Voila ce que donne dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-3-amd64 (Debian 2.6.32-9) (maks@debian.org) (gcc version 4.3.4 (Debian 4.3.4-8) ) #1 SMP Wed Feb 24 18:07:42 UTC 2010
[ 0.000000] Command line: BOOT_IMAGE=/vmlinuz-2.6.32-3-amd64 root=UUID=9b65fe8f-a30d-45d2-9a8b-7261b29c9853 ro quiet
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003fff0000 (usable)
[ 0.000000] BIOS-e820: 000000003fff0000 - 000000003fff3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003fff3000 - 0000000040000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000d0000000 - 00000000e0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] last_pfn = 0x3fff0 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask FFC0000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] initial memory mapped : 0 - 20000000
[ 0.000000] init_memory_mapping: 0000000000000000-000000003fff0000
[ 0.000000] 0000000000 - 003fe00000 page 2M
[ 0.000000] 003fe00000 - 003fff0000 page 4k
[ 0.000000] kernel direct mapping tables up to 3fff0000 @ 8000-b000
[ 0.000000] RAMDISK: 2f827000 - 30033b3a
[ 0.000000] ACPI: RSDP 00000000000f6c50 00014 (v00 Nvidia)
[ 0.000000] ACPI: RSDT 000000003fff3000 00030 (v01 Nvidia AWRDACPI 42302E31 AWRD 01010101)
[ 0.000000] ACPI: FACP 000000003fff3040 00074 (v01 Nvidia AWRDACPI 42302E31 AWRD 01010101)
[ 0.000000] ACPI: DSDT 000000003fff30c0 04BF2 (v01 NVIDIA AWRDACPI 00001000 MSFT 0100000C)
[ 0.000000] ACPI: FACS 000000003fff0000 00040
[ 0.000000] ACPI: MCFG 000000003fff7d40 0003C (v01 Nvidia AWRDACPI 42302E31 AWRD 01010101)
[ 0.000000] ACPI: APIC 000000003fff7cc0 0007C (v01 Nvidia AWRDACPI 42302E31 AWRD 01010101)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] Scanning NUMA topology in Northbridge 24
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at 0000000000000000-000000003fff0000
[ 0.000000] Bootmem setup node 0 0000000000000000-000000003fff0000
[ 0.000000] NODE_DATA [0000000000009000 - 0000000000010fff]
[ 0.000000] bootmap [0000000000011000 - 0000000000018fff] pages 8
[ 0.000000] (7 early reservations) ==> bootmem [0000000000 - 003fff0000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000006000 - 0000008000] TRAMPOLINE ==> [0000006000 - 0000008000]
[ 0.000000] #2 [0001000000 - 000166aa14] TEXT DATA BSS ==> [0001000000 - 000166aa14]
[ 0.000000] #3 [002f827000 - 0030033b3a] RAMDISK ==> [002f827000 - 0030033b3a]
[ 0.000000] #4 [000009f800 - 0000100000] BIOS reserved ==> [000009f800 - 0000100000]
[ 0.000000] #5 [000166b000 - 000166b091] BRK ==> [000166b000 - 000166b091]
[ 0.000000] #6 [0000008000 - 0000009000] PGTABLE ==> [0000008000 - 0000009000]
[ 0.000000] found SMP MP-table at [ffff8800000f52c0] f52c0
[ 0.000000] [ffffea0000000000-ffffea0000dfffff] PMD -> [ffff880001c00000-ffff8800029fffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] DMA32 0x00001000 -> 0x00100000
[ 0.000000] Normal 0x00100000 -> 0x00100000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0003fff0
[ 0.000000] On node 0 totalpages: 262031
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 100 pages reserved
[ 0.000000] DMA zone: 3843 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 3528 pages used for memmap
[ 0.000000] DMA32 zone: 254504 pages, LIFO batch:31
[ 0.000000] Nvidia board detected. Ignoring ACPI timer override.
[ 0.000000] If you got timer trouble try acpi_use_timer_override
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: BIOS IRQ0 pin2 override ignored.
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] ACPI: IRQ14 used by override.
[ 0.000000] ACPI: IRQ15 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 2 CPUs, 1 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 24
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 40000000:90000000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 29 pages/cpu @ffff880001800000 s89880 r8192 d20712 u1048576
[ 0.000000] pcpu-alloc: s89880 r8192 d20712 u1048576 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 258347
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-2.6.32-3-amd64 root=UUID=9b65fe8f-a30d-45d2-9a8b-7261b29c9853 ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Checking aperture…
[ 0.000000] No AGP bridge found
[ 0.000000] Node 0: aperture @ c5f0000000 size 32 MB
[ 0.000000] Aperture beyond 4GB. Ignoring.
[ 0.000000] Memory: 1018412k/1048512k available (3014k kernel code, 388k absent, 29712k reserved, 1860k data, 580k init)
[ 0.000000] SLUB: Genslabs=14, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:4352 nr_irqs:424
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2010.461 MHz processor.
[ 0.004005] Calibrating delay loop (skipped), value calculated using timer frequency… 4020.92 BogoMIPS (lpj=8041844)
[ 0.004030] Security Framework initialized
[ 0.004036] SELinux: Disabled at boot.
[ 0.004136] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.004783] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.005083] Mount-cache hash table entries: 256
[ 0.005247] Initializing cgroup subsys ns
[ 0.005251] Initializing cgroup subsys cpuacct
[ 0.005255] Initializing cgroup subsys devices
[ 0.005257] Initializing cgroup subsys freezer
[ 0.005260] Initializing cgroup subsys net_cls
[ 0.005285] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 0.005287] CPU: L2 Cache: 512K (64 bytes/line)
[ 0.005290] CPU 0/0x0 -> Node 0
[ 0.005292] tseg: 0000000000
[ 0.005307] mce: CPU supports 5 MCE banks
[ 0.005318] Performance Events: AMD PMU driver.
[ 0.005324] … version: 0
[ 0.005326] … bit width: 48
[ 0.005327] … generic registers: 4
[ 0.005329] … value mask: 0000ffffffffffff
[ 0.005331] … max period: 00007fffffffffff
[ 0.005333] … fixed-purpose events: 0
[ 0.005335] … event mask: 000000000000000f
[ 0.005347] SMP alternatives: switching to UP code
[ 0.011641] ACPI: Core revision 20090903
[ 0.018929] Setting APIC routing to flat
[ 0.019235] …TIMER: vector=0x30 apic1=0 pin1=0 apic2=-1 pin2=-1
[ 0.058929] CPU0: AMD Athlon™ 64 Processor 3200+ stepping 00
[ 0.060001] Brought up 1 CPUs
[ 0.060001] Total of 1 processors activated (4020.92 BogoMIPS).
[ 0.060001] CPU0 attaching NULL sched-domain.
[ 0.060001] devtmpfs: initialized
[ 0.060028] regulator: core version 0.5
[ 0.060085] NET: Registered protocol family 16
[ 0.060191] node 0 link 0: io port [1000, fffff]
[ 0.060194] TOM: 0000000040000000 aka 1024M
[ 0.060197] node 0 link 0: mmio [d0000000, dfffffff]
[ 0.060200] node 0 link 0: mmio [feb00000, fec0ffff]
[ 0.060203] node 0 link 0: mmio [a0000, bffff]
[ 0.060206] node 0 link 0: mmio [40000000, ffb7ffff]
[ 0.060209] bus: [00,ff] on node 0 link 0
[ 0.060211] bus: 00 index 0 io port: [0, ffff]
[ 0.060214] bus: 00 index 1 mmio: [40000000, fcffffffff]
[ 0.060216] bus: 00 index 2 mmio: [feb00000, fec0ffff]
[ 0.060219] bus: 00 index 3 mmio: [a0000, bffff]
[ 0.060224] ACPI: bus type pci registered
[ 0.060288] PCI: MCFG configuration 0: base d0000000 segment 0 buses 0 - 255
[ 0.060290] PCI: MCFG area at d0000000 reserved in E820
[ 0.066170] PCI: Using MMCONFIG at d0000000 - dfffffff
[ 0.066173] PCI: Using configuration type 1 for base access
[ 0.066670] bio: create slab at 0
[ 0.067319] ACPI: EC: Look up EC in DSDT
[ 0.070297] ACPI Warning: Package List length (0x6) larger than NumElements count (0x3), truncated
[ 0.070302] (20090903/dsobject-515)
[ 0.074340] ACPI: Interpreter enabled
[ 0.074346] ACPI: (supports S0 S1 S4 S5)
[ 0.074377] ACPI: Using IOAPIC for interrupt routing
[ 0.082026] ACPI: No dock devices found.
[ 0.082123] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.082230] HPET not enabled in BIOS. You might try hpet=force boot option
[ 0.082249] pci 0000:00:01.1: reg 10 io port: [0xe400-0xe41f]
[ 0.082258] pci 0000:00:01.1: reg 20 io port: [0x1c00-0x1c3f]
[ 0.082262] pci 0000:00:01.1: reg 24 io port: [0x1c40-0x1c7f]
[ 0.082272] pci 0000:00:01.1: PME# supported from D3hot D3cold
[ 0.082275] pci 0000:00:01.1: PME# disabled
[ 0.082296] pci 0000:00:02.0: reg 10 32bit mmio: [0xf2102000-0xf2102fff]
[ 0.082313] pci 0000:00:02.0: supports D1 D2
[ 0.082315] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.082318] pci 0000:00:02.0: PME# disabled
[ 0.082338] pci 0000:00:02.1: reg 10 32bit mmio: [0xfeb00000-0xfeb000ff]
[ 0.082358] pci 0000:00:02.1: supports D1 D2
[ 0.082360] pci 0000:00:02.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.082363] pci 0000:00:02.1: PME# disabled
[ 0.082386] pci 0000:00:04.0: reg 10 io port: [0xb400-0xb4ff]
[ 0.082390] pci 0000:00:04.0: reg 14 io port: [0xb800-0xb8ff]
[ 0.082394] pci 0000:00:04.0: reg 18 32bit mmio: [0xf2105000-0xf2105fff]
[ 0.082408] pci 0000:00:04.0: supports D1 D2
[ 0.082429] pci 0000:00:06.0: reg 20 io port: [0xf000-0xf00f]
[ 0.082454] pci 0000:00:07.0: reg 10 io port: [0x9f0-0x9f7]
[ 0.082458] pci 0000:00:07.0: reg 14 io port: [0xbf0-0xbf3]
[ 0.082462] pci 0000:00:07.0: reg 18 io port: [0x970-0x977]
[ 0.082466] pci 0000:00:07.0: reg 1c io port: [0xb70-0xb73]
[ 0.082470] pci 0000:00:07.0: reg 20 io port: [0xcc00-0xcc0f]
[ 0.082474] pci 0000:00:07.0: reg 24 32bit mmio: [0xf2100000-0xf2100fff]
[ 0.082497] pci 0000:00:08.0: reg 10 io port: [0x9e0-0x9e7]
[ 0.082501] pci 0000:00:08.0: reg 14 io port: [0xbe0-0xbe3]
[ 0.082504] pci 0000:00:08.0: reg 18 io port: [0x960-0x967]
[ 0.082508] pci 0000:00:08.0: reg 1c io port: [0xb60-0xb63]
[ 0.082512] pci 0000:00:08.0: reg 20 io port: [0xe000-0xe00f]
[ 0.082516] pci 0000:00:08.0: reg 24 32bit mmio: [0xf2101000-0xf2101fff]
[ 0.082552] pci 0000:00:0a.0: reg 10 32bit mmio: [0xf2103000-0xf2103fff]
[ 0.082557] pci 0000:00:0a.0: reg 14 io port: [0xe800-0xe807]
[ 0.082572] pci 0000:00:0a.0: supports D1 D2
[ 0.082574] pci 0000:00:0a.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.082577] pci 0000:00:0a.0: PME# disabled
[ 0.082608] pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.082611] pci 0000:00:0b.0: PME# disabled
[ 0.082643] pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.082646] pci 0000:00:0c.0: PME# disabled
[ 0.082678] pci 0000:00:0d.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.082681] pci 0000:00:0d.0: PME# disabled
[ 0.082712] pci 0000:00:0e.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.082715] pci 0000:00:0e.0: PME# disabled
[ 0.082823] pci 0000:01:07.0: reg 10 io port: [0x9000-0x90ff]
[ 0.082828] pci 0000:01:07.0: reg 14 32bit mmio: [0xf2000000-0xf20000ff]
[ 0.082854] pci 0000:01:07.0: supports D1 D2
[ 0.082856] pci 0000:01:07.0: PME# supported from D1 D2 D3hot D3cold
[ 0.082859] pci 0000:01:07.0: PME# disabled
[ 0.082885] pci 0000:00:09.0: transparent bridge
[ 0.082888] pci 0000:00:09.0: bridge io port: [0x9000-0x9fff]
[ 0.082891] pci 0000:00:09.0: bridge 32bit mmio: [0xf2000000-0xf20fffff]
[ 0.082924] pci 0000:00:0b.0: bridge io port: [0x6000-0x6fff]
[ 0.082958] pci 0000:00:0c.0: bridge io port: [0x8000-0x8fff]
[ 0.082992] pci 0000:00:0d.0: bridge io port: [0x7000-0x7fff]
[ 0.083020] pci 0000:05:00.0: reg 10 64bit mmio pref: [0xe0000000-0xefffffff]
[ 0.083028] pci 0000:05:00.0: reg 18 64bit mmio: [0xf1000000-0xf100ffff]
[ 0.083033] pci 0000:05:00.0: reg 20 io port: [0xa000-0xa0ff]
[ 0.083040] pci 0000:05:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.083056] pci 0000:05:00.0: supports D1 D2
[ 0.083084] pci 0000:05:00.1: reg 10 64bit mmio: [0xf1010000-0xf1013fff]
[ 0.083111] pci 0000:05:00.1: supports D1 D2
[ 0.088052] pci 0000:00:0e.0: bridge io port: [0xa000-0xafff]
[ 0.088055] pci 0000:00:0e.0: bridge 32bit mmio: [0xf0000000-0xf1ffffff]
[ 0.088059] pci 0000:00:0e.0: bridge 64bit mmio pref: [0xe0000000-0xefffffff]
[ 0.088073] ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PRT]
[ 0.088290] ACPI: PCI Interrupt Routing Table [_SB.PCI0.HUB0._PRT]
[ 0.144744] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.144879] ACPI: PCI Interrupt Link [LNK2] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.145015] ACPI: PCI Interrupt Link [LNK3] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.145148] ACPI: PCI Interrupt Link [LNK4] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.145280] ACPI: PCI Interrupt Link [LNK5] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.145415] ACPI: PCI Interrupt Link [LUBA] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[ 0.145547] ACPI: PCI Interrupt Link [LUBB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.145682] ACPI: PCI Interrupt Link [LMAC] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.145816] ACPI: PCI Interrupt Link [LACI] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[ 0.145949] ACPI: PCI Interrupt Link [LMCI] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.146083] ACPI: PCI Interrupt Link [LSMB] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.146221] ACPI: PCI Interrupt Link [LUB2] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.146354] ACPI: PCI Interrupt Link [LIDE] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.146497] ACPI: PCI Interrupt Link [LSID] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[ 0.146643] ACPI: PCI Interrupt Link [LFID] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.146788] ACPI: PCI Interrupt Link [LPCA] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.146946] ACPI: PCI Interrupt Link [APC1] (IRQs 16) *0, disabled.
[ 0.147097] ACPI: PCI Interrupt Link [APC2] (IRQs 17) *0, disabled.
[ 0.147247] ACPI: PCI Interrupt Link [APC3] (IRQs 18) *0
[ 0.147396] ACPI: PCI Interrupt Link [APC4] (IRQs 19) *0
[ 0.147490] ACPI: PCI Interrupt Link [APC5] (IRQs *16), disabled.
[ 0.147647] ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22 23) *0
[ 0.147805] ACPI: PCI Interrupt Link [APCG] (IRQs 20 21 22 23) *0, disabled.
[ 0.147962] ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22 23) *0
[ 0.148126] ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22 23) *0
[ 0.148283] ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22 23) *0, disabled.
[ 0.148440] ACPI: PCI Interrupt Link [APCS] (IRQs 20 21 22 23) *0
[ 0.148597] ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22 23) *0
[ 0.148754] ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22 23) *0, disabled.
[ 0.148920] ACPI: PCI Interrupt Link [APSI] (IRQs 20 21 22 23) *0
[ 0.149089] ACPI: PCI Interrupt Link [APSJ] (IRQs 20 21 22 23) *0
[ 0.149254] ACPI: PCI Interrupt Link [APCP] (IRQs 20 21 22 23) *0, disabled.
[ 0.149373] vgaarb: device added: PCI:0000:05:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.149376] vgaarb: loaded
[ 0.149464] PCI: Using ACPI for IRQ routing
[ 0.149605] Switching to clocksource jiffies
[ 0.150638] pnp: PnP ACPI init
[ 0.150658] ACPI: bus type pnp registered
[ 0.155025] pnp: PnP ACPI: found 16 devices
[ 0.155027] ACPI: ACPI bus type pnp unregistered
[ 0.155039] system 00:00: ioport range 0x1000-0x107f has been reserved
[ 0.155042] system 00:00: ioport range 0x1080-0x10ff has been reserved
[ 0.155045] system 00:00: ioport range 0x1400-0x147f has been reserved
[ 0.155048] system 00:00: ioport range 0x1480-0x14ff has been reserved
[ 0.155051] system 00:00: ioport range 0x1800-0x187f has been reserved
[ 0.155055] system 00:00: ioport range 0x1880-0x18ff has been reserved
[ 0.155066] system 00:03: ioport range 0x4d0-0x4d1 has been reserved
[ 0.155069] system 00:03: ioport range 0x800-0x87f has been reserved
[ 0.155072] system 00:03: ioport range 0x295-0x314 has been reserved
[ 0.155075] system 00:03: ioport range 0x294-0x297 could not be reserved
[ 0.155083] system 00:0e: iomem range 0xd0000000-0xdfffffff has been reserved
[ 0.155088] system 00:0f: iomem range 0xd1800-0xd3fff has been reserved
[ 0.155092] system 00:0f: iomem range 0xf0000-0xf7fff could not be reserved
[ 0.155095] system 00:0f: iomem range 0xf8000-0xfbfff could not be reserved
[ 0.155098] system 00:0f: iomem range 0xfc000-0xfffff could not be reserved
[ 0.155101] system 00:0f: iomem range 0x3fff0000-0x3fffffff could not be reserved
[ 0.155105] system 00:0f: iomem range 0xffff0000-0xffffffff has been reserved
[ 0.155108] system 00:0f: iomem range 0x0-0x9ffff could not be reserved
[ 0.155111] system 00:0f: iomem range 0x100000-0x3ffeffff could not be reserved
[ 0.155114] system 00:0f: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.155118] system 00:0f: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.159827] Switching to clocksource acpi_pm
[ 0.159902] pci 0000:00:09.0: PCI bridge, secondary bus 0000:01
[ 0.159905] pci 0000:00:09.0: IO window: 0x9000-0x9fff
[ 0.159908] pci 0000:00:09.0: MEM window: 0xf2000000-0xf20fffff
[ 0.159911] pci 0000:00:09.0: PREFETCH window: disabled
[ 0.159915] pci 0000:00:0b.0: PCI bridge, secondary bus 0000:02
[ 0.159917] pci 0000:00:0b.0: IO window: 0x6000-0x6fff
[ 0.159920] pci 0000:00:0b.0: MEM window: disabled
[ 0.159923] pci 0000:00:0b.0: PREFETCH window: disabled
[ 0.159926] pci 0000:00:0c.0: PCI bridge, secondary bus 0000:03
[ 0.159929] pci 0000:00:0c.0: IO window: 0x8000-0x8fff
[ 0.159932] pci 0000:00:0c.0: MEM window: disabled
[ 0.159934] pci 0000:00:0c.0: PREFETCH window: disabled
[ 0.159938] pci 0000:00:0d.0: PCI bridge, secondary bus 0000:04
[ 0.159940] pci 0000:00:0d.0: IO window: 0x7000-0x7fff
[ 0.159943] pci 0000:00:0d.0: MEM window: disabled
[ 0.159946] pci 0000:00:0d.0: PREFETCH window: disabled
[ 0.159952] pci 0000:00:0e.0: PCI bridge, secondary bus 0000:05
[ 0.159955] pci 0000:00:0e.0: IO window: 0xa000-0xafff
[ 0.159958] pci 0000:00:0e.0: MEM window: 0xf0000000-0xf1ffffff
[ 0.159961] pci 0000:00:0e.0: PREFETCH window: 0x000000e0000000-0x000000efffffff
[ 0.159970] pci 0000:00:09.0: setting latency timer to 64
[ 0.159975] pci 0000:00:0b.0: setting latency timer to 64
[ 0.159980] pci 0000:00:0c.0: setting latency timer to 64
[ 0.159985] pci 0000:00:0d.0: setting latency timer to 64
[ 0.159989] pci 0000:00:0e.0: setting latency timer to 64
[ 0.159993] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.159996] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffffffffffff]
[ 0.160000] pci_bus 0000:01: resource 0 io: [0x9000-0x9fff]
[ 0.160000] pci_bus 0000:01: resource 1 mem: [0xf2000000-0xf20fffff]
[ 0.160000] pci_bus 0000:01: resource 3 io: [0x00-0xffff]
[ 0.160000] pci_bus 0000:01: resource 4 mem: [0x000000-0xffffffffffffffff]
[ 0.160000] pci_bus 0000:02: resource 0 io: [0x6000-0x6fff]
[ 0.160000] pci_bus 0000:03: resource 0 io: [0x8000-0x8fff]
[ 0.160000] pci_bus 0000:04: resource 0 io: [0x7000-0x7fff]
[ 0.160000] pci_bus 0000:05: resource 0 io: [0xa000-0xafff]
[ 0.160000] pci_bus 0000:05: resource 1 mem: [0xf0000000-0xf1ffffff]
[ 0.160000] pci_bus 0000:05: resource 2 pref mem [0xe0000000-0xefffffff]
[ 0.160000] NET: Registered protocol family 2
[ 0.160000] IP route cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.160000] TCP established hash table entries: 131072 (order: 9, 2097152 bytes)
[ 0.160000] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.160000] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.160000] TCP reno registered
[ 0.160000] NET: Registered protocol family 1
[ 0.160000] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.160000] pci 0000:00:0b.0: Found disabled HT MSI Mapping
[ 0.160000] pci 0000:00:0b.0: Linking AER extended capability
[ 0.160000] pci 0000:00:0c.0: Found disabled HT MSI Mapping
[ 0.160000] pci 0000:00:0c.0: Linking AER extended capability
[ 0.160000] pci 0000:00:0d.0: Found disabled HT MSI Mapping
[ 0.160000] pci 0000:00:0d.0: Linking AER extended capability
[ 0.160000] pci 0000:00:0e.0: Found disabled HT MSI Mapping
[ 0.160000] pci 0000:00:0e.0: Linking AER extended capability
[ 0.160000] pci 0000:05:00.0: Boot video device
[ 0.160000] Unpacking initramfs…
[ 0.383590] Freeing initrd memory: 8242k freed
[ 0.389011] audit: initializing netlink socket (disabled)
[ 0.389025] type=2000 audit(1273067024.388:1): initialized
[ 0.389185] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.390736] VFS: Disk quotas dquot_6.5.2
[ 0.390798] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.390876] msgmni has been set to 2005
[ 0.391065] alg: No test for stdrng (krng)
[ 0.391117] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.391120] io scheduler noop registered
[ 0.391122] io scheduler anticipatory registered
[ 0.391124] io scheduler deadline registered
[ 0.391162] io scheduler cfq registered (default)
[ 0.391277] alloc irq_desc for 24 on node 0
[ 0.391279] alloc kstat_irqs on node 0
[ 0.391290] pcieport 0000:00:0b.0: irq 24 for MSI/MSI-X
[ 0.391295] pcieport 0000:00:0b.0: setting latency timer to 64
[ 0.391383] alloc irq_desc for 25 on node 0
[ 0.391385] alloc kstat_irqs on node 0
[ 0.391392] pcieport 0000:00:0c.0: irq 25 for MSI/MSI-X
[ 0.391396] pcieport 0000:00:0c.0: setting latency timer to 64
[ 0.391480] alloc irq_desc for 26 on node 0
[ 0.391482] alloc kstat_irqs on node 0
[ 0.391487] pcieport 0000:00:0d.0: irq 26 for MSI/MSI-X
[ 0.391491] pcieport 0000:00:0d.0: setting latency timer to 64
[ 0.391571] alloc irq_desc for 27 on node 0
[ 0.391573] alloc kstat_irqs on node 0
[ 0.391578] pcieport 0000:00:0e.0: irq 27 for MSI/MSI-X
[ 0.391582] pcieport 0000:00:0e.0: setting latency timer to 64
[ 0.393115] Linux agpgart interface v0.103
[ 0.393118] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.393202] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.393286] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.393522] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.393690] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 0.393746] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.397064] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.397069] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.397182] mice: PS/2 mouse device common for all mice
[ 0.397232] rtc_cmos 00:05: RTC can wake from S4
[ 0.397271] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 0.397294] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 0.397307] cpuidle: using governor ladder
[ 0.397309] cpuidle: using governor menu
[ 0.397314] No iBFT detected.
[ 0.397698] TCP cubic registered
[ 0.397824] NET: Registered protocol family 10
[ 0.398387] lo: Disabled Privacy Extensions
[ 0.398735] Mobile IPv6
[ 0.398738] NET: Registered protocol family 17
[ 0.398827] PM: Resume from disk failed.
[ 0.398834] registered taskstats version 1
[ 0.399094] rtc_cmos 00:05: setting system clock to 2010-05-05 13:43:44 UTC (1273067024)
[ 0.399142] Freeing unused kernel memory: 580k freed
[ 0.399456] Write protecting the kernel read-only data: 4144k
[ 0.418480] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 0.717761] usbcore: registered new interface driver usbfs
[ 0.717857] usbcore: registered new interface driver hub
[ 0.717947] usbcore: registered new device driver usb
[ 0.732658] Uniform Multi-Platform E-IDE driver
[ 0.735020] SCSI subsystem initialized
[ 0.757880] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 0.757888] ACPI: Power Button [PWRB]
[ 0.758006] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 0.758010] ACPI: Power Button [PWRF]
[ 0.764298] Floppy drive(s): fd0 is 1.44M
[ 0.765383] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.765398] 8139too Fast Ethernet driver 0.9.28
[ 0.768218] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.64.
[ 0.768530] ACPI: PCI Interrupt Link [APCH] enabled at IRQ 23
[ 0.768536] alloc irq_desc for 23 on node 0
[ 0.768538] alloc kstat_irqs on node 0
[ 0.768549] forcedeth 0000:00:0a.0: PCI INT A -> Link[APCH] -> GSI 23 (level, low) -> IRQ 23
[ 0.768554] forcedeth 0000:00:0a.0: setting latency timer to 64
[ 0.768603] nv_probe: set workaround bit for reversed mac addr
[ 0.769414] ACPI: PCI Interrupt Link [APC4] enabled at IRQ 19
[ 0.769417] alloc irq_desc for 19 on node 0
[ 0.769419] alloc kstat_irqs on node 0
[ 0.769425] 8139too 0000:01:07.0: PCI INT A -> Link[APC4] -> GSI 19 (level, low) -> IRQ 19
[ 0.770336] eth0: RealTek RTL8139 at 0xffffc900106d2000, 00:19:5b:59:31:ea, IRQ 19
[ 0.770772] libata version 3.00 loaded.
[ 0.783567] FDC 0 is a post-1991 82077
[ 1.289118] forcedeth 0000:00:0a.0: ifname eth1, PHY OUI 0x3f1 @ 7, addr 00:14:85:14:de:6f
[ 1.289123] forcedeth 0000:00:0a.0: highdma csum gbit lnktim desc-v3
[ 1.289618] amd74xx 0000:00:06.0: UDMA133 controller
[ 1.289622] amd74xx 0000:00:06.0: IDE controller (0x10de:0x0053 rev 0xa2)
[ 1.289654] amd74xx 0000:00:06.0: BIOS didn’t set cable bits correctly. Enabling workaround.
[ 1.289657] amd74xx 0000:00:06.0: not 100% native mode: will probe irqs later
[ 1.289663] ide0: BM-DMA at 0xf000-0xf007
[ 1.289669] ide1: BM-DMA at 0xf008-0xf00f
[ 1.289674] Probing IDE interface ide0…
[ 1.576090] hda: WDC WD2500JB-57REA0, ATA DISK drive
[ 2.248095] hda: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 2.248141] hda: UDMA/100 mode selected
[ 2.248211] Probing IDE interface ide1…
[ 2.984089] hdc: ASUS DRW-1608P2, ATAPI CD/DVD-ROM drive
[ 3.824020] hdd: CD-RW BCE4012IM, ATAPI CD/DVD-ROM drive
[ 3.824068] hdc: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 3.824169] hdc: UDMA/66 mode selected
[ 3.824294] hdd: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 3.824374] hdd: UDMA/33 mode selected
[ 3.824512] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 3.836631] ide1 at 0x170-0x177,0x376 on irq 15
[ 3.841116] ACPI: PCI Interrupt Link [APCL] enabled at IRQ 22
[ 3.841122] alloc irq_desc for 22 on node 0
[ 3.841125] alloc kstat_irqs on node 0
[ 3.841134] ehci_hcd 0000:00:02.1: PCI INT B -> Link[APCL] -> GSI 22 (level, low) -> IRQ 22
[ 3.841151] ehci_hcd 0000:00:02.1: setting latency timer to 64
[ 3.841154] ehci_hcd 0000:00:02.1: EHCI Host Controller
[ 3.841181] ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 1
[ 3.841206] ehci_hcd 0000:00:02.1: debug port 1
[ 3.841211] ehci_hcd 0000:00:02.1: cache line size of 64 is not supported
[ 3.841228] ehci_hcd 0000:00:02.1: irq 22, io mem 0xfeb00000
[ 3.852017] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00
[ 3.852038] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.852041] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.852044] usb usb1: Product: EHCI Host Controller
[ 3.852046] usb usb1: Manufacturer: Linux 2.6.32-3-amd64 ehci_hcd
[ 3.852048] usb usb1: SerialNumber: 0000:00:02.1
[ 3.852186] usb usb1: configuration #1 chosen from 1 choice
[ 3.852241] hub 1-0:1.0: USB hub found
[ 3.852250] hub 1-0:1.0: 10 ports detected
[ 3.852842] sata_nv 0000:00:07.0: version 3.5
[ 3.853207] ACPI: PCI Interrupt Link [APSI] enabled at IRQ 21
[ 3.853212] alloc irq_desc for 21 on node 0
[ 3.853215] alloc kstat_irqs on node 0
[ 3.853224] sata_nv 0000:00:07.0: PCI INT A -> Link[APSI] -> GSI 21 (level, low) -> IRQ 21
[ 3.853274] sata_nv 0000:00:07.0: setting latency timer to 64
[ 3.854600] scsi0 : sata_nv
[ 3.856300] scsi1 : sata_nv
[ 3.856558] ata1: SATA max UDMA/133 cmd 0x9f0 ctl 0xbf0 bmdma 0xcc00 irq 21
[ 3.856561] ata2: SATA max UDMA/133 cmd 0x970 ctl 0xb70 bmdma 0xcc08 irq 21
[ 3.857092] ACPI: PCI Interrupt Link [APSJ] enabled at IRQ 20
[ 3.857097] alloc irq_desc for 20 on node 0
[ 3.857100] alloc kstat_irqs on node 0
[ 3.857109] sata_nv 0000:00:08.0: PCI INT A -> Link[APSJ] -> GSI 20 (level, low) -> IRQ 20
[ 3.857158] sata_nv 0000:00:08.0: setting latency timer to 64
[ 3.857242] scsi2 : sata_nv
[ 3.857356] scsi3 : sata_nv
[ 3.857549] ata3: SATA max UDMA/133 cmd 0x9e0 ctl 0xbe0 bmdma 0xe000 irq 20
[ 3.857552] ata4: SATA max UDMA/133 cmd 0x960 ctl 0xb60 bmdma 0xe008 irq 20
[ 3.867956] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.868317] ACPI: PCI Interrupt Link [APCF] enabled at IRQ 23
[ 3.868322] ohci_hcd 0000:00:02.0: PCI INT A -> Link[APCF] -> GSI 23 (level, low) -> IRQ 23
[ 3.868341] ohci_hcd 0000:00:02.0: setting latency timer to 64
[ 3.868344] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 3.868360] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2
[ 3.868392] ohci_hcd 0000:00:02.0: irq 23, io mem 0xf2102000
[ 3.926028] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.926031] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.926033] usb usb2: Product: OHCI Host Controller
[ 3.926036] usb usb2: Manufacturer: Linux 2.6.32-3-amd64 ohci_hcd
[ 3.926038] usb usb2: SerialNumber: 0000:00:02.0
[ 3.926174] usb usb2: configuration #1 chosen from 1 choice
[ 3.926233] hub 2-0:1.0: USB hub found
[ 3.926243] hub 2-0:1.0: 10 ports detected
[ 4.168024] ata3: SATA link down (SStatus 0 SControl 300)
[ 4.168043] ata1: SATA link down (SStatus 0 SControl 300)
[ 4.480019] ata2: SATA link down (SStatus 0 SControl 300)
[ 4.792022] ata4: SATA link down (SStatus 0 SControl 300)
[ 4.810432] ide-gd driver 1.18
[ 4.810470] hda: max request size: 512KiB
[ 4.810791] ide-cd driver 5.00
[ 4.818109] hda: Host Protected Area detected.
[ 4.818110] current capacity is 488395055 sectors (250058 MB)
[ 4.818112] native capacity is 488397168 sectors (250059 MB)
[ 4.818115] hda: 488395055 sectors (250058 MB) w/8192KiB Cache, CHS=30401/255/63
[ 4.818186] hda: cache flushes supported
[ 4.818230] hda: hda1 hda2 hda3 hda4 < hda5 hda6 hda7 hda8 hda9 >
[ 4.936192] ide-cd: hdc: ATAPI 40X DVD-ROM DVD-R CD-R/RW drive, 2000kB Cache
[ 4.936198] Uniform CD-ROM driver Revision: 3.20
[ 4.961013] ide-cd: hdd: ATAPI 48X CD-ROM CD-R/RW drive, 2048kB Cache
[ 5.499296] PM: Starting manual resume from disk
[ 5.499301] PM: Resume from partition 3:3
[ 5.499303] PM: Checking hibernation image.
[ 5.499555] PM: Error -22 checking image file
[ 5.499557] PM: Resume from disk failed.
[ 5.543773] kjournald starting. Commit interval 5 seconds
[ 5.543783] EXT3-fs: mounted filesystem with ordered data mode.
[ 7.280694] udev: starting version 151
[ 7.933663] udev: renamed network interface eth0 to eth1
[ 7.967170] udev: renamed network interface eth1_rename to eth0
[ 8.494885] parport_pc 00:0b: reported by Plug and Play ACPI
[ 8.494925] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[ 8.500525] processor LNXCPU:00: registered as cooling_device0
[ 8.548557] i2c i2c-0: nForce2 SMBus adapter at 0x1c00
[ 8.548599] i2c i2c-1: nForce2 SMBus adapter at 0x1c40
[ 8.580049] EDAC MC: Ver: 2.1.0 Feb 24 2010
[ 8.590981] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 8.610635] EDAC amd64_edac: Ver: 3.2.0 Feb 24 2010
[ 8.616657] EDAC amd64: This node reports that Memory ECC is currently disabled, set F3x44[22] (0000:00:18.3).
[ 8.616664] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[ 8.616666] Either enable ECC checking or force module loading by setting ‘ecc_enable_override’.
[ 8.616667] (Note that use of the override may cause unknown side effects.)
[ 8.616687] amd64_edac: probe of 0000:00:18.2 failed with error -22
[ 9.405817] input: ImExPS/2 Logitech Wheel Mouse as /devices/platform/i8042/serio1/input/input5
[ 9.521152] ACPI: PCI Interrupt Link [APCJ] enabled at IRQ 22
[ 9.521158] Intel ICH 0000:00:04.0: PCI INT A -> Link[APCJ] -> GSI 22 (level, low) -> IRQ 22
[ 9.521187] Intel ICH 0000:00:04.0: setting latency timer to 64
[ 9.844029] intel8x0_measure_ac97_clock: measured 54729 usecs (2688 samples)
[ 9.844033] intel8x0: clocking to 46911
[ 10.633073] Adding 1951888k swap on /dev/hda3. Priority:-1 extents:1 across:1951888k
[ 10.821998] EXT3 FS on hda2, internal journal
[ 10.970123] loop: module loaded
[ 12.350626] fuse init (API version 7.13)
[ 12.533747] kjournald starting. Commit interval 5 seconds
[ 12.533876] EXT3 FS on hda1, internal journal
[ 12.533880] EXT3-fs: mounted filesystem with ordered data mode.
[ 12.567420] kjournald starting. Commit interval 5 seconds
[ 12.567626] EXT3 FS on hda6, internal journal
[ 12.567630] EXT3-fs: mounted filesystem with ordered data mode.
[ 12.585291] kjournald starting. Commit interval 5 seconds
[ 12.585778] EXT3 FS on hda7, internal journal
[ 12.585781] EXT3-fs: mounted filesystem with ordered data mode.
[ 14.097288] eth1: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 14.709631] ehci_hcd 0000:00:02.1: remove, state 4
[ 14.709640] usb usb1: USB disconnect, address 1
[ 14.710211] ehci_hcd 0000:00:02.1: USB bus 1 deregistered
[ 14.710231] ehci_hcd 0000:00:02.1: PCI INT B disabled
[ 14.964131] powernow-k8: Found 1 AMD Athlon™ 64 Processor 3200+ processors (1 cpu cores) (version 2.20.00)
[ 14.964177] powernow-k8: 0 : fid 0xc (2000 MHz), vid 0x6
[ 14.964180] powernow-k8: 1 : fid 0xa (1800 MHz), vid 0x8
[ 14.964182] powernow-k8: 2 : fid 0x2 (1000 MHz), vid 0x12
[ 15.556021] Clocksource tsc unstable (delta = -250009747 ns)
[ 24.880020] eth1: no IPv6 routers present
[ 28.927509] Bluetooth: Core ver 2.15
[ 28.927588] NET: Registered protocol family 31
[ 28.927592] Bluetooth: HCI device and connection manager initialized
[ 28.927598] Bluetooth: HCI socket layer initialized
[ 29.068709] Bluetooth: L2CAP ver 2.14
[ 29.068714] Bluetooth: L2CAP socket layer initialized
[ 29.426378] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 29.426384] Bluetooth: BNEP filters: protocol multicast
[ 29.607156] Bridge firewalling registered
[ 29.869897] Bluetooth: SCO (Voice Link) ver 0.6
[ 29.869903] Bluetooth: SCO socket layer initialized
[ 30.391680] lp0: using parport0 (interrupt-driven).
[ 30.426658] ppdev: user-space parallel port driver
[ 56.616511] end_request: I/O error, dev fd0, sector 0
[ 68.784492] end_request: I/O error, dev fd0, sector 0
Cordialement
