résultats des ls :
ls ()/ = ./  …/   lost+found/   home/   windows/   etc/   media/   vmlinuz   var/    usr/    lib/    bin/    sbin/  temp/   sys/    run/    root/   proc/    dev/    boot/    mnt/     srv/     opt/    initrd.img
ls ()/boot = ./   …/   config-3.16.0-4-686-pae    vmlinuz-3 …   grub/    System.map-3…  initrd.img-3…
- contenu de results.txt ( en fait je faisais une erreur d’adresse ):
                  Boot Info Script 0.61      [1 April 2012]
============================= Boot Info Summary: ===============================
 => Grub2 (v1.99) is installed in the MBR of /dev/sda and looks at sector 1 of
    the same hard drive for core.img. core.img is at this location and looks
    for (,msdos6)/boot/grub on this drive.
 => Grub2 (v1.99) is installed in the MBR of /dev/sdb and looks at sector 1 of
    for (,msdos1)/boot/grub on this drive.
sda1: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Grub2 (v1.99)
    Boot sector info:  Grub2 (v1.99) is installed in the boot sector of sda1
                       and looks at sector 1157974032 of the same hard drive
                       for core.img, but core.img can not be found at this
                       location. No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:        /bootmgr /Boot/BCD
sda2: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Windows Vista/7: NTFS
    Boot sector info:  No errors found in the Boot Parameter Block.
    Operating System:  Windows 7
    Boot files:        /bootmgr /Boot/BCD /Windows/System32/winload.exe
sda3: __________________________________________________________________________
    File system:       ntfs
    Operating System:
    Boot files:
sda4: __________________________________________________________________________
    File system:       Extended Partition
    Boot sector type:  -
    Boot sector info:
sda5: __________________________________________________________________________
    File system:       vfat
    Boot sector type:  -
    Operating System:
    Boot files:
sda6: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Mounting failed:   mount : /dev/sda6 est déjà monté ou sda6 est occupé
sda7: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:
    Boot files:
sda8: __________________________________________________________________________
    File system:       swap
    Boot sector type:  -
    Boot sector info:
sdb1: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:  Debian GNU/Linux 8
    Boot files:        /boot/grub/grub.cfg /etc/fstab
sdb2: __________________________________________________________________________
    Boot sector type:  -
    Boot sector info:
sdb5: __________________________________________________________________________
    File system:       swap
    Boot sector type:  -
    Boot sector info:
sdb3: __________________________________________________________________________
    File system:       vfat
    Boot sector type:  FAT32
    Boot sector info:  According to the info in the boot sector, sdb3 starts
                       at sector 0. But according to the info from fdisk,
                       sdb3 starts at sector 52741395.
    Operating System:
    Boot files:
sdb4: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:  Debian GNU/Linux 7
    Boot files:        /boot/grub/grub.cfg /etc/fstab /boot/grub/core.img
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disque /dev/sda : 640.1 Go, 640135028736 octets
255 têtes, 63 secteurs/piste, 77825 cylindres, total 1250263728 secteurs
Unités = secteurs de 1 * 512 = 512 octets
Taille de secteur (logique / physique) : 512 octets / 4096 octets
Partition  Boot  Start Sector    End Sector  # of Sectors  Id System
/dev/sda1    *          2,048       821,247       819,200  27 Hidden NTFS (Recovery Environment)
/dev/sda2             821,248   625,461,247   624,640,000   7 NTFS / exFAT / HPFS
/dev/sda3         625,461,248 1,152,603,826   527,142,579   7 NTFS / exFAT / HPFS
/dev/sda4       1,152,604,158 1,250,260,991    97,656,834   5 Extended
/dev/sda5       1,211,201,536 1,250,260,991    39,059,456   b W95 FAT32
/dev/sda6       1,152,604,160 1,181,900,799    29,296,640  83 Linux
/dev/sda7       1,181,902,848 1,209,243,647    27,340,800  83 Linux
/dev/sda8       1,209,245,696 1,211,189,247     1,943,552  82 Linux swap / Solaris
Drive: sdb _____________________________________________________________________
Disque /dev/sdb : 500.1 Go, 500107862016 octets
255 têtes, 63 secteurs/piste, 60801 cylindres, total 976773168 secteurs
/dev/sdb1    *          2,048    27,342,847    27,340,800  83 Linux
/dev/sdb2          48,830,462    52,740,095     3,909,634   5 Extended
/dev/sdb5          48,830,464    52,740,095     3,909,632  82 Linux swap / Solaris
/dev/sdb3          52,741,395   976,768,064   924,026,670   c W95 FAT32 (LBA)
/dev/sdb4          29,298,688    48,829,937    19,531,250  83 Linux
"blkid" output: ________________________________________________________________
Device           UUID                                   TYPE       LABEL
/dev/sda1        AA064AFC064AC8D1                       ntfs       SYSTEM
/dev/sda2        B81265821265468A                       ntfs       WINDOWS
/dev/sda3        A44085BF408598A6                       ntfs       Data
/dev/sda5        4D9E-904E                              vfat
/dev/sda6        0980c8a6-ae77-4ccc-9009-e41466867c49   ext4
/dev/sda7        4d93b358-7017-4658-813b-8bbba8628cc9   ext4
/dev/sda8        fd3bd207-8b42-49f5-8512-0a86dcb7bc1b   swap
/dev/sdb1        ed167aa2-53c2-43d2-a198-3239c5577285   ext4
/dev/sdb3        3879-C506                              vfat       NOUVEAU VOL
/dev/sdb4        ea0bc0d3-8633-4596-853c-7c32631151fe   ext4
/dev/sdb5        83a5eac0-e219-4540-a616-271871ff7493   swap
================================ Mount points: =================================
Device           Mount_Point              Type       Options
/dev/disk/by-uuid/0980c8a6-ae77-4ccc-9009-e41466867c49 /                        ext4       (rw,relatime,errors=remount-ro,user_xattr,barrier=1,data=ordered)
/dev/sda7        /home                    ext4       (rw,relatime,user_xattr,barrier=1,data=ordered)
/dev/sdb1        /media/usb0              ext4       (rw,nosuid,nodev,noexec,relatime,user_xattr,barrier=1,data=ordered,user=mm)
/dev/sdb3        /media/NOUVEAU VOL       vfat       (rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0077,codepage=cp437,iocharset=utf8,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks)
/dev/sdb4        /media/ea0bc0d3-8633-4596-853c-7c32631151fe ext4       (rw,nosuid,nodev,relatime,user_xattr,barrier=1,data=ordered,uhelper=udisks)
=========================== sdb1/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
  set have_grubenv=true
  load_env
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
if [ x$feature_default_font_path = xy ] ; then
   font=unicode
else
insmod part_msdos
insmod ext2
set root='hd1,msdos1'
if [ x$feature_platform_search_hint = xy ]; then
  search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//sas/disk@0,msdos1' --hint-bios=hd1,msdos1 --hint-efi=hd1,msdos1 --hint-baremetal=ahci1,msdos1  ed167aa2-53c2-43d2-a198-3239c5577285
else
  search --no-floppy --fs-uuid --set=root ed167aa2-53c2-43d2-a198-3239c5577285
fi
    font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
  set locale_dir=$prefix/locale
  set lang=fr_FR
  insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
  set timeout=-1
else
  if [ x$feature_timeout_style = xy ] ; then
    set timeout_style=menu
    set timeout=5
  # Fallback normal timeout code in case the timeout_style feature is
  # unavailable.
  else
    set timeout=5
  fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=cyan/blue
set menu_color_highlight=white/blue
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
	set gfxpayload="${1}"
set linux_gfx_mode=
export linux_gfx_mode
menuentry 'Debian GNU/Linux' --class debian --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-ed167aa2-53c2-43d2-a198-3239c5577285' {
	load_video
	insmod gzio
	if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
	insmod part_msdos
	insmod ext2
	else
	fi
	echo	'Chargement de Linux 3.16.0-4-686-pae…'
	linux	/boot/vmlinuz-3.16.0-4-686-pae root=UUID=ed167aa2-53c2-43d2-a198-3239c5577285 ro  quiet
	echo	'Chargement du disque mémoire initial…'
	initrd	/boot/initrd.img-3.16.0-4-686-pae
submenu 'Options avancées pour Debian GNU/Linux' $menuentry_id_option 'gnulinux-advanced-ed167aa2-53c2-43d2-a198-3239c5577285' {
	menuentry 'Debian GNU/Linux, avec Linux 3.16.0-4-686-pae' --class debian --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.16.0-4-686-pae-advanced-ed167aa2-53c2-43d2-a198-3239c5577285' {
		load_video
		insmod gzio
		insmod part_msdos
		insmod ext2
		else
		fi
	menuentry 'Debian GNU/Linux, with Linux 3.16.0-4-686-pae (recovery mode)' --class debian --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.16.0-4-686-pae-recovery-ed167aa2-53c2-43d2-a198-3239c5577285' {
		load_video
		insmod gzio
		insmod part_msdos
		insmod ext2
		else
		fi
		linux	/boot/vmlinuz-3.16.0-4-686-pae root=UUID=ed167aa2-53c2-43d2-a198-3239c5577285 ro single
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows 7 (loader) (sur /dev/sda1)' --class windows --class os $menuentry_id_option 'osprober-chain-AA064AFC064AC8D1' {
	insmod part_msdos
	insmod ntfs
	set root='hd0,msdos1'
	  search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//disk@0,msdos1' --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1  AA064AFC064AC8D1
	else
	  search --no-floppy --fs-uuid --set=root AA064AFC064AC8D1
	fi
	parttool ${root} hidden-
	chainloader +1
menuentry 'Windows 7 (loader) (sur /dev/sda2)' --class windows --class os $menuentry_id_option 'osprober-chain-B81265821265468A' {
	insmod part_msdos
	insmod ntfs
	set root='hd0,msdos2'
	  search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//disk@0,msdos2' --hint-bios=hd0,msdos2 --hint-efi=hd0,msdos2 --hint-baremetal=ahci0,msdos2  B81265821265468A
	else
	  search --no-floppy --fs-uuid --set=root B81265821265468A
	fi
	chainloader +1
menuentry 'Debian GNU/Linux (7.8) (sur /dev/sda6)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-0980c8a6-ae77-4ccc-9009-e41466867c49' {
	insmod part_msdos
	insmod ext2
	set root='hd0,msdos6'
	  search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//disk@0,msdos6' --hint-bios=hd0,msdos6 --hint-efi=hd0,msdos6 --hint-baremetal=ahci0,msdos6  0980c8a6-ae77-4ccc-9009-e41466867c49
	else
	  search --no-floppy --fs-uuid --set=root 0980c8a6-ae77-4ccc-9009-e41466867c49
	fi
	linux /boot/vmlinuz-3.2.0-4-686-pae root=UUID=0980c8a6-ae77-4ccc-9009-e41466867c49 ro quiet
	initrd /boot/initrd.img-3.2.0-4-686-pae
submenu 'Options avancées pour Debian GNU/Linux (7.8) (sur /dev/sda6)' $menuentry_id_option 'osprober-gnulinux-advanced-0980c8a6-ae77-4ccc-9009-e41466867c49' {
	menuentry 'Debian GNU/Linux, avec Linux 3.2.0-4-686-pae (sur /dev/sda6)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-3.2.0-4-686-pae--0980c8a6-ae77-4ccc-9009-e41466867c49' {
		insmod part_msdos
		insmod ext2
		else
		fi
	menuentry 'Debian GNU/Linux, avec Linux 3.2.0-4-686-pae (mode de dépannage) (sur /dev/sda6)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-3.2.0-4-686-pae-root=UUID=0980c8a6-ae77-4ccc-9009-e41466867c49 ro single-0980c8a6-ae77-4ccc-9009-e41466867c49' {
		insmod part_msdos
		insmod ext2
		else
		fi
		linux /boot/vmlinuz-3.2.0-4-686-pae root=UUID=0980c8a6-ae77-4ccc-9009-e41466867c49 ro single
menuentry 'Debian GNU/Linux (7.4) (sur /dev/sdb4)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-ea0bc0d3-8633-4596-853c-7c32631151fe' {
	insmod part_msdos
	insmod ext2
	set root='hd1,msdos4'
	  search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//sas/disk@0,msdos4' --hint-bios=hd1,msdos4 --hint-efi=hd1,msdos4 --hint-baremetal=ahci1,msdos4  ea0bc0d3-8633-4596-853c-7c32631151fe
	else
	  search --no-floppy --fs-uuid --set=root ea0bc0d3-8633-4596-853c-7c32631151fe
	fi
	linux /boot/vmlinuz-3.2.0-4-686-pae root=UUID=ea0bc0d3-8633-4596-853c-7c32631151fe ro quiet
submenu 'Options avancées pour Debian GNU/Linux (7.4) (sur /dev/sdb4)' $menuentry_id_option 'osprober-gnulinux-advanced-ea0bc0d3-8633-4596-853c-7c32631151fe' {
	menuentry 'Debian GNU/Linux, avec Linux 3.2.0-4-686-pae (sur /dev/sdb4)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-3.2.0-4-686-pae--ea0bc0d3-8633-4596-853c-7c32631151fe' {
		insmod part_msdos
		insmod ext2
		else
		fi
	menuentry 'Debian GNU/Linux, avec Linux 3.2.0-4-686-pae (mode de dépannage) (sur /dev/sdb4)' --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-3.2.0-4-686-pae-root=UUID=ea0bc0d3-8633-4596-853c-7c32631151fe ro single-ea0bc0d3-8633-4596-853c-7c32631151fe' {
		insmod part_msdos
		insmod ext2
		else
		fi
		linux /boot/vmlinuz-3.2.0-4-686-pae root=UUID=ea0bc0d3-8633-4596-853c-7c32631151fe ro single
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sdb1/etc/fstab: ================================
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sdb1 during installation
UUID=ed167aa2-53c2-43d2-a198-3239c5577285 /               ext4    errors=remount-ro 0       1
# /home was on /dev/sdb4 during installation
UUID=ea0bc0d3-8633-4596-853c-7c32631151fe /home           ext4    defaults        0       2
# /windows was on /dev/sdb3 during installation
UUID=3879-C506  /windows        vfat    utf8            0       0
# swap was on /dev/sda8 during installation
UUID=fd3bd207-8b42-49f5-8512-0a86dcb7bc1b none            swap    sw              0       0
# swap was on /dev/sdb5 during installation
UUID=83a5eac0-e219-4540-a616-271871ff7493 none            swap    sw              0       0
/dev/sr0        /media/cdrom0   udf,iso9660 user,noauto     0       0
=================== sdb1: Location of files loaded by Grub: ====================
           GiB - GB             File                                 Fragment(s)
               =                boot/grub/grub.cfg                             1
               =                boot/initrd.img-3.16.0-4-686-pae               2
               =                boot/vmlinuz-3.16.0-4-686-pae                  1
               =                vmlinuz                                        1
=========================== sdb4/boot/grub/grub.cfg: ===========================
  load_env
fi
set default="0"
  set boot_once=true
fi
  fi
  insmod vbe
  insmod vga
  insmod video_bochs
  insmod video_cirrus
insmod part_msdos
insmod ext2
set root='(hd1,msdos4)'
if loadfont /usr/share/grub/unicode.pf2 ; then
  set gfxmode=640x480
  load_video
  insmod gfxterm
  insmod part_msdos
  insmod ext2
  set locale_dir=($root)/boot/grub/locale
  set lang=fr_FR
  insmod gettext
fi
set timeout=10
insmod part_msdos
insmod ext2
insmod png
if background_image /usr/share/images/desktop-base/joy-grub.png; then
  set color_normal=white/black
  set color_highlight=black/white
else
fi
menuentry 'Debian GNU/Linux, avec Linux 3.2.0-4-686-pae' --class debian --class gnu-linux --class gnu --class os {
	load_video
	insmod gzio
	insmod part_msdos
	insmod ext2
	echo	'Chargement de Linux 3.2.0-4-686-pae ...'
	echo	'Chargement du disque mémoire initial ...'
menuentry 'Debian GNU/Linux, avec Linux 3.2.0-4-686-pae (mode de dépannage)' --class debian --class gnu-linux --class gnu --class os {
	load_video
	insmod gzio
	insmod part_msdos
	insmod ext2
menuentry "Windows 7 (loader) (on /dev/sda1)" --class windows --class os {
	insmod part_msdos
	insmod ntfs
	set root='(hd0,msdos1)'
	chainloader +1
menuentry "Windows 7 (loader) (on /dev/sda2)" --class windows --class os {
	insmod part_msdos
	insmod ntfs
	set root='(hd0,msdos2)'
	chainloader +1
menuentry "Debian GNU/Linux, avec Linux 3.2.0-4-686-pae (on /dev/sda6)" --class gnu-linux --class gnu --class os {
	insmod part_msdos
	insmod ext2
	set root='(hd0,msdos6)'
menuentry "Debian GNU/Linux, avec Linux 3.2.0-4-686-pae (mode de dépannage) (on /dev/sda6)" --class gnu-linux --class gnu --class os {
	insmod part_msdos
	insmod ext2
menuentry "Ubuntu (on /dev/sdb1)" --class gnu-linux --class gnu --class os {
	insmod part_msdos
	insmod ext2
	set root='(hd1,msdos1)'
	search --no-floppy --fs-uuid --set=root ad4df15f-a440-41d2-9946-bf5636e8e60f
	linux /boot/vmlinuz-3.11.0-14-generic root=UUID=ad4df15f-a440-41d2-9946-bf5636e8e60f ro quiet splash $vt_handoff
	initrd /boot/initrd.img-3.11.0-14-generic
menuentry "Ubuntu, avec Linux 3.11.0-14-generic (on /dev/sdb1)" --class gnu-linux --class gnu --class os {
	insmod part_msdos
	insmod ext2
menuentry "Ubuntu, avec Linux 3.11.0-14-generic (mode de dépannage) (on /dev/sdb1)" --class gnu-linux --class gnu --class os {
	insmod part_msdos
	insmod ext2
	linux /boot/vmlinuz-3.11.0-14-generic root=UUID=ad4df15f-a440-41d2-9946-bf5636e8e60f ro recovery nomodeset
menuentry "Ubuntu, avec Linux 3.11.0-12-generic (on /dev/sdb1)" --class gnu-linux --class gnu --class os {
	insmod part_msdos
	insmod ext2
	linux /boot/vmlinuz-3.11.0-12-generic root=UUID=ad4df15f-a440-41d2-9946-bf5636e8e60f ro quiet splash $vt_handoff
	initrd /boot/initrd.img-3.11.0-12-generic
menuentry "Ubuntu, avec Linux 3.11.0-12-generic (mode de dépannage) (on /dev/sdb1)" --class gnu-linux --class gnu --class os {
	insmod part_msdos
	insmod ext2
	linux /boot/vmlinuz-3.11.0-12-generic root=UUID=ad4df15f-a440-41d2-9946-bf5636e8e60f ro recovery nomodeset
if [ -f  $prefix/custom.cfg ]; then
fi
=============================== sdb4/etc/fstab: ================================
# / was on /dev/sdb4 during installation
UUID=ea0bc0d3-8633-4596-853c-7c32631151fe /               ext4    errors=remount-ro 0       1
# /home was on /dev/sdb6 during installation
UUID=faff3791-2e20-4220-b773-07e2cc723489 /home           ext4    defaults        0       2
# swap was on /dev/sda7 during installation
UUID=49200714-3495-4456-a502-610a1a08c2a8 none            swap    sw              0       0
UUID=fa27ed45-e646-447e-851d-5010312c60b9 none            swap    sw              0       0
/dev/sdb1       /media/usb0     auto    rw,user,noauto  0       0
/dev/sdb2       /media/usb1     auto    rw,user,noauto  0       0
/dev/sdb3       /media/usb2     auto    rw,user,noauto  0       0
/dev/sdb4       /media/usb3     auto    rw,user,noauto  0       0
/dev/sdb5       /media/usb4     auto    rw,user,noauto  0       0
/dev/sdb6       /media/usb5     auto    rw,user,noauto  0       0
/dev/sdc1       /media/usb6     auto    rw,user,noauto  0       0
=================== sdb4: Location of files loaded by Grub: ====================
               =                boot/grub/core.img                             1
               =                boot/initrd.img-3.2.0-4-686-pae                2
               =                boot/vmlinuz-3.2.0-4-686-pae                   1
               =                initrd.img                                     2
               =                vmlinuz                                        1
=============================== StdErr Messages: ===============================
xz : (stdin): Les données compressées sont corrompues
awk: cmd. line:36: Math support is not compiled in
