Voila mon soucis. Apres avoir redemarrer mon linux (debian etch), je me suis apercue que le systeme n arrivait plus a monter un de mes disques. Ce qui est tres facheux ccar il contient pas mal d image disque que j utilise dans le cadre de mon travail…
il s agit de hdf1
bref… voici mon fstab :
/etc/fstab: static file system information.
proc /proc proc defaults 0 0
/dev/hda1 / reiserfs notail 0 1
/dev/hda6 /home reiserfs defaults 0 2
/dev/hda5 none swap sw 0 0
/dev/hdb /media/cdrom0 udf,iso9660 user,noauto 0 0
/dev/fd0 /media/floppy0 auto rw,user,noauto 0 0
/dev/hdf1 /mnt/hdd80Go ext3 defaults 0 2
/dev/hdg5 /mnt/hdd160Go ext3 defaults 0 2
quand je fais un fdisk -l /dev/hdf (ou fdisk -l /dev/hdf1) je n’obtient aucune reponse (alors que je devrais obtenir la table de partition !!)
quant au “dmesg | tail” , le voici :
[ 967.242894] end_request: I/O error, dev hdf, sector 63
[ 967.242894] end_request: I/O error, dev hdf, sector 65
[ 967.242894] end_request: I/O error, dev hdf, sector 67
[ 967.242894] end_request: I/O error, dev hdf, sector 69
[ 967.242894] end_request: I/O error, dev hdf, sector 71
[ 967.242894] end_request: I/O error, dev hdf, sector 73
[ 967.242894] end_request: I/O error, dev hdf, sector 75
[ 967.242894] end_request: I/O error, dev hdf, sector 77
[ 967.242894] end_request: I/O error, dev hdf, sector 79
[ 967.242894] end_request: I/O error, dev hdf, sector 81
[ 967.242894] end_request: I/O error, dev hdf, sector 83
[ 967.242894] end_request: I/O error, dev hdf, sector 85
[ 967.242894] end_request: I/O error, dev hdf, sector 87
[ 967.242894] end_request: I/O error, dev hdf, sector 89
[ 967.242894] end_request: I/O error, dev hdf, sector 91
[ 967.242894] end_request: I/O error, dev hdf, sector 93
[ 967.242894] hdf: wcache flush failed!
j’ai aussi essaye ca, en vain :
dumpe2fs /dev/hdf1
dumpe2fs 1.41.3 (12-Oct-2008)
dumpe2fs: Attempt to read block from filesystem resulted in short read lors de la tentative d’ouverture de /dev/hdf1
Impossible de trouver un superbloc de système de fichiers valide
alors, c’est grave docteur ?
COrdialement
