Dpkg-reconfigure kdm ?
gerard@glu:~$ sudo dpkg-reconfigure kdm [sudo] password for gerard: insserv: warning: script 'K07smfpd' missing LSB tags and overrides insserv: warning: script 'smfpd' missing LSB tags and overrides insserv: There is a loop at service smfpd if started insserv: There is a loop between service rc.local and mountnfs if started insserv: loop involving service mountnfs at depth 7 insserv: loop involving service networking at depth 6 insserv: There is a loop between service smfpd and mountall if started insserv: loop involving service mountall at depth 4 insserv: loop involving service checkfs at depth 3 insserv: loop involving service mountnfs-bootclean at depth 9 insserv: loop involving service resolvconf at depth 6 insserv: There is a loop between service smfpd and mountall-bootclean if started insserv: loop involving service mountall-bootclean at depth 8 insserv: There is a loop between service smfpd and checkroot if started insserv: loop involving service checkroot at depth 3 insserv: loop involving service keyboard-setup at depth 2 insserv: loop involving service cryptdisks-early at depth 5 insserv: loop involving service hwclock at depth 3 insserv: There is a loop between service rc.local and udev if started insserv: loop involving service udev at depth 1 insserv: There is a loop at service rc.local if started insserv: loop involving service rc.local at depth 2 insserv: loop involving service smfpd at depth 1 insserv: loop involving service kbd at depth 11 insserv: loop involving service rsyslog at depth 1 insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: loop involving service mountkernfs at depth 1 insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Starting smfpd depends on rc.local and therefore on system facility `$all' which can not be true! insserv: Max recursions depth 99 reached insserv: exiting now without changing boot order! update-rc.d: error: insserv rejected the script header
Qu’est-ce qui lui prend ?
Et si tu fais une simulation ?
Re,
Simulation ?
Tout fonctionne très bien, mais je n’apprécie pas ce genre d’insultes !
Mauvais coucheur, va !
Qu’est-ce que tu trouve bizarre dans ton truc ?
Salut Ricardo,
Merci d’avoir fait remonter ce post pour me laisser une chance d’avoir une réponse :023
[code][18:30:32] ~ # dpkg-reconfigure kdm
[18:30:40] ~ #
[18:30:41] ~ # debconf-show kdm
kdm/stop_running_server_with_children: false
kdm/daemon_name: /usr/bin/kdm
  • shared/default-x-display-manager: kdm
    [18:30:44] ~ # [/code]
[18:31:36] ~ # version Linux Sid 3.10-3-686-pae #1 SMP Debian 3.10.11-1 (2013-09-10) i686 GNU/Linux No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux unstable (sid) Release: unstable Codename: sid [18:31:44] ~ #
Re,
@BelZéButh
Ceci ne me dit pas pourquoi j’ai une telle tartine de remarques :slightly_smiling:
Tout simplement quelques scripts, dont les entêtes LSB ne sont pas conformes. (Cf. le retour console ci-plus haut)
[quote]insserv: warning: script
insserv: Starting[/quote]
Si je ne m’abuse … :083
Au fait …
Tu ne nous as pas fait part de la raison, t’obligeant à avoir recours, à une re-configuration de kdm … :whistle:
Postscriptum : à défaut, cette action aura au moins, le mérite de faire remonter ton post, dans le cas ou …
Aucune utilité sauf celle d’expérimenter pour répondre à un post sur ce forum. Je voulais revoir ma copie, et j’ai été servi :laughing:
[quote=“ggoodluck47”]Salut,
Aucune utilité sauf celle d’expérimenter pour répondre à un post sur ce forum. Je voulais revoir ma copie, et j’ai été servi :laughing:[/quote]
Un plaisir, partagé. :005
Dommage que nous n’en sachions guère davantage, sur ce support.
C’est bien regrettable.
Sinon, es-tu parvenu à une fin heureuse, lors de cette simulation ?
Tu as un script de démarrage (/etc/init.d/smfpd) qui n’a pas d’en-têtes LSB. Le reste des “insultes” n’est très probablement dû qu’à ce problème initial.
Comme ce script ne fait apparemment pas partie de Debian (apt-file search smfpd ne retourne rien), difficile de savoir de quoi il retourne.
En cherchant très rapidement, il semblerait que ça soit un daemon pour permettre l’accès aux imprimantes sur port parallèle. Si ça ne te concerne pas, essaye de le désactiver avec update-rc.d smfpd remove et ensuite refais un insserv pour voir si ça règle la question.
Si par contre tu as une imprimante (ou autre périphérique) sur port parallèle, le mieux serait probablement de rajouter un en-tête LSB approprié au script d’origine (et toujours insserv pour voir si c’est mieux).
1 - remove ne s’exécute pas et j’ai droit aux mêmes insanités !
2 - ajouter les en-têtes améliore la situation mais me dit (une seule fois) que les en-têtes ne sont pas supportées :slightly_smiling: Il faudra bien qu’il s’y fasse :laughing:
Je soupçonne l’installeur Samsung de ma laser, une hérésie qui oblige de lancer une session graphique ROOT pour installer ses drivers !
Bah sinon tu peux toujours y aller à la sauvage, en supprimant les liens /etc/rc*.d/*smfpd à la main.
Salut et merci
Bah sinon tu peux toujours y aller à la sauvage, en supprimant les liens /etc/rc*.d/*smfpd à la main.[/quote]
Maintenant que je sais d’où ça vient, je le traite au sirop de mépris :laughing:
Ouais enfin ça fout le souk dans insserv et du coup je suis pas certain que tes liens rc.d se mettent correctement à jour si tu (dé)installes un service… Ça peut être embêtant.
Re,
Ma solution :
### BEGIN INIT INFO
## Provides:          rc.local
## Required-Start:    $all
## Required-Stop:
## Default-Start:     2 3 4 5
## Default-Stop:
## Short-Description: Run /etc/rc.local if it exist
### END INIT INFO
Il est content d’avoir l’en-tête et ne fais de mal à personne puisqu’elle est vide :laughing:
Si cette en-tête est dans /etc/init.d/smfpd, change la ligne Provides pour lire smfpd à la place de rc.local ça sera mieux (tu as déjà un script rc.local donc y’a un conflit de noms ce qui explique certainement qu’insserv te gueule dessus).
Re,
Cet en-tête je l’ai importé, il n’y avait rien du tout. C’est ta remarque qui m’a amené à en mettre une, n’importe laquelle de préférence et comme je n’ai plus d’usage des ports parallèles …
Le nom en face de Provides est important pour insserv (c’est le nom du service), et comme tu as copié tel quel l’en-tête de rc.local tu as aussi copié son nom de service en même temps. Donc insserv se retrouve avec un nom de service en double et te grogne après.
D’où mon conseil précédent de mettre smfpd à la place de rc.local en face de Provides pour éviter qu’insserv ne se retrouve enduit d’erreur à cause du doublon. Ça devrait être suffisant pour faire disparaître tout message lorsque tu remets tes services à jour (insserv tout seul).
