Bonjour, j’ai installé bluemind avec la méthode décrite dans la doc officiel :
blue-mind.net/communaute/ins … 64-bit-142
Maintenant, j’aimerais désinstallé bluemind, mais je n’y arrive pas.
en tapant locate bluemind, apparamment les paquets deb qui ont servit à installer bluemind sont dans /var/spool/bluemind-pkgs :
# locate bluemind
/tmp/bluemind-installer-3.0.12923-wheezy.bin.log
/var/lib/apt/lists/_var_spool_bluemind-pkgs_._Packages
/var/spool/bluemind-pkgs/Packages.gz
/var/spool/bluemind-pkgs/bm-admin-console_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-calendar_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-cas-role_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-client-access_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-conf_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-connector-thunderbird_3.0.12923_all.deb
/var/spool/bluemind-pkgs/bm-contact_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-core_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-cyrus-imapd_2.4.17-12923_amd64.deb
/var/spool/bluemind-pkgs/bm-cyrus_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-dav_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-default-app_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-eas_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-edge-role_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-elasticsearch_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-full_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-grafana_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-hps_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-hsm-role_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-im_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-imap-i18n_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-installation-wizard_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-ips_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-jdk_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-ldap-role_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-lmtpd_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-locator_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-mailbox-role_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-milter_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-mq_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-node_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-pimp_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-plugin-core-cti-xivo_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-plugin-core-ldap-export_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-plugin-core-ldap-import_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-plugin-core-ldap-samba-export_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-plugin-core-milter_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-plugin-core-password-bruteforce_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-plugin-core-password-sizestrength_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-postfix_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-push_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-settings_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-smbtools_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-soap_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-storage_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-tika_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-tomcat_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-webmail_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-xivobridge_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/bm-xmpp_3.0.12923_amd64.deb
/var/spool/bluemind-pkgs/cyrus-common-2.4_2.4.17-12923_amd64.deb
/var/spool/bluemind-pkgs/cyrus-common_2.4.17-12923_amd64.deb
/var/spool/bluemind-pkgs/influxdb_0.7.3_amd64.deb
/var/spool/bluemind-pkgs/nginx-common_1.6.0-1-12923_all.deb
/var/spool/bluemind-pkgs/nginx-doc_1.6.0-1-12923_all.deb
/var/spool/bluemind-pkgs/nginx-extras-dbg_1.6.0-1-12923_amd64.deb
/var/spool/bluemind-pkgs/nginx-extras_1.6.0-1-12923_amd64.deb
/var/spool/bluemind-pkgs/nginx-full-dbg_1.6.0-1-12923_amd64.deb
/var/spool/bluemind-pkgs/nginx-full_1.6.0-1-12923_amd64.deb
/var/spool/bluemind-pkgs/nginx-light-dbg_1.6.0-1-12923_amd64.deb
/var/spool/bluemind-pkgs/nginx-light_1.6.0-1-12923_amd64.deb
/var/spool/bluemind-pkgs/nginx-naxsi-dbg_1.6.0-1-12923_amd64.deb
/var/spool/bluemind-pkgs/nginx-naxsi-ui_1.6.0-1-12923_all.deb
/var/spool/bluemind-pkgs/nginx-naxsi_1.6.0-1-12923_amd64.deb
/var/spool/bluemind-pkgs/nginx_1.6.0-1-12923_all.deb
/var/spool/bluemind-pkgs/ysnp_3.0.12923_amd64.deb
root@localhost:/var/spool/bluemind-pkgs#
=> mais en tapant par exemple dpkg -r bm-calendar, ça ne marche pas.
root@localhost:/var/spool/bluemind-pkgs# dpkg -r bm-calendar
dpkg : avertissement : requête ignorée : suppression de bm-calendar, qui n'est pas installé
Une idée ?
Merci d’avance, cordialement
