Depuis la mise a jour de wheezy hier au soir lorsque je connecte mon
disque dur usb avec deux partitions je ne vois que la premiere partition sur le bureau.
voici le kern.log
May 8 19:13:03 MultiMedia kernel: [ 528.852060] usb 1-6: new high speed USB device using ehci_hcd and address 4
May 8 19:13:03 MultiMedia kernel: [ 528.985473] usb 1-6: New USB device found, idVendor=1058, idProduct=0704
May 8 19:13:03 MultiMedia kernel: [ 528.985482] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
May 8 19:13:03 MultiMedia kernel: [ 528.985488] usb 1-6: Product: External HDD
May 8 19:13:03 MultiMedia kernel: [ 528.985493] usb 1-6: Manufacturer: Western Digital
May 8 19:13:03 MultiMedia kernel: [ 528.985497] usb 1-6: SerialNumber: 57442D575845593038434136343531
May 8 19:13:03 MultiMedia kernel: [ 528.986552] usb-storage 1-6:1.0: Quirks match for vid 1058 pid 0704: 8000
May 8 19:13:03 MultiMedia kernel: [ 528.986602] scsi3 : usb-storage 1-6:1.0
May 8 19:13:04 MultiMedia kernel: [ 529.984841] scsi 3:0:0:0: Direct-Access WD 2500BEV External 1.75 PQ: 0 ANSI: 4
May 8 19:13:04 MultiMedia kernel: [ 529.987515] sd 3:0:0:0: Attached scsi generic sg4 type 0
May 8 19:13:04 MultiMedia kernel: [ 529.987714] sd 3:0:0:0: [sdd] 488397168 512-byte logical blocks: (250 GB/232 GiB)
May 8 19:13:04 MultiMedia kernel: [ 529.988568] sd 3:0:0:0: [sdd] Write Protect is off
May 8 19:13:04 MultiMedia kernel: [ 529.988577] sd 3:0:0:0: [sdd] Mode Sense: 23 00 00 00
May 8 19:13:04 MultiMedia kernel: [ 529.989575] sd 3:0:0:0: [sdd] No Caching mode page present
May 8 19:13:04 MultiMedia kernel: [ 529.989583] sd 3:0:0:0: [sdd] Assuming drive cache: write through
May 8 19:13:04 MultiMedia kernel: [ 529.992582] sd 3:0:0:0: [sdd] No Caching mode page present
May 8 19:13:04 MultiMedia kernel: [ 529.992591] sd 3:0:0:0: [sdd] Assuming drive cache: write through
May 8 19:13:04 MultiMedia kernel: [ 530.041616] sdd: sdd1 sdd2
May 8 19:13:04 MultiMedia kernel: [ 530.044518] sd 3:0:0:0: [sdd] No Caching mode page present
May 8 19:13:04 MultiMedia kernel: [ 530.044527] sd 3:0:0:0: [sdd] Assuming drive cache: write through
May 8 19:13:04 MultiMedia kernel: [ 530.044534] sd 3:0:0:0: [sdd] Attached SCSI disk
Merci pour votre aide
Segusiaves
