Pour ne pas mourir idiot (et ne plus me taper la réinstallation des drivers nVidia à chaque noyau
) je veux passer à DKMS.
Mais…
- Quel paquet installer ?
apt-cache search dkms
batman-adv-dkms - DKMS Source for the batman-advanced kernel module
batmand-gateway-dkms - DKMS Source for the batmand-gateway kernel module
blcr-dkms - DKMS support for BLCR kernel module
dkms - Dynamic Kernel Module Support Framework
ipheth-dkms - USB tethering driver for the iPhone [DKMS driver source]
ndiswrapper-dkms - Source for the ndiswrapper Linux kernel module (DKMS)
openafs-modules-dkms - AFS distributed filesystem kernel module DKMS source
oss4-dkms - Open Sound System - DKMS module sources
tp-smapi-dkms - ThinkPad hardware/firmware access modules source - dkms version
fglrx-modules-dkms - dkms module source for the non-free AMD/ATI r6xx - r7xx display driver
nvidia-glx - NVIDIA binary Xorg driver
nvidia-kernel-dkms - NVIDIA binary kernel module DKMS source
nvidia-kernel-source - NVIDIA binary kernel module source
virtualbox-ose-dkms - x86 virtualization solution - kernel module sources for dkms
virtualbox-ose-guest-dkms - x86 virtualization solution - guest addition module source for dkms
virtualbox-ose - x86 virtualization solution - base binaries
open-vm-dkms - Source for VMware guest systems driver (DKMS)
Quels éventuels problèmes liés aux installations préalables (Méthode classique ou avec les run) ?
A-ton le choix quant aux drivers installés ?
Dans le désordre…
190.53 190.42 195.36.08 ( bad, recalled ) 195.36.15 195.36.24 185.18.36 185.18.31 185.18.29 185.18.14 180.60 180.51 180.44 71.86.13 71.86.11 71.86.09 71.86.06 96.43.16 96.43.14 96.43.13 96.43.11 173.14.25 173.14.22 173.14.20 173.14.18 173.14.12
Bref… Des infos de ceux qui on fait le “saut” !
