Dist-upgrade lenny vers squeeze interrompu
Je suis occupé à faire un dist-upgrade de Lenny à Squeeze et malheureusement le processus vient de se terminer sur un message d’erreur:
Errors were encountered while processing: /var/cache/apt/archives/udev_157-1_i386.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
et quand je reprend la commande, j’obtiens ceci:
fantasio:/home/gv# apt-get dist-upgrade Reading package lists... Done Building dependency tree Reading state information... Done You might want to run `apt-get -f install' to correct these. The following packages have unmet dependencies: amarok: Depends: amarok-utils (= 2.3.0-2) but it is not installed Depends: phonon-backend-xine but it is not installed or phonon-backend Depends: kdebase-runtime (>= 4:4.3.0) but it is not installed Depends: kdelibs5 (>= 4:4.3.4) but it is not installed Depends: libgpod4-nogtk (>= 0.7.0) but it is not installed or libgpod4 (>= 0.7.0) but it is not installed Depends: liblastfm0 (>= 0.4.0~git20090710) but it is not installed Depends: libloudmouth1-0 (>= 1.1.4-2) but it is not installed Depends: libmtp8 (>= 0.3.1) but it is not installed Depends: libtag-extras1 (>= 1.0.1) but it is not installed Depends: libtag1c2a (>= 1.6-2~) but 1.5-3 is installed Depends: phonon but it is not installed Depends: libqtscript4-core but it is not installed Depends: libqtscript4-gui but it is not installed Depends: libqtscript4-network but it is not installed Depends: libqtscript4-xml but it is not installed Depends: libqtscript4-sql but it is not installed Depends: libqtscript4-uitools but it is not installed Recommends: kdemultimedia-kio-plugins (>= 4:4.2.0) but 4:3.5.9-2 is installed consolekit: Recommends: libpam-ck-connector but it is not installed Breaks: udev (< 147) but 0.125-7+lenny3 is installed libqt4-webkit: Depends: libqt4-xmlpatterns (= 4:4.6.3-1) but it is not installed E: Unmet dependencies. Try using -f.
En pratique, avant tout reboot et tant que mon système fonctionne, que faire?
Merci d’avance,
G.
Suivre ses conseils :slightly_smiling:
De mémoire Cluxter avait expliqué dans un fil le passage vers une version supérieur problematique avec udev.
J’me rappel pas bien :blush:
Essayer
#aptitude -t testing install udev Puis le dist-upgrade
:question: :question: :question:
