Oui oui, j’ai mis la livebox en mode association.
[code]doms-debian:/home/doms# /etc/init.d/networking restart
Reconfiguring network interfaces…There is already a pid file /var/run/dhclient.ra0.pid with pid 1946
killed old client process, removed PID file
Internet Systems Consortium DHCP Client V3.1.1
Copyright 2004-2008 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
Listening on LPF/ra0/00:26:5a:7f:af:13
Sending on LPF/ra0/00:26:5a:7f:af:13
Sending on Socket/fallback
DHCPDISCOVER on ra0 to 255.255.255.255 port 67 interval 6
DHCPDISCOVER on ra0 to 255.255.255.255 port 67 interval 15
DHCPOFFER from 192.168.1.1
DHCPREQUEST on ra0 to 255.255.255.255 port 67
DHCPACK from 192.168.1.1
bound to 192.168.1.10 – renewal in 276275 seconds.
Stopping the Firestarter firewall…wlan0: error fetching interface information: Device not found
Starting the Firestarter firewall…wlan0: error fetching interface information: Device not found
failed!
run-parts: /etc/network/if-up.d/50firestarter exited with return code 2
done.
Reconfiguring network interfaces…Stopping the Firestarter firewall…wlan0: error fetching interface information: Device not found
failed!
run-parts: /etc/network/if-down.d/50firestarter exited with return code 2
There is already a pid file /var/run/dhclient.ra0.pid with pid 4006
DHCPRELEASE on ra0 to 192.168.1.1 port 67
Error for wireless request “Set Mode” (8B06) :
SET failed on device ra0 ; Network is down.
Error for wireless request “Set Encode” (8B2A) :
Error for wireless request “Set ESSID” (8B1A) :
DHCPDISCOVER on ra0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on ra0 to 255.255.255.255 port 67 interval 9
DHCPDISCOVER on ra0 to 255.255.255.255 port 67 interval 14
DHCPDISCOVER on ra0 to 255.255.255.255 port 67 interval 16
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
failed!
done.
iwlist ra0 scan : (je n’ai pas pu tout mettre)
Cell 06 - Address: 06:1D:19:70:B4:B2
Protocol:802.11b/g
ESSID:"SFR_WPA_01E6E"
Mode:Managed
Frequency:2.427 GHz (Channel 4)
Quality:23/100 Signal level:-81 dBm Noise level:-89 dBm
Encryption key:on
Bit Rates:54 Mb/s
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (2) : CCMP TKIP
Authentication Suites (1) : PSK
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : TKIP
IE: Unknown: DD2C0050F204104A00011010440001021057000100104700100000000E0E0000000000000000000900103C000101
Cell 07 - Address: 00:1D:6A:D5:E7:35
Protocol:802.11b/g
ESSID:"Livebox-D26D"
Mode:Managed
Frequency:2.437 GHz (Channel 6)
Quality:23/100 Signal level:-81 dBm Noise level:-85 dBm
Encryption key:on
Bit Rates:54 Mb/s
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (1) : TKIP
Cell 08 - Address: 00:1D:6A:5A:74:06
Protocol:802.11b/g/n
ESSID:"Livebox-eb6c"
Mode:Managed
Quality:7/100 Signal level:-87 dBm Noise level:-95 dBm
Encryption key:on
Bit Rates:54 Mb/s
IE: WPA Version 1
Group Cipher : TKIP
Group Cipher : TKIP
IE: Unknown: DD2C0050F204104A0001101044000102105700010010470010565AA94967C14C0EAA8FF349E6F59311103C000101
Cell 09 - Address: 00:16:41:0D:B5:05
Protocol:802.11b/g
ESSID:"Wanadoo_2d69"
Mode:Managed
Frequency:2.457 GHz (Channel 10)
Quality:52/100 Signal level:-69 dBm Noise level:-92 dBm
Encryption key:on
Bit Rates:54 Mb/s
Cell 10 - Address: 00:1A:6B:C0:FC:BC
Protocol:802.11b/g
ESSID:"Livebox-4684"
Mode:Managed
Quality:0/100 Signal level:-95 dBm Noise level:-90 dBm
Encryption key:on
Bit Rates:54 Mb/s
Cell 11 - Address: 00:17:33:F2:35:25
Protocol:802.11b/g
ESSID:"NEUF_3524"
Mode:Managed
Frequency:2.462 GHz (Channel 11)
Quality:100/100 Signal level:-43 dBm Noise level:-92 dBm
Encryption key:on
Bit Rates:54 Mb/s
IE: WPA Version 1
Group Cipher : TKIP
Cell 12 - Address: 00:17:33:F2:35:2C
Protocol:802.11b/g
ESSID:"Neuf WiFi"
Mode:Managed
Encryption key:off
Bit Rates:54 Mb/s
Cell 13 - Address: 00:03:C9:AC:83:C2
Protocol:802.11b/g
ESSID:"ALICE-D9F34F"
Mode:Managed
Quality:0/100 Signal level:-95 dBm Noise level:-100 dBm
Encryption key:on
Bit Rates:54 Mb/s
oms-debian:/home/doms# iwconfig
lo no wireless extensions.
ra0 Ralink STA ESSID:“11n-AP” Nickname:"RT2870STA"
Mode:Auto Frequency=2.412 GHz Access Point: Not-Associated
Bit Rate:1 Mb/s
RTS thr:off Fragment thr:off
Encryption key:off
Link Quality=66/100 Signal level:-69 dBm Noise level:-91 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
doms-debian:/home/doms# ifconfig
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:560 (560.0 B) TX bytes:560 (560.0 B)
ra0 Link encap:Ethernet HWaddr 00:26:5a:7f:af:13
adr inet6: fe80::226:5aff:fe7f:af13/64 Scope:Lien
RX bytes:21653173 (20.6 MiB) TX bytes:2903897 (2.7 MiB)[/code]
