Ok, donc encore merci d’être là
Voilà la suite :
# dpkg -i --force-architecture --force-depends dpkg_1.13.26_i386.deb
dpkg - warning, overriding problem because --force enabled:
package architecture (i386) does not match system ()
dpkg: regarding dpkg_1.13.26_i386.deb containing dpkg, pre-dependency problem:
dpkg pre-depends on libc6 (>= 2.3.6-6)
dpkg: warning - ignoring pre-dependency problem !
dpkg pre-depends on coreutils (>= 5.93-1)
(Reading database ... 0 files and directories currently installed.)
Unpacking dpkg (from dpkg_1.13.26_i386.deb) ...
dpkg: dpkg: dependency problems, but configuring anyway as you request:
dpkg depends on libc6 (>= 2.3.6-6); however:
Package libc6 is not installed.
dpkg depends on coreutils (>= 5.93-1); however:
Package coreutils is not installed.
Setting up dpkg (1.13.26) ...
Après ça, le apt-get -f install me demande toujours de remove plein de choses, dont DPKG.
Si j’essaye d’installer autre chose, par exemple ncftp, j’ai toujours et encore le problème avec la libc6. Je pense vraiment que c’est elle qui est bousillée :
# apt-get install ncftp
Reading package lists... Done
Building dependency tree... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies.
dpkg: PreDepends: libc6 (>= 2.11) but 2.3.6.ds1-13etch5 is to be installed
PreDepends: xz-utils but it is not installable
locales: Depends: glibc-2.11-1 but it is not installable
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Dois-je tenter quand-même le apt-get -f install, quitte à devoir resintaller dpks à la main ensuite ? Mais il va me supprimer openssh, et je suis connecté en SSH…
Ou dois-je trouver un moyen de rétablir ma libc6 ?
EDIT
J’ai tenter de forcer l’installation de libc6 :
# apt-get install --force-yes libc6
dpkg: PreDepends: libc6 (>= 2.11) but 2.3.6.ds1-13etch10+b1 is to be installed
Je sèche…
