C’est une très bonne idée.
J’ai installé manuellement nvidia-settings, via un .deb. En exécutant nvidia-settings, je reçois le message ``You do not appear to be using the NVIDIA X driver. Please edit your X configuration file (just run nvidia-xconfig as root), and restart the X server.’’ Le problème, c’est que ça ne me reconna^it pas la commande, lorsque je tape nvidia-xconfig. Du coup, je me suis dit qu’il était peut-^etre bien d’installer nvidia-glx. Ce n’est pas si simple, puisque # dpkg -i nvidia-glx_173.14.09-5_i386.deb
Selecting previously deselected package nvidia-glx.
(Reading database ... 174311 files and directories currently installed.)
Unpacking nvidia-glx (from nvidia-glx_173.14.09-5_i386.deb) ...
dpkg: dependency problems prevent configuration of nvidia-glx:
nvidia-glx depends on nvidia-kernel-173.14.09; however:
Package nvidia-kernel-173.14.09 is not installed.
Pas un problème: [code]
apt-get -s install nvidia-kernel-173.14.09
Reading package lists… Done
Building dependency tree
Reading state information… Done
Package nvidia-kernel-173.14.09 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Il faut rester calme!
Je télécharge nvidia-kernel-173.14.09. Pas de chance, il faut nvidia-kernel-common. Je l’installe. J’installe tout, dans le sens inverse, forcément. Tout va bien, mais [code]
nvidia-xconfig
bash: nvidia-xconfig: command not found
Il fallait simplement installer nvidia-xconfig. Je l’installe. Du coup,
# nvidia-xconfig
Using X configuration file: "/etc/X11/xorg.conf".
VALIDATION ERROR: Data incomplete in file /etc/X11/xorg.conf.
At least one Device section is required.
Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.backup'
New X configuration file written to '/etc/X11/xorg.conf'
Est-ce positif? Cela étant, toujours le m^eme message de la part de nvidia-settings. Pourtant,
[code]
cat xorg.conf
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 1.0 (buildd@ninsei) Fri Sep 5 22:23:08 UTC 2008
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice “Keyboard0” "CoreKeyboard"
InputDevice “Mouse0” "CorePointer"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section “InputDevice”
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option “Protocol” "auto"
Option “Device” "/dev/psaux"
Option “Emulate3Buttons” "no"
Option “ZAxisMapping” "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 30.0 - 110.0
VertRefresh 50.0 - 150.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
[/code], de sorte qu’il y a au moins un élément dans la section “Device”!
Mon intuition m’a dit de redémarrer, et, en redémarrant, tout a fonctionné. Merci!
