C’est certainement la raison de mes problèmes de compilation
lns-vlq-16-mar-82-255-31-186:/home/ricardod2# apt-get install dpkg
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
lns-vlq-16-mar-82-255-31-186:/home/ricardod2# dpkg --configure -a
Paramétrage de kernel-image-2.6.8-2-686 (2.6.8-12) ...
/boot/initrd.img-2.6.8-2-686 points to /boot/initrd.img-2.6.8-2-686 -- doing nothing at /var/lib/dpkg/info/kernel-image-2.6.8-2-686.postinst line 547.
/boot/vmlinuz-2.6.8-2-686 points to /boot/vmlinuz-2.6.8-2-686 -- doing nothing at /var/lib/dpkg/info/kernel-image-2.6.8-2-686.postinst line 547.
Searching for GRUB installation directory ... found: /boot/grub .
Testing for an existing GRUB menu.list file... found: /boot/grub/menu.lst .
Searching for splash image... none found, skipping...
Found kernel: /boot/vmlinuz
Je suis allé voir cette ligne dont il est question et voici une partie du fichier avec la ligne , tout en bas, en gras
[code]# This routine is responsible for setting up the symbolic links.
sub image_magic {
my $kimage = $[0]; # Nmae of the symbolic link
my $image_dest = $[1]; # The directory the links goes into
Well, in any case, if the destination (the symlink we are trying
to create) is a directory, we should do nothing, except throw a
diagnostic.
if (-d “$kimage” ) {
die (“Hmm. $kimage is a directory, which I did not expect. I am\n” .
“trying to create a symbolic link with that name linked to \n” .
"$image_dest . Since a directory exists here, my assumptions \n" .
“are way off, and I am aborting.\n” );
exit (3);
if ($move_image)
{ # Maybe $image_dest is in on dos, or something?
really_move_image($kimage, $image_dest);
return;
if (-l “$kimage”)
{ # There is a symbolic link
my $force_move = 0;
if ($no_symlink || $reverse_symlink)
{ # we do not want links, yet we have a symbolic link here!
warn "found a symbolic link in " . $image_dest . "$kimage \n" .
"even though no_symlink is defined\n" if $no_symlink;
"even though reverse_symlink is defined\n" if $reverse_symlink;
# make sure we change this state of affairs
$force_move = 1;
else
# OK. We found symlink, and we should have a symlink here.
my $vmlinuz_target = readlink "$kimage";
my $target = CanonicalizePath("$realimageloc" . "$kimage-$version");
if (!defined($vmlinuz_target))
{ # what, a dangling symlink?
warn "The link " . $image_dest . "$kimage is a dangling link\n";
$force_move = 1;
else
{ # Found where the link points to
my $cwd;
chomp ($cwd=`pwd`);
if ($vmlinuz_target !~ m|^/|o)
$vmlinuz_target = $cwd . "/" . $vmlinuz_target;
$vmlinuz_target =~ s|/+|/|o;
$vmlinuz_target = CanonicalizePath($vmlinuz_target);
if ("$vmlinuz_target" ne "$target")
if ($minimal_swap)
if (-l "$kimage.old")
my $old_target = readlink "$kimage.old";
if ($old_target !~ m|^/|o)
$old_target = $cwd . "/" . $old_target;
$old_target =~ s|/+|/|o;
$old_target = CanonicalizePath($old_target);
if ("$old_target" ne "$target")
$force_move = 1;
else
warn "$kimage.old --> $target -- doing nothing";
$force_move = 0;
else
$force_move = 1;
else
$force_move = 1;
else
warn “$vmlinuz_target points to $target – doing nothing”;
$force_move = 0;
Si ça donne une idée à qq’un, je lui en serai reconnaissant
Ce problème bloque aussi Synaptic
