[code]### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
load_env
fi
set default=“0"
if [ “${prev_saved_entry}” ]; then
set saved_entry=”${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z “${boot_once}” ]; then
saved_entry="${chosen}"
fi
function load_video {
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
insmod part_msdos
insmod ext2
set root=’(hd0,msdos1)‘
search --no-floppy --fs-uuid --set=root 5240a51d-b7c4-4bf7-9c9f-3624336a3bc7
if loadfont /usr/share/grub/unicode.pf2 ; then
set gfxmode=640x480
load_video
insmod gfxterm
insmod part_msdos
insmod ext2
set root=’(hd0,msdos1)'
set locale_dir=($root)/boot/grub/locale
set lang=fr_FR
insmod gettext
fi
terminal_output gfxterm
set timeout=5
END /etc/grub.d/00_header
BEGIN /etc/grub.d/05_debian_theme
insmod part_msdos
insmod ext2
insmod png
if background_image /usr/share/images/desktop-base/joy-grub.png; then
set color_normal=white/black
set color_highlight=black/white
else
set menu_color_normal=cyan/blue
set menu_color_highlight=white/blue
fi
END /etc/grub.d/05_debian_theme
BEGIN /etc/grub.d/10_linux
menuentry ‘Debian GNU/Linux, avec Linux 3.2.0-4-amd64’ --class debian --class gnu-linux --class gnu --class os {
load_video
insmod gzio
insmod part_msdos
insmod ext2
echo 'Chargement de Linux 3.2.0-4-amd64 …'
linux /boot/vmlinuz-3.2.0-4-amd64 root=UUID=5240a51d-b7c4-4bf7-9c9f-3624336a3bc7 ro initrd=/install/gtk/initrd.gz quiet
echo 'Chargement du disque mémoire initial …‘
initrd /boot/initrd.img-3.2.0-4-amd64
menuentry ‘Debian GNU/Linux, avec Linux 3.2.0-4-amd64 (mode de dépannage)’ --class debian --class gnu-linux --class gnu --class os {
load_video
insmod gzio
insmod part_msdos
insmod ext2
linux /boot/vmlinuz-3.2.0-4-amd64 root=UUID=5240a51d-b7c4-4bf7-9c9f-3624336a3bc7 ro single initrd=/install/gtk/initrd.gz
echo 'Chargement du disque mémoire initial …'
END /etc/grub.d/10_linux
BEGIN /etc/grub.d/20_linux_xen
END /etc/grub.d/20_linux_xen
BEGIN /etc/grub.d/20_memtest86+
menuentry “Memory test (memtest86+)” {
insmod part_msdos
insmod ext2
linux16 /boot/memtest86+.bin
menuentry “Memory test (memtest86+, serial console 115200)” {
insmod part_msdos
insmod ext2
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
menuentry “Memory test (memtest86+, experimental multiboot)” {
insmod part_msdos
insmod ext2
multiboot /boot/memtest86+_multiboot.bin
menuentry “Memory test (memtest86+, serial console 115200, experimental multiboot)” {
insmod part_msdos
insmod ext2
multiboot /boot/memtest86+_multiboot.bin console=ttyS0,115200n8
END /etc/grub.d/20_memtest86+
BEGIN /etc/grub.d/30_os-prober
END /etc/grub.d/30_os-prober
BEGIN /etc/grub.d/40_custom
This file provides an easy way to add custom menu entries. Simply type the
menu entries you want to add after this comment. Be careful not to change
the ‘exec tail’ line above.
END /etc/grub.d/40_custom
BEGIN /etc/grub.d/41_custom
if [ -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
END /etc/grub.d/41_custom ###[/code]
Mon install s’est bien passée, debian detecte mon disque sous windows et il semble intact.
Cependant, aucune trace de cet OS dans grub.cfg
