oui #nemes1s#, la souris fonctionne sous windows et est bien branchée 8)
J’ai fais un lsmod. il n’y a pas de module psmouse chargé. ( j’ai vu un mousedev) Ce module est il nécessaire BobX?
A part ca voilà mon fichier XF86Config-4:
[color=red]
XF86Config-4 (XFree86 X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the XF86Config-4 manual page.
(Type “man XF86Config-4” at the shell prompt.)
This file is automatically updated on xserver-xfree86 package upgrades only
if it has not been modified since the last upgrade of the xserver-xfree86
package.
If you have edited this file but would like it to be automatically updated
again, run the following commands as root:
cp /etc/X11/XF86Config-4 /etc/X11/XF86Config-4.custom
md5sum /etc/X11/XF86Config-4 >/var/lib/xfree86/XF86Config-4.md5sum
dpkg-reconfigure xserver-xfree86
Section "Files"
FontPath “unix/:7100” # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/Speedo"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option “XkbRules” "xfree86"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/psaux"
Option “Protocol” "PS/2"
Option “ZAxisMapping” "4 5"
EndSection
Identifier "Generic Mouse"
Driver "mouse"
Option “SendCoreEvents” "true"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
EndSection
Section "Device"
Identifier "ATI Radeon 9200 SE"
Driver "ati"
EndSection
Section "Monitor"
Identifier "IIyama Vision Master 1404"
HorizSync 30-70
VertRefresh 50-160
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Radeon 9200 SE"
Monitor "IIyama Vision Master 1404"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1152x864” “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "Generic Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
[/color]
A part ca j’ai remarqué que j’ai beau changer les options dans le dpkg-reconfigure xserver-xfree86, j’ai l’impression que les paramètres ne sont pas modifiés.
J’ai mis n’importe quoi pour voir : vmware en driver graphique option ISA:1, un écran 14 pouces ( j’ai un 17) et une résolution de fou en 1600*1200…
et bien kdm se lance sans broncher comme avant. y a que la souris qui ne fonctionne pas…!
voilàvoilà…
