Disque dur introuvable
Bonjour à tous. J’ai un gros problème survenu du jour au lendemain, un de mes disque dur n’est plus reconnu par debian ni même par le bios. Le noyau est le 2.6.32-5-amd64.
le /var/log/dmesg me donne ça
[ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 2.6.32-5-amd64 (Debian 2.6.32-45) (dannf@debian.org) (gcc version 4.3.5 (Debian 4.3.5-4) ) #1 SMP Sun May 6 04:00:17 UTC 2012 [ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=UUID=fc27eddd-0bf9-4871-b69f-92a42e8ea3e1 ro quiet [ 0.000000] KERNEL supported cpus: [ 0.000000] Intel GenuineIntel [ 0.000000] AMD AuthenticAMD [ 0.000000] Centaur CentaurHauls [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009cc00 (usable) [ 0.000000] BIOS-e820: 000000000009cc00 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 00000000cff80000 (usable) [ 0.000000] BIOS-e820: 00000000cff80000 - 00000000cff8e000 (ACPI data) [ 0.000000] BIOS-e820: 00000000cff8e000 - 00000000cffd0000 (ACPI NVS) [ 0.000000] BIOS-e820: 00000000cffd0000 - 00000000d0000000 (reserved) [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved) [ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved) [ 0.000000] BIOS-e820: 0000000100000000 - 00000001b0000000 (usable) [ 0.000000] DMI present. [ 0.000000] AMI BIOS detected: BIOS may corrupt low RAM, working around it. [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] last_pfn = 0x1b0000 max_arch_pfn = 0x400000000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-DFFFF write-protect [ 0.000000] E0000-EFFFF write-through [ 0.000000] F0000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 1B0000000 mask FF0000000 uncachable [ 0.000000] 1 base 1C0000000 mask FC0000000 uncachable [ 0.000000] 2 base 000000000 mask E00000000 write-back [ 0.000000] 3 base 0D0000000 mask FF0000000 uncachable [ 0.000000] 4 base 0E0000000 mask FE0000000 uncachable [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] e820 update range: 00000000d0000000 - 0000000100000000 (usable) ==> (reserved) [ 0.000000] last_pfn = 0xcff80 max_arch_pfn = 0x400000000 [ 0.000000] initial memory mapped : 0 - 20000000 [ 0.000000] init_memory_mapping: 0000000000000000-00000000cff80000 [ 0.000000] 0000000000 - 00cfe00000 page 2M [ 0.000000] 00cfe00000 - 00cff80000 page 4k [ 0.000000] kernel direct mapping tables up to cff80000 @ 10000-16000 [ 0.000000] init_memory_mapping: 0000000100000000-00000001b0000000 [ 0.000000] 0100000000 - 01b0000000 page 2M [ 0.000000] kernel direct mapping tables up to 1b0000000 @ 14000-1c000 [ 0.000000] RAMDISK: 376d7000 - 37fefaf3 [ 0.000000] ACPI: RSDP 00000000000fbb10 00014 (v00 ACPIAM) [ 0.000000] ACPI: RSDT 00000000cff80000 00040 (v01 A_M_I_ OEMRSDT 07000901 MSFT 00000097) [ 0.000000] ACPI: FACP 00000000cff80200 00084 (v02 A_M_I_ OEMFACP 07000901 MSFT 00000097) [ 0.000000] ACPI: DSDT 00000000cff80440 08888 (v01 A1014 A1014001 00000001 INTL 20060113) [ 0.000000] ACPI: FACS 00000000cff8e000 00040 [ 0.000000] ACPI: APIC 00000000cff80390 0006C (v01 A_M_I_ OEMAPIC 07000901 MSFT 00000097) [ 0.000000] ACPI: MCFG 00000000cff80400 0003C (v01 A_M_I_ OEMMCFG 07000901 MSFT 00000097) [ 0.000000] ACPI: OEMB 00000000cff8e040 00081 (v01 A_M_I_ AMI_OEM 07000901 MSFT 00000097) [ 0.000000] ACPI: HPET 00000000cff88cd0 00038 (v01 A_M_I_ OEMHPET 07000901 MSFT 00000097) [ 0.000000] ACPI: OSFR 00000000cff88d10 000B0 (v01 A_M_I_ OEMOSFR 07000901 MSFT 00000097) [ 0.000000] ACPI: SSDT 00000000cff8e5d0 00A7C (v01 DpgPmm CpuPm 00000012 INTL 20060113) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] No NUMA configuration found [ 0.000000] Faking a node at 0000000000000000-00000001b0000000 [ 0.000000] Bootmem setup node 0 0000000000000000-00000001b0000000 [ 0.000000] NODE_DATA [0000000000017000 - 000000000001efff] [ 0.000000] bootmap [000000000001f000 - 0000000000054fff] pages 36 [ 0.000000] (8 early reservations) ==> bootmem [0000000000 - 01b0000000] [ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000] [ 0.000000] #1 [0000006000 - 0000008000] TRAMPOLINE ==> [0000006000 - 0000008000] [ 0.000000] #2 [0001000000 - 00016d95c4] TEXT DATA BSS ==> [0001000000 - 00016d95c4] [ 0.000000] #3 [00376d7000 - 0037fefaf3] RAMDISK ==> [00376d7000 - 0037fefaf3] [ 0.000000] #4 [000009cc00 - 0000100000] BIOS reserved ==> [000009cc00 - 0000100000] [ 0.000000] #5 [00016da000 - 00016da280] BRK ==> [00016da000 - 00016da280] [ 0.000000] #6 [0000010000 - 0000014000] PGTABLE ==> [0000010000 - 0000014000] [ 0.000000] #7 [0000014000 - 0000017000] PGTABLE ==> [0000014000 - 0000017000] [ 0.000000] found SMP MP-table at [ffff8800000ff780] ff780 [ 0.000000] [ffffea0000000000-ffffea0005ffffff] PMD -> [ffff880001800000-ffff880006dfffff] on node 0 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] DMA32 0x00001000 -> 0x00100000 [ 0.000000] Normal 0x00100000 -> 0x001b0000 [ 0.000000] Movable zone start PFN for each node [ 0.000000] early_node_map[3] active PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009c [ 0.000000] 0: 0x00000100 -> 0x000cff80 [ 0.000000] 0: 0x00100000 -> 0x001b0000 [ 0.000000] On node 0 totalpages: 1572620 [ 0.000000] DMA zone: 56 pages used for memmap [ 0.000000] DMA zone: 109 pages reserved [ 0.000000] DMA zone: 3815 pages, LIFO batch:0 [ 0.000000] DMA32 zone: 14280 pages used for memmap [ 0.000000] DMA32 zone: 833464 pages, LIFO batch:31 [ 0.000000] Normal zone: 9856 pages used for memmap [ 0.000000] Normal zone: 711040 pages, LIFO batch:31 [ 0.000000] ACPI: PM-Timer IO Port: 0x808 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled) [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x8086a301 base: 0xfed00000 [ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs [ 0.000000] nr_irqs_gsi: 24 [ 0.000000] PM: Registered nosave memory: 000000000009c000 - 000000000009d000 [ 0.000000] PM: Registered nosave memory: 000000000009d000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000 [ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000 [ 0.000000] PM: Registered nosave memory: 00000000cff80000 - 00000000cff8e000 [ 0.000000] PM: Registered nosave memory: 00000000cff8e000 - 00000000cffd0000 [ 0.000000] PM: Registered nosave memory: 00000000cffd0000 - 00000000d0000000 [ 0.000000] PM: Registered nosave memory: 00000000d0000000 - 00000000fee00000 [ 0.000000] PM: Registered nosave memory: 00000000fee00000 - 00000000fee01000 [ 0.000000] PM: Registered nosave memory: 00000000fee01000 - 00000000fff00000 [ 0.000000] PM: Registered nosave memory: 00000000fff00000 - 0000000100000000 [ 0.000000] Allocating PCI resources starting at d0000000 (gap: d0000000:2ee00000) [ 0.000000] Booting paravirtualized kernel on bare hardware [ 0.000000] NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 30 pages/cpu @ffff880007000000 s90328 r8192 d24360 u524288 [ 0.000000] pcpu-alloc: s90328 r8192 d24360 u524288 alloc=1*2097152 [ 0.000000] pcpu-alloc: [0] 0 1 2 3 [ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 1548319 [ 0.000000] Policy zone: Normal [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=UUID=fc27eddd-0bf9-4871-b69f-92a42e8ea3e1 ro quiet [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] xsave/xrstor: enabled xstate_bv 0x3, cntxt size 0x240 [ 0.000000] Checking aperture... [ 0.000000] No AGP bridge found [ 0.000000] Calgary: detecting Calgary via BIOS EBDA area [ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing! [ 0.000000] PCI-DMA: Using software bounce buffering for IO (SWIOTLB) [ 0.000000] Placing 64MB software IO TLB between ffff88000719e000 - ffff88000b19e000 [ 0.000000] software IO TLB at phys 0x719e000 - 0xb19e000 [ 0.000000] Memory: 6119212k/7077888k available (3083k kernel code, 787408k absent, 171268k reserved, 2048k data, 592k init) [ 0.000000] SLUB: Genslabs=14, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] NR_IRQS:4352 nr_irqs:440 [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] hpet clockevent registered [ 0.000000] Fast TSC calibration using PIT [ 0.000000] Detected 2700.148 MHz processor. [ 0.004005] Calibrating delay loop (skipped), value calculated using timer frequency.. 5400.29 BogoMIPS (lpj=10800592) [ 0.004023] Security Framework initialized [ 0.004028] SELinux: Disabled at boot. [ 0.004538] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes) [ 0.011247] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.013536] Mount-cache hash table entries: 256 [ 0.013686] Initializing cgroup subsys ns [ 0.013690] Initializing cgroup subsys cpuacct [ 0.013693] Initializing cgroup subsys devices [ 0.013695] Initializing cgroup subsys freezer [ 0.013696] Initializing cgroup subsys net_cls [ 0.013718] CPU: L1 I cache: 32K, L1 D cache: 32K [ 0.013720] CPU: L2 cache: 2048K [ 0.013723] CPU 0/0x0 -> Node 0 [ 0.013724] CPU: Physical Processor ID: 0 [ 0.013725] CPU: Processor Core ID: 0 [ 0.013728] mce: CPU supports 6 MCE banks [ 0.013735] CPU0: Thermal monitoring enabled (TM2) [ 0.013739] using mwait in idle threads. [ 0.013740] Performance Events: Core2 events, Intel PMU driver. [ 0.013745] ... version: 2 [ 0.013746] ... bit width: 40 [ 0.013748] ... generic registers: 2 [ 0.013749] ... value mask: 000000ffffffffff [ 0.013750] ... max period: 000000007fffffff [ 0.013751] ... fixed-purpose events: 3 [ 0.013752] ... event mask: 0000000700000003 [ 0.014593] ACPI: Core revision 20090903 [ 0.024059] Setting APIC routing to flat [ 0.024366] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.065348] CPU0: Intel Pentium(R) Dual-Core CPU E5400 @ 2.70GHz stepping 0a [ 0.068001] Booting processor 1 APIC 0x1 ip 0x6000 [ 0.008000] Initializing CPU#1 [ 0.008000] CPU: L1 I cache: 32K, L1 D cache: 32K [ 0.008000] CPU: L2 cache: 2048K [ 0.008000] CPU 1/0x1 -> Node 0 [ 0.008000] CPU: Physical Processor ID: 0 [ 0.008000] CPU: Processor Core ID: 1 [ 0.008000] CPU1: Thermal monitoring enabled (TM2) [ 0.152067] CPU1: Intel Pentium(R) Dual-Core CPU E5400 @ 2.70GHz stepping 0a [ 0.152073] checking TSC synchronization [CPU#0 -> CPU#1]: passed. [ 0.156019] Brought up 2 CPUs [ 0.156021] Total of 2 processors activated (10534.30 BogoMIPS). [ 0.156831] CPU0 attaching sched-domain: [ 0.156834] domain 0: span 0-1 level MC [ 0.156836] groups: group ffff88000700fbf0 cpus 0 group ffff88000708fbf0 cpus 1 [ 0.156841] CPU1 attaching sched-domain: [ 0.156843] domain 0: span 0-1 level MC [ 0.156844] groups: group ffff88000708fbf0 cpus 1 group ffff88000700fbf0 cpus 0 [ 0.156892] devtmpfs: initialized [ 0.160038] regulator: core version 0.5 [ 0.160054] NET: Registered protocol family 16 [ 0.160130] ACPI: bus type pci registered [ 0.160189] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255 [ 0.160191] PCI: Not using MMCONFIG. [ 0.160192] PCI: Using configuration type 1 for base access [ 0.160493] bio: create slab <bio-0> at 0 [ 0.160493] ACPI: EC: Look up EC in DSDT [ 0.162470] ACPI: Executed 1 blocks of module-level executable AML code [ 0.173028] ACPI: Interpreter enabled [ 0.173030] ACPI: (supports S0 S1 S3 S4 S5) [ 0.173048] ACPI: Using IOAPIC for interrupt routing [ 0.173092] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255 [ 0.175287] PCI: MCFG area at e0000000 reserved in ACPI motherboard resources [ 0.183471] PCI: Using MMCONFIG at e0000000 - efffffff [ 0.190112] ACPI Warning: Incorrect checksum in table [OEMB] - CD, should be CC (20090903/tbutils-314) [ 0.190224] ACPI: No dock devices found. [ 0.190325] ACPI: PCI Root Bridge [PCI0] (0000:00) [ 0.190419] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold [ 0.190421] pci 0000:00:01.0: PME# disabled [ 0.190480] pci 0000:00:1a.0: reg 20 io port: [0xb800-0xb81f] [ 0.190546] pci 0000:00:1a.1: reg 20 io port: [0xb880-0xb89f] [ 0.190611] pci 0000:00:1a.2: reg 20 io port: [0xbc00-0xbc1f] [ 0.190679] pci 0000:00:1a.7: reg 10 32bit mmio: [0xf9fffc00-0xf9ffffff] [ 0.190741] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold [ 0.190745] pci 0000:00:1a.7: PME# disabled [ 0.190779] pci 0000:00:1b.0: reg 10 64bit mmio: [0xf9ff8000-0xf9ffbfff] [ 0.190825] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold [ 0.190828] pci 0000:00:1b.0: PME# disabled [ 0.190893] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.190896] pci 0000:00:1c.0: PME# disabled [ 0.190964] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold [ 0.190967] pci 0000:00:1c.4: PME# disabled [ 0.191033] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold [ 0.191036] pci 0000:00:1c.5: PME# disabled [ 0.191082] pci 0000:00:1d.0: reg 20 io port: [0xb080-0xb09f] [ 0.191147] pci 0000:00:1d.1: reg 20 io port: [0xb400-0xb41f] [ 0.191213] pci 0000:00:1d.2: reg 20 io port: [0xb480-0xb49f] [ 0.191281] pci 0000:00:1d.7: reg 10 32bit mmio: [0xf9fff800-0xf9fffbff] [ 0.191343] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold [ 0.191347] pci 0000:00:1d.7: PME# disabled [ 0.191514] pci 0000:00:1f.2: reg 10 io port: [0xac00-0xac07] [ 0.191519] pci 0000:00:1f.2: reg 14 io port: [0xa880-0xa883] [ 0.191524] pci 0000:00:1f.2: reg 18 io port: [0xa800-0xa807] [ 0.191528] pci 0000:00:1f.2: reg 1c io port: [0xa480-0xa483] [ 0.191533] pci 0000:00:1f.2: reg 20 io port: [0xa400-0xa41f] [ 0.191538] pci 0000:00:1f.2: reg 24 32bit mmio: [0xf9ffe800-0xf9ffefff] [ 0.191574] pci 0000:00:1f.2: PME# supported from D3hot [ 0.191577] pci 0000:00:1f.2: PME# disabled [ 0.191602] pci 0000:00:1f.3: reg 10 64bit mmio: [0xf9fff400-0xf9fff4ff] [ 0.191613] pci 0000:00:1f.3: reg 20 io port: [0x400-0x41f] [ 0.191653] pci 0000:01:00.0: reg 10 32bit mmio: [0xfd000000-0xfdffffff] [ 0.191660] pci 0000:01:00.0: reg 14 64bit mmio pref: [0xd0000000-0xdfffffff] [ 0.191667] pci 0000:01:00.0: reg 1c 64bit mmio: [0xfa000000-0xfbffffff] [ 0.191672] pci 0000:01:00.0: reg 24 io port: [0xcc00-0xcc7f] [ 0.191676] pci 0000:01:00.0: reg 30 32bit mmio pref: [0xfe980000-0xfe9fffff] [ 0.191781] pci 0000:00:01.0: bridge io port: [0xc000-0xcfff] [ 0.191784] pci 0000:00:01.0: bridge 32bit mmio: [0xfa000000-0xfe9fffff] [ 0.191787] pci 0000:00:01.0: bridge 64bit mmio pref: [0xd0000000-0xdfffffff] [ 0.191824] pci 0000:00:1c.0: bridge 64bit mmio pref: [0xf8f00000-0xf8ffffff] [ 0.191864] pci 0000:03:00.0: reg 10 io port: [0xec00-0xec07] [ 0.191871] pci 0000:03:00.0: reg 14 io port: [0xe880-0xe883] [ 0.191878] pci 0000:03:00.0: reg 18 io port: [0xe800-0xe807] [ 0.191885] pci 0000:03:00.0: reg 1c io port: [0xe480-0xe483] [ 0.191892] pci 0000:03:00.0: reg 20 io port: [0xe400-0xe40f] [ 0.191899] pci 0000:03:00.0: reg 24 32bit mmio: [0xfebffc00-0xfebffdff] [ 0.191954] pci 0000:03:00.0: supports D1 [ 0.191956] pci 0000:03:00.0: PME# supported from D0 D1 D3hot [ 0.191960] pci 0000:03:00.0: PME# disabled [ 0.191984] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force' [ 0.192042] pci 0000:00:1c.4: bridge io port: [0xe000-0xefff] [ 0.192046] pci 0000:00:1c.4: bridge 32bit mmio: [0xfeb00000-0xfebfffff] [ 0.192098] pci 0000:02:00.0: reg 10 64bit mmio: [0xfeac0000-0xfeafffff] [ 0.192106] pci 0000:02:00.0: reg 18 io port: [0xdc00-0xdc7f] [ 0.192179] pci 0000:02:00.0: PME# supported from D3hot D3cold [ 0.192183] pci 0000:02:00.0: PME# disabled [ 0.192210] pci 0000:02:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force' [ 0.192265] pci 0000:00:1c.5: bridge io port: [0xd000-0xdfff] [ 0.192268] pci 0000:00:1c.5: bridge 32bit mmio: [0xfea00000-0xfeafffff] [ 0.192312] pci 0000:00:1e.0: transparent bridge [ 0.192336] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.192460] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P2._PRT] [ 0.192509] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT] [ 0.192600] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P8._PRT] [ 0.192646] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P9._PRT] [ 0.192710] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT] [ 0.206306] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15) [ 0.206399] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15) [ 0.206490] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 11 12 14 *15) [ 0.206581] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 10 11 12 14 15) [ 0.206672] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled. [ 0.206763] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 *14 15) [ 0.206855] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 7 10 11 12 14 15) [ 0.206946] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *7 10 11 12 14 15) [ 0.207042] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none [ 0.207045] vgaarb: loaded [ 0.207060] PCI: Using ACPI for IRQ routing [ 0.207060] HPET: 4 timers in total, 0 timers will be used for per-cpu timer [ 0.207060] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0 [ 0.207060] hpet0: 4 comparators, 64-bit 14.318180 MHz counter [ 0.212027] Switching to clocksource tsc [ 0.213048] pnp: PnP ACPI init [ 0.213058] ACPI: bus type pnp registered [ 0.215483] pnp: PnP ACPI: found 16 devices [ 0.215484] ACPI: ACPI bus type pnp unregistered [ 0.215493] system 00:01: iomem range 0xfed14000-0xfed19fff has been reserved [ 0.215499] system 00:06: ioport range 0x290-0x29f has been reserved [ 0.215503] system 00:07: ioport range 0x4d0-0x4d1 has been reserved [ 0.215505] system 00:07: ioport range 0x800-0x87f has been reserved [ 0.215507] system 00:07: ioport range 0x500-0x57f has been reserved [ 0.215509] system 00:07: iomem range 0xfed08000-0xfed08fff has been reserved [ 0.215512] system 00:07: iomem range 0xfed1c000-0xfed1ffff has been reserved [ 0.215514] system 00:07: iomem range 0xfed20000-0xfed3ffff has been reserved [ 0.215516] system 00:07: iomem range 0xfed50000-0xfed8ffff has been reserved [ 0.215520] system 00:0a: iomem range 0xffc00000-0xffefffff has been reserved [ 0.215524] system 00:0b: iomem range 0xfec00000-0xfec00fff could not be reserved [ 0.215527] system 00:0b: iomem range 0xfee00000-0xfee00fff has been reserved [ 0.215531] system 00:0e: iomem range 0xe0000000-0xefffffff has been reserved [ 0.215535] system 00:0f: iomem range 0x0-0x9ffff could not be reserved [ 0.215537] system 00:0f: iomem range 0xc0000-0xcffff could not be reserved [ 0.215540] system 00:0f: iomem range 0xe0000-0xfffff could not be reserved [ 0.215542] system 00:0f: iomem range 0x100000-0xcfffffff could not be reserved [ 0.220220] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01 [ 0.220223] pci 0000:00:01.0: IO window: 0xc000-0xcfff [ 0.220226] pci 0000:00:01.0: MEM window: 0xfa000000-0xfe9fffff [ 0.220228] pci 0000:00:01.0: PREFETCH window: 0x000000d0000000-0x000000dfffffff [ 0.220232] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:04 [ 0.220234] pci 0000:00:1c.0: IO window: 0x1000-0x1fff [ 0.220238] pci 0000:00:1c.0: MEM window: 0xf0000000-0xf03fffff [ 0.220241] pci 0000:00:1c.0: PREFETCH window: 0x000000f8f00000-0x000000f8ffffff [ 0.220246] pci 0000:00:1c.4: PCI bridge, secondary bus 0000:03 [ 0.220248] pci 0000:00:1c.4: IO window: 0xe000-0xefff [ 0.220252] pci 0000:00:1c.4: MEM window: 0xfeb00000-0xfebfffff [ 0.220255] pci 0000:00:1c.4: PREFETCH window: 0x000000f0400000-0x000000f05fffff [ 0.220260] pci 0000:00:1c.5: PCI bridge, secondary bus 0000:02 [ 0.220262] pci 0000:00:1c.5: IO window: 0xd000-0xdfff [ 0.220266] pci 0000:00:1c.5: MEM window: 0xfea00000-0xfeafffff [ 0.220269] pci 0000:00:1c.5: PREFETCH window: 0x000000f0600000-0x000000f07fffff [ 0.220274] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:05 [ 0.220275] pci 0000:00:1e.0: IO window: disabled [ 0.220279] pci 0000:00:1e.0: MEM window: disabled [ 0.220282] pci 0000:00:1e.0: PREFETCH window: disabled [ 0.220291] alloc irq_desc for 16 on node -1 [ 0.220293] alloc kstat_irqs on node -1 [ 0.220297] pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 0.220300] pci 0000:00:01.0: setting latency timer to 64 [ 0.220306] pci 0000:00:1c.0: enabling device (0106 -> 0107) [ 0.220309] alloc irq_desc for 17 on node -1 [ 0.220310] alloc kstat_irqs on node -1 [ 0.220313] pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17 [ 0.220316] pci 0000:00:1c.0: setting latency timer to 64 [ 0.220322] pci 0000:00:1c.4: PCI INT A -> GSI 17 (level, low) -> IRQ 17 [ 0.220325] pci 0000:00:1c.4: setting latency timer to 64 [ 0.220331] pci 0000:00:1c.5: PCI INT B -> GSI 16 (level, low) -> IRQ 16 [ 0.220334] pci 0000:00:1c.5: setting latency timer to 64 [ 0.220339] pci 0000:00:1e.0: setting latency timer to 64 [ 0.220342] pci_bus 0000:00: resource 0 io: [0x00-0xffff] [ 0.220344] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffffffffffff] [ 0.220346] pci_bus 0000:01: resource 0 io: [0xc000-0xcfff] [ 0.220348] pci_bus 0000:01: resource 1 mem: [0xfa000000-0xfe9fffff] [ 0.220350] pci_bus 0000:01: resource 2 pref mem [0xd0000000-0xdfffffff] [ 0.220352] pci_bus 0000:04: resource 0 io: [0x1000-0x1fff] [ 0.220353] pci_bus 0000:04: resource 1 mem: [0xf0000000-0xf03fffff] [ 0.220355] pci_bus 0000:04: resource 2 pref mem [0xf8f00000-0xf8ffffff] [ 0.220357] pci_bus 0000:03: resource 0 io: [0xe000-0xefff] [ 0.220358] pci_bus 0000:03: resource 1 mem: [0xfeb00000-0xfebfffff] [ 0.220360] pci_bus 0000:03: resource 2 pref mem [0xf0400000-0xf05fffff] [ 0.220362] pci_bus 0000:02: resource 0 io: [0xd000-0xdfff] [ 0.220364] pci_bus 0000:02: resource 1 mem: [0xfea00000-0xfeafffff] [ 0.220365] pci_bus 0000:02: resource 2 pref mem [0xf0600000-0xf07fffff] [ 0.220367] pci_bus 0000:05: resource 3 io: [0x00-0xffff] [ 0.220369] pci_bus 0000:05: resource 4 mem: [0x000000-0xffffffffffffffff] [ 0.220394] NET: Registered protocol family 2 [ 0.220592] IP route cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.221967] TCP established hash table entries: 524288 (order: 11, 8388608 bytes) [ 0.226569] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes) [ 0.227143] TCP: Hash tables configured (established 524288 bind 65536) [ 0.227146] TCP reno registered [ 0.227262] NET: Registered protocol family 1 [ 0.227291] pci 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 0.227307] pci 0000:00:1a.0: PCI INT A disabled [ 0.227314] alloc irq_desc for 21 on node -1 [ 0.227316] alloc kstat_irqs on node -1 [ 0.227324] pci 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21 [ 0.227338] pci 0000:00:1a.1: PCI INT B disabled [ 0.227343] alloc irq_desc for 18 on node -1 [ 0.227344] alloc kstat_irqs on node -1 [ 0.227347] pci 0000:00:1a.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 0.227361] pci 0000:00:1a.2: PCI INT C disabled [ 0.227370] pci 0000:00:1a.7: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 0.227397] pci 0000:00:1a.7: PCI INT C disabled [ 0.227407] alloc irq_desc for 23 on node -1 [ 0.227408] alloc kstat_irqs on node -1 [ 0.227411] pci 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23 [ 0.227425] pci 0000:00:1d.0: PCI INT A disabled [ 0.227431] alloc irq_desc for 19 on node -1 [ 0.227432] alloc kstat_irqs on node -1 [ 0.227434] pci 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19 [ 0.227448] pci 0000:00:1d.1: PCI INT B disabled [ 0.227454] pci 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 0.227468] pci 0000:00:1d.2: PCI INT C disabled [ 0.227477] pci 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23 [ 0.227494] pci 0000:00:1d.7: PCI INT A disabled [ 0.227510] pci 0000:01:00.0: Boot video device [ 0.227562] Unpacking initramfs... [ 0.401182] Freeing initrd memory: 9314k freed [ 0.405485] audit: initializing netlink socket (disabled) [ 0.405499] type=2000 audit(1338110366.403:1): initialized [ 0.408257] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 0.409319] VFS: Disk quotas dquot_6.5.2 [ 0.409358] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.409423] msgmni has been set to 11969 [ 0.409568] alg: No test for stdrng (krng) [ 0.409607] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.409609] io scheduler noop registered [ 0.409611] io scheduler anticipatory registered [ 0.409612] io scheduler deadline registered [ 0.409654] io scheduler cfq registered (default) [ 0.409744] alloc irq_desc for 24 on node -1 [ 0.409746] alloc kstat_irqs on node -1 [ 0.409755] pcieport 0000:00:01.0: irq 24 for MSI/MSI-X [ 0.409760] pcieport 0000:00:01.0: setting latency timer to 64 [ 0.409836] alloc irq_desc for 25 on node -1 [ 0.409838] alloc kstat_irqs on node -1 [ 0.409843] pcieport 0000:00:1c.0: irq 25 for MSI/MSI-X [ 0.409849] pcieport 0000:00:1c.0: setting latency timer to 64 [ 0.409940] alloc irq_desc for 26 on node -1 [ 0.409941] alloc kstat_irqs on node -1 [ 0.409947] pcieport 0000:00:1c.4: irq 26 for MSI/MSI-X [ 0.409953] pcieport 0000:00:1c.4: setting latency timer to 64 [ 0.410042] alloc irq_desc for 27 on node -1 [ 0.410043] alloc kstat_irqs on node -1 [ 0.410048] pcieport 0000:00:1c.5: irq 27 for MSI/MSI-X [ 0.410054] pcieport 0000:00:1c.5: setting latency timer to 64 [ 0.411227] Linux agpgart interface v0.103 [ 0.411267] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.411351] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 0.411652] 00:0d: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 0.411745] input: Macintosh mouse button emulation as /devices/virtual/input/input0 [ 0.411789] PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1 [ 0.411790] PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp [ 0.412267] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 0.412319] mice: PS/2 mouse device common for all mice [ 0.412347] rtc_cmos 00:03: RTC can wake from S4 [ 0.412376] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0 [ 0.412398] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs [ 0.412408] cpuidle: using governor ladder [ 0.412409] cpuidle: using governor menu [ 0.412413] No iBFT detected. [ 0.412650] TCP cubic registered [ 0.412730] NET: Registered protocol family 10 [ 0.413276] Mobile IPv6 [ 0.413278] NET: Registered protocol family 17 [ 0.413335] PM: Resume from disk failed. [ 0.413350] registered taskstats version 1 [ 0.413683] rtc_cmos 00:03: setting system clock to 2012-05-27 09:19:27 UTC (1338110367) [ 0.413716] Initalizing network drop monitor service [ 0.413737] Freeing unused kernel memory: 592k freed [ 0.413923] Write protecting the kernel read-only data: 4240k [ 0.424592] udev[56]: starting version 164 [ 0.434899] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1 [ 0.503692] usbcore: registered new interface driver usbfs [ 0.503870] usbcore: registered new interface driver hub [ 0.503984] usbcore: registered new device driver usb [ 0.505128] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.505155] ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 0.505181] ehci_hcd 0000:00:1a.7: setting latency timer to 64 [ 0.505184] ehci_hcd 0000:00:1a.7: EHCI Host Controller [ 0.505203] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1 [ 0.505242] ehci_hcd 0000:00:1a.7: debug port 1 [ 0.506785] ATL1E 0000:02:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17 [ 0.506795] ATL1E 0000:02:00.0: setting latency timer to 64 [ 0.509131] ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported [ 0.509204] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xf9fffc00 [ 0.516930] SCSI subsystem initialized [ 0.527048] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00 [ 0.527082] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.527084] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.527086] usb usb1: Product: EHCI Host Controller [ 0.527088] usb usb1: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd [ 0.527089] usb usb1: SerialNumber: 0000:00:1a.7 [ 0.527187] usb usb1: configuration #1 chosen from 1 choice [ 0.527211] hub 1-0:1.0: USB hub found [ 0.527221] hub 1-0:1.0: 6 ports detected [ 0.527283] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23 [ 0.527312] ehci_hcd 0000:00:1d.7: setting latency timer to 64 [ 0.527315] ehci_hcd 0000:00:1d.7: EHCI Host Controller [ 0.527322] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2 [ 0.527357] ehci_hcd 0000:00:1d.7: debug port 1 [ 0.528778] libata version 3.00 loaded. [ 0.529536] pata_marvell 0000:03:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 0.529562] pata_marvell 0000:03:00.0: setting latency timer to 64 [ 0.529693] scsi0 : pata_marvell [ 0.529788] scsi1 : pata_marvell [ 0.529822] ata1: PATA max UDMA/100 cmd 0xec00 ctl 0xe880 bmdma 0xe400 irq 16 [ 0.529824] ata2: DUMMY [ 0.531254] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported [ 0.531268] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf9fff800 [ 0.543881] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00 [ 0.543913] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.543917] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.543921] usb usb2: Product: EHCI Host Controller [ 0.543924] usb usb2: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd [ 0.543927] usb usb2: SerialNumber: 0000:00:1d.7 [ 0.544022] usb usb2: configuration #1 chosen from 1 choice [ 0.544048] hub 2-0:1.0: USB hub found [ 0.544054] hub 2-0:1.0: 6 ports detected [ 0.544099] ahci 0000:00:1f.2: version 3.0 [ 0.544113] ahci 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19 [ 0.544180] alloc irq_desc for 28 on node -1 [ 0.544182] alloc kstat_irqs on node -1 [ 0.544190] ahci 0000:00:1f.2: irq 28 for MSI/MSI-X [ 0.544230] ahci: SSS flag set, parallel bus scan disabled [ 0.544259] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl SATA mode [ 0.544262] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pmp pio slum part ccc ems sxs [ 0.544266] ahci 0000:00:1f.2: setting latency timer to 64 [ 0.583817] scsi2 : ahci [ 0.583936] scsi3 : ahci [ 0.583992] scsi4 : ahci [ 0.584039] scsi5 : ahci [ 0.584085] scsi6 : ahci [ 0.584129] scsi7 : ahci [ 0.584273] ata3: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffe900 irq 28 [ 0.584276] ata4: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffe980 irq 28 [ 0.584278] ata5: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffea00 irq 28 [ 0.584280] ata6: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffea80 irq 28 [ 0.584282] ata7: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffeb00 irq 28 [ 0.584285] ata8: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffeb80 irq 28 [ 0.609043] uhci_hcd: USB Universal Host Controller Interface driver [ 0.609088] uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 0.609097] uhci_hcd 0000:00:1a.0: setting latency timer to 64 [ 0.609099] uhci_hcd 0000:00:1a.0: UHCI Host Controller [ 0.609119] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3 [ 0.609147] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000b800 [ 0.609185] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.609187] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.609189] usb usb3: Product: UHCI Host Controller [ 0.609190] usb usb3: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd [ 0.609192] usb usb3: SerialNumber: 0000:00:1a.0 [ 0.609287] usb usb3: configuration #1 chosen from 1 choice [ 0.609333] hub 3-0:1.0: USB hub found [ 0.609340] hub 3-0:1.0: 2 ports detected [ 0.609383] uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21 [ 0.609390] uhci_hcd 0000:00:1a.1: setting latency timer to 64 [ 0.609393] uhci_hcd 0000:00:1a.1: UHCI Host Controller [ 0.609399] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4 [ 0.609430] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000b880 [ 0.609459] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.609461] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.609463] usb usb4: Product: UHCI Host Controller [ 0.609464] usb usb4: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd [ 0.609466] usb usb4: SerialNumber: 0000:00:1a.1 [ 0.609535] usb usb4: configuration #1 chosen from 1 choice [ 0.609580] hub 4-0:1.0: USB hub found [ 0.609586] hub 4-0:1.0: 2 ports detected [ 0.609625] uhci_hcd 0000:00:1a.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 0.609632] uhci_hcd 0000:00:1a.2: setting latency timer to 64 [ 0.609634] uhci_hcd 0000:00:1a.2: UHCI Host Controller [ 0.609639] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5 [ 0.609660] uhci_hcd 0000:00:1a.2: irq 18, io base 0x0000bc00 [ 0.609686] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.609688] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.609689] usb usb5: Product: UHCI Host Controller [ 0.609690] usb usb5: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd [ 0.609692] usb usb5: SerialNumber: 0000:00:1a.2 [ 0.609735] usb usb5: configuration #1 chosen from 1 choice [ 0.609754] hub 5-0:1.0: USB hub found [ 0.609759] hub 5-0:1.0: 2 ports detected [ 0.609796] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23 [ 0.609802] uhci_hcd 0000:00:1d.0: setting latency timer to 64 [ 0.609804] uhci_hcd 0000:00:1d.0: UHCI Host Controller [ 0.609810] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6 [ 0.609829] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000b080 [ 0.609857] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.609859] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.609861] usb usb6: Product: UHCI Host Controller [ 0.609862] usb usb6: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd [ 0.609864] usb usb6: SerialNumber: 0000:00:1d.0 [ 0.609905] usb usb6: configuration #1 chosen from 1 choice [ 0.609925] hub 6-0:1.0: USB hub found [ 0.609931] hub 6-0:1.0: 2 ports detected [ 0.609964] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19 [ 0.609970] uhci_hcd 0000:00:1d.1: setting latency timer to 64 [ 0.609972] uhci_hcd 0000:00:1d.1: UHCI Host Controller [ 0.609977] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7 [ 0.610003] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000b400 [ 0.610028] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.610030] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.610031] usb usb7: Product: UHCI Host Controller [ 0.610033] usb usb7: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd [ 0.610034] usb usb7: SerialNumber: 0000:00:1d.1 [ 0.610075] usb usb7: configuration #1 chosen from 1 choice [ 0.610095] hub 7-0:1.0: USB hub found [ 0.610100] hub 7-0:1.0: 2 ports detected [ 0.610136] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 0.610142] uhci_hcd 0000:00:1d.2: setting latency timer to 64 [ 0.610144] uhci_hcd 0000:00:1d.2: UHCI Host Controller [ 0.610149] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8 [ 0.610171] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000b480 [ 0.610195] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.610197] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.610199] usb usb8: Product: UHCI Host Controller [ 0.610200] usb usb8: Manufacturer: Linux 2.6.32-5-amd64 uhci_hcd [ 0.610201] usb usb8: SerialNumber: 0000:00:1d.2 [ 0.610243] usb usb8: configuration #1 chosen from 1 choice [ 0.610286] hub 8-0:1.0: USB hub found [ 0.610292] hub 8-0:1.0: 2 ports detected [ 0.692006] ata1.00: ATAPI: TDK DVDRW1616N, 2.79, max UDMA/33 [ 0.708032] ata1.00: configured for UDMA/33 [ 0.709158] scsi 0:0:0:0: CD-ROM TDK DVDRW1616N 2.79 PQ: 0 ANSI: 5 [ 0.891389] usb 2-3: new high speed USB device using ehci_hcd and address 2 [ 1.068016] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 1.069020] ata3.00: ATA-8: ST3160316CS, SC13, max UDMA/133 [ 1.069025] ata3.00: 312581808 sectors, multi 0: LBA48 NCQ (depth 31/32) [ 1.070240] ata3.00: configured for UDMA/133 [ 1.084160] scsi 2:0:0:0: Direct-Access ATA ST3160316CS SC13 PQ: 0 ANSI: 5 [ 1.172439] usb 2-3: New USB device found, idVendor=1307, idProduct=0330 [ 1.172443] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 1.172447] usb 2-3: Product: Mass Storage Device [ 1.172450] usb 2-3: Manufacturer: Generic [ 1.172453] usb 2-3: SerialNumber: 00000000000006 [ 1.172551] usb 2-3: configuration #1 chosen from 1 choice [ 1.177389] Initializing USB Mass Storage driver... [ 1.177484] scsi8 : SCSI emulation for USB Mass Storage devices [ 1.177552] usbcore: registered new interface driver usb-storage [ 1.177554] USB Mass Storage support registered. [ 1.177558] usb-storage: device found at 2 [ 1.177559] usb-storage: waiting for device to settle before scanning [ 1.404019] ata4: SATA link down (SStatus 0 SControl 300) [ 1.468012] usb 4-2: new low speed USB device using uhci_hcd and address 2 [ 1.646447] usb 4-2: New USB device found, idVendor=06a3, idProduct=ff0c [ 1.646451] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 1.646455] usb 4-2: Product: Cyborg Force Rumble Pad [ 1.646458] usb 4-2: Manufacturer: Saitek PLC [ 1.646563] usb 4-2: configuration #1 chosen from 1 choice [ 1.888018] usb 7-2: new low speed USB device using uhci_hcd and address 2 [ 2.065009] usb 7-2: New USB device found, idVendor=046d, idProduct=c00e [ 2.065014] usb 7-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.065018] usb 7-2: Product: USB-PS/2 Optical Mouse [ 2.065021] usb 7-2: Manufacturer: Logitech [ 2.065128] usb 7-2: configuration #1 chosen from 1 choice [ 2.308017] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 2.308521] ata5.00: ATAPI: TSSTcorp CDDVDW SH-S223B, SB01, max UDMA/100 [ 2.309306] ata5.00: configured for UDMA/100 [ 2.324595] scsi 4:0:0:0: CD-ROM TSSTcorp CDDVDW SH-S223B SB01 PQ: 0 ANSI: 5 [ 3.840020] ata6: SATA link down (SStatus 0 SControl 300) [ 3.856098] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen [ 3.856146] ata6: irq_stat 0x00000040, connection status changed [ 3.856191] ata6: SError: { CommWake DevExch } [ 3.856237] ata6: hard resetting link [ 4.176015] ata7: SATA link down (SStatus 0 SControl 300) [ 4.512017] ata8: SATA link down (SStatus 0 SControl 300) [ 4.534768] usbcore: registered new interface driver hiddev [ 4.542151] sr0: scsi3-mmc drive: 48x/48x writer cd/rw xa/form2 cdda tray [ 4.542156] Uniform CD-ROM driver Revision: 3.20 [ 4.542305] sr 0:0:0:0: Attached scsi CD-ROM sr0 [ 4.542456] sd 2:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB) [ 4.542506] sd 2:0:0:0: [sda] Write Protect is off [ 4.542508] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 4.542527] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 4.542643] sda:sr1: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray [ 4.545672] sr 4:0:0:0: Attached scsi CD-ROM sr1 [ 4.558789] sda1 sda2 < sda5 sda6 > [ 4.580305] sd 2:0:0:0: [sda] Attached SCSI disk [ 4.583865] sr 0:0:0:0: Attached scsi generic sg0 type 5 [ 4.584664] sd 2:0:0:0: Attached scsi generic sg1 type 0 [ 4.584691] sr 4:0:0:0: Attached scsi generic sg2 type 5 [ 4.637497] input: Saitek PLC Cyborg Force Rumble Pad as /devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.0/input/input2 [ 4.637572] generic-usb 0003:06A3:FF0C.0001: input,hidraw0: USB HID v1.10 Joystick [Saitek PLC Cyborg Force Rumble Pad] on usb-0000:00:1a.1-2/input0 [ 4.650232] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:1d.1/usb7/7-2/7-2:1.0/input/input3 [ 4.650295] generic-usb 0003:046D:C00E.0002: input,hidraw1: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1d.1-2/input0 [ 4.650318] usbcore: registered new interface driver usbhid [ 4.650320] usbhid: v2.6:USB HID core driver [ 4.946418] device-mapper: uevent: version 1.0.3 [ 4.946585] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com [ 5.145513] PM: Starting manual resume from disk [ 5.145516] PM: Resume from partition 8:5 [ 5.145517] PM: Checking hibernation image. [ 5.171763] PM: Error -22 checking image file [ 5.171767] PM: Resume from disk failed. [ 5.244241] EXT4-fs (sda1): mounted filesystem with ordered data mode [ 5.796030] ata6: SATA link down (SStatus 0 SControl 300) [ 5.796041] ata6: EH complete [ 5.824992] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen [ 5.825040] ata6: irq_stat 0x00000040, connection status changed [ 5.825085] ata6: SError: { CommWake DevExch } [ 5.825136] ata6: limiting SATA link speed to 1.5 Gbps [ 5.825141] ata6: hard resetting link [ 6.176131] usb-storage: device scan complete [ 6.176624] scsi 8:0:0:0: Direct-Access Generic USB CF Reader 0.00 PQ: 0 ANSI: 2 [ 6.177120] scsi 8:0:0:1: Direct-Access Generic USB SD Reader 0.00 PQ: 0 ANSI: 2 [ 6.177619] scsi 8:0:0:2: Direct-Access Generic USB MS Reader 0.00 PQ: 0 ANSI: 2 [ 6.178117] scsi 8:0:0:3: Direct-Access Generic USB SM Reader 0.00 PQ: 0 ANSI: 2 [ 6.178435] sd 8:0:0:0: Attached scsi generic sg3 type 0 [ 6.178550] sd 8:0:0:1: Attached scsi generic sg4 type 0 [ 6.178649] sd 8:0:0:2: Attached scsi generic sg5 type 0 [ 6.178753] sd 8:0:0:3: Attached scsi generic sg6 type 0 [ 6.180848] sd 8:0:0:1: [sdc] Attached SCSI removable disk [ 6.182098] sd 8:0:0:0: [sdb] Attached SCSI removable disk [ 6.182722] sd 8:0:0:2: [sdd] Attached SCSI removable disk [ 6.183347] sd 8:0:0:3: [sde] Attached SCSI removable disk [ 7.190997] udev[491]: starting version 164 [ 7.487483] input: PC Speaker as /devices/platform/pcspkr/input/input4 [ 7.515513] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5 [ 7.515519] ACPI: Power Button [PWRB] [ 7.515564] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6 [ 7.515567] ACPI: Power Button [PWRF] [ 7.533269] ACPI: SSDT 00000000cff8e0d0 00277 (v01 DpgPmm P001Ist 00000011 INTL 20060113) [ 7.533494] processor LNXCPU:00: registered as cooling_device0 [ 7.534183] ACPI: SSDT 00000000cff8e350 00277 (v01 DpgPmm P002Ist 00000012 INTL 20060113) [ 7.534393] processor LNXCPU:01: registered as cooling_device1 [ 7.735182] i801_smbus 0000:00:1f.3: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 7.735187] ACPI: I/O resource 0000:00:1f.3 [0x400-0x41f] conflicts with ACPI region SMRG [0x400-0x40f] [ 7.735231] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 8.276535] ata6: SATA link down (SStatus 0 SControl 310) [ 8.276546] ata6: EH complete [ 8.310034] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 8.310084] ata6: irq_stat 0x00000040, connection status changed [ 8.310129] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 8.310181] ata6: limiting SATA link speed to 1.5 Gbps [ 8.310186] ata6: hard resetting link [ 8.778126] nvidia: module license 'NVIDIA' taints kernel. [ 8.778130] Disabling lock debugging due to kernel taint [ 8.907048] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 8.907057] nvidia 0000:01:00.0: setting latency timer to 64 [ 8.907061] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem [ 8.907419] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 290.10 Wed Nov 16 17:39:29 PST 2011 [ 9.477577] alloc irq_desc for 22 on node -1 [ 9.477579] alloc kstat_irqs on node -1 [ 9.477586] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22 [ 9.477626] HDA Intel 0000:00:1b.0: setting latency timer to 64 [ 9.576571] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input7 [ 10.363442] Adding 9804792k swap on /dev/sda5. Priority:-1 extents:1 across:9804792k [ 10.826724] loop: module loaded [ 10.923599] w83627ehf: Found W83667HG chip at 0x290 [ 10.923662] ACPI: I/O resource w83627ehf [0x295-0x296] conflicts with ACPI region HWRE [0x290-0x299] [ 10.923725] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 11.292519] ata6: SATA link down (SStatus 0 SControl 310) [ 11.292531] ata6: EH complete [ 11.324953] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 11.325022] ata6: irq_stat 0x00000040, connection status changed [ 11.325076] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 11.325139] ata6: limiting SATA link speed to 1.5 Gbps [ 11.325142] ata6: hard resetting link [ 12.328031] ata6: SATA link down (SStatus 0 SControl 310) [ 12.328042] ata6: EH complete [ 12.344559] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 12.344626] ata6: irq_stat 0x00000040, connection status changed [ 12.344680] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 12.344739] ata6: limiting SATA link speed to 1.5 Gbps [ 12.344747] ata6: hard resetting link [ 14.316521] ata6: SATA link down (SStatus 0 SControl 310) [ 14.316532] ata6: EH complete [ 14.350756] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 14.350822] ata6: irq_stat 0x00000040, connection status changed [ 14.350875] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 14.350935] ata6: limiting SATA link speed to 1.5 Gbps [ 14.350944] ata6: hard resetting link [ 16.320030] ata6: SATA link down (SStatus 0 SControl 310) [ 16.320041] ata6: EH complete [ 16.352424] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 16.352489] ata6: irq_stat 0x00000040, connection status changed [ 16.352549] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 16.352609] ata6: limiting SATA link speed to 1.5 Gbps [ 16.352619] ata6: hard resetting link [ 18.324021] ata6: SATA link down (SStatus 0 SControl 310) [ 18.324032] ata6: EH complete [ 18.362689] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 18.362755] ata6: irq_stat 0x00000040, connection status changed [ 18.362809] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 18.362868] ata6: limiting SATA link speed to 1.5 Gbps [ 18.362878] ata6: hard resetting link [ 20.300021] ata6: SATA link down (SStatus 0 SControl 310) [ 20.300033] ata6: EH complete [ 20.336031] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 20.336097] ata6: irq_stat 0x00000040, connection status changed [ 20.336151] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 20.336210] ata6: limiting SATA link speed to 1.5 Gbps [ 20.336219] ata6: hard resetting link [ 22.812022] ata6: SATA link down (SStatus 0 SControl 310) [ 22.812033] ata6: EH complete [ 22.832830] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 22.832897] ata6: irq_stat 0x00000040, connection status changed [ 22.832950] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 22.833010] ata6: limiting SATA link speed to 1.5 Gbps [ 22.833018] ata6: hard resetting link [ 25.332028] ata6: SATA link down (SStatus 0 SControl 310) [ 25.332038] ata6: EH complete [ 25.358145] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 25.358212] ata6: irq_stat 0x00000040, connection status changed [ 25.358265] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 25.358325] ata6: limiting SATA link speed to 1.5 Gbps [ 25.358334] ata6: hard resetting link [ 26.872029] ata6: SATA link down (SStatus 0 SControl 310) [ 26.872040] ata6: EH complete [ 26.884962] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 26.885028] ata6: irq_stat 0x00000040, connection status changed [ 26.885082] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 26.885141] ata6: limiting SATA link speed to 1.5 Gbps [ 26.885150] ata6: hard resetting link [ 28.880028] ata6: SATA link down (SStatus 0 SControl 310) [ 28.880039] ata6: EH complete [ 28.917166] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 28.917232] ata6: irq_stat 0x00000040, connection status changed [ 28.917286] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 28.917346] ata6: limiting SATA link speed to 1.5 Gbps [ 28.917355] ata6: hard resetting link [ 31.872032] ata6: SATA link down (SStatus 0 SControl 310) [ 31.872043] ata6: EH complete [ 31.893851] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 31.893918] ata6: irq_stat 0x00000040, connection status changed [ 31.893971] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 31.894032] ata6: limiting SATA link speed to 1.5 Gbps [ 31.894040] ata6: hard resetting link [ 33.352023] ata6: SATA link down (SStatus 0 SControl 310) [ 33.352035] ata6: EH complete [ 33.378268] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 33.378334] ata6: irq_stat 0x00000040, connection status changed [ 33.378387] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 33.378447] ata6: limiting SATA link speed to 1.5 Gbps [ 33.378457] ata6: hard resetting link [ 35.372029] ata6: SATA link down (SStatus 0 SControl 310) [ 35.372040] ata6: EH complete [ 35.384950] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 35.385016] ata6: irq_stat 0x00000040, connection status changed [ 35.385072] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 35.385123] ata6: limiting SATA link speed to 1.5 Gbps [ 35.385126] ata6: hard resetting link [ 37.356522] ata6: SATA link down (SStatus 0 SControl 310) [ 37.356533] ata6: EH complete [ 37.382591] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 37.382657] ata6: irq_stat 0x00000040, connection status changed [ 37.382711] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 37.382776] ata6: limiting SATA link speed to 1.5 Gbps [ 37.382779] ata6: hard resetting link [ 39.856515] ata6: SATA link down (SStatus 0 SControl 310) [ 39.856526] ata6: EH complete [ 39.887989] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 39.888057] ata6: irq_stat 0x00000040, connection status changed [ 39.888110] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 39.888175] ata6: limiting SATA link speed to 1.5 Gbps [ 39.888177] ata6: hard resetting link [ 41.400021] ata6: SATA link down (SStatus 0 SControl 310) [ 41.400032] ata6: EH complete [ 41.406071] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 41.406137] ata6: irq_stat 0x00000040, connection status changed [ 41.406191] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 41.406251] ata6: limiting SATA link speed to 1.5 Gbps [ 41.406260] ata6: hard resetting link [ 43.848019] ata6: SATA link down (SStatus 0 SControl 310) [ 43.848030] ata6: EH complete [ 43.877912] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 43.877978] ata6: irq_stat 0x00000040, connection status changed [ 43.878032] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 43.878092] ata6: limiting SATA link speed to 1.5 Gbps [ 43.878100] ata6: hard resetting link [ 45.840028] ata6: SATA link down (SStatus 0 SControl 310) [ 45.840039] ata6: EH complete [ 45.869692] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 45.869758] ata6: irq_stat 0x00000040, connection status changed [ 45.869812] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 45.869871] ata6: limiting SATA link speed to 1.5 Gbps [ 45.869881] ata6: hard resetting link [ 47.864027] ata6: SATA link down (SStatus 0 SControl 310) [ 47.864037] ata6: EH complete [ 47.893629] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 47.893695] ata6: irq_stat 0x00000040, connection status changed [ 47.893749] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 47.893809] ata6: limiting SATA link speed to 1.5 Gbps [ 47.893818] ata6: hard resetting link [ 49.888022] ata6: SATA link down (SStatus 0 SControl 310) [ 49.888034] ata6: EH complete [ 49.908985] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 49.909050] ata6: irq_stat 0x00000040, connection status changed [ 49.909106] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 49.909157] ata6: limiting SATA link speed to 1.5 Gbps [ 49.909160] ata6: hard resetting link [ 52.360044] ata6: COMRESET failed (errno=-32) [ 52.360099] ata6: reset failed (errno=-32), retrying in 8 secs [ 58.527223] kjournald starting. Commit interval 5 seconds [ 58.527417] EXT3 FS on sda6, internal journal [ 58.527423] EXT3-fs: mounted filesystem with ordered data mode. [ 59.420495] fuse init (API version 7.13) [ 59.908013] ata6: hard resetting link [ 61.968027] ata6: SATA link down (SStatus 0 SControl 310) [ 61.968038] ata6: EH complete [ 61.968362] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 61.968426] ata6: irq_stat 0x00000040, connection status changed [ 61.968479] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 61.968539] ata6: limiting SATA link speed to 1.5 Gbps [ 61.968544] ata6: hard resetting link [ 62.371194] alloc irq_desc for 29 on node -1 [ 62.371197] alloc kstat_irqs on node -1 [ 62.371212] ATL1E 0000:02:00.0: irq 29 for MSI/MSI-X [ 62.371331] ATL1E 0000:02:00.0: ATL1E: eth0 NIC Link is Up<100 Mbps Full Duplex> [ 62.372267] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 62.373052] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 63.908032] ata6: SATA link down (SStatus 0 SControl 310) [ 63.908043] ata6: EH complete [ 63.935186] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 63.935253] ata6: irq_stat 0x00000040, connection status changed [ 63.935307] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 63.935371] ata6: limiting SATA link speed to 1.5 Gbps [ 63.935374] ata6: hard resetting link [ 66.384023] ata6: SATA link down (SStatus 0 SControl 310) [ 66.384034] ata6: EH complete [ 66.401486] ata6: exception Emask 0x10 SAct 0x0 SErr 0x4050002 action 0xe frozen [ 66.401489] ata6: irq_stat 0x00000040, connection status changed [ 66.401492] ata6: SError: { RecovComm PHYRdyChg CommWake DevExch } [ 66.401499] ata6: limiting SATA link speed to 1.5 Gbps [ 66.401502] ata6: hard resetting link [ 66.420231] Bluetooth: Core ver 2.15 [ 66.420534] NET: Registered protocol family 31 [ 66.420535] Bluetooth: HCI device and connection manager initialized [ 66.420537] Bluetooth: HCI socket layer initialized [ 66.562818] Bluetooth: L2CAP ver 2.14 [ 66.562820] Bluetooth: L2CAP socket layer initialized [ 66.723822] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 66.723824] Bluetooth: BNEP filters: protocol multicast [ 66.782676] Bridge firewalling registered
le disque en question est en ext3 fait 250go et contient uniquement mes données perso. J’ai eu le même problème avec mon disque de 500go en ext4 qui est maintenant débranché faute de solutions trouvées.
le /var/log/boot
Sun May 27 11:19:37 2012: Setting parameters of disc: (none). Sun May 27 11:19:37 2012: Setting preliminary keymap...done. Sun May 27 11:19:37 2012: Activating swap...done. Sun May 27 11:19:37 2012: Checking root file system...fsck from util-linux-ng 2.17.2 Sun May 27 11:19:37 2012: /dev/sda1: clean, 179903/7331840 files, 1940236/29296875 blocks (check in 3 mounts) Sun May 27 11:19:37 2012: done. Sun May 27 11:19:37 2012: Cleaning up ifupdown.... Sun May 27 11:19:37 2012: Loading kernel modules...done. Sun May 27 11:19:38 2012: Activating lvm and md swap...done. Sun May 27 11:19:38 2012: Checking file systems...fsck from util-linux-ng 2.17.2 Sun May 27 11:19:38 2012: /dev/sda6 has been mounted 24 times without being checked, check forced. Sun May 27 11:19:38 2012: /dev/sda6: 15591/1831424 files (7.3% non-contiguous), 2857022/7324160 blocks % Sun May 27 11:20:25 2012: done. Sun May 27 11:20:25 2012: Setting up networking.... Sun May 27 11:20:25 2012: Mounting local filesystems...mount: special device /dev/sdb1 does not exist Sun May 27 11:20:25 2012: ^[[31mfailed.^[[39;49m Sun May 27 11:20:25 2012: Activating swapfile swap...done. Sun May 27 11:20:25 2012: Cleaning up temporary files.... Sun May 27 11:20:25 2012: Configuring network interfaces...done. Sun May 27 11:20:26 2012: Starting portmap daemon.... Sun May 27 11:20:26 2012: Starting NFS common utilities: statd. Sun May 27 11:20:26 2012: Cleaning up temporary files.... Sun May 27 11:20:26 2012: Setting up ALSA...done. Sun May 27 11:20:26 2012: Setting console screen modes. Sun May 27 11:20:26 2012: ^[]R^[[9;30]^[[14;30]Skipping font and keymap setup (handled by console-setup). Sun May 27 11:20:26 2012: Setting up console font and keymap...done. Sun May 27 11:20:26 2012: Setting kernel variables ...done. Sun May 27 11:20:27 2012: Setting sensors limits. Sun May 27 11:20:27 2012: INIT: Entering runlevel: 2 Sun May 27 11:20:27 2012: Using makefile-style concurrent boot in runlevel 2. Sun May 27 11:20:27 2012: Starting portmap daemon...Already running.. Sun May 27 11:20:27 2012: Starting NFS common utilities: statd. Sun May 27 11:20:27 2012: Starting enhanced syslogd: rsyslogd. Sun May 27 11:20:28 2012: Enabling additional executable binary formats: binfmt-support. Sun May 27 11:20:28 2012: Starting system message bus: dbus. Sun May 27 11:20:28 2012: Starting network connection manager: NetworkManager. Sun May 27 11:20:29 2012: Starting GNOME Display Manager: gdm3. Sun May 27 11:20:31 2012: Starting ACPI services.... Sun May 27 11:20:31 2012: Starting anac(h)ronistic cron: anacron. Sun May 27 11:20:32 2012: Starting deferred execution scheduler: atd. Sun May 27 11:20:32 2012: Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon. Sun May 27 11:20:33 2012: Starting bluetooth: bluetoothd. Sun May 27 11:20:35 2012: Starting periodic command scheduler: cron. Sun May 27 11:20:35 2012: Starting Common Unix Printing System: cupsd. Sun May 27 11:20:35 2012: Starting MTA: exim4. Sun May 27 11:20:35 2012: Starting Hardware abstraction layer: hald. Sun May 27 11:20:37 2012: Starting kerneloops: Sun May 27 11:20:37 2012: Loading cpufreq kernel modules...done (acpi-cpufreq). Sun May 27 11:20:37 2012: CPUFreq Utilities: Setting ondemand CPUFreq governor...CPU0...CPU1...done. Sun May 27 11:20:38 2012: saned disabled; edit /etc/default/saned Sun May 27 11:20:38 2012: /etc/rc.local: 13: cannot create /proc/asound/card0/pcm0p/oss: Directory nonexistent
Si le disque n’est plus reconnu par le bios c’est mauvais signe…
as-tu vérifié les connexions? y’a-t’il un bruit particulier (“clic”)
vérifier également la config du bios
salut. les connexions sont bonnes mais un des disques fait un peu de bruit. par contre je sais pas dire lequel est-ce. Qu’est-ce que je peux vérifier dans le bios ?
La solution passe par la dichotomie : Tu en déconnectes la moitié et tu écoutes … jusqu’à découvrir lequel fait du bruit :slightly_smiling:
c’est bien le 250go qui fait du bruit mais cette information ne me permet pas de récupérer mes données.
packages.debian.org/search?keywo … lla-search
forum.hardware.fr/hfr/OSAlternat … 8662_1.htm
bon courage
Re,
Et bien sûr tu as changé les câbles (alimentation ET données) ?
merci pour toutes ces infos. je vais laisser les disques se reposer un peu et lire tout ça pendant ce temps là.
Bon après plusieurs tentatives infructueuses j’ai réussi à récupérer l’intégralité de mes données hier soir. Après un passage au congélateur j’ai fais un premier essai. Le disque est reconnu dans le bios, se monte sur debian mais fait toujours beaucoup de bruit. Entre temps j’avais racheté un 500Go donc je tente un “dd_rhelp”. Après de longues heures le 250Go est à nouveau invisible, je redémarre avec juste le 500Go mais il n’est pas montable (problème de superblock). Cependant je vois mes fichiers avec testdisk mais impossible de les récupérer. Je lance un e2fsck qui me pose un million de questions pour au final n’arriver à rien :013 . Du coup deuxième session au congélateur puis repos durant quelques jours. Pendant ce temps formatage du 500Go. Je rebranche le 250 et là plus aucun bruit mécanique suspect et le disque se monte bien. Je lance un testdisk et tente de copier les données, et apparement il me retrouve tout. Après de longues heures de copies j’ai enfin toutes mes données sur un disque neuf et bien sûr le 250 n’a plus de problème :017 .
Pour conclure un congélateur est vraiment capable de miracles, pour tout ceux qui auraient ce soucis congélo + testdisk = enjoy
Combien de temps au congélo et à quelle température : -18° ?
C’est un vieux frigo américain donc je sais pas si il fonctionne encore bien mais environ -18°C je dirais. La première fois il est resté 2 semaines 1/2 et la deuxième 10 jours. Et après 3-4 jours pour décongeler à température ambiante.
… :open_mouth: je suis bluffé
Pour le decongeler tu l’as mis dans une pièce ayant toujours la même température ou tu le mettais dans un endroit chaud la journée ?
François à déjà fait la démonstration de l’efficacité de cette pratique.
Mais ça ne fonctionne pas à tous les coups; J’ai déjà essayé, sans succès… Ça doit dépendre du type et de la sévérité de la panne.
Je pense que le disque était revenu à température ambiante dés les premières heures.
[quote=“Tristan.T”]… :open_mouth: je suis bluffé
Pour le decongeler tu l’as mis dans une pièce ayant toujours la même température ou tu le mettais dans un endroit chaud la journée ?[/quote]
La température varie un peu dans la pièce mais ce qui compte c’est qu’il décongèle. La deuxième fois je l’avais même laissé 15 minutes en plein soleil sur le balcon.
Ce qui compte c’est la contraction/dilatation du métal qui peut libérer le bras s’il est bloqué.
Si un disque est physiquement endommagé (chute, choc…) le congélateur ne peut rien.
