J’ai une Debian Etch et je voudrais utiliser un scanner Primax 19200 usb.
J’ai trouver un driver sur:
homepages.paradise.net.nz/stevenel/scanner/
Les consignes sont les suivantes:
Hopefully the process of patching both SANE and the kernel have now been simplified
Patch your kernel with the supplied file to enable the E3 and E4 support
Install the updated scanner.o file into your modules directory and “modprobe scanner”
Download the 1.0.9 sane backend and unpack
Patch the source with the supplied diff file from the download directory
gunzip -c e3_driver_0.6.diff.gz | patch -p1 -
Now build and install the sane release as normal
Once build try “scanimage -L” to see if it detects your scanner
If this fails type “export SANE_DEBUG_VIDEO=128” and retry the above
Also refer to the FAQ page for more tips on debugging
Note you will still need some support files as detailed in the 0.4 notes below
Mais je suis un peu perdu. Je me demande quel fichier il demande.
allopilij:/usr/src# gunzip -c e3_driver_0.6.diff.gz | patch -p1
can’t find file to patch at input line 4
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff -r -c -N sane-backends-1.0.9/AUTHORS sane-backends-1.0.9.viceo/AUTHORS
|*** sane-backends-1.0.9/AUTHORS Sun Sep 1 04:13:48 2002
| — sane-backends-1.0.9.viceo/AUTHORS Mon Oct 28 17:25:10 2002 |
File to patch:
De plus, je n’ai pas de module scanner comme cité ci-dessus.
Je suis complètement perdu.
Merci de votre attention
