Désinstallation propre
J’ai déjà postéaujourd’hui pour un problème d’exim qui ne fonctionnait plus(résolu), mais là je me pose une autre question concernant les résidus d’exim que voici (commande locate exim) :
/etc/cron.daily/exim4-base
/etc/default/exim4
/etc/exim4
/etc/exim4/conf.d
/etc/exim4/conf.d/acl
/etc/exim4/conf.d/acl/00_exim4-config_header
/etc/exim4/conf.d/acl/20_exim4-config_whitelist_local_deny
/etc/exim4/conf.d/acl/30_exim4-config_check_mail
/etc/exim4/conf.d/acl/30_exim4-config_check_rcpt
/etc/exim4/conf.d/acl/40_exim4-config_check_data
/etc/exim4/conf.d/auth
/etc/exim4/conf.d/auth/00_exim4-config_header
/etc/exim4/conf.d/auth/30_exim4-config_examples
/etc/exim4/conf.d/main
/etc/exim4/conf.d/main/01_exim4-config_listmacrosdefs
/etc/exim4/conf.d/main/02_exim4-config_options
/etc/exim4/conf.d/main/03_exim4-config_tlsoptions
/etc/exim4/conf.d/main/90_exim4-config_log_selector
/etc/exim4/conf.d/retry
/etc/exim4/conf.d/retry/00_exim4-config_header
/etc/exim4/conf.d/retry/30_exim4-config
/etc/exim4/conf.d/rewrite
/etc/exim4/conf.d/rewrite/00_exim4-config_header
/etc/exim4/conf.d/rewrite/31_exim4-config_rewriting
/etc/exim4/conf.d/router
/etc/exim4/conf.d/router/00_exim4-config_header
/etc/exim4/conf.d/router/100_exim4-config_domain_literal
/etc/exim4/conf.d/router/150_exim4-config_hubbed_hosts
/etc/exim4/conf.d/router/200_exim4-config_primary
/etc/exim4/conf.d/router/300_exim4-config_real_local
/etc/exim4/conf.d/router/400_exim4-config_system_aliases
/etc/exim4/conf.d/router/500_exim4-config_hubuser
/etc/exim4/conf.d/router/600_exim4-config_userforward
/etc/exim4/conf.d/router/700_exim4-config_procmail
/etc/exim4/conf.d/router/800_exim4-config_maildrop
/etc/exim4/conf.d/router/900_exim4-config_local_user
/etc/exim4/conf.d/router/mmm_mail4root
/etc/exim4/conf.d/transport
/etc/exim4/conf.d/transport/00_exim4-config_header
/etc/exim4/conf.d/transport/30_exim4-config_address_file
/etc/exim4/conf.d/transport/30_exim4-config_address_pipe
/etc/exim4/conf.d/transport/30_exim4-config_address_reply
/etc/exim4/conf.d/transport/30_exim4-config_maildir_home
/etc/exim4/conf.d/transport/30_exim4-config_maildrop_pipe
/etc/exim4/conf.d/transport/30_exim4-config_mail_spool
/etc/exim4/conf.d/transport/30_exim4-config_procmail_pipe
/etc/exim4/conf.d/transport/30_exim4-config_remote_smtp
/etc/exim4/conf.d/transport/30_exim4-config_remote_smtp_smarthost
/etc/exim4/conf.d/transport/35_exim4-config_address_directory
/etc/exim4/exim4.conf.template
/etc/exim4/passwd.client
/etc/exim4/update-exim4.conf.conf
/etc/init.d/exim4
/etc/logrotate.d/exim4-base
/etc/ppp/ip-up.d/exim4
/etc/rc0.d/K20exim4
/etc/rc1.d/K20exim4
/etc/rc2.d/S20exim4
/etc/rc3.d/S20exim4
/etc/rc4.d/S20exim4
/etc/rc5.d/S20exim4
/etc/rc6.d/K20exim4
/var/cache/apt/archives/exim_3.36-18.2_i386.deb
/var/cache/apt/archives/exim4_4.63-17_all.deb
/var/cache/apt/archives/exim4-base_4.63-17_i386.deb
/var/cache/apt/archives/exim4-config_4.63-17_all.deb
/var/cache/apt/archives/exim4-daemon-light_4.63-17_i386.deb
/var/lib/dpkg/info/exim4-base.list
/var/lib/dpkg/info/exim4-base.postrm
/var/lib/dpkg/info/exim4-config.list
/var/lib/dpkg/info/exim4-config.postrm
/var/lib/dpkg/info/exim4-daemon-light.list
/var/lib/dpkg/info/exim4-daemon-light.postrm
/var/lib/dpkg/info/exim4.list
/var/lib/dpkg/info/exim4.postrm
/var/lib/exim4
/var/lib/exim4/config.autogenerated
/var/run/exim4
C’est normal qu’il reste tout ça après un apt-get remove --purge?
Y’a possibilité de tout enlever?
que donne aptitude search exim ?
Et peut-être que tu n’as pas retiré le service en lui même et du coup aptitude n’a pas pu tout virer ?
J’dis ça comme ça…
Et comment est-ce qu’on supprime le service?
Je ne suis pas sûr du tout que ce soit cela le problème, cela dit il me semble qu’une chose un peu identique m’était arrivé lorsque j’ai voulu virer portmap.
Mais sinon pour retirer le service: update-rc.d -f exim4 remove
il m’arrive quelque fois que des résidus de configuration ne soient pas desinstallé avec leur soft meme avec un aptitude remove --purge.
Dans ce cas, pour virer tous ces résidus, j’ai recours à cette commande :
