Dropbear client authentification sur serveur open-ssh
Je tente avec désespoir maintenant de m’authentifier depuis un client dropbear sur mon serveur qui a openssh.
Ca fonctionne bien par mot de passe mais j’aimerais m’authentifier par clef. Voila comment j’ai procédé :
En premier je génère mes clefs :
dropbearkey -t rsa -f /home/root/id_rsa
ensuite je prends que la partie public de la clef et je la colle dans le fichieruthorized_keys2:
dropbearkey -y -f /home/root/id_rsa |grep ssh-rsa >> /home/root/authorized_keys2
j’envoie le fichier sur mon serveur :
scp /home/root/authorized_keys2 jimbo@192.168.1.100:/root/.ssh
je tente de me connecter et la c’est le drame :
ssh -vv jim@192.168.30.145 OpenSSH_5.8p1 Debian-7ubuntu1, OpenSSL 1.0.0e 6 Sep 2011 debug1: Reading configuration data /etc/ssh/ssh_config debug1: Applying options for * debug2: ssh_connect: needpriv 0 debug1: Connecting to 192.168.30.145 [192.168.30.145] port 22. debug1: Connection established. debug1: identity file /home/jim/.ssh/id_rsa type -1 debug1: identity file /home/jim/.ssh/id_rsa-cert type -1 debug1: identity file /home/jim/.ssh/id_dsa type -1 debug1: identity file /home/jim/.ssh/id_dsa-cert type -1 debug1: identity file /home/jim/.ssh/id_ecdsa type -1 debug1: identity file /home/jim/.ssh/id_ecdsa-cert type -1 debug1: Remote protocol version 2.0, remote software version OpenSSH_5.8p1 Debian-1ubuntu3 debug1: match: OpenSSH_5.8p1 Debian-1ubuntu3 pat OpenSSH* debug1: Enabling compatibility mode for protocol 2.0 debug1: Local version string SSH-2.0-OpenSSH_5.8p1 Debian-7ubuntu1 debug2: fd 3 setting O_NONBLOCK debug1: SSH2_MSG_KEXINIT sent debug1: SSH2_MSG_KEXINIT received debug2: kex_parse_kexinit: ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1 debug2: kex_parse_kexinit: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-rsa-cert-v01@openssh.com,ssh-dss-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-dss-cert-v00@openssh.com,ssh-rsa,ssh-dss debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96 debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96 debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib debug2: kex_parse_kexinit: debug2: kex_parse_kexinit: debug2: kex_parse_kexinit: first_kex_follows 0 debug2: kex_parse_kexinit: reserved 0 debug2: kex_parse_kexinit: ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1 debug2: kex_parse_kexinit: ssh-rsa,ssh-dss,ecdsa-sha2-nistp256 debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96 debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96 debug2: kex_parse_kexinit: none,zlib@openssh.com debug2: kex_parse_kexinit: none,zlib@openssh.com debug2: kex_parse_kexinit: debug2: kex_parse_kexinit: debug2: kex_parse_kexinit: first_kex_follows 0 debug2: kex_parse_kexinit: reserved 0 debug2: mac_setup: found hmac-md5 debug1: kex: server->client aes128-ctr hmac-md5 none debug2: mac_setup: found hmac-md5 debug1: kex: client->server aes128-ctr hmac-md5 none debug1: sending SSH2_MSG_KEX_ECDH_INIT debug1: expecting SSH2_MSG_KEX_ECDH_REPLY debug1: Server host key: ECDSA 7c:fe:14:ba:3f:7c:b5:98:14:58:f8:a4:ea:ab:da:fd debug1: Host '192.168.30.145' is known and matches the ECDSA host key. debug1: Found key in /home/jim/.ssh/known_hosts:1 debug1: ssh_ecdsa_verify: signature correct debug2: kex_derive_keys debug2: set_newkeys: mode 1 debug1: SSH2_MSG_NEWKEYS sent debug1: expecting SSH2_MSG_NEWKEYS debug2: set_newkeys: mode 0 debug1: SSH2_MSG_NEWKEYS received debug1: Roaming not allowed by server debug1: SSH2_MSG_SERVICE_REQUEST sent debug2: service_accept: ssh-userauth debug1: SSH2_MSG_SERVICE_ACCEPT received debug2: key: /home/jim/.ssh/id_rsa ((nil)) debug2: key: /home/jim/.ssh/id_dsa ((nil)) debug2: key: /home/jim/.ssh/id_ecdsa ((nil)) debug1: Authentications that can continue: publickey debug1: Next authentication method: publickey debug1: Trying private key: /home/jim/.ssh/id_rsa debug1: key_parse_private_pem: PEM_read_PrivateKey failed debug1: read PEM private key done: type <unknown> Enter passphrase for key '/home/jim/.ssh/id_rsa': debug2: no passphrase given, try next key debug1: Trying private key: /home/jim/.ssh/id_dsa debug1: Trying private key: /home/jim/.ssh/id_ecdsa debug2: we did not send a packet, disable method debug1: No more authentication methods to try. Permission denied (publickey). jim@jim-Latitude-D420:~/.ssh$ ssh -vv jim@192.168.30.145 OpenSSH_5.8p1 Debian-7ubuntu1, OpenSSL 1.0.0e 6 Sep 2011 debug1: Reading configuration data /etc/ssh/ssh_config debug1: Applying options for * debug2: ssh_connect: needpriv 0 debug1: Connecting to 192.168.30.145 [192.168.30.145] port 22. debug1: Connection established. debug1: identity file /home/jim/.ssh/id_rsa type -1 debug1: identity file /home/jim/.ssh/id_rsa-cert type -1 debug1: identity file /home/jim/.ssh/id_dsa type -1 debug1: identity file /home/jim/.ssh/id_dsa-cert type -1 debug1: identity file /home/jim/.ssh/id_ecdsa type -1 debug1: identity file /home/jim/.ssh/id_ecdsa-cert type -1 debug1: Remote protocol version 2.0, remote software version OpenSSH_5.8p1 Debian-1ubuntu3 debug1: match: OpenSSH_5.8p1 Debian-1ubuntu3 pat OpenSSH* debug1: Enabling compatibility mode for protocol 2.0 debug1: Local version string SSH-2.0-OpenSSH_5.8p1 Debian-7ubuntu1 debug2: fd 3 setting O_NONBLOCK debug1: SSH2_MSG_KEXINIT sent debug1: SSH2_MSG_KEXINIT received debug2: kex_parse_kexinit: ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1 debug2: kex_parse_kexinit: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-rsa-cert-v01@openssh.com,ssh-dss-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-dss-cert-v00@openssh.com,ssh-rsa,ssh-dss debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96 debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96 debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib debug2: kex_parse_kexinit: debug2: kex_parse_kexinit: debug2: kex_parse_kexinit: first_kex_follows 0 debug2: kex_parse_kexinit: reserved 0 debug2: kex_parse_kexinit: ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1 debug2: kex_parse_kexinit: ssh-rsa,ssh-dss,ecdsa-sha2-nistp256 debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96 debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96 debug2: kex_parse_kexinit: none,zlib@openssh.com debug2: kex_parse_kexinit: none,zlib@openssh.com debug2: kex_parse_kexinit: debug2: kex_parse_kexinit: debug2: kex_parse_kexinit: first_kex_follows 0 debug2: kex_parse_kexinit: reserved 0 debug2: mac_setup: found hmac-md5 debug1: kex: server->client aes128-ctr hmac-md5 none debug2: mac_setup: found hmac-md5 debug1: kex: client->server aes128-ctr hmac-md5 none debug1: sending SSH2_MSG_KEX_ECDH_INIT debug1: expecting SSH2_MSG_KEX_ECDH_REPLY debug1: Server host key: ECDSA 7c:fe:14:ba:3f:7c:b5:98:14:58:f8:a4:ea:ab:da:fd debug1: Host '192.168.30.145' is known and matches the ECDSA host key. debug1: Found key in /home/jim/.ssh/known_hosts:1 debug1: ssh_ecdsa_verify: signature correct debug2: kex_derive_keys debug2: set_newkeys: mode 1 debug1: SSH2_MSG_NEWKEYS sent debug1: expecting SSH2_MSG_NEWKEYS debug2: set_newkeys: mode 0 debug1: SSH2_MSG_NEWKEYS received debug1: Roaming not allowed by server debug1: SSH2_MSG_SERVICE_REQUEST sent debug2: service_accept: ssh-userauth debug1: SSH2_MSG_SERVICE_ACCEPT received debug2: key: /home/jim/.ssh/id_rsa ((nil)) debug2: key: /home/jim/.ssh/id_dsa ((nil)) debug2: key: /home/jim/.ssh/id_ecdsa ((nil)) debug1: Authentications that can continue: publickey debug1: Next authentication method: publickey debug1: Trying private key: /home/jim/.ssh/id_rsa debug1: key_parse_private_pem: PEM_read_PrivateKey failed debug1: read PEM private key done: type <unknown> Enter passphrase for key '/home/jim/.ssh/id_rsa': debug2: no passphrase given, try next key debug1: Trying private key: /home/jim/.ssh/id_dsa debug1: Trying private key: /home/jim/.ssh/id_ecdsa debug2: we did not send a packet, disable method debug1: No more authentication methods to try. Permission denied (publickey).
Côté serveur en mode debug,se qui malheureusement n’apporte pas vraiment n’information :
Mar 29 08:11:36 jim-HP-Compaq-dc7900-Ultra-Slim-Desktop sshd[21233]: debug1: Forked child 23278. sshd[23278]: Set /proc/self/oom_score_adj to 0 sshd[23278]: debug1: rexec start in 5 out 5 newsock 5 pipe 7 sock 8 sshd[23278]: debug1: inetd sockets after dupping: 3, 3 sshd[23278]: Connection from 192.168.30.147 port 41039 sshd[23278]: debug1: Client protocol version 2.0; client software version OpenSSH_5.8p1 Debian-7ubuntu1 sshd[23278]: debug1: match: OpenSSH_5.8p1 Debian-7ubuntu1 pat OpenSSH* sshd[23278]: debug1: Enabling compatibility mode for protocol 2.0 sshd[23278]: debug1: Local version string SSH-2.0-OpenSSH_5.8p1 Debian-1ubuntu3 sshd[23278]: debug1: PAM: initializing for "jim" sshd[23278]: debug1: PAM: setting PAM_RHOST to "jim-latitude-d420.local" shd[23278]: debug1: PAM: setting PAM_TTY to "ssh" sshd[23278]: debug1: do_cleanup sshd[23278]: debug1: PAM: cleanup
Droit sur le dossier et fichier :
.ssh# ls -alh total 12K drwx------ 2 jim jim 4.0K 2012-03-28 09:05 . drwx------ 24 jim jim 4.0K 2012-03-27 14:43 .. -rw------- 1 root root 235 2012-03-28 11:27 authorized_keys
et le fichier authorized_keys à une tête normal a comparé de celui généré par open-ssh :
ssh-rsa AAAAB3NzaC1yc2EAA blablablabnal kGeDZSZs jim@jim-Latitude-D420
vous auriez une piste de recherche ?
