Je sais bien que l’on ne doit mettre qu’un seul sujet par message, mais comme les deux problèmes sont apparus à la suite de la même maj… :
- Je ne peux plus monter les cles USB en tant qu’utilisateur normal, mais seulement en tant que root, qu’elle soient formatées en FAT ou en NTFS.
Recherche dans syslog :
root@Delta-7:/home/yoda# tail -f /var/log/syslog
May 27 14:45:12 Delta-7 rsyslogd: [origin software="rsyslogd" swVersion="7.4.8" x-pid="1910" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
May 27 14:45:13 Delta-7 anacron[4231]: Job `cron.daily' terminated
May 27 14:45:13 Delta-7 anacron[4231]: Normal exit (1 job run)
May 27 14:46:26 Delta-7 kernel: [ 9866.754961] [UFW BLOCK] IN=wlan0 OUT= MAC=01:00:5e:00:00:01:cc:33:bb:39:65:9c:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
May 27 14:47:27 Delta-7 kernel: [ 9927.338471] usb 1-2: USB disconnect, device number 8
May 27 14:47:50 Delta-7 kernel: [ 9950.437503] usb 1-1: new high-speed USB device number 9 using xhci_hcd
May 27 14:47:50 Delta-7 mtp-probe: checking bus 1, device 9: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
May 27 14:47:50 Delta-7 mtp-probe: bus: 1, device: 9 was not an MTP device
May 27 14:47:50 Delta-7 kernel: [ 9950.494336] usb 1-1: New USB device found, idVendor=8564, idProduct=1000
May 27 14:47:50 Delta-7 kernel: [ 9950.494339] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
May 27 14:47:50 Delta-7 kernel: [ 9950.494341] usb 1-1: Product: Mass Storage Device
May 27 14:47:50 Delta-7 kernel: [ 9950.494342] usb 1-1: Manufacturer: JetFlash
May 27 14:47:50 Delta-7 kernel: [ 9950.494343] usb 1-1: SerialNumber: 6GORX86P
May 27 14:47:50 Delta-7 kernel: [ 9950.494775] usb-storage 1-1:1.0: USB Mass Storage device detected
May 27 14:47:50 Delta-7 kernel: [ 9950.494823] scsi11 : usb-storage 1-1:1.0
May 27 14:47:51 Delta-7 kernel: [ 9951.496234] scsi 11:0:0:0: Direct-Access JetFlash Transcend 16GB 8.01 PQ: 0 ANSI: 2
May 27 14:47:51 Delta-7 kernel: [ 9951.497774] scsi 11:0:0:1: CD-ROM Generic AutoRun Disk 8.00 PQ: 0 ANSI: 2
May 27 14:47:51 Delta-7 kernel: [ 9951.499212] sd 11:0:0:0: [sdc] 31352820 512-byte logical blocks: (16.0 GB/14.9 GiB)
May 27 14:47:51 Delta-7 kernel: [ 9951.500592] sr1: scsi3-mmc drive: 52x/52x cd/rw xa/form2 tray
May 27 14:47:51 Delta-7 kernel: [ 9951.500680] sr 11:0:0:1: Attached scsi CD-ROM sr1
May 27 14:47:51 Delta-7 kernel: [ 9951.500746] sd 11:0:0:0: [sdc] Write Protect is off
May 27 14:47:51 Delta-7 kernel: [ 9951.500749] sd 11:0:0:0: [sdc] Mode Sense: 03 00 00 00
May 27 14:47:51 Delta-7 kernel: [ 9951.501092] sd 11:0:0:0: [sdc] No Caching mode page found
May 27 14:47:51 Delta-7 kernel: [ 9951.501095] sd 11:0:0:0: [sdc] Assuming drive cache: write through
May 27 14:47:51 Delta-7 kernel: [ 9951.502674] sd 11:0:0:0: [sdc] No Caching mode page found
May 27 14:47:51 Delta-7 kernel: [ 9951.502677] sd 11:0:0:0: [sdc] Assuming drive cache: write through
May 27 14:47:51 Delta-7 kernel: [ 9951.737563] sdc: sdc1
May 27 14:47:51 Delta-7 kernel: [ 9951.744466] sd 11:0:0:0: [sdc] No Caching mode page found
May 27 14:47:51 Delta-7 kernel: [ 9951.744469] sd 11:0:0:0: [sdc] Assuming drive cache: write through
May 27 14:47:51 Delta-7 kernel: [ 9951.744471] sd 11:0:0:0: [sdc] Attached SCSI removable disk
May 27 14:47:52 Delta-7 kernel: [ 9952.620967] xhci_hcd 0000:00:14.0: WARN Event TRB for slot 8 ep 4 with no TDs queued?
May 27 14:47:52 Delta-7 kernel: [ 9952.729205] sr 11:0:0:1: GET_EVENT and TUR disagree continuously, suppress GET_EVENT events
- Le deuxième problème est que je ne peux plus me connecter à de nouveaux réseaux Wifi, mais uniquement à ceux auxquels je me suis déjà connecté.
Je répète que tout fonctionnait très bien… AVANT
Merci pour votre aide.
