désolé de ne répondre que maintenant,j’ai été pas mal occupé.
voila les logs de ma dernière tentative:
mail.log:
Jan 25 15:58:34 intranet postfix/submission/smtpd[4509]: connect from *
Jan 25 15:58:34 intranet postfix/submission/smtpd[4509]: AF6DD3FAAF: client=*, sasl_method=PLAIN, sasl_username=*
Jan 25 15:58:34 intranet postfix/cleanup[4513]: AF6DD3FAAF: message-id=<201401251558.33574.*>
Jan 25 15:59:59 intranet postfix/qmgr[5459]: AF6DD3FAAF: from=<*>, size=8891125, nrcpt=1 (queue active)
Jan 25 15:59:59 intranet clamsmtpd: 100062: accepted connection from: 127.0.0.1
Jan 25 15:59:59 intranet postfix/smtpd[4516]: connect from localhost[127.0.0.1]
Jan 25 15:59:59 intranet postfix/smtpd[4516]: 2ED883FB29: client=localhost[127.0.0.1], orig_queue_id=AF6DD3FAAF, orig_client=*
Jan 25 16:00:00 intranet postfix/cleanup[4513]: 2ED883FB29: message-id=<201401251558.33574.*>
Jan 25 16:00:00 intranet postfix/qmgr[5459]: 2ED883FB29: from=<*>, size=8891358, nrcpt=1 (queue active)
Jan 25 16:00:00 intranet postfix/smtp[4514]: AF6DD3FAAF: to=<*>, relay=127.0.0.1[127.0.0.1]:10025, delay=86, delays=84/0.01/0.05/1.1, dsn=2.0.0, status=sent (250 2.0.0 Ok: queued as 2ED883FB29)
Jan 25 16:00:00 intranet clamsmtpd: 100062: from=*, to=*, status=CLEAN
Jan 25 16:00:00 intranet postfix/qmgr[5459]: AF6DD3FAAF: removed
Jan 25 16:00:00 intranet postfix/smtpd[4516]: disconnect from localhost[127.0.0.1]
Jan 25 16:00:04 intranet postfix/submission/smtpd[4509]: disconnect from *
Jan 25 16:01:50 intranet postfix/smtp[4519]: 2ED883FB29: to=<*>, relay=gmail-smtp-in.l.google.com[173.194.78.27]:25, delay=111, delays=1.1/0.01/0.46/109, dsn=2.0.0, status=sent (250 2.0.0 OK 1390662109 iy5si3290991wic.65 - gsmtp)
Jan 25 16:01:50 intranet postfix/qmgr[5459]: 2ED883FB29: removed
Jan 25 16:03:24 intranet postfix/anvil[4511]: statistics: max connection rate 1/60s for (submission:82.225.48.153) at Jan 25 15:58:34
Jan 25 16:03:24 intranet postfix/anvil[4511]: statistics: max connection count 1 for (submission:82.225.48.153) at Jan 25 15:58:34
Jan 25 16:03:24 intranet postfix/anvil[4511]: statistics: max cache size 1 at Jan 25 15:58:34
dovecot.log :
2014-01-25 15:58:13 imap-login: Info: Login: user=<*>, method=PLAIN, rip=*, lip=192.168.1.1, mpid=4508, TLS, session=<eQgrtMzw+wBS4TCZ>
2014-01-25 16:03:19 imap(*): Info: Disconnected: Logged out in=8892176 out=10125
les fichiers mail.err et mail.warn sont vides.
le mail.info contient la méme chose que mail.log
sur ce test , j’ai utilisé kmail.
l’envoi du mail s’est bien passé, puis kmail pert la connexion, ainsi que putty.
c’est ici que thunderbird plante avec “impossible de copier dans le dossier envoyé”, mais kmail attend que la connexion revienne avant d’effectuer avec succes la copie dans le dossier Sent.
quand putty plante (network error:software caused connexion abort) , il se passe environ une minute avant que je puis me reconnecter, si j’essaye avant j’ai “network error:connexion timed out”
log dovecot d’un test effectué juste aprés,avec toutes les options de debug activées,même resultat:
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x10, ret=1: before/accept initialization *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2001, ret=1: before/accept initialization *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2002, ret=-1: unknown state *
2014-01-25 16:17:00 auth: Debug: Loading modules from directory: /usr/lib/dovecot/modules/auth
2014-01-25 16:17:00 auth: Debug: auth client connected (pid=5228)
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 read client hello A *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write server hello A *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write certificate A *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write key exchange A *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write server done A *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 flush data *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2002, ret=-1: SSLv3 read client certificate A *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 read client key exchange A *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 read finished A *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write session ticket A *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write change cipher spec A *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2001, ret=1: SSLv3 write finished A *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x20, ret=1: SSL negotiation finished successfully *
2014-01-25 16:17:00 imap-login: Warning: SSL: where=0x2002, ret=1: SSL negotiation finished successfully *
2014-01-25 16:17:00 auth: Debug: client in: AUTH 1 PLAIN service=imap secured session=* lip=192.168.1.1 rip=* lport=993 rport=37467 resp=*
2014-01-25 16:17:00 auth-worker(5231): Debug: Loading modules from directory: /usr/lib/dovecot/modules/auth
2014-01-25 16:17:00 auth-worker(5231): Debug: pam(*,*): lookup service=dovecot
2014-01-25 16:17:00 auth-worker(5231): Debug: pam(*,*): #1/1 style=1 msg=Password:
2014-01-25 16:17:00 auth: Debug: client out: OK 1 user=*
2014-01-25 16:17:00 auth: Debug: master in: REQUEST 1364459521 5228 1 4d8b687c0c59d9941c8d1f9955fd7bca
2014-01-25 16:17:00 auth: Debug: passwd(*,*,<OD1W98zwWwBS4TCZ>): lookup
2014-01-25 16:17:00 auth: Debug: master out: USER 1364459521 * system_groups_user=* uid=1000 gid=1000 home=/home/*
2014-01-25 16:17:00 imap-login: Info: Login: user=<*>, method=PLAIN, rip=*, lip=192.168.1.1, mpid=5232, TLS, session=<*>
2014-01-25 16:17:00 imap(*): Debug: Effective uid=1000, gid=1000, home=/home/*
2014-01-25 16:17:00 imap(*): Debug: Namespace inbox: type=private, prefix=, sep=, inbox=yes, hidden=no, list=yes, subscriptions=yes location=~/Maildir
2014-01-25 16:17:00 imap(*): Debug: mdbox autodetect: stat(/home/*/Maildir/storage) failed: No such file or directory
2014-01-25 16:17:00 imap(*): Debug: sdbox autodetect: stat(/home/*/Maildir/mailboxes) failed: No such file or directory
2014-01-25 16:17:00 imap(*): Debug: maildir++: root=/home/*/Maildir, index=, control=, inbox=/home/*/Maildir, alt=
2014-01-25 16:17:20 auth: Debug: auth client connected (pid=0)
2014-01-25 16:17:20 auth: Debug: client in: AUTH 1 PLAIN service=smtp nologin lip=192.168.1.1 rip=* secured resp=*
2014-01-25 16:17:20 auth-worker(5231): Debug: pam(*,*): lookup service=dovecot
2014-01-25 16:17:20 auth-worker(5231): Debug: pam(*,*): #1/1 style=1 msg=Password:
2014-01-25 16:17:20 auth: Debug: client out: OK 1 user=*
des idées?
