rebonsoir,
le sislog était sans internet,
voici le même avec une connnexion internet en effet, je constate que l’arrêt lorsque il ny a pas internet est plus rapide
Mar 26 20:55:33 debian shutdown[7418]: shutting down for system halt
Mar 26 20:55:33 debian init: Switching to runlevel: 0
Mar 26 20:55:37 debian nmbd[3892]: [2011/03/26 20:55:37, 0] nmbd/nmbd.c:terminate(58)
Mar 26 20:55:37 debian nmbd[3892]: Got SIGTERM: going down…
Mar 26 20:55:39 debian authdaemond: stopping authdaemond children
Mar 26 20:55:39 debian afpd[3225]: shutting down on signal 15
Mar 26 20:55:39 debian atalkd[2937]: done
Mar 26 20:55:45 debian modprobe: WARNING: Not loading blacklisted module ipv6
Mar 26 20:58:54 debian lwresd[2351]: shutting down
Mar 26 20:58:54 debian lwresd[2351]: exiting
Mar 26 20:58:54 debian kernel: Kernel logging (proc) stopped.
Mar 26 20:58:54 debian kernel: Kernel log daemon terminating.
Mar 26 20:58:55 debian exiting on signal 15
Feb 26 05:57:16 debian syslogd 1.4.1#18: restart.
Feb 26 05:57:16 debian kernel: klogd 1.4.1#18, log source = /proc/kmsg started.
Feb 26 05:57:16 debian kernel: Linux version 2.6.18-6-486 (Debian 2.6.18.dfsg.1-24) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 Sat Dec 27 08:57:46 UTC 2008
Feb 26 05:57:16 debian kernel: BIOS-provided physical RAM map:
Feb 26 05:57:16 debian kernel: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Feb 26 05:57:16 debian kernel: BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Feb 26 05:57:16 debian kernel: BIOS-e820: 00000000000e8000 - 0000000000100000 (reserved)
Feb 26 05:57:16 debian kernel: BIOS-e820: 0000000000100000 - 000000003ffb0000 (usable)
Feb 26 05:57:16 debian kernel: BIOS-e820: 000000003ffb0000 - 000000003ffc0000 (ACPI data)
Feb 26 05:57:16 debian kernel: BIOS-e820: 000000003ffc0000 - 000000003fff0000 (ACPI NVS)
Feb 26 05:57:16 debian kernel: BIOS-e820: 000000003fff0000 - 0000000040000000 (reserved)
Feb 26 05:57:16 debian kernel: BIOS-e820: 00000000ff7c0000 - 0000000100000000 (reserved)
Feb 26 05:57:16 debian kernel: Warning only 896MB will be used.
Feb 26 05:57:16 debian kernel: Use a HIGHMEM enabled kernel.
Feb 26 05:57:16 debian kernel: 896MB LOWMEM available.
Feb 26 05:57:16 debian kernel: On node 0 totalpages: 229376
Feb 26 05:57:16 debian kernel: DMA zone: 4096 pages, LIFO batch:0
Feb 26 05:57:16 debian kernel: Normal zone: 225280 pages, LIFO batch:31
Feb 26 05:57:16 debian kernel: DMI 2.3 present.
Feb 26 05:57:16 debian kernel: ACPI: RSDP (v000 ACPIAM ) @ 0x000f8730
Feb 26 05:57:16 debian kernel: ACPI: RSDT (v001 A_M_I OEMRSDT 0x12000627 MSFT 0x00000097) @ 0x3ffb0000
Feb 26 05:57:16 debian kernel: ACPI: FADT (v002 A M I OEMFACP 0x12000627 MSFT 0x00000097) @ 0x3ffb0200
Feb 26 05:57:16 debian kernel: ACPI: MADT (v001 A_M_I OEMAPIC 0x12000627 MSFT 0x00000097) @ 0x3ffb0390
Feb 26 05:57:16 debian kernel: ACPI: OEMB (v001 A_M_I AMI_OEM 0x12000627 MSFT 0x00000097) @ 0x3ffc0040
Feb 26 05:57:16 debian kernel: ACPI: HPET (v001 A_M_I OEMHPET0 0x12000627 MSFT 0x00000097) @ 0x3ffb4380
Feb 26 05:57:16 debian kernel: ACPI: DSDT (v001 K8UNF K8UNF211 0x00000211 INTL 0x02002026) @ 0x00000000
Feb 26 05:57:16 debian kernel: ACPI: PM-Timer IO Port: 0x4008
Feb 26 05:57:16 debian kernel: ACPI: Local APIC address 0xfee00000
Feb 26 05:57:16 debian kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Feb 26 05:57:16 debian kernel: Processor #0 15:12 APIC version 16
Feb 26 05:57:16 debian kernel: ACPI: LAPIC (acpi_id[0x02] lapic_id[0x81] disabled)
Feb 26 05:57:16 debian kernel: ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
Feb 26 05:57:16 debian kernel: IOAPIC[0]: apic_id 1, version 17, address 0xfec00000, GSI 0-23
Feb 26 05:57:16 debian kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Feb 26 05:57:16 debian kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Feb 26 05:57:16 debian kernel: ACPI: IRQ0 used by override.
Feb 26 05:57:16 debian kernel: ACPI: IRQ2 used by override.
Feb 26 05:57:16 debian kernel: ACPI: IRQ9 used by override.
Feb 26 05:57:16 debian kernel: Enabling APIC mode: Flat. Using 1 I/O APICs
Feb 26 05:57:16 debian kernel: ACPI: HPET id: 0x10de8201 base: 0xfed00000
Feb 26 05:57:16 debian kernel: Using ACPI (MADT) for SMP configuration information
Feb 26 05:57:16 debian kernel: Allocating PCI resources starting at 50000000 (gap: 40000000:bf7c0000)
Feb 26 05:57:16 debian kernel: Detected 1808.847 MHz processor.
Feb 26 05:57:16 debian kernel: Built 1 zonelists. Total pages: 229376
Feb 26 05:57:16 debian kernel: Kernel command line: root=/dev/hdc3 ro
Feb 26 05:57:16 debian kernel: mapped APIC to ffffd000 (fee00000)
Feb 26 05:57:16 debian kernel: mapped IOAPIC to ffffc000 (fec00000)
Feb 26 05:57:16 debian kernel: Enabling fast FPU save and restore… done.
Feb 26 05:57:16 debian kernel: Enabling unmasked SIMD FPU exception support… done.
Feb 26 05:57:16 debian kernel: Initializing CPU#0
Feb 26 05:57:16 debian kernel: PID hash table entries: 4096 (order: 12, 16384 bytes)
Feb 26 05:57:16 debian kernel: spurious 8259A interrupt: IRQ7.
Feb 26 05:57:16 debian kernel: Console: colour VGA+ 80x25
Feb 26 05:57:16 debian kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Feb 26 05:57:16 debian kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Feb 26 05:57:16 debian kernel: Memory: 902096k/917504k available (1501k kernel code, 14824k reserved, 601k data, 256k init, 0k highmem)
Feb 26 05:57:16 debian kernel: Checking if this processor honours the WP bit even in supervisor mode… Ok.
Feb 26 05:57:16 debian kernel: hpet0: at MMIO 0xfed00000 (virtual 0xf8800000), IRQs 2, 8, 31
Feb 26 05:57:16 debian kernel: hpet0: 3 32-bit timers, 25000000 Hz
Feb 26 05:57:16 debian kernel: Using HPET for base-timer
Feb 26 05:57:16 debian kernel: Calibrating delay using timer specific routine… 3619.63 BogoMIPS (lpj=7239273)
Feb 26 05:57:16 debian kernel: Security Framework v1.0.0 initialized
Feb 26 05:57:16 debian kernel: SELinux: Disabled at boot.
Feb 26 05:57:16 debian kernel: Capability LSM initialized
Feb 26 05:57:16 debian kernel: Mount-cache hash table entries: 512
Feb 26 05:57:16 debian kernel: CPU: After generic identify, caps: 078bfbff e3d3fbff 00000000 00000000 00000001 00000000 00000001
Feb 26 05:57:16 debian kernel: CPU: After vendor identify, caps: 078bfbff e3d3fbff 00000000 00000000 00000001 00000000 00000001
Feb 26 05:57:16 debian kernel: CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
Feb 26 05:57:16 debian kernel: CPU: L2 Cache: 128K (64 bytes/line)
Feb 26 05:57:16 debian kernel: CPU: After all inits, caps: 078bfbff e3d3fbff 00000000 00000410 00000001 00000000 00000001
Feb 26 05:57:16 debian kernel: Compat vDSO mapped to ffffe000.
Feb 26 05:57:16 debian kernel: CPU: AMD Sempron™ Processor 3000+ stepping 02
Feb 26 05:57:16 debian kernel: Checking ‘hlt’ instruction… OK.
Feb 26 05:57:16 debian kernel: ACPI: Core revision 20060707
Feb 26 05:57:16 debian kernel: ENABLING IO-APIC IRQs
Feb 26 05:57:16 debian kernel: …TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Feb 26 05:57:16 debian kernel: checking if image is initramfs… it is
Feb 26 05:57:16 debian kernel: Freeing initrd memory: 4242k freed
Feb 26 05:57:16 debian kernel: NET: Registered protocol family 16
Feb 26 05:57:16 debian kernel: EISA bus registered
Feb 26 05:57:16 debian kernel: ACPI: bus type pci registered
Feb 26 05:57:16 debian kernel: PCI: Using configuration type 1
Feb 26 05:57:16 debian kernel: Setting up standard PCI resources
Feb 26 05:57:16 debian kernel: ACPI: Interpreter enabled
Feb 26 05:57:16 debian kernel: ACPI: Using IOAPIC for interrupt routing
Feb 26 05:57:16 debian kernel: ACPI: PCI Root Bridge [PCI0] (0000:00)
Feb 26 05:57:16 debian kernel: PCI: Probing PCI hardware (bus 00)
Feb 26 05:57:16 debian kernel: Boot video device is 0000:01:00.0
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PRT]
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Routing Table [_SB.PCI0.P0P1._PRT]
Feb 26 05:57:16 debian kernel: ACPI: Power Resource [ISAV] (on)
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 16 17 18 19) *0, disabled.
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 16 17 18 19) *9
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 16 17 18 19) *0, disabled.
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 16 17 18 19) *11
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 16 17 18 19) *11
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LUS0] (IRQs 20 21 22) *9
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LUS1] (IRQs 20 21 22) *5
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LUS2] (IRQs 20 21 22) *3
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LKLN] (IRQs 20 21 22) *9
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LAUI] (IRQs 20 21 22) *0, disabled.
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LKMO] (IRQs 20 21 22) *0, disabled.
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LKSM] (IRQs 20 21 22) *0, disabled.
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LTID] (IRQs 20 21 22) *10
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LTIE] (IRQs 20 21 22) *0, disabled.
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LATA] (IRQs 22) 14
Feb 26 05:57:16 debian kernel: Linux Plug and Play Support v0.97 © Adam Belay
Feb 26 05:57:16 debian kernel: pnp: PnP ACPI init
Feb 26 05:57:16 debian kernel: pnp: PnP ACPI: found 13 devices
Feb 26 05:57:16 debian kernel: PnPBIOS: Disabled by ACPI PNP
Feb 26 05:57:16 debian kernel: PCI: Using ACPI for IRQ routing
Feb 26 05:57:16 debian kernel: PCI: If a device doesn’t work, try “pci=routeirq”. If it helps, post a report
Feb 26 05:57:16 debian kernel: pnp: 00:0b: ioport range 0x290-0x29f has been reserved
Feb 26 05:57:16 debian kernel: PCI: Bridge: 0000:00:0b.0
Feb 26 05:57:16 debian kernel: IO window: disabled.
Feb 26 05:57:16 debian kernel: MEM window: fc900000-fe9fffff
Feb 26 05:57:16 debian kernel: PREFETCH window: f0800000-f47fffff
Feb 26 05:57:16 debian kernel: PCI: Bridge: 0000:00:0e.0
Feb 26 05:57:16 debian kernel: IO window: c000-cfff
Feb 26 05:57:16 debian kernel: MEM window: fea00000-feafffff
Feb 26 05:57:16 debian kernel: PREFETCH window: disabled.
Feb 26 05:57:16 debian kernel: PCI: Setting latency timer of device 0000:00:0e.0 to 64
Feb 26 05:57:16 debian kernel: NET: Registered protocol family 2
Feb 26 05:57:16 debian kernel: IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
Feb 26 05:57:16 debian kernel: TCP established hash table entries: 131072 (order: 7, 524288 bytes)
Feb 26 05:57:16 debian kernel: TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
Feb 26 05:57:16 debian kernel: TCP: Hash tables configured (established 131072 bind 65536)
Feb 26 05:57:16 debian kernel: TCP reno registered
Feb 26 05:57:16 debian kernel: audit: initializing netlink socket (disabled)
Feb 26 05:57:16 debian kernel: audit(1172465814.760:1): initialized
Feb 26 05:57:16 debian kernel: VFS: Disk quotas dquot_6.5.1
Feb 26 05:57:16 debian kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Feb 26 05:57:16 debian kernel: Initializing Cryptographic API
Feb 26 05:57:16 debian kernel: io scheduler noop registered
Feb 26 05:57:16 debian kernel: io scheduler anticipatory registered
Feb 26 05:57:16 debian kernel: io scheduler deadline registered
Feb 26 05:57:16 debian kernel: io scheduler cfq registered (default)
Feb 26 05:57:16 debian kernel: isapnp: Scanning for PnP cards…
Feb 26 05:57:16 debian kernel: isapnp: No Plug & Play device found
Feb 26 05:57:16 debian kernel: hpet_resources: 0xfed00000 is busy
Feb 26 05:57:16 debian kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Feb 26 05:57:16 debian kernel: serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Feb 26 05:57:16 debian kernel: 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Feb 26 05:57:16 debian kernel: RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
Feb 26 05:57:16 debian kernel: PNP: No PS/2 controller found. Probing ports directly.
Feb 26 05:57:16 debian kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Feb 26 05:57:16 debian kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Feb 26 05:57:16 debian kernel: mice: PS/2 mouse device common for all mice
Feb 26 05:57:16 debian kernel: EISA: Probing bus 0 at eisa.0
Feb 26 05:57:16 debian kernel: Cannot allocate resource for EISA slot 4
Feb 26 05:57:16 debian kernel: Cannot allocate resource for EISA slot 5
Feb 26 05:57:16 debian kernel: EISA: Detected 0 cards.
Feb 26 05:57:16 debian kernel: TCP bic registered
Feb 26 05:57:16 debian kernel: NET: Registered protocol family 17
Feb 26 05:57:16 debian kernel: NET: Registered protocol family 8
Feb 26 05:57:16 debian kernel: NET: Registered protocol family 20
Feb 26 05:57:16 debian kernel: Using IPI Shortcut mode
Feb 26 05:57:16 debian kernel: ACPI: (supports S0 S1 S3 S4 S5)
Feb 26 05:57:16 debian kernel: Freeing unused kernel memory: 256k freed
Feb 26 05:57:16 debian kernel: Time: tsc clocksource has been installed.
Feb 26 05:57:16 debian kernel: ACPI: Getting cpuindex for acpiid 0x2
Feb 26 05:57:16 debian kernel: usbcore: registered new driver usbfs
Feb 26 05:57:16 debian kernel: usbcore: registered new driver hub
Feb 26 05:57:16 debian kernel: forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.56.
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LKLN] enabled at IRQ 22
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt 0000:00:05.0[A] -> Link [LKLN] -> GSI 22 (level, low) -> IRQ 169
Feb 26 05:57:16 debian kernel: PCI: Setting latency timer of device 0000:00:05.0 to 64
Feb 26 05:57:16 debian kernel: SCSI subsystem initialized
Feb 26 05:57:16 debian kernel: ohci_hcd: 2005 April 22 USB 1.1 ‘Open’ Host Controller (OHCI) Driver (PCI)
Feb 26 05:57:16 debian kernel: libata version 2.00 loaded.
Feb 26 05:57:16 debian kernel: eth0: forcedeth.c: subsystem: 01849:00df bound to 0000:00:05.0
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LUS2] enabled at IRQ 21
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt 0000:00:02.2[C] -> Link [LUS2] -> GSI 21 (level, low) -> IRQ 177
Feb 26 05:57:16 debian kernel: PCI: Setting latency timer of device 0000:00:02.2 to 64
Feb 26 05:57:16 debian kernel: ehci_hcd 0000:00:02.2: EHCI Host Controller
Feb 26 05:57:16 debian kernel: ehci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 1
Feb 26 05:57:16 debian kernel: ehci_hcd 0000:00:02.2: debug port 1
Feb 26 05:57:16 debian kernel: PCI: cache line size of 64 is not supported by device 0000:00:02.2
Feb 26 05:57:16 debian kernel: ehci_hcd 0000:00:02.2: irq 177, io mem 0xfebfdc00
Feb 26 05:57:16 debian kernel: ehci_hcd 0000:00:02.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Feb 26 05:57:16 debian kernel: usb usb1: configuration #1 chosen from 1 choice
Feb 26 05:57:16 debian kernel: hub 1-0:1.0: USB hub found
Feb 26 05:57:16 debian kernel: hub 1-0:1.0: 8 ports detected
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LUS0] enabled at IRQ 20
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [LUS0] -> GSI 20 (level, low) -> IRQ 185
Feb 26 05:57:16 debian kernel: PCI: Setting latency timer of device 0000:00:02.0 to 64
Feb 26 05:57:16 debian kernel: ohci_hcd 0000:00:02.0: OHCI Host Controller
Feb 26 05:57:16 debian kernel: ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2
Feb 26 05:57:16 debian kernel: ohci_hcd 0000:00:02.0: irq 185, io mem 0xfebff000
Feb 26 05:57:16 debian kernel: usb usb2: configuration #1 chosen from 1 choice
Feb 26 05:57:16 debian kernel: hub 2-0:1.0: USB hub found
Feb 26 05:57:16 debian kernel: hub 2-0:1.0: 4 ports detected
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LUS1] enabled at IRQ 22
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [LUS1] -> GSI 22 (level, low) -> IRQ 169
Feb 26 05:57:16 debian kernel: PCI: Setting latency timer of device 0000:00:02.1 to 64
Feb 26 05:57:16 debian kernel: ohci_hcd 0000:00:02.1: OHCI Host Controller
Feb 26 05:57:16 debian kernel: ohci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 3
Feb 26 05:57:16 debian kernel: ohci_hcd 0000:00:02.1: irq 169, io mem 0xfebfe000
Feb 26 05:57:16 debian kernel: usb usb3: configuration #1 chosen from 1 choice
Feb 26 05:57:16 debian kernel: hub 3-0:1.0: USB hub found
Feb 26 05:57:16 debian kernel: hub 3-0:1.0: 4 ports detected
Feb 26 05:57:16 debian kernel: sata_nv 0000:00:0a.0: version 2.0
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LTID] enabled at IRQ 21
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt 0000:00:0a.0[A] -> Link [LTID] -> GSI 21 (level, low) -> IRQ 177
Feb 26 05:57:16 debian kernel: PCI: Setting latency timer of device 0000:00:0a.0 to 64
Feb 26 05:57:16 debian kernel: ata1: SATA max UDMA/133 cmd 0xF80 ctl 0xF02 bmdma 0xE000 irq 177
Feb 26 05:57:16 debian kernel: ata2: SATA max UDMA/133 cmd 0xE80 ctl 0xE02 bmdma 0xE008 irq 177
Feb 26 05:57:16 debian kernel: scsi0 : sata_nv
Feb 26 05:57:16 debian kernel: ata1: SATA link down (SStatus 0 SControl 300)
Feb 26 05:57:16 debian kernel: scsi1 : sata_nv
Feb 26 05:57:16 debian kernel: ata2: SATA link down (SStatus 0 SControl 300)
Feb 26 05:57:16 debian kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Feb 26 05:57:16 debian kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Feb 26 05:57:16 debian kernel: NFORCE3-250: IDE controller at PCI slot 0000:00:08.0
Feb 26 05:57:16 debian kernel: NFORCE3-250: chipset revision 162
Feb 26 05:57:16 debian kernel: NFORCE3-250: not 100%% native mode: will probe irqs later
Feb 26 05:57:16 debian kernel: NFORCE3-250: 0000:00:08.0 (rev a2) UDMA133 controller
Feb 26 05:57:16 debian kernel: ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:pio, hdb:DMA
Feb 26 05:57:16 debian kernel: ide1: BM-DMA at 0xffa8-0xffaf, BIOS settings: hdc:DMA, hdd:DMA
Feb 26 05:57:16 debian kernel: Probing IDE interface ide0…
Feb 26 05:57:16 debian kernel: hdb: BENQ DVD DD DW1640, ATAPI CD/DVD-ROM drive
Feb 26 05:57:16 debian kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Feb 26 05:57:16 debian kernel: Probing IDE interface ide1…
Feb 26 05:57:16 debian kernel: hdc: Maxtor 6Y080P0, ATA DISK drive
Feb 26 05:57:16 debian kernel: hdd: ST3750640A, ATA DISK drive
Feb 26 05:57:16 debian kernel: ide1 at 0x170-0x177,0x376 on irq 15
Feb 26 05:57:16 debian kernel: r8169 Gigabit Ethernet driver 2.2LK-NAPI loaded
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 19
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt 0000:02:05.0[A] -> Link [LNKB] -> GSI 19 (level, low) -> IRQ 193
Feb 26 05:57:16 debian kernel: eth1: RTL8169sb/8110sb at 0xf881cc00, 00:0c:76:b6:07:ae, IRQ 193
Feb 26 05:57:16 debian kernel: hdb: ATAPI 48X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(33)
Feb 26 05:57:16 debian kernel: Uniform CD-ROM driver Revision: 3.20
Feb 26 05:57:16 debian kernel: hdc: max request size: 128KiB
Feb 26 05:57:16 debian kernel: hdc: 160086528 sectors (81964 MB) w/7936KiB Cache, CHS=65535/16/63, UDMA(33)
Feb 26 05:57:16 debian kernel: hdc: cache flushes supported
Feb 26 05:57:16 debian kernel: hdc: hdc1 hdc2 < hdc5 hdc6 > hdc3
Feb 26 05:57:16 debian kernel: hdd: max request size: 512KiB
Feb 26 05:57:16 debian kernel: hdd: 1465149168 sectors (750156 MB) w/16384KiB Cache, CHS=65535/255/63, UDMA(33)
Feb 26 05:57:16 debian kernel: hdd: cache flushes supported
Feb 26 05:57:16 debian kernel: Attempting manual resume
Feb 26 05:57:16 debian kernel: kjournald starting. Commit interval 5 seconds
Feb 26 05:57:16 debian kernel: EXT3-fs: mounted filesystem with ordered data mode.
Feb 26 05:57:16 debian kernel: Linux agpgart interface v0.101 © Dave Jones
Feb 26 05:57:16 debian kernel: agpgart: Detected AGP bridge 0
Feb 26 05:57:16 debian kernel: agpgart: Setting up Nforce3 AGP.
Feb 26 05:57:16 debian kernel: agpgart: aperture base > 4G
Feb 26 05:57:16 debian kernel: i2c_adapter i2c-0: nForce2 SMBus adapter at 0x5000
Feb 26 05:57:16 debian kernel: i2c_adapter i2c-1: nForce2 SMBus adapter at 0x5040
Feb 26 05:57:16 debian kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Feb 26 05:57:16 debian kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Feb 26 05:57:16 debian kernel: Real Time Clock Driver v1.12ac
Feb 26 05:57:16 debian kernel: input: PC Speaker as /class/input/input0
Feb 26 05:57:16 debian kernel: Floppy drive(s): fd0 is 1.44M
Feb 26 05:57:16 debian kernel: parport: PnPBIOS parport detected.
Feb 26 05:57:16 debian kernel: parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,EPP,ECP,DMA]
Feb 26 05:57:16 debian kernel: FDC 0 is a post-1991 82077
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 18
Feb 26 05:57:16 debian kernel: ACPI: PCI Interrupt 0000:02:07.0[A] -> Link [LNKD] -> GSI 18 (level, low) -> IRQ 201
Feb 26 05:57:16 debian kernel: es1371: version v0.32 time 09:17:23 Dec 27 2008
Feb 26 05:57:16 debian kernel: Adding 626464k swap on /dev/hdc6. Priority:-1 extents:1 across:626464k
Feb 26 05:57:16 debian kernel: EXT3 FS on hdc3, internal journal
Feb 26 05:57:16 debian kernel: loop: loaded (max 8 devices)
Feb 26 05:57:16 debian kernel: device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
Feb 26 05:57:16 debian kernel: r8169: eth1: link up
Feb 26 05:57:16 debian named[2348]: starting BIND 9.3.4-P1.1 -u bind
Feb 26 05:57:16 debian named[2348]: found 1 CPU, using 1 worker thread
Feb 26 05:57:16 debian named[2348]: loading configuration from '/etc/bind/named.conf’
Feb 26 05:57:16 debian modprobe: WARNING: Not loading blacklisted module ipv6
Feb 26 05:57:16 debian named[2348]: no IPv6 interfaces found
Feb 26 05:57:16 debian named[2348]: listening on IPv4 interface eth0, 77.207.152.60#53
Feb 26 05:57:16 debian named[2348]: listening on IPv4 interface eth1, 192.168.8.1#53
Feb 26 05:57:16 debian named[2348]: couldn’t add command channel 127.0.0.1#953: address not available
Feb 26 05:57:16 debian named[2348]: zone 0.in-addr.arpa/IN: loaded serial 1
Feb 26 05:57:16 debian named[2348]: zone 127.in-addr.arpa/IN: loaded serial 1
Feb 26 05:57:16 debian named[2348]: zone 255.in-addr.arpa/IN: loaded serial 1
Feb 26 05:57:16 debian named[2348]: zone localhost/IN: loaded serial 1
Feb 26 05:57:16 debian named[2348]: running
Feb 26 05:57:16 debian lwresd[2364]: starting BIND 9.3.4-P1.1
Feb 26 05:57:16 debian lwresd[2364]: found 1 CPU, using 1 worker thread
Feb 26 05:57:17 debian lwresd[2364]: loading configuration from '/etc/bind/lwresd.conf’
Feb 26 05:57:17 debian lwresd[2364]: none:0: open: /etc/bind/lwresd.conf: file not found
Feb 26 05:57:17 debian lwresd[2364]: loading configuration from '/etc/resolv.conf’
Feb 26 05:57:17 debian modprobe: WARNING: Not loading blacklisted module ipv6
Feb 26 05:57:17 debian lwresd[2364]: no IPv6 interfaces found
Feb 26 05:57:17 debian lwresd[2364]: none:0: open: /etc/bind/rndc.key: permission denied
Feb 26 05:57:17 debian lwresd[2364]: couldn’t add command channel 127.0.0.1#953: permission denied
Feb 26 05:57:17 debian lwresd[2364]: failed to add lwres socket: 127.0.0.1#921: address not available
Feb 26 05:57:17 debian lwresd[2364]: running
Feb 26 05:57:18 debian mysqld_safe[2468]: started
Feb 26 05:57:18 debian mysqld[2471]: 070226 5:57:18 InnoDB: Started; log sequence number 0 43655
Feb 26 05:57:18 debian mysqld[2471]: 070226 5:57:18 [ERROR] Can’t start server: Bind on TCP/IP port: Cannot assign requested address
Feb 26 05:57:18 debian mysqld[2471]: 070226 5:57:18 [ERROR] Do you already have another mysqld server running on port: 3306 ?
Feb 26 05:57:18 debian mysqld[2471]: 070226 5:57:18 [ERROR] Aborting
Feb 26 05:57:18 debian mysqld[2471]: 070226 5:57:18 InnoDB: Starting shutdown…
Feb 26 05:57:20 debian mysqld[2471]: 070226 5:57:20 InnoDB: Shutdown completed; log sequence number 0 43655
Feb 26 05:57:20 debian mysqld[2471]: 070226 5:57:20 [Note] /usr/sbin/mysqld: Shutdown complete
Feb 26 05:57:20 debian mysqld_safe[2517]: ended
Mar 12 01:28:47 debian ntpdate[1990]: no server suitable for synchronization found
Mar 12 01:28:47 debian ntpdate[2095]: step time server 88.178.32.159 offset 64351884.812386 sec
Mar 12 01:28:57 debian /etc/init.d/mysql[2700]: 0 processes alive and ‘/usr/bin/mysqladmin --defaults-file=/etc/mysql/debian.cnf ping’ resulted in
Mar 12 01:28:57 debian /etc/init.d/mysql[2700]: ^G/usr/bin/mysqladmin: connect to server at ‘localhost’ failed
Mar 12 01:28:57 debian /etc/init.d/mysql[2700]: error: 'Can’t connect to local MySQL server through socket ‘/var/run/mysqld/mysqld.sock’ (2)'
Mar 12 01:28:57 debian /etc/init.d/mysql[2700]: Check that mysqld is running and that the socket: ‘/var/run/mysqld/mysqld.sock’ exists!
Mar 12 01:29:01 debian kernel: ACPI: Power Button (FF) [PWRF]
Mar 12 01:29:01 debian kernel: ACPI: Power Button (CM) [PWRB]
Mar 12 01:29:01 debian authdaemond: modules=“authpam”, daemons=5
Mar 12 01:29:01 debian authdaemond: Installing libauthpam
Mar 12 01:29:01 debian authdaemond: Installation complete: authpam
Mar 12 01:29:02 debian dhcpd: Internet Systems Consortium DHCP Server V3.0.4
Mar 12 01:29:02 debian dhcpd: Copyright 2004-2006 Internet Systems Consortium.
Mar 12 01:29:02 debian dhcpd: All rights reserved.
Mar 12 01:29:02 debian dhcpd: For info, please visit isc.org/sw/dhcp/
Mar 12 01:29:02 debian dhcpd: Wrote 0 deleted host decls to leases file.
Mar 12 01:29:02 debian dhcpd: Wrote 0 new dynamic host decls to leases file.
Mar 12 01:29:02 debian dhcpd: Wrote 7 leases to leases file.
Mar 12 01:29:04 debian kernel: ip_tables: © 2000-2006 Netfilter Core Team
Mar 12 01:29:04 debian kernel: Netfilter messages via NETLINK v0.30.
Mar 12 01:29:04 debian kernel: ip_conntrack version 2.4 (7168 buckets, 57344 max) - 224 bytes per conntrack
Mar 12 01:29:04 debian kernel: kjournald starting. Commit interval 5 seconds
Mar 12 01:29:04 debian kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Mar 12 01:29:04 debian kernel: EXT3 FS on hdd, internal journal
Mar 12 01:29:04 debian kernel: EXT3-fs: mounted filesystem with ordered data mode.
Mar 12 01:29:04 debian kernel: NET: Registered protocol family 5
Mar 12 01:29:04 debian atalkd[2950]: restart (2.0.3)
Mar 12 01:29:05 debian atalkd[2950]: zip_getnetinfo for eth0
Mar 12 01:29:25 debian last message repeated 2 times
Mar 12 01:29:35 debian atalkd[2950]: as_timer multiple interfaces, no seed
Mar 12 01:29:35 debian atalkd[2950]: as_timer can’t configure eth0
Mar 12 01:29:35 debian atalkd[2950]: as_timer waiting for router
Mar 12 01:29:35 debian atalkd[2950]: ready 0/0/0
Mar 12 01:29:52 debian papd[3236]: restart (2.0.3)
Mar 12 01:29:52 debian papd[3236]: CUPS support enabled (1.2)
Mar 12 01:29:52 debian afpd[3238]: Registering CNID module [last]
Mar 12 01:29:52 debian afpd[3238]: Registering CNID module [cdb]
Mar 12 01:29:52 debian afpd[3238]: Registering CNID module [dbd]
Mar 12 01:29:52 debian afpd[3238]: Loading ConfigFile
Mar 12 01:29:52 debian afpd[3238]: Finished parsing Config File
Mar 12 01:29:52 debian cnid_metad: error binding to socket for localhost: Cannot assign requested address
Mar 12 01:29:52 debian kernel: Installing knfsd (copyright © 1996 okir@monad.swb.de).
Mar 12 01:29:52 debian kernel: NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
Mar 12 01:29:52 debian kernel: NFSD: starting 90-second grace period
Mar 12 01:30:02 debian afpd[3238]: Can’t register debian:AFPServer@
Mar 12 01:30:02 debian afpd[3238]: ASIP started on 127.0.1.1:548(4) (2.0.3)
Mar 12 01:30:27 debian kernel: portmap: server localhost not responding, timed out
Mar 12 01:30:27 debian kernel: RPC: failed to contact portmap (errno -5).
Mar 12 01:31:02 debian kernel: portmap: server localhost not responding, timed out
Mar 12 01:31:02 debian kernel: RPC: failed to contact portmap (errno -5).
Mar 12 01:31:36 debian dhcpd: DHCPREQUEST for 192.168.8.200 from 00:22:15:ed:23:29 via eth1
Mar 12 01:31:36 debian dhcpd: DHCPACK on 192.168.8.200 to 00:22:15:ed:23:29 (mon_micro) via eth1
Mar 12 01:31:37 debian kernel: portmap: server localhost not responding, timed out
Mar 12 01:31:37 debian kernel: RPC: failed to contact portmap (errno -5).
Mar 12 01:31:37 debian nfsd[3257]: nfssvc: Input/output error
Mar 12 01:31:37 debian smbd[3906]: [2009/03/12 01:31:37, 0] printing/pcap.c:pcap_cache_reload(159)
Mar 12 01:31:37 debian smbd[3906]: Unable to open printcap file /etc/printcap for read!
Mar 12 01:31:38 debian modprobe: WARNING: Not loading blacklisted module ipv6
Mar 12 01:31:38 debian winbindd[3927]: [2009/03/12 01:31:38, 0] nsswitch/winbindd_util.c:winbindd_param_init(787)
Mar 12 01:31:38 debian winbindd[3927]: winbindd: idmap uid range missing or invalid
Mar 12 01:31:38 debian winbindd[3927]: [2009/03/12 01:31:38, 0] nsswitch/winbindd_util.c:winbindd_param_init(788)
Mar 12 01:31:38 debian winbindd[3927]: winbindd: cannot continue, exiting.
Mar 12 01:31:38 debian rpc.statd[3985]: Version 1.0.10 Starting
Mar 12 01:31:41 debian modprobe: WARNING: Not loading blacklisted module ipv6
