[quote] Debian package for ov51x-jpeg
I have released a debian package that allows you to build your own ov51x-jpeg module using module-assistant. If you are using debian unstable, this package is now included with the distribution.
* You should use this source in your /etc/apt/sources.list:
ov51x-jpeg repository
deb rastageeks.org/downloads/debian binary/
(backport sources have been removed since they are not needed any more)
* You can also grab the sources, either with this source in /etc/apt/sources.list:
deb-src rastageeks.org/downloads/debian source/
Or at this point: rastageeks.org/downloads/debian/source/
Read installation instructions for how to build and install the module. [/quote]
Ben ds ton lien, il est précisé qu’il existe un paquet Debian de ton module et que tu peux ensuite l’installer avec ‘module assistant’.
Je viens de vérifier et en effet, sous Sid, le paquet
ov51x-jpeg-source
existe donc vérifie s’il existe chez toi (etch, lenny, sid ???)
ensuite, tu l’installeras avec m-a
