J’ai formaté mon disque dur externe de 500Gio en ext3, car je ne vais l’utiliser que sous GNU/Linux, que je vais utiliser rsync dessus et que je veux conserver les droits, et que je préfère un fs libre.
Las, le montage par l’utilisateur en ligne de commande ou en graphique échoue :
fdisk -l :
[quote]Disk /dev/sda: 160.0 GB, 160041885696 bytes
255 heads, 63 sectors/track, 19457 cylinders
Disk identifier: 0x145160c1
/dev/sda1 1 31 248976 83 Linux
/dev/sda2 32 2098 16603177+ 5 Extended
/dev/sda3 2099 19457 139436167+ 83 Linux
/dev/sda5 32 274 1951866 82 Linux swap / Solaris
/dev/sda6 275 1490 9767488+ 83 Linux
/dev/sda7 1491 1733 1951866 83 Linux
/dev/sda8 1734 2098 2931831 83 Linux
Disk /dev/sdb: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders
Disk identifier: 0x592287cb
/dev/sdb1 1 60801 488384001 83 Linux
/etc/fstab :
[quote]# /etc/fstab: static file system information.
Use ‘vol_id --uuid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
proc /proc proc defaults 0 0
/ was on /dev/sdb6 during installation
UUID=8e614040-7172-4080-b6c4-39aaf3b0a0d2 / ext3 errors=remount-ro 0 1
/boot was on /dev/sdb1 during installation
UUID=5685d940-5160-4ca8-834a-f613034edd6a /boot ext3 defaults 0 2
/home was on /dev/sdb3 during installation
UUID=40d85e6f-81dd-4c05-88ef-0441ee5d2a16 /home ext3 defaults 0 2
/tmp was on /dev/sdb7 during installation
UUID=de18a575-25da-485e-9576-bf3a048403eb /tmp ext3 defaults 0 2
/var was on /dev/sdb8 during installation
UUID=e6b76f11-0ecf-4c98-8009-a6a066bf6568 /var ext3 defaults 0 2
swap was on /dev/sdb5 during installation
UUID=5a902581-6c58-4444-82f6-81be27c620ae none swap sw 0 0
/dev/sda1 /media/usb0 auto rw,user,noauto 0 0
UUID=5685d940-5160-4ca8-834a-f613034edd6a /media/usb0 auto rw,user,noauto 0 0
UUID=d6c678c5-4470-4c2f-88e3-1096fb9ee2ea /media/HERCULE auto defaults 0 2
Changer le propriétaire du dossier /media/HERCULE ne change rien. L’objectif est que les deux utilisateurs de mes deux PCs puissent le monter et y accéder simplement en graphique. En déplacement, je trouverais toujours à y accéder en ligne de commande, etc.
Si quelqu’un a une idée…
