salut j’ai le résultat suivant avec ma lenny x86.
ca arrive souvent que les séquences soient mixé de la sorte??? même si je me trouve a mayotte ???
PING www.l.google.com (74.125.232.113) 56(84) bytes of data.
64 bytes from 74.125.232.113: icmp_seq=1 ttl=50 time=961 ms
64 bytes from 74.125.232.113: icmp_seq=3 ttl=49 time=1136 ms
64 bytes from 74.125.232.113: icmp_seq=2 ttl=50 time=685 ms
64 bytes from 74.125.232.113: icmp_seq=5 ttl=50 time=1382 ms
64 bytes from 74.125.232.113: icmp_seq=4 ttl=50 time=1540 ms
64 bytes from 74.125.232.113: icmp_seq=7 ttl=49 time=1130 ms
64 bytes from 74.125.232.113: icmp_seq=6 ttl=50 time=894 ms
64 bytes from 74.125.232.113: icmp_seq=8 ttl=50 time=630 ms
64 bytes from 74.125.232.113: icmp_seq=10 ttl=49 time=1262 ms
64 bytes from 74.125.232.113: icmp_seq=9 ttl=50 time=1098 ms
64 bytes from 74.125.232.113: icmp_seq=12 ttl=49 time=1817 ms
64 bytes from 74.125.232.113: icmp_seq=11 ttl=49 time=1392 ms
64 bytes from 74.125.232.113: icmp_seq=13 ttl=50 time=1297 ms
--- www.l.google.com ping statistics ---
13 packets transmitted, 13 received, 0% packet loss, time 17979ms
rtt min/avg/max/mdev = 630.197/1171.582/1817.585/319.782 ms, pipe 3
ou encore ceci… commencer par 4 c’est pas mal hein ???
PING www.l.google.com (74.125.230.81) 56(84) bytes of data.
64 bytes from 74.125.230.81: icmp_seq=4 ttl=52 time=3083 ms
64 bytes from 74.125.230.81: icmp_seq=1 ttl=52 time=2081 ms
64 bytes from 74.125.230.81: icmp_seq=2 ttl=52 time=1093 ms
64 bytes from 74.125.230.81: icmp_seq=3 ttl=52 time=1027 ms
64 bytes from 74.125.230.81: icmp_seq=5 ttl=52 time=946 ms
64 bytes from 74.125.230.81: icmp_seq=7 ttl=52 time=1198 ms
64 bytes from 74.125.230.81: icmp_seq=6 ttl=52 time=1325 ms
64 bytes from 74.125.230.81: icmp_seq=8 ttl=52 time=1116 ms
64 bytes from 74.125.230.81: icmp_seq=10 ttl=52 time=1299 ms
64 bytes from 74.125.230.81: icmp_seq=9 ttl=52 time=1036 ms
64 bytes from 74.125.230.81: icmp_seq=11 ttl=52 time=1414 ms
64 bytes from 74.125.230.81: icmp_seq=12 ttl=52 time=1000 ms
64 bytes from 74.125.230.81: icmp_seq=15 ttl=52 time=2518 ms
64 bytes from 74.125.230.81: icmp_seq=13 ttl=52 time=1937 ms
64 bytes from 74.125.230.81: icmp_seq=14 ttl=52 time=1545 ms
64 bytes from 74.125.230.81: icmp_seq=16 ttl=52 time=4045 ms
64 bytes from 74.125.230.81: icmp_seq=17 ttl=52 time=633 ms
^C64 bytes from 74.125.230.81: icmp_seq=18 ttl=52 time=622 ms
en ping sur une machine local j’ai ceci…
#~/>ping 172.16.2.2
PING 172.16.2.2 (172.16.2.2) 56(84) bytes of data.
64 bytes from 172.16.2.2: icmp_seq=1 ttl=128 time=0.420 ms
64 bytes from 172.16.2.2: icmp_seq=2 ttl=128 time=0.209 ms
64 bytes from 172.16.2.2: icmp_seq=3 ttl=128 time=0.211 ms
64 bytes from 172.16.2.2: icmp_seq=4 ttl=128 time=0.198 ms
64 bytes from 172.16.2.2: icmp_seq=5 ttl=128 time=0.214 ms
64 bytes from 172.16.2.2: icmp_seq=6 ttl=128 time=0.219 ms
64 bytes from 172.16.2.2: icmp_seq=7 ttl=128 time=0.207 ms
64 bytes from 172.16.2.2: icmp_seq=8 ttl=128 time=0.205 ms
64 bytes from 172.16.2.2: icmp_seq=9 ttl=128 time=0.211 ms
64 bytes from 172.16.2.2: icmp_seq=10 ttl=128 time=0.203 ms
^C
--- 172.16.2.2 ping statistics ---
10 packets transmitted, 10 received, 0% packet loss, time 8999ms
rtt min/avg/max/mdev = 0.198/0.229/0.420/0.066 ms
de loin ça ressemble à “dude in the middle” non ?
