Bonjour j’ai installer debian testing et quand je tente d’installer des paquet l’installation ce fait mais finit par
Processing triggers for libc-bin (2.24-11) ...
dpkg: cycle found while processing triggers:
chain of packages whose triggers are or may be responsible:
libc-bin -> libc-bin
packages' pending triggers which are or may be unresolvable:
libc-bin: ldconfig
dpkg: error processing package libc-bin (--configure):
triggers looping, abandoned
Errors were encountered while processing:
libc-bin
J’ai tenter de faire un
sudo apt-get -f install
mais même résultat
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
apt-listchanges: Can't set locale; make sure $LC_* and $LANG are correct!
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "",
LC_ALL = (unset),
LC_TIME = "ca_FR.UTF-8",
LC_MONETARY = "ca_FR.UTF-8",
LC_COLLATE = "ca_FR.UTF-8",
LC_MEASUREMENT = "ca_FR.UTF-8",
LC_NUMERIC = "ca_FR.UTF-8",
LANG = "fr_FR.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
Setting up libc-bin (2.24-11) ...
libc-bin: ldconfig
libc-bin
ou encore
sudo dpkg --configure libc-bin
libc-bin: ldconfig
libc-bin
Je peut caché le problème avec
sudo dpkg --configure --no-triggers libc-bin
Mais évidement il reviens si je fait un
sudo dpkg --configure --triggers libc-bin
J’ai aussi tenté de désinstaller et réinstaller libc-bin
Mais toujours la même erreur vous avez une idée?
Ce bug est présent depuis quelque jour mais jusque à maintenant il n’avais aucune incidence mais la j’ai installé qtcreator et quand je le lance j’ai
qtcreator
qtcreator: relocation error: /usr/bin/../lib/x86_64-linux-gnu/qtcreator/../libm.so.6: symbol __get_cpu_features, version GLIBC_PRIVATE not defined in file libc.so.6 with link time reference
