Bonsoir,
J’utilise nouveau en lieu et place du driver proprio nvidia sur ma machine. Tout fonctionne y compris l’accélération 3d. Seul bémol, depuis aujourd’hui (j’ai mis à jour hier je suis en sid) j’ai des messages de ce type toutes les 10 secondes dans mon dmesg
[ 104.136196] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 104.136200] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 104.136203] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 104.136205] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 104.136207] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 104.136209] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 104.136211] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 104.136213] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 104.136215] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 104.136217] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 104.136218]
[ 104.233240] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 104.233243] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 104.233244] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 104.233247] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 104.233249] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 104.233251] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 104.233253] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 104.233255] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 104.233257] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 104.233258] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 104.233260]
[ 104.330286] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 104.330288] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 104.330290] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 104.330292] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 104.330294] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 104.330296] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 104.330298] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 104.330300] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 104.330302] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 104.330304] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 104.330306]
[ 104.427327] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 104.427329] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 104.427330] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 104.427333] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 104.427335] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 104.427336] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 104.427338] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 104.427340] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 104.427342] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 104.427344] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 104.427346]
[ 104.427349] nouveau 0000:01:00.0: DVI-I-1: EDID block 0 invalid.
[ 104.427352] [drm] nouveau 0000:01:00.0: DDC responded, but no EDID for DVI-I-1
[ 104.540097] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 104.540100] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 104.540103] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 104.540106] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 104.540108] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 104.540110] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 104.540112] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 104.540114] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 104.540116] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 104.540118] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 104.540119]
[ 104.637175] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 104.637177] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 104.637179] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 104.637181] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 104.637183] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 104.637185] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 104.637187] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 104.637189] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 104.637191] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 104.637193] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 104.637194]
[ 104.734219] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 104.734221] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 104.734223] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 104.734225] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 104.734227] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 104.734229] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 104.734231] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 104.734233] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 104.734235] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 104.734237] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 104.734238]
[ 104.831285] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 104.831287] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 104.831289] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 104.831291] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 104.831293] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 104.831295] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 104.831297] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 104.831299] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 104.831301] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 104.831303] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 104.831304]
[ 104.831308] nouveau 0000:01:00.0: DVI-I-1: EDID block 0 invalid.
[ 104.831311] [drm] nouveau 0000:01:00.0: DDC responded, but no EDID for DVI-I-1
[ 104.995370] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 104.995374] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 104.995376] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 104.995378] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 104.995380] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 104.995383] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 104.995385] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 104.995387] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 104.995389] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 104.995390] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 104.995392]
[ 105.092466] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 105.092468] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 105.092470] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 105.092472] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 105.092474] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 105.092476] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 105.092478] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 105.092480] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 105.092482] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 105.092484] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 105.092485]
[ 105.189507] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 105.189509] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 105.189511] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 105.189513] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 105.189515] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 105.189517] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 105.189519] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 105.189521] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 105.189523] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 105.189525] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 105.189527]
[ 105.286547] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 105.286549] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 105.286551] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 105.286553] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 105.286555] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 105.286557] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 105.286559] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 105.286561] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 105.286563] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 105.286565] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 105.286567]
[ 105.286569] nouveau 0000:01:00.0: DVI-I-1: EDID block 0 invalid.
[ 105.286572] [drm] nouveau 0000:01:00.0: DDC responded, but no EDID for DVI-I-1
[ 108.529082] [drm] nouveau 0000:01:00.0: unplugged DVI-I-1
[ 108.685129] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 144
[ 108.685132] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 108.685134] <3>0f ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 108.685136] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 108.685138] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 108.685140] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 108.685142] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 108.685144] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 108.685146] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 108.685148] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 108.685149]
[ 108.783451] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 108.783453] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 108.783455] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 108.783458] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 108.783460] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 108.783462] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 108.783464] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 108.783466] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 108.783468] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 108.783470] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 108.783471]
[ 108.880501] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 108.880503] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 108.880505] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 108.880507] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 108.880509] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 108.880511] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 108.880513] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 108.880515] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 108.880517] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 108.880519] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 108.880520]
[ 108.977542] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 244
[ 108.977544] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 108.977546] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 108.977548] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 108.977550] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 108.977552] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 108.977554] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 108.977556] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 108.977558] <3>4b 18 52 0e 00 0a 20 20 20 20 20 20 00 00 00 fc K.R... ....
[ 108.977560] <3>00 56 41 31 39 31 36 77 53 45 52 49 45 53 00 05 .VA1916wSERIES..
[ 108.977561]
[ 108.977564] nouveau 0000:01:00.0: DVI-I-1: EDID block 0 invalid.
[ 108.977566] [drm] nouveau 0000:01:00.0: DDC responded, but no EDID for DVI-I-1
[ 108.985001] [drm] nouveau 0000:01:00.0: unplugged DVI-I-1
[ 109.088442] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 101
[ 109.088445] [drm:drm_edid_block_valid] *ERROR* Raw EDID:
[ 109.088447] <3>00 ff ff ff ff ff ff 00 5a 63 1f f9 01 01 01 01 ........Zc......
[ 109.088449] <3>03 12 01 03 08 29 1a 78 00 e5 b5 a3 55 49 99 27 .....).x....UI.'
[ 109.088451] <3>13 50 54 bf ef 80 95 00 95 0f 81 80 81 40 71 4f .PT..........@qO
[ 109.088453] <3>01 01 01 03 01 01 9a 29 a0 d0 51 84 22 30 50 50 .......)..Q."0PP
[ 109.088455] <3>36 00 9a 00 11 00 00 1c 00 00 00 ff 00 51 4e 30 6............QN0
[ 109.088457] <3>30 38 30 33 32 34 32 33 36 0a 00 00 00 fd 00 32 080324236......2
[ 109.088459] <3>4b 18 52 0e 01 ff ff ff ff ff ff ff ff ff ff ff K.R.............
[ 109.088460] <3>ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
[ 109.088462]
[ 109.106966] [drm] nouveau 0000:01:00.0: DDC responded, but no EDID for DVI-I-1
De plus, pendant cet intervalle de temps, la machine lag.
Pour ceux qui ont ce problème j’ai un petit moyen de contournement en attendant que ce bug cesse, il s’agit de débrancher et rebrancher son cable reliant l’écran à l’UC (VGA avec adapteur DVI dans mon cas).
