Disque stat2 en 16 bits ?
Hello
Je ne sais pas pourquoi et peut être est ce voulu que sa soie en 16 et pas en 32 :smt017
#  hdparm -c /dev/sda
/dev/sda:
 IO_support   =  0 (default 16-bit)
Tantative de correction avec :
hdparm -c 1 /dev/sda
/dev/sda:
 setting 32-bit IO_support flag to 1
 HDIO_SET_32BIT failed: Invalid argument
:smt089
bon le débit semble correct bien que sa me paraisse un peux bizzard.
Mai le cache est de 16MB donc sa ne correspond pas aparament !
 hdparm -Tt /dev/sda
/dev/sda:
 Timing cached reads:   1162 MB in  2.00 seconds = 580.31 MB/sec
 Timing buffered disk reads:  204 MB in  3.02 seconds =  67.56 MB/sec
information supplémentaires:
hdparm -I /dev/sda
/dev/sda:
ATA device, with non-removable media
        Model Number:       Hitachi HDT725032VLA360
        Serial Number:      VFH200R2DUTRUT
        Firmware Revision:  V54OA7EA
Standards:
        Used: ATA/ATAPI-7 T13 1532D revision 1
        Supported: 7 6 5 4
Configuration:
        Logical         max     current
        cylinders       16383   16383
        heads           16      16
        sectors/track   63      63
        CHS current addressable sectors:   16514064
        LBA    user addressable sectors:  268435455
        LBA48  user addressable sectors:  625142448
        device size with M = 1024*1024:      305245 MBytes
        device size with M = 1000*1000:      320072 MBytes (320 GB)
Capabilities:
        LBA, IORDY(can be disabled)
        Queue depth: 32
        Standby timer values: spec'd by Standard, no device specific minimum
        R/W multiple sector transfer: Max = 16  Current = 1
        Advanced power management level: unknown setting (0x0000)
        Recommended acoustic management value: 128, current value: 254
        DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
             Cycle time: min=120ns recommended=120ns
        PIO: pio0 pio1 pio2 pio3 pio4
             Cycle time: no flow control=120ns  IORDY flow control=120ns
Commands/features:
        Enabled Supported:
           *    SMART feature set
                Security Mode feature set
           *    Power Management feature set
           *    Write cache
           *    Look-ahead
           *    Host Protected Area feature set
           *    WRITE_BUFFER command
           *    READ_BUFFER command
           *    DOWNLOAD_MICROCODE
                Advanced Power Management feature set
                Power-Up In Standby feature set
                SET_FEATURES required to spinup after power up
                Address Offset Reserved Area Boot
                SET_MAX security extension
                Automatic Acoustic Management feature set
           *    48-bit Address feature set
           *    Device Configuration Overlay feature set
           *    Mandatory FLUSH_CACHE
           *    FLUSH_CACHE_EXT
           *    SMART error logging
           *    SMART self-test
                Media Card Pass-Through
           *    General Purpose Logging feature set
           *    WRITE_{DMA|MULTIPLE}_FUA_EXT
           *    64-bit World wide name
           *    URG for READ_STREAM[_DMA]_EXT
           *    URG for WRITE_STREAM[_DMA]_EXT
           *    Segmented DOWNLOAD_MICROCODE
           *    SATA-I signaling speed (1.5Gb/s)
           *    SATA-II signaling speed (3.0Gb/s)
           *    Native Command Queueing (NCQ)
           *    Host-initiated interface power management
           *    Phy event counters
                Non-Zero buffer offsets in DMA Setup FIS
                DMA Setup Auto-Activate optimization
                Device-initiated interface power management
                In-order data delivery
           *    Software settings preservation
           *    SMART Command Transport (SCT) feature set
           *    SCT Long Sector Access (AC1)
           *    SCT LBA Segment Access (AC2)
           *    SCT Error Recovery Control (AC3)
           *    SCT Features Control (AC4)
           *    SCT Data Tables (AC5)
Security:
        Master password revision code = 65534
                supported
        not     enabled
        not     locked
        not     frozen
        not     expired: security count
        not     supported: enhanced erase
        128min for SECURITY ERASE UNIT.
Checksum: correct
c’est possible ou pas le 32 bits ou pas ? car la c’est détecter en scsi a la place du sata , en supposant que cela soie normal.
Je ne pense pas que cela justifie les16 ?
Une idée
C’est pareil pour mes deux SATA chez moi, hdparm est fait pour des disques PATA.
Le SATA et le SCSI utilisent la même terminologie (je ne sais pas si c’est le bon mot) à savoir /dev/sdX.
Et tu as les même performance ?
Avec le nemchmarck ci dessus ?
Oui j’ai les mêmes performances.
Ok mai ne penses-tu pas que on aurais de miellieur performance en 32 ?
Merci pour ta réponse :slightly_smiling:
Ben 67Mo pour du SATA c’est très bien !! Après regarde du côté de Sdparm mais je ne peux pas t’en dire plus à ce sujet.
