Ça fait un sacré pavé…
Et je ne sais pas trop comment interpréter tout ça :
# dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-5-amd64 (Debian 2.6.32-30) (ben@decadent.org.uk) (gcc version 4.3.5 (Debian 4.3.5-4) ) #1 SMP Wed Jan 12 03:40:32 UTC 2011
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=/dev/mapper/GV--panolis-VL--racine ro quiet
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009e400 (usable)
[ 0.000000] BIOS-e820: 000000000009e400 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000dfe70000 (usable)
[ 0.000000] BIOS-e820: 00000000dfe70000 - 00000000dfe88000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000dfe88000 - 00000000dfedc000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000dfedc000 - 00000000e0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffe00000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 0000000120000000 (usable)
[ 0.000000] DMI 2.6 present.
[ 0.000000] AMI BIOS detected: BIOS may corrupt low RAM, working around it.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0x120000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-D3FFF write-protect
[ 0.000000] D4000-DFFFF uncachable
[ 0.000000] E0000-E7FFF write-through
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F00000000 write-back
[ 0.000000] 1 base 100000000 mask FE0000000 write-back
[ 0.000000] 2 base 0E0000000 mask FE0000000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000e0000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0xdfe70 max_arch_pfn = 0x400000000
[ 0.000000] initial memory mapped : 0 - 20000000
[ 0.000000] init_memory_mapping: 0000000000000000-00000000dfe70000
[ 0.000000] 0000000000 - 00dfe00000 page 2M
[ 0.000000] 00dfe00000 - 00dfe70000 page 4k
[ 0.000000] kernel direct mapping tables up to dfe70000 @ 10000-16000
[ 0.000000] init_memory_mapping: 0000000100000000-0000000120000000
[ 0.000000] 0100000000 - 0120000000 page 2M
[ 0.000000] kernel direct mapping tables up to 120000000 @ 14000-1a000
[ 0.000000] RAMDISK: 375c1000 - 37fef723
[ 0.000000] ACPI: RSDP 00000000000fb2a0 00024 (v02 ACPIAM)
[ 0.000000] ACPI: XSDT 00000000dfe70100 0005C (v01 072210 XSDT1556 20100722 MSFT 00000097)
[ 0.000000] ACPI: FACP 00000000dfe70290 000F4 (v03 072210 FACP1556 20100722 MSFT 00000097)
[ 0.000000] ACPI: DSDT 00000000dfe704a0 0F4CC (v01 A1420 A1420001 00000001 INTL 20060113)
[ 0.000000] ACPI: FACS 00000000dfe88000 00040
[ 0.000000] ACPI: APIC 00000000dfe70390 000CC (v01 072210 APIC1556 20100722 MSFT 00000097)
[ 0.000000] ACPI: MCFG 00000000dfe70460 0003C (v01 072210 OEMMCFG 20100722 MSFT 00000097)
[ 0.000000] ACPI: OEMB 00000000dfe88040 00072 (v01 072210 OEMB1556 20100722 MSFT 00000097)
[ 0.000000] ACPI: HPET 00000000dfe7f970 00038 (v01 072210 OEMHPET 20100722 MSFT 00000097)
[ 0.000000] ACPI: OSFR 00000000dfe7f9b0 000B0 (v01 072210 OEMOSFR 20100722 MSFT 00000097)
[ 0.000000] ACPI: SSDT 00000000dfe897e0 00363 (v01 DpgPmm CpuPm 00000012 INTL 20060113)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at 0000000000000000-0000000120000000
[ 0.000000] Bootmem setup node 0 0000000000000000-0000000120000000
[ 0.000000] NODE_DATA [0000000000015000 - 000000000001cfff]
[ 0.000000] bootmap [000000000001d000 - 0000000000040fff] pages 24
[ 0.000000] (8 early reservations) ==> bootmem [0000000000 - 0120000000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000006000 - 0000008000] TRAMPOLINE ==> [0000006000 - 0000008000]
[ 0.000000] #2 [0001000000 - 000168a414] TEXT DATA BSS ==> [0001000000 - 000168a414]
[ 0.000000] #3 [00375c1000 - 0037fef723] RAMDISK ==> [00375c1000 - 0037fef723]
[ 0.000000] #4 [000009e400 - 0000100000] BIOS reserved ==> [000009e400 - 0000100000]
[ 0.000000] #5 [000168b000 - 000168b2c8] BRK ==> [000168b000 - 000168b2c8]
[ 0.000000] #6 [0000010000 - 0000014000] PGTABLE ==> [0000010000 - 0000014000]
[ 0.000000] #7 [0000014000 - 0000015000] PGTABLE ==> [0000014000 - 0000015000]
[ 0.000000] found SMP MP-table at [ffff8800000ff780] ff780
[ 0.000000] [ffffea0000000000-ffffea0003ffffff] PMD -> [ffff880001800000-ffff8800051fffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] DMA32 0x00001000 -> 0x00100000
[ 0.000000] Normal 0x00100000 -> 0x00120000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009e
[ 0.000000] 0: 0x00000100 -> 0x000dfe70
[ 0.000000] 0: 0x00100000 -> 0x00120000
[ 0.000000] On node 0 totalpages: 1048062
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 105 pages reserved
[ 0.000000] DMA zone: 3821 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 14280 pages used for memmap
[ 0.000000] DMA32 zone: 898728 pages, LIFO batch:31
[ 0.000000] Normal zone: 1792 pages used for memmap
[ 0.000000] Normal zone: 129280 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x84] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x85] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x86] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x87] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x09] lapic_id[0x88] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0a] lapic_id[0x89] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0b] lapic_id[0x8a] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0c] lapic_id[0x8b] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0d] lapic_id[0x8c] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0e] lapic_id[0x8d] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x0f] lapic_id[0x8e] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x10] lapic_id[0x8f] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x07] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 7, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 16 CPUs, 12 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 24
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 000000000009f000
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
[ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 00000000dfe70000 - 00000000dfe88000
[ 0.000000] PM: Registered nosave memory: 00000000dfe88000 - 00000000dfedc000
[ 0.000000] PM: Registered nosave memory: 00000000dfedc000 - 00000000e0000000
[ 0.000000] PM: Registered nosave memory: 00000000e0000000 - 00000000fee00000
[ 0.000000] PM: Registered nosave memory: 00000000fee00000 - 00000000fee01000
[ 0.000000] PM: Registered nosave memory: 00000000fee01000 - 00000000ffe00000
[ 0.000000] PM: Registered nosave memory: 00000000ffe00000 - 0000000100000000
[ 0.000000] Allocating PCI resources starting at e0000000 (gap: e0000000:1ee00000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:16 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 30 pages/cpu @ffff880005400000 s90328 r8192 d24360 u131072
[ 0.000000] pcpu-alloc: s90328 r8192 d24360 u131072 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 1031829
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=/dev/mapper/GV--panolis-VL--racine ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Checking aperture...
[ 0.000000] No AGP bridge found
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.000000] Placing 64MB software IO TLB between ffff8800055fe000 - ffff8800095fe000
[ 0.000000] software IO TLB at phys 0x55fe000 - 0x95fe000
[ 0.000000] Memory: 4047428k/4718592k available (3079k kernel code, 526344k absent, 144820k reserved, 1892k data, 592k init)
[ 0.000000] SLUB: Genslabs=14, HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:4352 nr_irqs:536
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] alloc irq_desc for 24 on node -1
[ 0.000000] alloc kstat_irqs on node -1
[ 0.000000] alloc irq_desc for 25 on node -1
[ 0.000000] alloc irq_desc for 26 on node -1
[ 0.000000] alloc irq_desc for 27 on node -1
[ 0.000000] alloc irq_desc for 28 on node -1
[ 0.000000] HPET: 8 timers in total, 5 timers will be used for per-cpu timer
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 2808.540 MHz processor.
[ 0.000003] Calibrating delay loop (skipped), value calculated using timer frequency.. 5617.08 BogoMIPS (lpj=11234160)
[ 0.000016] Security Framework initialized
[ 0.000019] SELinux: Disabled at boot.
[ 0.000236] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.001508] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.002089] Mount-cache hash table entries: 256
[ 0.002180] Initializing cgroup subsys ns
[ 0.002182] Initializing cgroup subsys cpuacct
[ 0.002186] Initializing cgroup subsys devices
[ 0.002187] Initializing cgroup subsys freezer
[ 0.002188] Initializing cgroup subsys net_cls
[ 0.002202] CPU: Physical Processor ID: 0
[ 0.002203] CPU: Processor Core ID: 0
[ 0.002206] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.002207] CPU: L2 cache: 256K
[ 0.002208] CPU: L3 cache: 8192K
[ 0.002210] CPU 0/0x0 -> Node 0
[ 0.002212] mce: CPU supports 9 MCE banks
[ 0.002221] CPU0: Thermal monitoring enabled (TM1)
[ 0.002223] CPU 0 MCA banks CMCI:2 CMCI:3 CMCI:5 CMCI:6 CMCI:8
[ 0.002229] using mwait in idle threads.
[ 0.002230] Performance Events: Nehalem/Corei7 events, Intel PMU driver.
[ 0.002234] ... version: 3
[ 0.002235] ... bit width: 48
[ 0.002236] ... generic registers: 4
[ 0.002237] ... value mask: 0000ffffffffffff
[ 0.002238] ... max period: 000000007fffffff
[ 0.002239] ... fixed-purpose events: 3
[ 0.002240] ... event mask: 000000070000000f
[ 0.002968] ACPI: Core revision 20090903
[ 0.034979] Setting APIC routing to physical flat
[ 0.035302] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.074921] CPU0: Intel(R) Core(TM) i5 CPU 760 @ 2.80GHz stepping 05
[ 0.180154] Booting processor 1 APIC 0x2 ip 0x6000
[ 0.191052] Initializing CPU#1
[ 0.267926] CPU: Physical Processor ID: 0
[ 0.267927] CPU: Processor Core ID: 1
[ 0.267929] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.267930] CPU: L2 cache: 256K
[ 0.267931] CPU: L3 cache: 8192K
[ 0.267933] CPU 1/0x2 -> Node 0
[ 0.267941] CPU1: Thermal monitoring enabled (TM1)
[ 0.267944] CPU 1 MCA banks CMCI:2 CMCI:3 CMCI:5 SHD:6 SHD:8
[ 0.267952] CPU1: Intel(R) Core(TM) i5 CPU 760 @ 2.80GHz stepping 05
[ 0.267958] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[ 0.287990] Booting processor 2 APIC 0x4 ip 0x6000
[ 0.298254] Initializing CPU#2
[ 0.375747] CPU: Physical Processor ID: 0
[ 0.375748] CPU: Processor Core ID: 2
[ 0.375750] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.375751] CPU: L2 cache: 256K
[ 0.375752] CPU: L3 cache: 8192K
[ 0.375754] CPU 2/0x4 -> Node 0
[ 0.375763] CPU2: Thermal monitoring enabled (TM1)
[ 0.375765] CPU 2 MCA banks CMCI:2 CMCI:3 CMCI:5 SHD:6 SHD:8
[ 0.375779] CPU2: Intel(R) Core(TM) i5 CPU 760 @ 2.80GHz stepping 05
[ 0.375785] checking TSC synchronization [CPU#0 -> CPU#2]: passed.
[ 0.395817] Booting processor 3 APIC 0x6 ip 0x6000
[ 0.406080] Initializing CPU#3
[ 0.483569] CPU: Physical Processor ID: 0
[ 0.483570] CPU: Processor Core ID: 3
[ 0.483572] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.483573] CPU: L2 cache: 256K
[ 0.483574] CPU: L3 cache: 8192K
[ 0.483576] CPU 3/0x6 -> Node 0
[ 0.483585] CPU3: Thermal monitoring enabled (TM1)
[ 0.483587] CPU 3 MCA banks CMCI:2 CMCI:3 CMCI:5 SHD:6 SHD:8
[ 0.483605] CPU3: Intel(R) Core(TM) i5 CPU 760 @ 2.80GHz stepping 05
[ 0.483611] checking TSC synchronization [CPU#0 -> CPU#3]: passed.
[ 0.503593] Brought up 4 CPUs
[ 0.503595] Total of 4 processors activated (22468.44 BogoMIPS).
[ 0.504780] CPU0 attaching sched-domain:
[ 0.504782] domain 0: span 0-3 level MC
[ 0.504784] groups: 0 1 2 3
[ 0.504789] CPU1 attaching sched-domain:
[ 0.504790] domain 0: span 0-3 level MC
[ 0.504791] groups: 1 2 3 0
[ 0.504795] CPU2 attaching sched-domain:
[ 0.504796] domain 0: span 0-3 level MC
[ 0.504797] groups: 2 3 0 1
[ 0.504801] CPU3 attaching sched-domain:
[ 0.504802] domain 0: span 0-3 level MC
[ 0.504803] groups: 3 0 1 2
[ 0.504968] devtmpfs: initialized
[ 0.508101] regulator: core version 0.5
[ 0.508137] NET: Registered protocol family 16
[ 0.508196] ACPI: bus type pci registered
[ 0.508247] PCI: MCFG configuration 0: base f8000000 segment 0 buses 0 - 63
[ 0.508249] PCI: Not using MMCONFIG.
[ 0.508250] PCI: Using configuration type 1 for base access
[ 0.508539] bio: create slab <bio-0> at 0
[ 0.509148] ACPI: EC: Look up EC in DSDT
[ 0.511077] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.523972] ACPI: Interpreter enabled
[ 0.523974] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.523992] ACPI: Using IOAPIC for interrupt routing
[ 0.524034] PCI: MCFG configuration 0: base f8000000 segment 0 buses 0 - 63
[ 0.525900] PCI: MCFG area at f8000000 reserved in ACPI motherboard resources
[ 0.527189] PCI: Using MMCONFIG at f8000000 - fbffffff
[ 0.534416] ACPI: No dock devices found.
[ 0.534676] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.534773] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.534776] pci 0000:00:03.0: PME# disabled
[ 0.535007] pci 0000:00:1a.0: reg 10 32bit mmio: [0xf5ffe000-0xf5ffe3ff]
[ 0.535054] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.535057] pci 0000:00:1a.0: PME# disabled
[ 0.535092] pci 0000:00:1b.0: reg 10 64bit mmio: [0xf5ff8000-0xf5ffbfff]
[ 0.535127] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.535130] pci 0000:00:1b.0: PME# disabled
[ 0.535182] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.535185] pci 0000:00:1c.0: PME# disabled
[ 0.535241] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.535243] pci 0000:00:1c.4: PME# disabled
[ 0.535296] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.535299] pci 0000:00:1c.5: PME# disabled
[ 0.535352] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[ 0.535355] pci 0000:00:1c.6: PME# disabled
[ 0.535408] pci 0000:00:1c.7: PME# supported from D0 D3hot D3cold
[ 0.535411] pci 0000:00:1c.7: PME# disabled
[ 0.535455] pci 0000:00:1d.0: reg 10 32bit mmio: [0xf5ffd000-0xf5ffd3ff]
[ 0.535505] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.535508] pci 0000:00:1d.0: PME# disabled
[ 0.535667] pci 0000:00:1f.2: reg 10 io port: [0x9880-0x9887]
[ 0.535672] pci 0000:00:1f.2: reg 14 io port: [0x9800-0x9803]
[ 0.535676] pci 0000:00:1f.2: reg 18 io port: [0x9480-0x9487]
[ 0.535681] pci 0000:00:1f.2: reg 1c io port: [0x9400-0x9403]
[ 0.535685] pci 0000:00:1f.2: reg 20 io port: [0x9080-0x909f]
[ 0.535690] pci 0000:00:1f.2: reg 24 32bit mmio: [0xf5ff7000-0xf5ff77ff]
[ 0.535716] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.535719] pci 0000:00:1f.2: PME# disabled
[ 0.535742] pci 0000:00:1f.3: reg 10 64bit mmio: [0xf5ffc000-0xf5ffc0ff]
[ 0.535753] pci 0000:00:1f.3: reg 20 io port: [0x400-0x41f]
[ 0.535791] pci 0000:01:00.0: reg 10 32bit mmio: [0xf6000000-0xf6ffffff]
[ 0.535799] pci 0000:01:00.0: reg 14 64bit mmio pref: [0xe0000000-0xefffffff]
[ 0.535806] pci 0000:01:00.0: reg 1c 64bit mmio pref: [0xf2000000-0xf3ffffff]
[ 0.535810] pci 0000:01:00.0: reg 24 io port: [0xac00-0xac7f]
[ 0.535814] pci 0000:01:00.0: reg 30 32bit mmio pref: [0xf7b00000-0xf7b7ffff]
[ 0.535861] pci 0000:01:00.1: reg 10 32bit mmio: [0xf7bfc000-0xf7bfffff]
[ 0.543555] pci 0000:00:03.0: bridge io port: [0xa000-0xafff]
[ 0.543557] pci 0000:00:03.0: bridge 32bit mmio: [0xf6000000-0xf7bfffff]
[ 0.543561] pci 0000:00:03.0: bridge 64bit mmio pref: [0xe0000000-0xf3ffffff]
[ 0.543678] pci 0000:04:00.0: reg 10 64bit mmio: [0xf7eff800-0xf7efffff]
[ 0.543685] pci 0000:04:00.0: reg 18 io port: [0xd800-0xd8ff]
[ 0.543737] pci 0000:04:00.0: supports D2
[ 0.543739] pci 0000:04:00.0: PME# supported from D2 D3hot D3cold
[ 0.543743] pci 0000:04:00.0: PME# disabled
[ 0.551557] pci 0000:00:1c.5: bridge io port: [0xd000-0xdfff]
[ 0.551560] pci 0000:00:1c.5: bridge 32bit mmio: [0xf7e00000-0xf7efffff]
[ 0.551644] pci 0000:03:00.0: reg 24 32bit mmio: [0xf7dfa000-0xf7dfbfff]
[ 0.551680] pci 0000:03:00.0: PME# supported from D3hot
[ 0.551684] pci 0000:03:00.0: PME# disabled
[ 0.551733] pci 0000:03:00.1: reg 10 io port: [0xcc00-0xcc07]
[ 0.551741] pci 0000:03:00.1: reg 14 io port: [0xc880-0xc883]
[ 0.551748] pci 0000:03:00.1: reg 18 io port: [0xc800-0xc807]
[ 0.551756] pci 0000:03:00.1: reg 1c io port: [0xc480-0xc483]
[ 0.551764] pci 0000:03:00.1: reg 20 io port: [0xc400-0xc40f]
[ 0.551827] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.551889] pci 0000:00:1c.6: bridge io port: [0xc000-0xcfff]
[ 0.551891] pci 0000:00:1c.6: bridge 32bit mmio: [0xf7d00000-0xf7dfffff]
[ 0.551937] pci 0000:02:00.0: reg 10 io port: [0xb800-0xb8ff]
[ 0.551954] pci 0000:02:00.0: reg 18 64bit mmio pref: [0xf4fff000-0xf4ffffff]
[ 0.551967] pci 0000:02:00.0: reg 20 64bit mmio pref: [0xf4ff8000-0xf4ffbfff]
[ 0.551974] pci 0000:02:00.0: reg 30 32bit mmio pref: [0xf7cf0000-0xf7cfffff]
[ 0.552010] pci 0000:02:00.0: supports D1 D2
[ 0.552011] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.552015] pci 0000:02:00.0: PME# disabled
[ 0.559547] pci 0000:00:1c.7: bridge io port: [0xb000-0xbfff]
[ 0.559550] pci 0000:00:1c.7: bridge 32bit mmio: [0xf7c00000-0xf7cfffff]
[ 0.559554] pci 0000:00:1c.7: bridge 64bit mmio pref: [0xf4f00000-0xf4ffffff]
[ 0.559584] pci 0000:07:01.0: reg 10 io port: [0xec00-0xec07]
[ 0.559590] pci 0000:07:01.0: reg 14 io port: [0xe880-0xe883]
[ 0.559595] pci 0000:07:01.0: reg 18 io port: [0xe800-0xe807]
[ 0.559600] pci 0000:07:01.0: reg 1c io port: [0xe480-0xe483]
[ 0.559606] pci 0000:07:01.0: reg 20 io port: [0xe400-0xe40f]
[ 0.559611] pci 0000:07:01.0: reg 24 32bit mmio: [0xf7fffc00-0xf7fffcff]
[ 0.559617] pci 0000:07:01.0: reg 30 32bit mmio pref: [0xf7f00000-0xf7f7ffff]
[ 0.559633] pci 0000:07:01.0: supports D1 D2
[ 0.559675] pci 0000:00:1e.0: transparent bridge
[ 0.559678] pci 0000:00:1e.0: bridge io port: [0xe000-0xefff]
[ 0.559680] pci 0000:00:1e.0: bridge 32bit mmio: [0xf7f00000-0xf7ffffff]
[ 0.559709] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.559874] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR1E._PRT]
[ 0.559971] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P3._PRT]
[ 0.560025] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR20._PRT]
[ 0.560071] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR24._PRT]
[ 0.560117] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR25._PRT]
[ 0.560163] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR26._PRT]
[ 0.560219] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR27._PRT]
[ 0.578362] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 *10 11 12 14 15)
[ 0.578459] ACPI: PCI Interrupt Link [LNKB] (IRQs *5)
[ 0.578553] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 10 11 *12 14 15)
[ 0.578648] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 *11 12 14 15)
[ 0.578743] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12 14 15) *0, disabled.
[ 0.578839] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12 14 *15)
[ 0.578934] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 6 7 10 11 12 *14 15)
[ 0.579029] ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 6 7 10 11 12 14 15)
[ 0.579104] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.579107] vgaarb: loaded
[ 0.579138] PCI: Using ACPI for IRQ routing
[ 0.579264] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 24, 25, 26, 27, 28, 0
[ 0.579268] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.583443] hpet: hpet2 irq 24 for MSI
[ 0.583491] hpet: hpet3 irq 25 for MSI
[ 0.587502] hpet: hpet4 irq 26 for MSI
[ 0.591505] hpet: hpet5 irq 27 for MSI
[ 0.591538] Switching to clocksource tsc
[ 0.592333] pnp: PnP ACPI init
[ 0.592339] ACPI: bus type pnp registered
[ 0.594251] pnp: PnP ACPI: found 14 devices
[ 0.594252] ACPI: ACPI bus type pnp unregistered
[ 0.594259] system 00:01: iomem range 0xfed14000-0xfed19fff has been reserved
[ 0.594263] system 00:06: ioport range 0x290-0x29f has been reserved
[ 0.594267] system 00:07: ioport range 0x4d0-0x4d1 has been reserved
[ 0.594269] system 00:07: ioport range 0x800-0x87f has been reserved
[ 0.594271] system 00:07: ioport range 0x500-0x57f has been reserved
[ 0.594273] system 00:07: iomem range 0xfed1c000-0xfed1ffff has been reserved
[ 0.594275] system 00:07: iomem range 0xfed20000-0xfed3ffff has been reserved
[ 0.594277] system 00:07: iomem range 0xfed40000-0xfed8ffff has been reserved
[ 0.594280] system 00:0a: iomem range 0xffc00000-0xffdfffff has been reserved
[ 0.594284] system 00:0b: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.594286] system 00:0b: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.594289] system 00:0c: iomem range 0xf8000000-0xfbffffff has been reserved
[ 0.594293] system 00:0d: iomem range 0x0-0x9ffff could not be reserved
[ 0.594295] system 00:0d: iomem range 0xc0000-0xcffff has been reserved
[ 0.594296] system 00:0d: iomem range 0xe0000-0xfffff could not be reserved
[ 0.594298] system 00:0d: iomem range 0x100000-0xdfffffff could not be reserved
[ 0.594300] system 00:0d: iomem range 0xfed90000-0xffffffff could not be reserved
[ 0.598901] pci 0000:07:01.0: BAR 6: address space collision on of device [0xf7f00000-0xf7f7ffff]
[ 0.598992] pci 0000:00:03.0: PCI bridge, secondary bus 0000:01
[ 0.598994] pci 0000:00:03.0: IO window: 0xa000-0xafff
[ 0.598997] pci 0000:00:03.0: MEM window: 0xf6000000-0xf7bfffff
[ 0.599000] pci 0000:00:03.0: PREFETCH window: 0x000000e0000000-0x000000f3ffffff
[ 0.599003] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:06
[ 0.599006] pci 0000:00:1c.0: IO window: 0x1000-0x1fff
[ 0.599009] pci 0000:00:1c.0: MEM window: 0xf4000000-0xf41fffff
[ 0.599012] pci 0000:00:1c.0: PREFETCH window: 0x000000f4200000-0x000000f43fffff
[ 0.599017] pci 0000:00:1c.4: PCI bridge, secondary bus 0000:05
[ 0.599019] pci 0000:00:1c.4: IO window: 0x2000-0x2fff
[ 0.599023] pci 0000:00:1c.4: MEM window: 0xf4400000-0xf45fffff
[ 0.599026] pci 0000:00:1c.4: PREFETCH window: 0x000000f4600000-0x000000f47fffff
[ 0.599030] pci 0000:00:1c.5: PCI bridge, secondary bus 0000:04
[ 0.599032] pci 0000:00:1c.5: IO window: 0xd000-0xdfff
[ 0.599036] pci 0000:00:1c.5: MEM window: 0xf7e00000-0xf7efffff
[ 0.599039] pci 0000:00:1c.5: PREFETCH window: 0x000000f4800000-0x000000f49fffff
[ 0.599044] pci 0000:00:1c.6: PCI bridge, secondary bus 0000:03
[ 0.599046] pci 0000:00:1c.6: IO window: 0xc000-0xcfff
[ 0.599050] pci 0000:00:1c.6: MEM window: 0xf7d00000-0xf7dfffff
[ 0.599053] pci 0000:00:1c.6: PREFETCH window: 0x000000f4a00000-0x000000f4bfffff
[ 0.599057] pci 0000:00:1c.7: PCI bridge, secondary bus 0000:02
[ 0.599059] pci 0000:00:1c.7: IO window: 0xb000-0xbfff
[ 0.599063] pci 0000:00:1c.7: MEM window: 0xf7c00000-0xf7cfffff
[ 0.599066] pci 0000:00:1c.7: PREFETCH window: 0x000000f4f00000-0x000000f4ffffff
[ 0.599071] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:07
[ 0.599073] pci 0000:00:1e.0: IO window: 0xe000-0xefff
[ 0.599077] pci 0000:00:1e.0: MEM window: 0xf7f00000-0xf7ffffff
[ 0.599080] pci 0000:00:1e.0: PREFETCH window: 0xf4c00000-0xf4cfffff
[ 0.599089] alloc irq_desc for 16 on node -1
[ 0.599090] alloc kstat_irqs on node -1
[ 0.599094] pci 0000:00:03.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.599097] pci 0000:00:03.0: setting latency timer to 64
[ 0.599102] pci 0000:00:1c.0: enabling device (0104 -> 0107)
[ 0.599105] alloc irq_desc for 17 on node -1
[ 0.599106] alloc kstat_irqs on node -1
[ 0.599109] pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 0.599112] pci 0000:00:1c.0: setting latency timer to 64
[ 0.599117] pci 0000:00:1c.4: enabling device (0104 -> 0107)
[ 0.599120] pci 0000:00:1c.4: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 0.599122] pci 0000:00:1c.4: setting latency timer to 64
[ 0.599128] pci 0000:00:1c.5: PCI INT B -> GSI 16 (level, low) -> IRQ 16
[ 0.599131] pci 0000:00:1c.5: setting latency timer to 64
[ 0.599137] alloc irq_desc for 18 on node -1
[ 0.599138] alloc kstat_irqs on node -1
[ 0.599141] pci 0000:00:1c.6: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.599144] pci 0000:00:1c.6: setting latency timer to 64
[ 0.599149] alloc irq_desc for 19 on node -1
[ 0.599150] alloc kstat_irqs on node -1
[ 0.599153] pci 0000:00:1c.7: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[ 0.599156] pci 0000:00:1c.7: setting latency timer to 64
[ 0.599160] pci 0000:00:1e.0: setting latency timer to 64
[ 0.599163] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.599165] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffffffffffff]
[ 0.599166] pci_bus 0000:01: resource 0 io: [0xa000-0xafff]
[ 0.599168] pci_bus 0000:01: resource 1 mem: [0xf6000000-0xf7bfffff]
[ 0.599169] pci_bus 0000:01: resource 2 pref mem [0xe0000000-0xf3ffffff]
[ 0.599171] pci_bus 0000:06: resource 0 io: [0x1000-0x1fff]
[ 0.599173] pci_bus 0000:06: resource 1 mem: [0xf4000000-0xf41fffff]
[ 0.599174] pci_bus 0000:06: resource 2 pref mem [0xf4200000-0xf43fffff]
[ 0.599176] pci_bus 0000:05: resource 0 io: [0x2000-0x2fff]
[ 0.599177] pci_bus 0000:05: resource 1 mem: [0xf4400000-0xf45fffff]
[ 0.599179] pci_bus 0000:05: resource 2 pref mem [0xf4600000-0xf47fffff]
[ 0.599180] pci_bus 0000:04: resource 0 io: [0xd000-0xdfff]
[ 0.599182] pci_bus 0000:04: resource 1 mem: [0xf7e00000-0xf7efffff]
[ 0.599183] pci_bus 0000:04: resource 2 pref mem [0xf4800000-0xf49fffff]
[ 0.599185] pci_bus 0000:03: resource 0 io: [0xc000-0xcfff]
[ 0.599186] pci_bus 0000:03: resource 1 mem: [0xf7d00000-0xf7dfffff]
[ 0.599188] pci_bus 0000:03: resource 2 pref mem [0xf4a00000-0xf4bfffff]
[ 0.599190] pci_bus 0000:02: resource 0 io: [0xb000-0xbfff]
[ 0.599191] pci_bus 0000:02: resource 1 mem: [0xf7c00000-0xf7cfffff]
[ 0.599193] pci_bus 0000:02: resource 2 pref mem [0xf4f00000-0xf4ffffff]
[ 0.599194] pci_bus 0000:07: resource 0 io: [0xe000-0xefff]
[ 0.599196] pci_bus 0000:07: resource 1 mem: [0xf7f00000-0xf7ffffff]
[ 0.599197] pci_bus 0000:07: resource 2 pref mem [0xf4c00000-0xf4cfffff]
[ 0.599199] pci_bus 0000:07: resource 3 io: [0x00-0xffff]
[ 0.599200] pci_bus 0000:07: resource 4 mem: [0x000000-0xffffffffffffffff]
[ 0.599217] NET: Registered protocol family 2
[ 0.599322] IP route cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.599990] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.602232] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.602535] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.602537] TCP reno registered
[ 0.602648] NET: Registered protocol family 1
[ 0.602721] pci 0000:01:00.0: Boot video device
[ 0.602761] Unpacking initramfs...
[ 0.773648] Freeing initrd memory: 10425k freed
[ 0.775605] audit: initializing netlink socket (disabled)
[ 0.775614] type=2000 audit(1295771290.612:1): initialized
[ 0.778238] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.779134] VFS: Disk quotas dquot_6.5.2
[ 0.779166] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.779223] msgmni has been set to 7925
[ 0.779369] alg: No test for stdrng (krng)
[ 0.779401] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.779403] io scheduler noop registered
[ 0.779405] io scheduler anticipatory registered
[ 0.779406] io scheduler deadline registered
[ 0.779429] io scheduler cfq registered (default)
[ 0.779516] alloc irq_desc for 29 on node -1
[ 0.779517] alloc kstat_irqs on node -1
[ 0.779524] pcieport 0000:00:03.0: irq 29 for MSI/MSI-X
[ 0.779529] pcieport 0000:00:03.0: setting latency timer to 64
[ 0.779606] alloc irq_desc for 30 on node -1
[ 0.779607] alloc kstat_irqs on node -1
[ 0.779612] pcieport 0000:00:1c.0: irq 30 for MSI/MSI-X
[ 0.779618] pcieport 0000:00:1c.0: setting latency timer to 64
[ 0.779699] alloc irq_desc for 31 on node -1
[ 0.779700] alloc kstat_irqs on node -1
[ 0.779705] pcieport 0000:00:1c.4: irq 31 for MSI/MSI-X
[ 0.779711] pcieport 0000:00:1c.4: setting latency timer to 64
[ 0.779794] alloc irq_desc for 32 on node -1
[ 0.779795] alloc kstat_irqs on node -1
[ 0.779800] pcieport 0000:00:1c.5: irq 32 for MSI/MSI-X
[ 0.779806] pcieport 0000:00:1c.5: setting latency timer to 64
[ 0.779887] alloc irq_desc for 33 on node -1
[ 0.779888] alloc kstat_irqs on node -1
[ 0.779893] pcieport 0000:00:1c.6: irq 33 for MSI/MSI-X
[ 0.779899] pcieport 0000:00:1c.6: setting latency timer to 64
[ 0.779982] alloc irq_desc for 34 on node -1
[ 0.779983] alloc kstat_irqs on node -1
[ 0.779988] pcieport 0000:00:1c.7: irq 34 for MSI/MSI-X
[ 0.779994] pcieport 0000:00:1c.7: setting latency timer to 64
[ 0.780051] Firmware did not grant requested _OSC control
[ 0.780052] aer 0000:00:03.0:pcie02: AER service couldn't init device: no _OSC support
[ 0.780928] Linux agpgart interface v0.103
[ 0.780954] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.781190] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 0.781227] PNP: No PS/2 controller found. Probing ports directly.
[ 0.782671] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.782675] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.782728] mice: PS/2 mouse device common for all mice
[ 0.782751] rtc_cmos 00:03: RTC can wake from S4
[ 0.782772] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 0.782797] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.782804] cpuidle: using governor ladder
[ 0.782806] cpuidle: using governor menu
[ 0.782808] No iBFT detected.
[ 0.783021] TCP cubic registered
[ 0.783092] NET: Registered protocol family 10
[ 0.783441] lo: Disabled Privacy Extensions
[ 0.783614] Mobile IPv6
[ 0.783615] NET: Registered protocol family 17
[ 0.783666] PM: Resume from disk failed.
[ 0.783671] registered taskstats version 1
[ 0.784103] rtc_cmos 00:03: setting system clock to 2011-01-23 08:28:11 UTC (1295771291)
[ 0.784125] Initalizing network drop monitor service
[ 0.784144] Freeing unused kernel memory: 592k freed
[ 0.784243] Write protecting the kernel read-only data: 4236k
[ 0.832360] udev[79]: starting version 164
[ 0.844548] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.844571] r8169 0000:02:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 0.844617] r8169 0000:02:00.0: setting latency timer to 64
[ 0.844657] alloc irq_desc for 35 on node -1
[ 0.844659] alloc kstat_irqs on node -1
[ 0.844672] r8169 0000:02:00.0: irq 35 for MSI/MSI-X
[ 0.845060] eth0: RTL8168d/8111d at 0xffffc90005088000, 20:cf:30:50:c7:64, XID 083000c0 IRQ 35
[ 0.867686] r8169 0000:02:00.0: firmware: requesting rtl_nic/rtl8168d-2.fw
[ 0.868878] SCSI subsystem initialized
[ 0.876820] usbcore: registered new interface driver usbfs
[ 0.876903] usbcore: registered new interface driver hub
[ 0.876989] usbcore: registered new device driver usb
[ 0.878275] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.878303] ehci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.878329] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 0.878332] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 0.878344] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.878368] ehci_hcd 0000:00:1a.0: debug port 2
[ 0.882259] ehci_hcd 0000:00:1a.0: cache line size of 32 is not supported
[ 0.882263] firewire_ohci 0000:04:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 0.882268] firewire_ohci 0000:04:00.0: setting latency timer to 64
[ 0.882526] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf5ffe000
[ 0.890810] libata version 3.00 loaded.
[ 0.893266] pata_jmicron 0000:03:00.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.893286] pata_jmicron 0000:03:00.1: setting latency timer to 64
[ 0.893331] scsi0 : pata_jmicron
[ 0.893391] scsi1 : pata_jmicron
[ 0.893869] ata1: PATA max UDMA/100 cmd 0xcc00 ctl 0xc880 bmdma 0xc400 irq 19
[ 0.893871] ata2: PATA max UDMA/100 cmd 0xc800 ctl 0xc480 bmdma 0xc408 irq 19
[ 0.895101] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.895118] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.895119] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.895121] usb usb1: Product: EHCI Host Controller
[ 0.895122] usb usb1: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd
[ 0.895123] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.895166] usb usb1: configuration #1 chosen from 1 choice
[ 0.895186] hub 1-0:1.0: USB hub found
[ 0.895190] hub 1-0:1.0: 2 ports detected
[ 0.895221] ahci 0000:00:1f.2: version 3.0
[ 0.895229] alloc irq_desc for 21 on node -1
[ 0.895230] alloc kstat_irqs on node -1
[ 0.895235] ahci 0000:00:1f.2: PCI INT D -> GSI 21 (level, low) -> IRQ 21
[ 0.895265] alloc irq_desc for 36 on node -1
[ 0.895266] alloc kstat_irqs on node -1
[ 0.895273] ahci 0000:00:1f.2: irq 36 for MSI/MSI-X
[ 0.895298] ahci: SSS flag set, parallel bus scan disabled
[ 0.911098] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 3 Gbps 0x3f impl SATA mode
[ 0.911101] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pmp pio slum part ems sxs apst
[ 0.911104] ahci 0000:00:1f.2: setting latency timer to 64
[ 0.951064] scsi2 : ahci
[ 0.951119] scsi3 : ahci
[ 0.951154] scsi4 : ahci
[ 0.951189] scsi5 : ahci
[ 0.951223] scsi6 : ahci
[ 0.951257] scsi7 : ahci
[ 0.951362] ata3: SATA max UDMA/133 abar m2048@0xf5ff7000 port 0xf5ff7100 irq 36
[ 0.951365] ata4: SATA max UDMA/133 abar m2048@0xf5ff7000 port 0xf5ff7180 irq 36
[ 0.951367] ata5: SATA max UDMA/133 abar m2048@0xf5ff7000 port 0xf5ff7200 irq 36
[ 0.951369] ata6: SATA max UDMA/133 abar m2048@0xf5ff7000 port 0xf5ff7280 irq 36
[ 0.951371] ata7: SATA max UDMA/133 abar m2048@0xf5ff7000 port 0xf5ff7300 irq 36
[ 0.951373] ata8: SATA max UDMA/133 abar m2048@0xf5ff7000 port 0xf5ff7380 irq 36
[ 0.951409] ahci 0000:03:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.951411] alloc irq_desc for 23 on node -1
[ 0.951413] alloc kstat_irqs on node -1
[ 0.951416] ehci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 0.951432] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.951435] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 0.951442] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.951467] ehci_hcd 0000:00:1d.0: debug port 2
[ 0.955348] ehci_hcd 0000:00:1d.0: cache line size of 32 is not supported
[ 0.955358] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf5ffd000
[ 0.959339] firewire_ohci: Added fw-ohci device 0000:04:00.0, OHCI version 1.10
[ 0.966985] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.967009] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.967013] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.967017] usb usb2: Product: EHCI Host Controller
[ 0.967026] ahci 0000:03:00.0: AHCI 0001.0000 32 slots 2 ports 3 Gbps 0x3 impl SATA mode
[ 0.967037] ahci 0000:03:00.0: flags: 64bit ncq led clo pmp pio
[ 0.967044] usb usb2: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd
[ 0.967047] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.967055] ahci 0000:03:00.0: setting latency timer to 64
[ 0.967096] usb usb2: configuration #1 chosen from 1 choice
[ 0.967116] hub 2-0:1.0: USB hub found
[ 0.967119] hub 2-0:1.0: 2 ports detected
[ 0.967153] scsi8 : ahci
[ 0.967200] scsi9 : ahci
[ 0.967263] ata9: SATA max UDMA/133 abar m8192@0xf7dfa000 port 0xf7dfa100 irq 18
[ 0.967267] ata10: SATA max UDMA/133 abar m8192@0xf7dfa000 port 0xf7dfa180 irq 18
[ 0.995894] pata_sil680 0000:07:01.0: version 0.4.9
[ 0.995903] pata_sil680 0000:07:01.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[ 0.995923] sil680: 133MHz clock.
[ 0.995978] scsi10 : pata_sil680
[ 0.996021] scsi11 : pata_sil680
[ 0.996044] ata11: PATA max UDMA/133 cmd 0xec00 ctl 0xe880 bmdma 0xe400 irq 21
[ 0.996046] ata12: PATA max UDMA/133 cmd 0xe800 ctl 0xe480 bmdma 0xe408 irq 21
[ 1.159078] ata11.00: ATAPI: HL-DT-STDVD-RAM GH22LP20, 1.00, max UDMA/66
[ 1.175095] ata11.00: configured for UDMA/66
[ 1.206587] usb 1-1: new high speed USB device using ehci_hcd and address 2
[ 1.286481] ata9: SATA link down (SStatus 0 SControl 300)
[ 1.286487] ata10: SATA link down (SStatus 0 SControl 300)
[ 1.342729] usb 1-1: New USB device found, idVendor=8087, idProduct=0020
[ 1.342733] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.342802] usb 1-1: configuration #1 chosen from 1 choice
[ 1.342866] hub 1-1:1.0: USB hub found
[ 1.342970] hub 1-1:1.0: 6 ports detected
[ 1.438215] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.443898] ata3.00: ATA-8: SAMSUNG HD103SJ, 1AJ100E4, max UDMA/133
[ 1.443903] ata3.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 1.449656] ata3.00: configured for UDMA/133
[ 1.454187] usb 2-1: new high speed USB device using ehci_hcd and address 2
[ 1.458238] firewire_core: created device fw0: GUID 001fc6000002bdca, S400
[ 1.462271] scsi 2:0:0:0: Direct-Access ATA SAMSUNG HD103SJ 1AJ1 PQ: 0 ANSI: 5
[ 1.586350] usb 2-1: New USB device found, idVendor=8087, idProduct=0020
[ 1.586355] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.586427] usb 2-1: configuration #1 chosen from 1 choice
[ 1.586633] hub 2-1:1.0: USB hub found
[ 1.586720] hub 2-1:1.0: 8 ports detected
[ 1.657984] usb 1-1.3: new high speed USB device using ehci_hcd and address 3
[ 1.852934] usb 1-1.3: New USB device found, idVendor=090c, idProduct=6000
[ 1.852938] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.852942] usb 1-1.3: Product: USB2.0 Card Reader
[ 1.852945] usb 1-1.3: Manufacturer: Generic , .
[ 1.852948] usb 1-1.3: SerialNumber: 12345678901234567890
[ 1.853012] usb 1-1.3: configuration #1 chosen from 1 choice
[ 1.856676] Initializing USB Mass Storage driver...
[ 1.856733] scsi12 : SCSI emulation for USB Mass Storage devices
[ 1.856773] usb-storage: device found at 3
[ 1.856774] usb-storage: waiting for device to settle before scanning
[ 1.856784] usbcore: registered new interface driver usb-storage
[ 1.856786] USB Mass Storage support registered.
[ 1.925451] usb 2-1.2: new full speed USB device using ehci_hcd and address 3
[ 2.020168] usb 2-1.2: New USB device found, idVendor=046d, idProduct=c52b
[ 2.020172] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.020176] usb 2-1.2: Product: USB Receiver
[ 2.020179] usb 2-1.2: Manufacturer: Logitech
[ 2.020248] usb 2-1.2: configuration #1 chosen from 1 choice
[ 2.089193] usb 2-1.5: new high speed USB device using ehci_hcd and address 4
[ 2.185292] usb 2-1.5: New USB device found, idVendor=0409, idProduct=005a
[ 2.185296] usb 2-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.185362] usb 2-1.5: configuration #1 chosen from 1 choice
[ 2.185440] hub 2-1.5:1.0: USB hub found
[ 2.185535] hub 2-1.5:1.0: 3 ports detected
[ 2.256928] usb 2-1.6: new low speed USB device using ehci_hcd and address 5
[ 2.348705] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.387846] ata4.00: ATA-8: ST9250410ASG, 0004SDM1, max UDMA/133
[ 2.387850] ata4.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 2.390339] ata4.00: configured for UDMA/133
[ 2.395712] usb 2-1.6: New USB device found, idVendor=051d, idProduct=0002
[ 2.395716] usb 2-1.6: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2.395719] usb 2-1.6: Product: Back-UPS BR 800 FW:9.o5 .I USB FW:o5
[ 2.395722] usb 2-1.6: Manufacturer: American Power Conversion
[ 2.395725] usb 2-1.6: SerialNumber: JB0945001168
[ 2.395791] usb 2-1.6: configuration #1 chosen from 1 choice
[ 2.404701] scsi 3:0:0:0: Direct-Access ATA ST9250410ASG 0004 PQ: 0 ANSI: 5
[ 2.468604] usb 2-1.7: new full speed USB device using ehci_hcd and address 6
[ 2.570809] usb 2-1.7: New USB device found, idVendor=08e6, idProduct=3437
[ 2.570813] usb 2-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.570817] usb 2-1.7: Product: USB SmartCard Reader
[ 2.570819] usb 2-1.7: Manufacturer: Gemplus
[ 2.570889] usb 2-1.7: configuration #1 chosen from 1 choice
[ 2.656310] usb 2-1.5.2: new full speed USB device using ehci_hcd and address 7
[ 2.724086] ata5: SATA link down (SStatus 0 SControl 300)
[ 2.768127] usb 2-1.5.2: New USB device found, idVendor=046d, idProduct=c318
[ 2.768131] usb 2-1.5.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.768135] usb 2-1.5.2: Product: Logitech Illuminated Keyboard
[ 2.768138] usb 2-1.5.2: Manufacturer: Logitech
[ 2.768208] usb 2-1.5.2: configuration #1 chosen from 1 choice
[ 2.855998] usb 2-1.5.3: new full speed USB device using ehci_hcd and address 8
[ 3.059532] ata6: SATA link down (SStatus 0 SControl 300)
[ 3.163142] usb 2-1.5.3: New USB device found, idVendor=056d, idProduct=0002
[ 3.163146] usb 2-1.5.3: New USB device strings: Mfr=4, Product=14, SerialNumber=0
[ 3.163150] usb 2-1.5.3: Product: EIZO USB HID Monitor
[ 3.163153] usb 2-1.5.3: Manufacturer: EIZO
[ 3.163218] usb 2-1.5.3: configuration #1 chosen from 1 choice
[ 3.394974] ata7: SATA link down (SStatus 0 SControl 300)
[ 3.730789] ata8: SATA link down (SStatus 0 SControl 300)
[ 3.747573] scsi 10:0:0:0: CD-ROM HL-DT-ST DVD-RAM GH22LP20 1.00 PQ: 0 ANSI: 5
[ 3.917527] sd 2:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[ 3.917560] sd 2:0:0:0: [sda] Write Protect is off
[ 3.917562] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.917565] sd 3:0:0:0: [sdb] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 3.917575] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.917595] sd 3:0:0:0: [sdb] Write Protect is off
[ 3.917597] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 3.917610] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.917710] sdb:
[ 3.917748] sda:
[ 3.923264] usbcore: registered new interface driver hiddev
[ 3.924341] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/input/input1
[ 3.924378] generic-usb 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:1d.0-1.2/input0
[ 3.924674] unknown partition table
[ 3.924885] sd 2:0:0:0: [sda] Attached SCSI disk
[ 3.926328] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.1/input/input2
[ 3.926414] generic-usb 0003:046D:C52B.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1d.0-1.2/input1
[ 3.928647] generic-usb 0003:046D:C52B.0003: hiddev1,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.0-1.2/input2
[ 3.962196] sdb1 sdb2 < sdb5 >
[ 3.972065] sd 3:0:0:0: [sdb] Attached SCSI disk
[ 3.976913] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 3.976917] Uniform CD-ROM driver Revision: 3.20
[ 3.976990] sr 10:0:0:0: Attached scsi CD-ROM sr0
[ 3.978988] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 3.979030] sd 3:0:0:0: Attached scsi generic sg1 type 0
[ 3.979048] sr 10:0:0:0: Attached scsi generic sg2 type 5
[ 4.236041] generic-usb 0003:051D:0002.0004: hiddev2,hidraw3: USB HID v1.10 Device [American Power Conversion Back-UPS BR 800 FW:9.o5 .I USB FW:o5 ] on usb-0000:00:1d.0-1.6/input0
[ 4.237485] input: Logitech Logitech Illuminated Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.2/2-1.5.2:1.0/input/input3
[ 4.237519] generic-usb 0003:046D:C318.0005: input,hidraw4: USB HID v1.11 Keyboard [Logitech Logitech Illuminated Keyboard] on usb-0000:00:1d.0-1.5.2/input0
[ 4.239561] input: Logitech Logitech Illuminated Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5.2/2-1.5.2:1.1/input/input4
[ 4.239612] generic-usb 0003:046D:C318.0006: input,hiddev3,hidraw5: USB HID v1.11 Device [Logitech Logitech Illuminated Keyboard] on usb-0000:00:1d.0-1.5.2/input1
[ 6.845526] usb-storage: device scan complete
[ 6.846785] scsi 12:0:0:0: Direct-Access Generic 6000 PQ: 0 ANSI: 0 CCS
[ 6.847055] sd 12:0:0:0: Attached scsi generic sg3 type 0
[ 6.848264] sd 12:0:0:0: [sdc] Attached SCSI removable disk
[ 9.003875] generic-usb 0003:056D:0002.0007: hiddev4,hidraw6: USB HID v1.10 Device [EIZO EIZO USB HID Monitor] on usb-0000:00:1d.0-1.5.3/input0
[ 9.003889] usbcore: registered new interface driver usbhid
[ 9.003890] usbhid: v2.6:USB HID core driver
[ 9.097060] device-mapper: uevent: version 1.0.3
[ 9.097129] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
[ 9.325869] PM: Starting manual resume from disk
[ 9.325871] PM: Resume from partition 254:1
[ 9.325872] PM: Checking hibernation image.
[ 9.326222] PM: Error -22 checking image file
[ 9.326225] PM: Resume from disk failed.
[ 9.358752] EXT4-fs (dm-0): mounted filesystem with ordered data mode
[ 10.519166] udev[575]: starting version 164
[ 10.967802] ACPI: SSDT 00000000dfe880c0 01238 (v01 DpgPmm P001Ist 00000011 INTL 20060113)
[ 10.968146] ACPI: SSDT 00000000dfe89300 004D5 (v01 PmRef P001Cst 00003001 INTL 20060113)
[ 10.968523] Monitor-Mwait will be used to enter C-1 state
[ 10.968525] ACPI: WMI: Mapper loaded
[ 10.968543] Monitor-Mwait will be used to enter C-2 state
[ 10.968595] processor LNXCPU:00: registered as cooling_device0
[ 10.968693] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 10.969051] processor LNXCPU:01: registered as cooling_device1
[ 10.969313] processor LNXCPU:02: registered as cooling_device2
[ 10.970034] processor LNXCPU:03: registered as cooling_device3
[ 11.084145] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input6
[ 11.084190] ACPI: Power Button [PWRB]
[ 11.084224] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input7
[ 11.084242] ACPI: Power Button [PWRF]
[ 11.233916] i801_smbus 0000:00:1f.3: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 11.233919] ACPI: I/O resource 0000:00:1f.3 [0x400-0x41f] conflicts with ACPI region SMRG [0x400-0x40f]
[ 11.233970] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 11.559776] nvidia: module license 'NVIDIA' taints kernel.
[ 11.559779] Disabling lock debugging due to kernel taint
[ 12.081110] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 12.081122] nvidia 0000:01:00.0: setting latency timer to 64
[ 12.081128] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 12.081483] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 260.19.21 Thu Nov 4 21:16:27 PDT 2010
[ 12.351992] alloc irq_desc for 22 on node -1
[ 12.351994] alloc kstat_irqs on node -1
[ 12.352000] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 12.352085] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 12.432016] HDA Intel 0000:01:00.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 12.432018] hda_intel: Disable MSI for Nvidia chipset
[ 12.432108] HDA Intel 0000:01:00.1: setting latency timer to 64
[ 14.272708] loop: module loaded
[ 14.885102] Adding 1949688k swap on /dev/mapper/GV--panolis-VL--swap. Priority:-1 extents:1 across:1949688k
[ 15.306861] input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input8
[ 65.973340] EXT4-fs (dm-4): mounted filesystem with ordered data mode
[ 66.016198] EXT4-fs (dm-5): mounted filesystem with ordered data mode
[ 66.096307] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 66.162265] EXT4-fs (dm-3): mounted filesystem with ordered data mode
[ 66.190871] EXT4-fs (dm-2): mounted filesystem with ordered data mode
[ 67.031907] fuse init (API version 7.13)
[ 73.244971] r8169: eth0: link up
[ 73.244979] r8169: eth0: link up
[ 83.278784] eth0: no IPv6 routers present
[ 92.566499] CPU0 attaching NULL sched-domain.
[ 92.566506] CPU1 attaching NULL sched-domain.
[ 92.566509] CPU2 attaching NULL sched-domain.
[ 92.566513] CPU3 attaching NULL sched-domain.
[ 92.591563] CPU0 attaching sched-domain:
[ 92.591567] domain 0: span 0-3 level MC
[ 92.591571] groups: 0 1 2 3
[ 92.591580] CPU1 attaching sched-domain:
[ 92.591583] domain 0: span 0-3 level MC
[ 92.591587] groups: 1 2 3 0
[ 92.591594] CPU2 attaching sched-domain:
[ 92.591597] domain 0: span 0-3 level MC
[ 92.591601] groups: 2 3 0 1
[ 92.591608] CPU3 attaching sched-domain:
[ 92.591611] domain 0: span 0-3 level MC
[ 92.591614] groups: 3 0 1 2
[ 126.399550] hda-intel: azx_get_response timeout, switching to polling mode: last cmd=0x01ef0100
[ 156.234296] usb 1-1.2: new high speed USB device using ehci_hcd and address 4
[ 156.330291] usb 1-1.2: New USB device found, idVendor=059f, idProduct=100a
[ 156.330296] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 156.330300] usb 1-1.2: Product: 2big triple
[ 156.330302] usb 1-1.2: Manufacturer: LaCie
[ 156.330305] usb 1-1.2: SerialNumber: 00D04B841709BB85
[ 156.330427] usb 1-1.2: configuration #1 chosen from 1 choice
[ 156.332540] scsi13 : SCSI emulation for USB Mass Storage devices
[ 156.332731] usb-storage: device found at 4
[ 156.332735] usb-storage: waiting for device to settle before scanning
[ 156.335954] input: LaCie 2big triple as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/input/input9
[ 156.336051] generic-usb 0003:059F:100A.0008: input,hidraw7: USB HID v1.11 Device [LaCie 2big triple] on usb-0000:00:1a.0-1.2/input1
[ 161.322339] usb-storage: device scan complete
[ 161.323209] scsi 13:0:0:0: Direct-Access ST350062 0AS SD25 PQ: 0 ANSI: 4
[ 161.324051] scsi 13:0:0:1: Direct-Access SAMSUNG HD103SJ 1AJ1 PQ: 0 ANSI: 4
[ 161.325034] sd 13:0:0:0: Attached scsi generic sg4 type 0
[ 161.325715] sd 13:0:0:1: Attached scsi generic sg5 type 0
[ 161.326213] sd 13:0:0:0: [sdd] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 161.327287] sd 13:0:0:0: [sdd] Write Protect is off
[ 161.327292] sd 13:0:0:0: [sdd] Mode Sense: 10 00 00 00
[ 161.327296] sd 13:0:0:0: [sdd] Assuming drive cache: write through
[ 161.327862] sd 13:0:0:1: [sde] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[ 161.328959] sd 13:0:0:1: [sde] Write Protect is off
[ 161.328963] sd 13:0:0:1: [sde] Mode Sense: 10 00 00 00
[ 161.328966] sd 13:0:0:1: [sde] Assuming drive cache: write through
[ 161.330496] sd 13:0:0:0: [sdd] Assuming drive cache: write through
[ 161.330502] sdd: sdd1
[ 161.348610] sd 13:0:0:1: [sde] Assuming drive cache: write through
[ 161.348617] sde: sde1
[ 161.355792] sd 13:0:0:0: [sdd] Assuming drive cache: write through
[ 161.355799] sd 13:0:0:0: [sdd] Attached SCSI disk
[ 161.365230] sd 13:0:0:1: [sde] Assuming drive cache: write through
[ 161.365236] sd 13:0:0:1: [sde] Attached SCSI disk
[ 230.675224] padlock: VIA PadLock not detected.
[ 230.706047] padlock: VIA PadLock Hash Engine not detected.
[ 240.672355] EXT4-fs (dm-6): mounted filesystem with ordered data mode
[ 269.529128] kjournald starting. Commit interval 5 seconds
[ 269.530757] EXT3 FS on sdd1, internal journal
[ 269.530764] EXT3-fs: mounted filesystem with ordered data mode.
