Je cherche à comprendre la sortie que donne la commande
Je sais que ça liste tous les paquets mais je souhaite savoir ce que signifient les 2 petites lettres avant le nom des paquets.
J’ai des ii et rc iU et iF.
Exemple concret :
dpkg -l | grep sql
ii libaprutil1-dbd-sqlite3:amd64 1.5.4-1 amd64 Apache Portable Runtime Utility Library - SQLite3 Driver
ii libdbd-mysql-perl 4.028-2+b1 amd64 Perl5 database interface to the MySQL database
ii libmysqlclient-dev 5.7.7-rc-1debian7 amd64 MySQL development headers
ii libmysqlclient18:amd64 5.5.43-0+deb8u1 amd64 MySQL database client library
ii libmysqlclient20:amd64 5.7.7-rc-1debian7 amd64 MySQL shared client libraries
ii libmysqld-dev 5.7.7-rc-1debian7 amd64 MySQL embedded server library
ii libqt4-sql:amd64 4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1 amd64 Qt 4 SQL module
ii libqt4-sql-sqlite:amd64 4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1 amd64 Qt 4 SQLite 3 database driver
ii libsqlite3-0:amd64 3.8.7.1-1+deb8u1 amd64 SQLite 3 shared library
rc mysql-apt-config 0.3.5-1debian7 all Auto configuration for MySQL APT Repo.
ii mysql-client-5.5 5.5.43-0+deb8u1 amd64 MySQL database client binaries
ii mysql-common 5.7.7-rc-1debian7 amd64 MySQL configuration for client and server
ii mysql-community-source 5.7.7-rc-1debian7 amd64 MySQL Source
iU mysql-server 5.5.43-0+deb8u1 all MySQL database server (metapackage depending on the latest version)
iF mysql-server-5.5 5.5.43-0+deb8u1 amd64 MySQL database server binaries and system database setup
ii mysql-server-core-5.5 5.5.43-0+deb8u1 amd64 MySQL database server binaries
ii postgresql 9.4+165 all object-relational SQL database (supported version)
ii postgresql-9.1 9.1.16-0+deb7u2 amd64 object-relational SQL database, version 9.1 server
ii postgresql-9.4 9.4.3-0+deb8u1 amd64 object-relational SQL database, version 9.4 server
ii postgresql-client-9.1 9.1.16-0+deb7u2 amd64 front-end programs for PostgreSQL 9.1
ii postgresql-client-9.4 9.4.3-0+deb8u1 amd64 front-end programs for PostgreSQL 9.4
ii postgresql-client-common 165 all manager for multiple PostgreSQL client versions
ii postgresql-common 165 all PostgreSQL database-cluster manager
PS : je crois mieux comprendre pourquoi mon mysql-server m’emmerde pour ceux qui suivent mes posts.
