voici le résultat du bootscript . Pour le reste je vais faire une installation complète avec environnement graphique et je testerai la commande debconf … d’ailleurs puis-je compléter mon installation (jessie) sans reprendre à zéro ?
            [code]  Boot Info Script 0.61      [1 April 2012]
============================= Boot Info Summary: ===============================
=> Grub2 (v1.99) is installed in the MBR of /dev/sda and looks at sector 1 of
the same hard drive for core.img. core.img is at this location and looks
for (,msdos6)/boot/grub on this drive.
=> Grub2 (v1.99) is installed in the MBR of /dev/sdb and looks at sector 1 of
for (,msdos1)/boot/grub on this drive.
sda1: __________________________________________________________________________
File system:       ntfs
Boot sector type:  Grub2 (v1.99)
Boot sector info:  Grub2 (v1.99) is installed in the boot sector of sda1
                   and looks at sector 1157974032 of the same hard drive
                   for core.img, but core.img can not be found at this
                   location. No errors found in the Boot Parameter Block.
Operating System:
Boot files:        /bootmgr /Boot/BCD
sda2: __________________________________________________________________________
File system:       ntfs
Boot sector type:  Windows Vista/7: NTFS
Boot sector info:  No errors found in the Boot Parameter Block.
Operating System:  Windows 7
Boot files:        /bootmgr /Boot/BCD /Windows/System32/winload.exe
sda3: __________________________________________________________________________
File system:       ntfs
Operating System:
Boot files:
sda4: __________________________________________________________________________
File system:       Extended Partition
Boot sector type:  -
Boot sector info:
sda5: __________________________________________________________________________
File system:       vfat
Boot sector type:  -
Operating System:
Boot files:
sda6: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Mounting failed:   mount : /dev/sda6 est déjà monté ou sda6 est occupé
sda7: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:
Boot files:
sda8: __________________________________________________________________________
File system:       swap
Boot sector type:  -
Boot sector info:
sdb1: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Debian GNU/Linux 8
Boot files:        /boot/grub/grub.cfg /etc/fstab
sdb2: __________________________________________________________________________
Boot sector type:  Unknown
Boot sector info:
sdb5: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:
Boot files:
sdb6: __________________________________________________________________________
File system:       swap
Boot sector type:  -
Boot sector info:
sdb7: __________________________________________________________________________
File system:       vfat
Boot sector type:  FAT32
Operating System:
Boot files:
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disque /dev/sda : 640.1 Go, 640135028736 octets
255 têtes, 63 secteurs/piste, 77825 cylindres, total 1250263728 secteurs
Unités = secteurs de 1 * 512 = 512 octets
Taille de secteur (logique / physique) : 512 octets / 4096 octets
Partition  Boot  Start Sector    End Sector  # of Sectors  Id System
/dev/sda1    *          2,048       821,247       819,200  27 Hidden NTFS (Recovery Environment)
/dev/sda2             821,248   625,461,247   624,640,000   7 NTFS / exFAT / HPFS
/dev/sda3         625,461,248 1,152,603,826   527,142,579   7 NTFS / exFAT / HPFS
/dev/sda4       1,152,604,158 1,250,260,991    97,656,834   5 Extended
/dev/sda5       1,211,201,536 1,250,260,991    39,059,456   b W95 FAT32
/dev/sda6       1,152,604,160 1,181,900,799    29,296,640  83 Linux
/dev/sda7       1,181,902,848 1,209,243,647    27,340,800  83 Linux
/dev/sda8       1,209,245,696 1,211,189,247     1,943,552  82 Linux swap / Solaris
Drive: sdb _____________________________________________________________________
Disque /dev/sdb : 500.1 Go, 500107862016 octets
255 têtes, 63 secteurs/piste, 60801 cylindres, total 976773168 secteurs
/dev/sdb1               2,048    29,296,639    29,294,592  83 Linux
/dev/sdb2          29,298,686   976,771,071   947,472,386   5 Extended
/dev/sdb5          29,298,688    68,358,143    39,059,456  83 Linux
/dev/sdb6          68,360,192    72,460,287     4,100,096  82 Linux swap / Solaris
/dev/sdb7          72,462,336   976,771,071   904,308,736   b W95 FAT32
“blkid” output: ________________________________________________________________
Device           UUID                                   TYPE       LABEL
/dev/sda1        AA064AFC064AC8D1                       ntfs       SYSTEM
/dev/sda2        B81265821265468A                       ntfs       WINDOWS
/dev/sda3        A44085BF408598A6                       ntfs       Data
/dev/sda5        4D9E-904E                              vfat
/dev/sda6        0980c8a6-ae77-4ccc-9009-e41466867c49   ext4
/dev/sda7        4d93b358-7017-4658-813b-8bbba8628cc9   ext4
/dev/sda8        2801ed40-25aa-4624-a20e-873221b1516f   swap
/dev/sdb1        5c5d6190-9d24-4b43-bf45-b424203691ea   ext4
/dev/sdb5        d703fbfb-e3b4-4b7a-a8e6-6617a9c253cf   ext4
/dev/sdb6        89e4b00c-341e-425e-86ea-ef288f1cae80   swap
/dev/sdb7        C990-11BE                              vfat
================================ Mount points: =================================
Device           Mount_Point              Type       Options
/dev/disk/by-uuid/0980c8a6-ae77-4ccc-9009-e41466867c49 /                        ext4       (rw,relatime,errors=remount-ro,user_xattr,barrier=1,data=ordered)
/dev/sda7        /home                    ext4       (rw,relatime,user_xattr,barrier=1,data=ordered)
/dev/sdb1        /media/usb0              ext4       (rw,nosuid,nodev,noexec,relatime,user_xattr,barrier=1,data=ordered,user=mm)
/dev/sdb5        /media/d703fbfb-e3b4-4b7a-a8e6-6617a9c253cf ext4       (rw,nosuid,nodev,relatime,user_xattr,barrier=1,data=ordered,uhelper=udisks)
/dev/sdb7        /media/C990-11BE         vfat       (rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0077,codepage=cp437,iocharset=utf8,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks)
=========================== sdb1/boot/grub/grub.cfg: ===========================
DO NOT EDIT THIS FILE
It is automatically generated by grub-mkconfig using templates
from /etc/grub.d and settings from /etc/default/grub
BEGIN /etc/grub.d/00_header
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
if [ “${next_entry}” ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="–id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ “${prev_saved_entry}” ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z “${boot_once}” ]; then
saved_entry="${chosen}"
fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd1,msdos1’
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-ieee1275=‘ieee1275//sas/disk@0,msdos1’ --hint-bios=hd1,msdos1 --hint-efi=hd1,msdos1 --hint-baremetal=ahci1,msdos1  5c5d6190-9d24-4b43-bf45-b424203691ea
else
search --no-floppy --fs-uuid --set=root 5c5d6190-9d24-4b43-bf45-b424203691ea
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=fr_FR
insmod gettext
fi
terminal_output gfxterm
if [ “${recordfail}” = 1 ] ; then
set timeout=-1
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=menu
set timeout=5
Fallback normal timeout code in case the timeout_style feature is
unavailable.
else
set timeout=5
fi
fi
END /etc/grub.d/00_header
BEGIN /etc/grub.d/05_debian_theme
set menu_color_normal=cyan/blue
set menu_color_highlight=white/blue
END /etc/grub.d/05_debian_theme
BEGIN /etc/grub.d/10_linux
function gfxmode {
set gfxpayload="${1}"
set linux_gfx_mode=
export linux_gfx_mode
menuentry ‘Debian GNU/Linux’ --class debian --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-simple-5c5d6190-9d24-4b43-bf45-b424203691ea’ {
load_video
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_msdos
insmod ext2
else
fi
echo	'Chargement de Linux 3.16.0-4-686-pae…'
linux	/boot/vmlinuz-3.16.0-4-686-pae root=UUID=5c5d6190-9d24-4b43-bf45-b424203691ea ro  quiet
echo	'Chargement du disque mémoire initial…'
initrd	/boot/initrd.img-3.16.0-4-686-pae
submenu ‘Options avancées pour Debian GNU/Linux’ $menuentry_id_option ‘gnulinux-advanced-5c5d6190-9d24-4b43-bf45-b424203691ea’ {
menuentry ‘Debian GNU/Linux, avec Linux 3.16.0-4-686-pae’ --class debian --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-3.16.0-4-686-pae-advanced-5c5d6190-9d24-4b43-bf45-b424203691ea’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Debian GNU/Linux, with Linux 3.16.0-4-686-pae (recovery mode)’ --class debian --class gnu-linux --class gnu --class os $menuentry_id_option ‘gnulinux-3.16.0-4-686-pae-recovery-5c5d6190-9d24-4b43-bf45-b424203691ea’ {
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux	/boot/vmlinuz-3.16.0-4-686-pae root=UUID=5c5d6190-9d24-4b43-bf45-b424203691ea ro single
END /etc/grub.d/10_linux
BEGIN /etc/grub.d/20_linux_xen
END /etc/grub.d/20_linux_xen
BEGIN /etc/grub.d/30_os-prober
menuentry ‘Windows 7 (loader) (sur /dev/sda1)’ --class windows --class os $menuentry_id_option ‘osprober-chain-AA064AFC064AC8D1’ {
insmod part_msdos
insmod ntfs
set root='hd0,msdos1’
search --no-floppy --fs-uuid --set=root --hint-ieee1275=‘ieee1275//disk@0,msdos1’ --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1  AA064AFC064AC8D1
else
search --no-floppy --fs-uuid --set=root AA064AFC064AC8D1
fi
parttool ${root} hidden-
chainloader +1
menuentry ‘Windows 7 (loader) (sur /dev/sda2)’ --class windows --class os $menuentry_id_option ‘osprober-chain-B81265821265468A’ {
insmod part_msdos
insmod ntfs
set root='hd0,msdos2’
search --no-floppy --fs-uuid --set=root --hint-ieee1275=‘ieee1275//disk@0,msdos2’ --hint-bios=hd0,msdos2 --hint-efi=hd0,msdos2 --hint-baremetal=ahci0,msdos2  B81265821265468A
else
search --no-floppy --fs-uuid --set=root B81265821265468A
fi
chainloader +1
menuentry ‘Debian GNU/Linux (7.8) (sur /dev/sda6)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-simple-0980c8a6-ae77-4ccc-9009-e41466867c49’ {
insmod part_msdos
insmod ext2
set root='hd0,msdos6’
search --no-floppy --fs-uuid --set=root --hint-ieee1275=‘ieee1275//disk@0,msdos6’ --hint-bios=hd0,msdos6 --hint-efi=hd0,msdos6 --hint-baremetal=ahci0,msdos6  0980c8a6-ae77-4ccc-9009-e41466867c49
else
search --no-floppy --fs-uuid --set=root 0980c8a6-ae77-4ccc-9009-e41466867c49
fi
linux /boot/vmlinuz-3.2.0-4-686-pae root=UUID=0980c8a6-ae77-4ccc-9009-e41466867c49 ro quiet
initrd /boot/initrd.img-3.2.0-4-686-pae
submenu ‘Options avancées pour Debian GNU/Linux (7.8) (sur /dev/sda6)’ $menuentry_id_option ‘osprober-gnulinux-advanced-0980c8a6-ae77-4ccc-9009-e41466867c49’ {
menuentry ‘Debian GNU/Linux, avec Linux 3.2.0-4-686-pae (sur /dev/sda6)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.2.0-4-686-pae–0980c8a6-ae77-4ccc-9009-e41466867c49’ {
insmod part_msdos
insmod ext2
else
fi
menuentry ‘Debian GNU/Linux, avec Linux 3.2.0-4-686-pae (mode de dépannage) (sur /dev/sda6)’ --class gnu-linux --class gnu --class os $menuentry_id_option ‘osprober-gnulinux-/boot/vmlinuz-3.2.0-4-686-pae-root=UUID=0980c8a6-ae77-4ccc-9009-e41466867c49 ro single-0980c8a6-ae77-4ccc-9009-e41466867c49’ {
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-3.2.0-4-686-pae root=UUID=0980c8a6-ae77-4ccc-9009-e41466867c49 ro single
END /etc/grub.d/30_os-prober
BEGIN /etc/grub.d/30_uefi-firmware
END /etc/grub.d/30_uefi-firmware
BEGIN /etc/grub.d/40_custom
This file provides an easy way to add custom menu entries.  Simply type the
menu entries you want to add after this comment.  Be careful not to change
the ‘exec tail’ line above.
END /etc/grub.d/40_custom
BEGIN /etc/grub.d/41_custom
if [ -f  ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z “${config_directory}” -a -f  $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
END /etc/grub.d/41_custom
=============================== sdb1/etc/fstab: ================================
/etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
/ was on /dev/sdb1 during installation
UUID=5c5d6190-9d24-4b43-bf45-b424203691ea /               ext4    errors=remount-ro 0       1
/home was on /dev/sdb5 during installation
UUID=d703fbfb-e3b4-4b7a-a8e6-6617a9c253cf /home           ext4    defaults        0       2
/windows was on /dev/sdb7 during installation
UUID=C990-11BE  /windows        vfat    utf8            0       0
swap was on /dev/sda8 during installation
UUID=2801ed40-25aa-4624-a20e-873221b1516f none            swap    sw              0       0
swap was on /dev/sdb6 during installation
UUID=89e4b00c-341e-425e-86ea-ef288f1cae80 none            swap    sw              0       0
/dev/sr0        /media/cdrom0   udf,iso9660 user,noauto     0       0
=================== sdb1: Location of files loaded by Grub: ====================
       GiB - GB             File                                 Fragment(s)
           =                boot/grub/grub.cfg                             1
           =                boot/initrd.img-3.16.0-4-686-pae               2
           =                boot/vmlinuz-3.16.0-4-686-pae                  1
           =                vmlinuz                                        1
======================== Unknown MBRs/Boot Sectors/etc: ========================
Unknown BootLoader on sdb2
00000000  ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |…|
000001b0  ff ff ff ff ff ff ff ff  ff ff ff ff ff ff 00 fe  |…|
000001c0  ff ff 83 fe ff ff 02 00  00 00 00 00 54 02 00 fe  |…T…|
000001d0  ff ff 05 fe ff ff 02 00  54 02 00 98 3e 00 00 00  |…T…>…|
000001e0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |…|
000001f0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 55 aa  |…U.|
00000200
=============================== StdErr Messages: ===============================
xz : (stdin): Les données compressées sont corrompues
awk: cmd. line:36: Math support is not compiled in
