DLNA Impossibilité de voir mon serveur
J’ai un soucis sur la mise en place du DLNA sur mon serveur Linux.
Il m’est impossible de faire détecter mon serveur sur mes PC Windows, ainsi que sur ma télé ou mes consoles de jeux.
J’ai essayer MiniDLNA, MediaTomb, Serviio, et surement d’autres cela fait 3 jours que je tourne sans trouver d’où vient mon problème.
Je suis resté sur MiniDLNA, afin de pousser mes tests.
MiniDLNA est configurer il ce lance bien au démarrage, voici mon minidlna.conf :
[code]# port for HTTP (descriptions, SOAP, media transfer) traffic
port=49200
network_interface=eth0
set this to the directory you want scanned.
* if have multiple directories, you can have multiple media_dir= lines
* if you want to restrict a media_dir to a specific content type, you
can prepend the type, followed by a comma, to the directory:
+ “A” for audio (eg. media_dir=A,/home/jmaggard/Music)
+ “V” for video (eg. media_dir=V,/home/jmaggard/Videos)
+ “P” for images (eg. media_dir=P,/home/jmaggard/Pictures)
media_dir=V,/media/Xbmc/videos
media_dir=A,/media/Xbmc/musiques
media_dir=P,/media/Xbmc/photos
set this if you want to customize the name that shows up on your clients
friendly_name=Serveur Multimédia
set this if you would like to specify the directory where you want MiniDLNA to store its database and album art cache
db_dir=/tmp
set this if you would like to specify the directory where you want MiniDLNA to store its log file
log_dir=/var/log
this should be a list of file names to check for when searching for album art
note: names should be delimited with a forward slash ("/")
album_art_names=Cover.jpg/cover.jpg/AlbumArtSmall.jpg/albumartsmall.jpg/AlbumArt.jpg/albumart.jpg/Album.jpg/album.jpg/Folder.jpg/folder.jpg/Thumb.jpg/thumb.jpg
set this to no to disable inotify monitoring to automatically discover new files
note: the default is yes
inotify=yes
set this to yes to enable support for streaming .jpg and .mp3 files to a TiVo supporting HMO
enable_tivo=no
set this to strictly adhere to DLNA standards.
* This will allow server-side downscaling of very large JPEG images,
which may hurt JPEG serving performance on (at least) Sony DLNA products.
strict_dlna=no
default presentation url is http address on port 80
#presentation_url=http://www.mylan/index.php
notify interval in seconds. default is 895 seconds.
notify_interval=900
serial and model number the daemon will report to clients
in its XML description
serial=12345678
model_number=1[/code]
Mon parefeu n’est pas activé iptables -L me renvois :
[code]root@Arma-Serveur:~# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Chain ufw-after-forward (0 references)
Chain ufw-after-input (0 references)
Chain ufw-after-logging-forward (0 references)
Chain ufw-after-logging-input (0 references)
Chain ufw-after-logging-output (0 references)
Chain ufw-after-output (0 references)
Chain ufw-before-forward (0 references)
Chain ufw-before-input (0 references)
Chain ufw-before-logging-forward (0 references)
Chain ufw-before-logging-input (0 references)
Chain ufw-before-logging-output (0 references)
Chain ufw-before-output (0 references)
Chain ufw-reject-forward (0 references)
Chain ufw-reject-input (0 references)
Chain ufw-reject-output (0 references)
Chain ufw-track-input (0 references)
Chain ufw-track-output (0 references)
target prot opt source destination[/code]
UPnp Inspector lancé sur mon Serveur Linux voit mon serveur DNLA :
Lorsque je tape mon IP sur le port 49200 sur un navigateur depuis une machine Windows il me detecte bien mes fichiers :
Pour terminé UPnp Inspector sur une machine Windows voit mes serveurs DLNA Windows mais pas celui sous Linux :
Mes machines Windows on aussi un serveur DLNA, qui eux sont bien visibles entres eux, ainsi que sur ma télé, et consoles, par contre mon serveur Linux ne voit aucun autres serveur DNLA que le sien et n’est pas visibles n’on plus par toutes autres machines.
Il est parait isolé de mon réseau.
Je fini par préciser que mon serveur Linux est visible sur toutes mes autre machines via Samba, FTP, et autres, il y a juste le DLNA qui me pose problème.
Je m’en remet à vos compétences pour m’aider dans la résolution de ce problème.
Merci d’avance.
2/3 trucs à vérifier :
Multicast est bien activé sur les interfaces réseau concernées ?
Rien des les tables autres que filter ne semble poser problème ? ([mono]itpables -t nat -L[/mono] , [mono]iptables -t mangle -L[/mono])
Il n’y a pas de routeur entre les machines qui pourrait bloquer le multicast ?
Il n’y a pas non-plus de switch manageable/intelligent qui pourrait faire du “multicast isolation” ?
En dernier recours, tu dois pouvoir écouter ce qui passe sur le réseau au niveau du protocole SSDP avec tcpdump ou autre sniffer, je suppose.
AnonymousCoward
