…que je ne sais pas “traduire”.
J’ai installé quelques softs pour faire des essais, sinon, rien de particulier.
/etc/cron.daily/logrotate:
Segmentation fault
run-parts: /etc/cron.daily/logrotate exited with return code 139
le script :
[code]#!/bin/sh
test -x /usr/sbin/logrotate || exit 0
/usr/sbin/logrotate /etc/logrotate.conf[/code]
logrotate.conf :
[code]# see “man logrotate” for details
rotate log files weekly
weekly
keep 4 weeks worth of backlogs
rotate 4
create new (empty) log files after rotating old ones
create
uncomment this if you want your log files compressed
#compress
packages drop log rotation information into this directory
include /etc/logrotate.d
no packages own wtmp, or btmp – we’ll rotate them here
/var/log/wtmp {
missingok
monthly
create 0664 root utmp
rotate 1
/var/log/btmp {
missingok
monthly
create 0660 root utmp
rotate 1
system-specific logs may be configured here[/code]
