voici ce que j’obtiens
[ 0.874636] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.874638] software IO TLB [mem 0xbb2a0000-0xbf2a0000] (64MB) mapped at [ffff9ceb3b2a0000-ffff9ceb3f29ffff]
[ 0.874962] audit: initializing netlink subsys (disabled)
[ 0.874978] audit: type=2000 audit(1520317617.860:1): initialized
[ 0.875304] workingset: timestamp_bits=40 max_order=21 bucket_order=0
[ 0.875336] zbud: loaded
[ 0.875995] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.876020] io scheduler noop registered
[ 0.876020] io scheduler deadline registered
[ 0.876028] io scheduler cfq registered (default)
[ 0.877101] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 0.877102] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.877103] pci 0000:01:00.1: Signaling PME through PCIe PME interrupt
[ 0.877105] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 0.877126] pcieport 0000:00:1c.0: Signaling PME through PCIe PME interrupt
[ 0.877131] pcie_pme 0000:00:1c.0:pcie001: service driver pcie_pme loaded
[ 0.877155] pcieport 0000:00:1c.1: Signaling PME through PCIe PME interrupt
[ 0.877159] pcie_pme 0000:00:1c.1:pcie001: service driver pcie_pme loaded
[ 0.877181] pcieport 0000:00:1c.2: Signaling PME through PCIe PME interrupt
[ 0.877186] pcie_pme 0000:00:1c.2:pcie001: service driver pcie_pme loaded
[ 0.877208] pcieport 0000:00:1c.3: Signaling PME through PCIe PME interrupt
[ 0.877212] pcie_pme 0000:00:1c.3:pcie001: service driver pcie_pme loaded
[ 0.877231] pcieport 0000:00:1c.4: Signaling PME through PCIe PME interrupt
[ 0.877234] pcie_pme 0000:00:1c.4:pcie001: service driver pcie_pme loaded
[ 0.877252] pcieport 0000:00:1c.5: Signaling PME through PCIe PME interrupt
[ 0.877253] pci 0000:07:00.0: Signaling PME through PCIe PME interrupt
[ 0.877257] pcie_pme 0000:00:1c.5:pcie001: service driver pcie_pme loaded
[ 0.877265] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.877269] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.877278] efifb: probing for efifb
[ 0.877287] efifb: framebuffer at 0xc0000000, using 1920k, total 1920k
[ 0.877288] efifb: mode is 800x600x32, linelength=3200, pages=1
[ 0.877288] efifb: scrolling: redraw
[ 0.877290] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.878638] Console: switching to colour frame buffer device 100x37
[ 0.879865] fb0: EFI VGA frame buffer device
[ 0.879871] intel_idle: MWAIT substates: 0x1120
[ 0.879871] intel_idle: v0.4.1 model 0x2A
[ 0.879985] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.880417] GHES: HEST is not enabled!
[ 0.880457] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.880863] Linux agpgart interface v0.103
[ 0.880918] AMD IOMMUv2 driver by Joerg Roedel jroedel@suse.de
[ 0.880919] AMD IOMMUv2 functionality not available on this system
[ 0.881191] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.881552] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.881555] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.881688] mousedev: PS/2 mouse device common for all mice
[ 0.881724] rtc_cmos 00:02: RTC can wake from S4
[ 0.881871] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 0.881895] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.881903] intel_pstate: Intel P-state driver initializing
[ 0.882182] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.882786] NET: Registered protocol family 10
[ 0.883151] mip6: Mobile IPv6
[ 0.883153] NET: Registered protocol family 17
[ 0.883156] mpls_gso: MPLS GSO support
[ 0.883436] microcode: sig=0x206a7, pf=0x2, revision=0x29
[ 0.883556] microcode: Microcode Update Driver: v2.01 tigran@aivazian.fsnet.co.uk, Peter Oruba
[ 0.883748] registered taskstats version 1
[ 0.883765] zswap: loaded using pool lzo/zbud
[ 0.883922] ima: No TPM chip found, activating TPM-bypass!
[ 0.884340] rtc_cmos 00:02: setting system clock to 2018-03-06 06:26:58 UTC (1520317618)
[ 0.884448] PM: Hibernation image not present or could not be loaded.
[ 0.886316] Freeing unused kernel memory: 1416K
[ 0.886317] Write protecting the kernel read-only data: 12288k
[ 0.887073] Freeing unused kernel memory: 1940K
[ 0.891401] Freeing unused kernel memory: 1228K
[ 0.899850] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.919702] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 0.919799] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 0.919812] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 0.920936] random: udevadm: uninitialized urandom read (16 bytes read)
[ 0.920986] random: udevadm: uninitialized urandom read (16 bytes read)
[ 0.922493] random: udevadm: uninitialized urandom read (16 bytes read)
[ 0.922571] random: udevadm: uninitialized urandom read (16 bytes read)
[ 0.922982] random: udevadm: uninitialized urandom read (16 bytes read)
[ 0.923065] random: udevadm: uninitialized urandom read (16 bytes read)
[ 0.923140] random: udevadm: uninitialized urandom read (16 bytes read)
[ 0.954086] ACPI: bus type USB registered
[ 0.954114] usbcore: registered new interface driver usbfs
[ 0.954126] usbcore: registered new interface driver hub
[ 0.954153] usbcore: registered new device driver usb
[ 0.954748] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.954954] i801_smbus 0000:00:1f.3: enabling device (0101 -> 0103)
[ 0.955085] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 0.955087] ehci-pci: EHCI PCI platform driver
[ 0.955490] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 0.955497] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.955515] ehci-pci 0000:00:1a.0: debug port 2
[ 0.956138] SCSI subsystem initialized
[ 0.957973] libata version 3.00 loaded.
[ 0.959433] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 0.959451] ehci-pci 0000:00:1a.0: irq 16, io mem 0xfe707000
[ 0.959960] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.960370] r8169 0000:07:00.0 eth0: RTL8168e/8111e at 0xffffb0c340c95000, 80:c1:6e:e6:0b:b8, XID 0c200000 IRQ 31
[ 0.960372] r8169 0000:07:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 0.962022] AVX version of gcm_enc/dec engaged.
[ 0.962023] AES CTR mode by8 optimization enabled
[ 0.973362] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.973452] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.973454] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.973456] usb usb1: Product: EHCI Host Controller
[ 0.973457] usb usb1: Manufacturer: Linux 4.9.0-6-amd64 ehci_hcd
[ 0.973458] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.973630] hub 1-0:1.0: USB hub found
[ 0.973644] hub 1-0:1.0: 2 ports detected
[ 0.973904] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.973909] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.973922] ehci-pci 0000:00:1d.0: debug port 2
[ 0.977833] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 0.977846] ehci-pci 0000:00:1d.0: irq 23, io mem 0xfe706000
[ 0.993396] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.993447] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.993448] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.993450] usb usb2: Product: EHCI Host Controller
[ 0.993451] usb usb2: Manufacturer: Linux 4.9.0-6-amd64 ehci_hcd
[ 0.993453] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.993648] hub 2-0:1.0: USB hub found
[ 0.993656] hub 2-0:1.0: 2 ports detected
[ 0.993804] ahci 0000:00:1f.2: version 3.0
[ 1.004072] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 3 Gbps 0x33 impl SATA mode
[ 1.004075] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ems apst
[ 1.038372] scsi host0: ahci
[ 1.038759] scsi host1: ahci
[ 1.039073] scsi host2: ahci
[ 1.039246] scsi host3: ahci
[ 1.039419] scsi host4: ahci
[ 1.039598] scsi host5: ahci
[ 1.039685] ata1: SATA max UDMA/133 abar m2048@0xfe705000 port 0xfe705100 irq 32
[ 1.039688] ata2: SATA max UDMA/133 abar m2048@0xfe705000 port 0xfe705180 irq 32
[ 1.039689] ata3: DUMMY
[ 1.039690] ata4: DUMMY
[ 1.039693] ata5: SATA max UDMA/133 abar m2048@0xfe705000 port 0xfe705300 irq 32
[ 1.039695] ata6: SATA max UDMA/133 abar m2048@0xfe705000 port 0xfe705380 irq 32
[ 1.301361] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.321383] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 1.352263] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.352284] ata6: SATA link down (SStatus 0 SControl 300)
[ 1.352306] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.352332] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.353351] ata1.00: ATA-8: ST31000524AS, HP64, max UDMA/100
[ 1.353354] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.354657] ata1.00: configured for UDMA/100
[ 1.355113] scsi 0:0:0:0: Direct-Access ATA ST31000524AS HP64 PQ: 0 ANSI: 5
[ 1.356109] ata5.00: ATAPI: hp DVD-RAM GH80N, RF03, max UDMA/100
[ 1.361035] ata5.00: configured for UDMA/100
[ 1.396804] scsi 4:0:0:0: CD-ROM hp DVD-RAM GH80N RF03 PQ: 0 ANSI: 5
[ 1.410604] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.410762] sd 0:0:0:0: [sda] Write Protect is off
[ 1.410766] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.410803] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 1.428960] sr 4:0:0:0: [sr0] scsi3-mmc drive: 40x/40x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.428962] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.429166] sr 4:0:0:0: Attached scsi CD-ROM sr0
[ 1.446804] sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7
[ 1.447992] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.453751] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.453755] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.454175] hub 1-1:1.0: USB hub found
[ 1.454215] hub 1-1:1.0: 4 ports detected
[ 1.473750] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.473753] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.474174] hub 2-1:1.0: USB hub found
[ 1.474242] hub 2-1:1.0: 6 ports detected
[ 1.717899] random: fast init done
[ 1.741346] usb 1-1.1: new high-speed USB device number 3 using ehci-pci
[ 1.765321] usb 2-1.4: new low-speed USB device number 3 using ehci-pci
[ 1.850448] usb 1-1.1: New USB device found, idVendor=1058, idProduct=0740
[ 1.850451] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 1.850453] usb 1-1.1: Product: My Passport 0740
[ 1.850455] usb 1-1.1: Manufacturer: Western Digital
[ 1.850457] usb 1-1.1: SerialNumber: 575838314538314143414136
[ 1.853379] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[ 1.853542] scsi host6: usb-storage 1-1.1:1.0
[ 1.853640] usbcore: registered new interface driver usb-storage
[ 1.854125] usbcore: registered new interface driver uas
[ 1.879586] usb 2-1.4: New USB device found, idVendor=1c4f, idProduct=0040
[ 1.879589] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.879591] usb 2-1.4: Product: USB Keyboard
[ 1.879593] usb 2-1.4: Manufacturer: SIGMACH1P
[ 1.881800] hidraw: raw HID events driver © Jiri Kosina
[ 1.887317] usbcore: registered new interface driver usbhid
[ 1.887319] usbhid: USB HID core driver
[ 1.888052] input: SIGMACH1P USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.0/0003:1C4F:0040.0001/input/input3
[ 1.897349] tsc: Refined TSC clocksource calibration: 2993.227 MHz
[ 1.897364] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b25471a39b, max_idle_ns: 440795297653 ns
[ 1.929319] usb 1-1.4: new high-speed USB device number 4 using ehci-pci
[ 1.945501] hid-generic 0003:1C4F:0040.0001: input,hidraw0: USB HID v1.10 Keyboard [SIGMACH1P USB Keyboard] on usb-0000:00:1d.0-1.4/input0
[ 1.946444] input: SIGMACH1P USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.1/0003:1C4F:0040.0002/input/input4
[ 1.957336] usb 2-1.5: new low-speed USB device number 4 using ehci-pci
[ 2.005436] hid-generic 0003:1C4F:0040.0002: input,hidraw1: USB HID v1.10 Device [SIGMACH1P USB Keyboard] on usb-0000:00:1d.0-1.4/input1
[ 2.038815] usb 1-1.4: New USB device found, idVendor=1058, idProduct=0748
[ 2.038818] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 2.038820] usb 1-1.4: Product: My Passport 0748
[ 2.038822] usb 1-1.4: Manufacturer: Western Digital
[ 2.038824] usb 1-1.4: SerialNumber: 575845314136333936383836
[ 2.039391] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[ 2.039723] scsi host7: usb-storage 1-1.4:1.0
[ 2.071096] usb 2-1.5: New USB device found, idVendor=413c, idProduct=3016
[ 2.071108] usb 2-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.071110] usb 2-1.5: Product: Dell Premium USB Optical Mouse
[ 2.075184] input: Dell Premium USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/0003:413C:3016.0003/input/input5
[ 2.075449] hid-generic 0003:413C:3016.0003: input,hidraw2: USB HID v1.11 Mouse [Dell Premium USB Optical Mouse] on usb-0000:00:1d.0-1.5/input0
[ 2.153347] usb 2-1.6: new high-speed USB device number 5 using ehci-pci
[ 2.230740] PM: Starting manual resume from disk
[ 2.230744] PM: Hibernation image partition 8:4 present
[ 2.230745] PM: Looking for hibernation image.
[ 2.231059] PM: Image not found (code -22)
[ 2.231060] PM: Hibernation image not present or could not be loaded.
[ 2.267388] usb 2-1.6: New USB device found, idVendor=058f, idProduct=6366
[ 2.267391] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.267393] usb 2-1.6: Product: Mass Storage Device
[ 2.267395] usb 2-1.6: Manufacturer: Generic
[ 2.267397] usb 2-1.6: SerialNumber: 058F63666433
[ 2.267762] usb-storage 2-1.6:1.0: USB Mass Storage device detected
[ 2.267931] scsi host8: usb-storage 2-1.6:1.0
[ 2.401964] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.858108] scsi 6:0:0:0: Direct-Access WD My Passport 0740 1003 PQ: 0 ANSI: 6
[ 2.858659] scsi 6:0:0:1: Enclosure WD SES Device 1003 PQ: 0 ANSI: 6
[ 2.894594] sd 6:0:0:0: [sdb] 976707584 512-byte logical blocks: (500 GB/466 GiB)
[ 2.895686] sd 6:0:0:0: [sdb] Write Protect is off
[ 2.895691] sd 6:0:0:0: [sdb] Mode Sense: 47 00 10 08
[ 2.896695] sd 6:0:0:0: [sdb] No Caching mode page found
[ 2.896735] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 2.900184] sdb: sdb1
[ 2.903395] sd 6:0:0:0: [sdb] Attached SCSI disk
[ 2.921495] clocksource: Switched to clocksource tsc
[ 3.050215] scsi 7:0:0:0: Direct-Access WD My Passport 0748 1022 PQ: 0 ANSI: 6
[ 3.050814] scsi 7:0:0:1: Enclosure WD SES Device 1022 PQ: 0 ANSI: 6
[ 3.082538] sd 7:0:0:0: [sdc] 1465081856 512-byte logical blocks: (750 GB/699 GiB)
[ 3.083518] sd 7:0:0:0: [sdc] Write Protect is off
[ 3.083522] sd 7:0:0:0: [sdc] Mode Sense: 47 00 10 08
[ 3.084504] sd 7:0:0:0: [sdc] No Caching mode page found
[ 3.084549] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[ 3.093803] sdc: sdc4
[ 3.096880] sd 7:0:0:0: [sdc] Attached SCSI disk
[ 3.216832] ip_tables: © 2000-2006 Netfilter Core Team
[ 3.274471] scsi 8:0:0:0: Direct-Access Multiple Card Reader 1.00 PQ: 0 ANSI: 0
[ 3.277415] sd 8:0:0:0: [sdd] Attached SCSI removable disk
[ 4.119241] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 4.119453] systemd[1]: Detected architecture x86-64.
[ 4.154700] systemd[1]: Set hostname to .
[ 4.539925] random: crng init done
[ 5.310210] systemd[1]: Listening on udev Control Socket.
[ 5.310510] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.310560] systemd[1]: Listening on udev Kernel Socket.
[ 5.310600] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 5.310656] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.310723] systemd[1]: Listening on Journal Socket.
[ 5.310926] systemd[1]: Created slice System Slice.
[ 5.622168] lp: driver loaded but no devices found
[ 5.639525] ppdev: user-space parallel port driver
[ 5.781999] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
[ 5.903958] RPC: Registered named UNIX socket transport module.
[ 5.903960] RPC: Registered udp transport module.
[ 5.903961] RPC: Registered tcp transport module.
[ 5.903962] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 6.574134] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (_SB.PCI0.EUSB.GPSS) (20160831/utaddress-247)
[ 6.574139] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 6.574140] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (_SB.PCI0.EUSB.GPSS) (20160831/utaddress-247)
[ 6.574143] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 6.574144] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (_SB.PCI0.EUSB.GPSS) (20160831/utaddress-247)
[ 6.574146] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 6.574147] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 6.588265] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input6
[ 6.588268] ACPI: Power Button [PWRB]
[ 6.588308] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input7
[ 6.588310] ACPI: Power Button [PWRF]
[ 6.641437] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 6.652577] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 6.652603] sr 4:0:0:0: Attached scsi generic sg1 type 5
[ 6.652627] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 6.652650] scsi 6:0:0:1: Attached scsi generic sg3 type 13
[ 6.652674] sd 7:0:0:0: Attached scsi generic sg4 type 0
[ 6.652696] scsi 7:0:0:1: Attached scsi generic sg5 type 13
[ 6.652719] sd 8:0:0:0: Attached scsi generic sg6 type 0
[ 6.677295] input: PC Speaker as /devices/platform/pcspkr/input/input8
[ 6.726171] EFI Variables Facility v0.08 2004-May-17
[ 6.868470] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
[ 6.868471] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[ 6.868471] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 6.868472] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
[ 6.873004] pstore: using zlib compression
[ 6.873017] pstore: Registered efi as persistent store backend
[ 6.897659] [drm] Initialized
[ 7.084135] snd_hda_intel 0000:00:1b.0: enabling device (0100 -> 0102)
[ 7.084281] snd_hda_intel 0000:01:00.1: enabling device (0100 -> 0102)
[ 7.084322] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 7.163615] [drm] radeon kernel modesetting enabled.
[ 7.190367] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC656: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 7.190370] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 7.190372] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 7.190373] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 7.190375] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 7.190377] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 7.190379] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 7.190380] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 7.198032] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9
[ 7.200024] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 7.200059] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 7.200092] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 7.200127] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 7.200160] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 7.291244] CRAT table not found
[ 7.291245] Finished initializing topology ret=0
[ 7.291254] kfd kfd: Initialized module
[ 7.392867] checking generic (c0000000 1e0000) vs hw (c0000000 10000000)
[ 7.392869] fb: switching to radeondrmfb from EFI VGA
[ 7.392908] Console: switching to colour dummy device 80x25
[ 7.393199] [drm] initializing kernel modesetting (CAICOS 0x1002:0x677B 0x1462:0x2496 0x00).
[ 7.393209] [drm] register mmio base: 0xFE620000
[ 7.393210] [drm] register mmio size: 131072
[ 7.393245] ATOM BIOS: HP
[ 7.393704] radeon 0000:01:00.0: VRAM: 1024M 0x0000000000000000 - 0x000000003FFFFFFF (1024M used)
[ 7.393706] radeon 0000:01:00.0: GTT: 1024M 0x0000000040000000 - 0x000000007FFFFFFF
[ 7.393709] [drm] Detected VRAM RAM=1024M, BAR=256M
[ 7.393710] [drm] RAM width 64bits DDR
[ 7.393759] [TTM] Zone kernel: Available graphics memory: 4080088 kiB
[ 7.393760] [TTM] Zone dma32: Available graphics memory: 2097152 kiB
[ 7.393761] [TTM] Initializing pool allocator
[ 7.393765] [TTM] Initializing DMA pool allocator
[ 7.393790] [drm] radeon: 1024M of VRAM memory ready
[ 7.393791] [drm] radeon: 1024M of GTT memory ready.
[ 7.393801] [drm] Loading CAICOS Microcode
[ 7.724834] radeon 0000:01:00.0: firmware: direct-loading firmware radeon/CAICOS_pfp.bin
[ 7.725917] radeon 0000:01:00.0: firmware: direct-loading firmware radeon/CAICOS_me.bin
[ 7.755582] radeon 0000:01:00.0: firmware: direct-loading firmware radeon/BTC_rlc.bin
[ 7.755837] radeon 0000:01:00.0: firmware: direct-loading firmware radeon/CAICOS_mc.bin
[ 7.766612] radeon 0000:01:00.0: firmware: direct-loading firmware radeon/CAICOS_smc.bin
[ 7.766619] [drm] Internal thermal controller with fan control
[ 7.770909] [drm] radeon: dpm initialized
[ 7.784326] radeon 0000:01:00.0: firmware: direct-loading firmware radeon/SUMO_uvd.bin
[ 7.784356] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 7.784908] [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
[ 7.793915] [drm] PCIE GART of 1024M enabled (table at 0x0000000000162000).
[ 7.794022] radeon 0000:01:00.0: WB enabled
[ 7.794025] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000040000c00 and cpu addr 0xffff9cecb3953c00
[ 7.794026] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000040000c0c and cpu addr 0xffff9cecb3953c0c
[ 7.794772] radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x0000000000072118 and cpu addr 0xffffb0c342232118
[ 7.794773] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 7.794774] [drm] Driver supports precise vblank timestamp query.
[ 7.794775] radeon 0000:01:00.0: radeon: MSI limited to 32-bit
[ 7.794811] radeon 0000:01:00.0: radeon: using MSI.
[ 7.794839] [drm] radeon: irq initialized.
[ 7.811245] [drm] ring test on 0 succeeded in 2 usecs
[ 7.811263] [drm] ring test on 3 succeeded in 7 usecs
[ 7.986972] [drm] ring test on 5 succeeded in 2 usecs
[ 7.986980] [drm] UVD initialized successfully.
[ 7.987332] [drm] ib test on ring 0 succeeded in 0 usecs
[ 7.987386] [drm] ib test on ring 3 succeeded in 0 usecs
[ 8.001106] Adding 16736252k swap on /dev/sda4. Priority:-1 extents:1 across:16736252k FS
[ 8.060972] iTCO_vendor_support: vendor-support=0
[ 8.119401] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 8.119436] iTCO_wdt: Found a Cougar Point TCO device (Version=2, TCOBASE=0x0460)
[ 8.119512] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 8.649092] [drm] ib test on ring 5 succeeded
[ 8.649524] [drm] Radeon Display Connectors
[ 8.649525] [drm] Connector 0:
[ 8.649526] [drm] HDMI-A-1
[ 8.649527] [drm] HPD2
[ 8.649529] [drm] DDC: 0x6460 0x6460 0x6464 0x6464 0x6468 0x6468 0x646c 0x646c
[ 8.649530] [drm] Encoders:
[ 8.649531] [drm] DFP1: INTERNAL_UNIPHY1
[ 8.649532] [drm] Connector 1:
[ 8.649532] [drm] DVI-I-1
[ 8.649533] [drm] HPD4
[ 8.649535] [drm] DDC: 0x6450 0x6450 0x6454 0x6454 0x6458 0x6458 0x645c 0x645c
[ 8.649536] [drm] Encoders:
[ 8.649537] [drm] DFP2: INTERNAL_UNIPHY
[ 8.649537] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 8.691105] [drm] fb mappable at 0xC0363000
[ 8.691106] [drm] vram apper at 0xC0000000
[ 8.691107] [drm] size 4325376
[ 8.691107] [drm] fb depth is 24
[ 8.691108] [drm] pitch is 5632
[ 8.691177] fbcon: radeondrmfb (fb0) is primary device
[ 8.722327] Console: switching to colour frame buffer device 170x48
[ 8.725133] radeon 0000:01:00.0: fb0: radeondrmfb frame buffer device
[ 8.741121] [drm] Initialized radeon 2.49.0 20080528 for 0000:01:00.0 on minor 0
[ 8.856728] intel_rapl: Found RAPL domain package
[ 8.856731] intel_rapl: Found RAPL domain core
[ 8.856733] intel_rapl: Found RAPL domain uncore
[ 8.856740] intel_rapl: RAPL package 0 domain package locked by BIOS
[ 8.915086] ses 6:0:0:1: Attached Enclosure device
[ 8.915096] ses 7:0:0:1: Attached Enclosure device
[ 9.590841] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 10.369551] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[ 10.516753] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 10.598040] systemd-journald[245]: Received request to flush runtime journal from PID 1
[ 11.931172] vboxdrv: loading out-of-tree module taints kernel.
[ 11.940107] vboxdrv: Found 4 processor cores
[ 11.957198] vboxdrv: TSC mode is Invariant, tentative frequency 2993226680 Hz
[ 11.957199] vboxdrv: Successfully loaded version 5.2.8 (interface 0x00290001)
[ 12.427758] VBoxNetFlt: Successfully started.
[ 12.447854] VBoxNetAdp: Successfully started.
[ 12.986003] VBoxPciLinuxInit
[ 14.954322] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.980463] r8169 0000:07:00.0: firmware: direct-loading firmware rtl_nic/rtl8168e-2.fw
[ 15.124679] r8169 0000:07:00.0 eth0: link down
[ 15.124690] r8169 0000:07:00.0 eth0: link down
[ 15.124717] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 16.271302] vboxpci: IOMMU not found (not registered)
[ 17.459196] r8169 0000:07:00.0 eth0: link up
[ 17.459214] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 37.442175] fuse init (API version 7.26)
[ 7906.073663] usb 2-1.4: USB disconnect, device number 3
[ 7927.045479] usb 1-1.4: USB disconnect, device number 4
[10772.825424] usb 2-1.4: new low-speed USB device number 6 using ehci-pci
[10772.939456] usb 2-1.4: New USB device found, idVendor=1c4f, idProduct=0040
[10772.939458] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[10772.939459] usb 2-1.4: Product: USB Keyboard
[10772.939461] usb 2-1.4: Manufacturer: SIGMACH1P
[10772.942535] input: SIGMACH1P USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.0/0003:1C4F:0040.0004/input/input15
[10773.001620] hid-generic 0003:1C4F:0040.0004: input,hidraw0: USB HID v1.10 Keyboard [SIGMACH1P USB Keyboard] on usb-0000:00:1d.0-1.4/input0
[10773.004898] input: SIGMACH1P USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.1/0003:1C4F:0040.0005/input/input16
[10773.061524] hid-generic 0003:1C4F:0040.0005: input,hidraw1: USB HID v1.10 Device [SIGMACH1P USB Keyboard] on usb-0000:00:1d.0-1.4/input1
je ne connaissais pas cette commande, je vais en profité pour éplucher tout ça…
en ce qui concerne la commande lsusb le disc dur branché n’apparaisse pas.
