option
Jul 9 19:51:25 SERVER kernel: [ 0.218751] pci 0000:00:0a.1: reg 20 io port: [0x1c00-0x1c3f]
Jul 9 19:51:25 SERVER kernel: [ 0.218761] pci 0000:00:0a.1: reg 24 io port: [0x1c40-0x1c7f]
Jul 9 19:51:25 SERVER kernel: [ 0.218804] pci 0000:00:0a.1: PME# supported from D3hot D3cold
Jul 9 19:51:25 SERVER kernel: [ 0.218813] pci 0000:00:0a.1: PME# disabled
Jul 9 19:51:25 SERVER kernel: [ 0.218908] pci 0000:00:0b.0: reg 10 32bit mmio: [0xfe02f000-0xfe02ffff]
Jul 9 19:51:25 SERVER kernel: [ 0.218955] pci 0000:00:0b.0: supports D1 D2
Jul 9 19:51:25 SERVER kernel: [ 0.218959] pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold
Jul 9 19:51:25 SERVER kernel: [ 0.218966] pci 0000:00:0b.0: PME# disabled
Jul 9 19:51:25 SERVER kernel: [ 0.219006] pci 0000:00:0b.1: reg 10 32bit mmio: [0xfe02e000-0xfe02e0ff]
Jul 9 19:51:25 SERVER kernel: [ 0.219058] pci 0000:00:0b.1: supports D1 D2
Jul 9 19:51:25 SERVER kernel: [ 0.219063] pci 0000:00:0b.1: PME# supported from D0 D1 D2 D3hot D3cold
Jul 9 19:51:25 SERVER kernel: [ 0.219070] pci 0000:00:0b.1: PME# disabled
Jul 9 19:51:25 SERVER kernel: [ 0.219128] pci 0000:00:0d.0: reg 20 io port: [0xf400-0xf40f]
Jul 9 19:51:25 SERVER kernel: [ 0.219197] pci 0000:00:0e.0: reg 10 io port: [0x9f0-0x9f7]
Jul 9 19:51:25 SERVER kernel: [ 0.219205] pci 0000:00:0e.0: reg 14 io port: [0xbf0-0xbf3]
Jul 9 19:51:25 SERVER kernel: [ 0.219214] pci 0000:00:0e.0: reg 18 io port: [0x970-0x977]
Jul 9 19:51:25 SERVER kernel: [ 0.219222] pci 0000:00:0e.0: reg 1c io port: [0xb70-0xb73]
Jul 9 19:51:25 SERVER kernel: [ 0.219231] pci 0000:00:0e.0: reg 20 io port: [0xe000-0xe00f]
Jul 9 19:51:25 SERVER kernel: [ 0.219239] pci 0000:00:0e.0: reg 24 32bit mmio: [0xfe02d000-0xfe02dfff]
Jul 9 19:51:25 SERVER kernel: [ 0.219320] pci 0000:00:0f.0: reg 10 io port: [0x9e0-0x9e7]
Jul 9 19:51:25 SERVER kernel: [ 0.219328] pci 0000:00:0f.0: reg 14 io port: [0xbe0-0xbe3]
Jul 9 19:51:25 SERVER kernel: [ 0.219337] pci 0000:00:0f.0: reg 18 io port: [0x960-0x967]
Jul 9 19:51:25 SERVER kernel: [ 0.219345] pci 0000:00:0f.0: reg 1c io port: [0xb60-0xb63]
Jul 9 19:51:25 SERVER kernel: [ 0.219354] pci 0000:00:0f.0: reg 20 io port: [0xcc00-0xcc0f]
Jul 9 19:51:25 SERVER kernel: [ 0.219362] pci 0000:00:0f.0: reg 24 32bit mmio: [0xfe02c000-0xfe02cfff]
Jul 9 19:51:25 SERVER kernel: [ 0.219514] pci 0000:00:14.0: reg 10 32bit mmio: [0xfe02b000-0xfe02bfff]
Jul 9 19:51:25 SERVER kernel: [ 0.219523] pci 0000:00:14.0: reg 14 io port: [0xc800-0xc807]
Jul 9 19:51:25 SERVER kernel: [ 0.219562] pci 0000:00:14.0: supports D1 D2
Jul 9 19:51:25 SERVER kernel: [ 0.219567] pci 0000:00:14.0: PME# supported from D0 D1 D2 D3hot D3cold
Jul 9 19:51:25 SERVER kernel: [ 0.219573] pci 0000:00:14.0: PME# disabled
Jul 9 19:51:25 SERVER kernel: [ 0.219772] pci 0000:00:02.0: bridge io port: [0xb000-0xbfff]
Jul 9 19:51:25 SERVER kernel: [ 0.219779] pci 0000:00:02.0: bridge 32bit mmio: [0xfde00000-0xfdefffff]
Jul 9 19:51:25 SERVER kernel: [ 0.219787] pci 0000:00:02.0: bridge 64bit mmio pref: [0xfdd00000-0xfddfffff]
Jul 9 19:51:25 SERVER kernel: [ 0.219827] pci 0000:02:00.0: reg 10 64bit mmio pref: [0xd0000000-0xdfffffff]
Jul 9 19:51:25 SERVER kernel: [ 0.219839] pci 0000:02:00.0: reg 18 64bit mmio: [0xfdac0000-0xfdadffff]
Jul 9 19:51:25 SERVER kernel: [ 0.219848] pci 0000:02:00.0: reg 20 io port: [0x9c00-0x9cff]
Jul 9 19:51:25 SERVER kernel: [ 0.219860] pci 0000:02:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
Jul 9 19:51:25 SERVER kernel: [ 0.219894] pci 0000:02:00.0: supports D1 D2
Jul 9 19:51:25 SERVER kernel: [ 0.219936] pci 0000:02:00.1: reg 10 64bit mmio: [0xfdafc000-0xfdafffff]
Jul 9 19:51:25 SERVER kernel: [ 0.219986] pci 0000:02:00.1: supports D1 D2
Jul 9 19:51:25 SERVER kernel: [ 0.228083] pci 0000:00:04.0: bridge io port: [0x9000-0x9fff]
Jul 9 19:51:25 SERVER kernel: [ 0.228089] pci 0000:00:04.0: bridge 32bit mmio: [0xfda00000-0xfdafffff]
Jul 9 19:51:25 SERVER kernel: [ 0.228097] pci 0000:00:04.0: bridge 64bit mmio pref: [0xd0000000-0xdfffffff]
Jul 9 19:51:25 SERVER kernel: [ 0.228149] pci 0000:03:06.0: reg 10 32bit mmio: [0xfdcff000-0xfdcff7ff]
Jul 9 19:51:25 SERVER kernel: [ 0.228160] pci 0000:03:06.0: reg 14 32bit mmio: [0xfdcf8000-0xfdcfbfff]
Jul 9 19:51:25 SERVER kernel: [ 0.228214] pci 0000:03:06.0: supports D1 D2
Jul 9 19:51:25 SERVER kernel: [ 0.228218] pci 0000:03:06.0: PME# supported from D0 D1 D2 D3hot
Jul 9 19:51:25 SERVER kernel: [ 0.228225] pci 0000:03:06.0: PME# disabled
Jul 9 19:51:25 SERVER kernel: [ 0.228269] pci 0000:00:10.0: transparent bridge
Jul 9 19:51:25 SERVER kernel: [ 0.228275] pci 0000:00:10.0: bridge io port: [0xa000-0xafff]
Jul 9 19:51:25 SERVER kernel: [ 0.228282] pci 0000:00:10.0: bridge 32bit mmio: [0xfdc00000-0xfdcfffff]
Jul 9 19:51:25 SERVER kernel: [ 0.228289] pci 0000:00:10.0: bridge 32bit mmio pref: [0xfdb00000-0xfdbfffff]
Jul 9 19:51:25 SERVER kernel: [ 0.228312] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
Jul 9 19:51:25 SERVER kernel: [ 0.228797] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
Jul 9 19:51:25 SERVER kernel: [ 0.442311] ACPI: PCI Interrupt Link [LNK1] (IRQs 5 7 9 10 11 14 15) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.442641] ACPI: PCI Interrupt Link [LNK2] (IRQs 5 7 9 10 11 14 15) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.442969] ACPI: PCI Interrupt Link [LNK3] (IRQs 5 7 9 10 11 14 15) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.443299] ACPI: PCI Interrupt Link [LNK4] (IRQs *5 7 9 10 11 14 15)
Jul 9 19:51:25 SERVER kernel: [ 0.443628] ACPI: PCI Interrupt Link [LNK5] (IRQs *5 7 9 10 11 14 15)
Jul 9 19:51:25 SERVER kernel: [ 0.443956] ACPI: PCI Interrupt Link [LNK6] (IRQs 5 7 9 10 *11 14 15)
Jul 9 19:51:25 SERVER kernel: [ 0.444291] ACPI: PCI Interrupt Link [LNK7] (IRQs 5 7 9 10 11 14 15) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.444619] ACPI: PCI Interrupt Link [LNK8] (IRQs 5 7 9 10 11 14 15) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.444949] ACPI: PCI Interrupt Link [LUBA] (IRQs 5 7 9 *10 11 14 15)
Jul 9 19:51:25 SERVER kernel: [ 0.445275] ACPI: PCI Interrupt Link [LUBB] (IRQs 5 7 9 10 11 14 15) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.445606] ACPI: PCI Interrupt Link [LMAC] (IRQs 5 7 9 *10 11 14 15)
Jul 9 19:51:25 SERVER kernel: [ 0.445933] ACPI: PCI Interrupt Link [LACI] (IRQs 5 7 9 10 11 14 15) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.446261] ACPI: PCI Interrupt Link [LAZA] (IRQs 5 7 9 10 11 14 15) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.446599] ACPI: PCI Interrupt Link [LPMU] (IRQs *5 7 9 10 11 14 15)
Jul 9 19:51:25 SERVER kernel: [ 0.446926] ACPI: PCI Interrupt Link [LMCI] (IRQs 5 7 9 10 11 14 15) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.447256] ACPI: PCI Interrupt Link [LSMB] (IRQs *5 7 9 10 11 14 15)
Jul 9 19:51:25 SERVER kernel: [ 0.447603] ACPI: PCI Interrupt Link [LUB2] (IRQs 5 7 9 10 *11 14 15)
Jul 9 19:51:25 SERVER kernel: [ 0.447931] ACPI: PCI Interrupt Link [LIDE] (IRQs 5 7 9 10 11 14 15) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.448272] ACPI: PCI Interrupt Link [LSID] (IRQs 5 7 9 *10 11 14 15)
Jul 9 19:51:25 SERVER kernel: [ 0.448611] ACPI: PCI Interrupt Link [LFID] (IRQs 5 7 9 10 *11 14 15)
Jul 9 19:51:25 SERVER kernel: [ 0.449037] ACPI: PCI Interrupt Link [APC1] (IRQs 16) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.449442] ACPI: PCI Interrupt Link [APC2] (IRQs 17) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.449845] ACPI: PCI Interrupt Link [APC3] (IRQs 18) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.450248] ACPI: PCI Interrupt Link [APC4] (IRQs 19) *0
Jul 9 19:51:25 SERVER kernel: [ 0.450650] ACPI: PCI Interrupt Link [APC5] (IRQs 16) *0
Jul 9 19:51:25 SERVER kernel: [ 0.451052] ACPI: PCI Interrupt Link [APC6] (IRQs 16) *0
Jul 9 19:51:25 SERVER kernel: [ 0.451454] ACPI: PCI Interrupt Link [APC7] (IRQs 16) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.451857] ACPI: PCI Interrupt Link [APC8] (IRQs 16) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.452268] ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22 23) *0
Jul 9 19:51:25 SERVER kernel: [ 0.452672] ACPI: PCI Interrupt Link [APCG] (IRQs 20 21 22 23) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.453076] ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22 23) *0
Jul 9 19:51:25 SERVER kernel: [ 0.453480] ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22 23) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.453884] ACPI: PCI Interrupt Link [APMU] (IRQs 20 21 22 23) *0
Jul 9 19:51:25 SERVER kernel: [ 0.454288] ACPI: PCI Interrupt Link [AAZA] (IRQs 20 21 22 23) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.454693] ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22 23) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.455099] ACPI: PCI Interrupt Link [APCS] (IRQs 20 21 22 23) *0
Jul 9 19:51:25 SERVER kernel: [ 0.455503] ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22 23) *0
Jul 9 19:51:25 SERVER kernel: [ 0.455906] ACPI: PCI Interrupt Link [APCM] (IRQs 20 21 22 23) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.456326] ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22 23) *0, disabled.
Jul 9 19:51:25 SERVER kernel: [ 0.456739] ACPI: PCI Interrupt Link [APSI] (IRQs 20 21 22 23) *0
Jul 9 19:51:25 SERVER kernel: [ 0.457143] ACPI: PCI Interrupt Link [APSJ] (IRQs 20 21 22 23) *0
Jul 9 19:51:25 SERVER kernel: [ 0.457405] vgaarb: device added: PCI:0000:02:00.0,decodes=io+mem,owns=io+mem,locks=none
Jul 9 19:51:25 SERVER kernel: [ 0.457413] vgaarb: loaded
Jul 9 19:51:25 SERVER kernel: [ 0.457458] PCI: Using ACPI for IRQ routing
Jul 9 19:51:25 SERVER kernel: [ 0.460108] pnp: PnP ACPI init
Jul 9 19:51:25 SERVER kernel: [ 0.460138] ACPI: bus type pnp registered
Jul 9 19:51:25 SERVER kernel: [ 0.473217] pnp: PnP ACPI: found 15 devices
Jul 9 19:51:25 SERVER kernel: [ 0.473222] ACPI: ACPI bus type pnp unregistered
Jul 9 19:51:25 SERVER kernel: [ 0.473244] system 00:01: ioport range 0x1000-0x107f has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473252] system 00:01: ioport range 0x1080-0x10ff has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473258] system 00:01: ioport range 0x1400-0x147f has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473265] system 00:01: ioport range 0x1480-0x14ff has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473271] system 00:01: ioport range 0x1800-0x187f has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473278] system 00:01: ioport range 0x1880-0x18ff has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473285] system 00:01: ioport range 0x2000-0x207f has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473292] system 00:01: ioport range 0x2080-0x20ff has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473300] system 00:01: iomem range 0xfefe0000-0xfefe01ff has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473313] system 00:02: ioport range 0x4d0-0x4d1 has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473320] system 00:02: ioport range 0x800-0x805 has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473327] system 00:02: ioport range 0x290-0x29f has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473333] system 00:02: ioport range 0x290-0x297 has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473349] system 00:0d: iomem range 0xe0000000-0xefffffff has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473361] system 00:0e: iomem range 0xd0000-0xd3fff has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473367] system 00:0e: iomem range 0xd5800-0xd7fff has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473374] system 00:0e: iomem range 0xf0000-0xfbfff could not be reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473381] system 00:0e: iomem range 0xfc000-0xfffff could not be reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473388] system 00:0e: iomem range 0x7fef0000-0x7fefffff could not be reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473395] system 00:0e: iomem range 0xffff0000-0xffffffff has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473402] system 00:0e: iomem range 0x0-0x9ffff could not be reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473409] system 00:0e: iomem range 0x100000-0x7feeffff could not be reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473416] system 00:0e: iomem range 0xfec00000-0xfec00fff could not be reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473423] system 00:0e: iomem range 0xfee00000-0xfeefffff has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473431] system 00:0e: iomem range 0xfefff000-0xfeffffff has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473438] system 00:0e: iomem range 0xfff80000-0xfff80fff has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473445] system 00:0e: iomem range 0xfff90000-0xfffbffff has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.473452] system 00:0e: iomem range 0xfffed000-0xfffeffff has been reserved
Jul 9 19:51:25 SERVER kernel: [ 0.478483] Switching to clocksource acpi_pm
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:02.0: PCI bridge, secondary bus 0000:01
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:02.0: IO window: 0xb000-0xbfff
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:02.0: MEM window: 0xfde00000-0xfdefffff
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:02.0: PREFETCH window: 0x000000fdd00000-0x000000fddfffff
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:04.0: PCI bridge, secondary bus 0000:02
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:04.0: IO window: 0x9000-0x9fff
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:04.0: MEM window: 0xfda00000-0xfdafffff
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:04.0: PREFETCH window: 0x000000d0000000-0x000000dfffffff
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:10.0: PCI bridge, secondary bus 0000:03
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:10.0: IO window: 0xa000-0xafff
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:10.0: MEM window: 0xfdc00000-0xfdcfffff
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:10.0: PREFETCH window: 0xfdb00000-0xfdbfffff
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:02.0: setting latency timer to 64
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:04.0: setting latency timer to 64
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci 0000:00:10.0: setting latency timer to 64
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffffffffffff]
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci_bus 0000:01: resource 0 io: [0xb000-0xbfff]
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci_bus 0000:01: resource 1 mem: [0xfde00000-0xfdefffff]
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci_bus 0000:01: resource 2 pref mem [0xfdd00000-0xfddfffff]
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci_bus 0000:02: resource 0 io: [0x9000-0x9fff]
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci_bus 0000:02: resource 1 mem: [0xfda00000-0xfdafffff]
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci_bus 0000:02: resource 2 pref mem [0xd0000000-0xdfffffff]
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci_bus 0000:03: resource 0 io: [0xa000-0xafff]
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci_bus 0000:03: resource 1 mem: [0xfdc00000-0xfdcfffff]
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci_bus 0000:03: resource 2 pref mem [0xfdb00000-0xfdbfffff]
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci_bus 0000:03: resource 3 io: [0x00-0xffff]
Jul 9 19:51:25 SERVER kernel: [ 0.478497] pci_bus 0000:03: resource 4 mem: [0x000000-0xffffffffffffffff]
Jul 9 19:51:25 SERVER kernel: [ 0.478497] NET: Registered protocol family 2
Jul 9 19:51:25 SERVER kernel: [ 0.478497] IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
Jul 9 19:51:25 SERVER kernel: [ 0.478623] TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
Jul 9 19:51:25 SERVER kernel: [ 0.482063] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Jul 9 19:51:25 SERVER kernel: [ 0.482903] TCP: Hash tables configured (established 262144 bind 65536)
Jul 9 19:51:25 SERVER kernel: [ 0.482909] TCP reno registered
Jul 9 19:51:25 SERVER kernel: [ 0.483100] NET: Registered protocol family 1
Jul 9 19:51:25 SERVER kernel: [ 0.483193] pci 0000:00:00.0: Found enabled HT MSI Mapping
Jul 9 19:51:25 SERVER kernel: [ 0.483233] pci 0000:00:00.0: Found enabled HT MSI Mapping
Jul 9 19:51:25 SERVER kernel: [ 0.484084] ACPI: PCI Interrupt Link [APCF] enabled at IRQ 23
Jul 9 19:51:25 SERVER kernel: [ 0.484093] alloc irq_desc for 23 on node 0
Jul 9 19:51:25 SERVER kernel: [ 0.484098] alloc kstat_irqs on node 0
Jul 9 19:51:25 SERVER kernel: [ 0.484117] pci 0000:00:0b.0: PCI INT A -> Link[APCF] -> GSI 23 (level, low) -> IRQ 23
Jul 9 19:51:25 SERVER kernel: [ 0.556041] pci 0000:00:0b.0: PCI INT A disabled
Jul 9 19:51:25 SERVER kernel: [ 0.556664] ACPI: PCI Interrupt Link [APCL] enabled at IRQ 22
Jul 9 19:51:25 SERVER kernel: [ 0.556670] alloc irq_desc for 22 on node 0
Jul 9 19:51:25 SERVER kernel: [ 0.556675] alloc kstat_irqs on node 0
Jul 9 19:51:25 SERVER kernel: [ 0.556688] pci 0000:00:0b.1: PCI INT B -> Link[APCL] -> GSI 22 (level, low) -> IRQ 22
Jul 9 19:51:25 SERVER kernel: [ 2.156027] pci 0000:00:0b.1: EHCI: BIOS handoff failed (BIOS bug?) 01010001
Jul 9 19:51:25 SERVER kernel: [ 2.156040] pci 0000:00:0b.1: PCI INT B disabled
Jul 9 19:51:25 SERVER kernel: [ 2.156111] pci 0000:00:09.0: Found disabled HT MSI Mapping
Jul 9 19:51:25 SERVER kernel: [ 2.156122] pci 0000:00:0e.0: Enabling HT MSI Mapping
Jul 9 19:51:25 SERVER kernel: [ 2.156195] pci 0000:00:09.0: Found disabled HT MSI Mapping
Jul 9 19:51:25 SERVER kernel: [ 2.156206] pci 0000:00:0f.0: Enabling HT MSI Mapping
Jul 9 19:51:25 SERVER kernel: [ 2.156282] pci 0000:00:09.0: Found disabled HT MSI Mapping
Jul 9 19:51:25 SERVER kernel: [ 2.156291] pci 0000:00:10.0: Enabling HT MSI Mapping
Jul 9 19:51:25 SERVER kernel: [ 2.156326] pci 0000:02:00.0: Boot video device
Jul 9 19:51:25 SERVER kernel: [ 2.156429] Unpacking initramfs...
Jul 9 19:51:25 SERVER kernel: [ 2.637541] Freeing initrd memory: 9095k freed
Jul 9 19:51:25 SERVER kernel: [ 2.649214] audit: initializing netlink socket (disabled)
Jul 9 19:51:25 SERVER kernel: [ 2.649251] type=2000 audit(1341856264.648:1): initialized
Jul 9 19:51:25 SERVER kernel: [ 2.655968] HugeTLB registered 2 MB page size, pre-allocated 0 pages
Jul 9 19:51:25 SERVER kernel: [ 2.659581] VFS: Disk quotas dquot_6.5.2
Jul 9 19:51:25 SERVER kernel: [ 2.659710] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jul 9 19:51:25 SERVER kernel: [ 2.659905] msgmni has been set to 4022
Jul 9 19:51:25 SERVER kernel: [ 2.660521] alg: No test for stdrng (krng)
Jul 9 19:51:25 SERVER kernel: [ 2.660678] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
Jul 9 19:51:25 SERVER kernel: [ 2.660685] io scheduler noop registered
Jul 9 19:51:25 SERVER kernel: [ 2.660689] io scheduler anticipatory registered
Jul 9 19:51:25 SERVER kernel: [ 2.660693] io scheduler deadline registered
Jul 9 19:51:25 SERVER kernel: [ 2.660836] io scheduler cfq registered (default)
Jul 9 19:51:25 SERVER kernel: [ 2.661150] alloc irq_desc for 24 on node 0
Jul 9 19:51:25 SERVER kernel: [ 2.661155] alloc kstat_irqs on node 0
Jul 9 19:51:25 SERVER kernel: [ 2.661172] pcieport 0000:00:02.0: irq 24 for MSI/MSI-X
Jul 9 19:51:25 SERVER kernel: [ 2.661182] pcieport 0000:00:02.0: setting latency timer to 64
Jul 9 19:51:25 SERVER kernel: [ 2.661406] alloc irq_desc for 25 on node 0
Jul 9 19:51:25 SERVER kernel: [ 2.661411] alloc kstat_irqs on node 0
Jul 9 19:51:25 SERVER kernel: [ 2.661424] pcieport 0000:00:04.0: irq 25 for MSI/MSI-X
Jul 9 19:51:25 SERVER kernel: [ 2.661432] pcieport 0000:00:04.0: setting latency timer to 64
Jul 9 19:51:25 SERVER kernel: [ 2.664625] Linux agpgart interface v0.103
Jul 9 19:51:25 SERVER kernel: [ 2.664732] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Jul 9 19:51:25 SERVER kernel: [ 2.664873] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Jul 9 19:51:25 SERVER kernel: [ 2.665031] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Jul 9 19:51:25 SERVER kernel: [ 2.665552] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Jul 9 19:51:25 SERVER kernel: [ 2.665765] 00:09: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Jul 9 19:51:25 SERVER kernel: [ 2.666137] input: Macintosh mouse button emulation as /devices/virtual/input
