Salut!!
Voci le config.h
[code]#define MOD ALT(‘g’)
/* you can at most specifiy MAX_ARGS (2) number of arguments */
Key keys[] = {
{ MOD, ‘c’, { create, { NULL } } },
{ MOD, ‘x’, { killclient, { NULL } } },
{ MOD, ‘j’, { focusnext, { NULL } } },
{ MOD, ‘u’, { focusnextnm, { NULL } } },
{ MOD, ‘i’, { focusprevnm, { NULL } } },
{ MOD, ‘k’, { focusprev, { NULL } } },
{ MOD, ‘t’, { setlayout, { “[]=” } } },
{ MOD, ‘g’, { setlayout, { “+++” } } },
{ MOD, ‘b’, { setlayout, { “TTT” } } },
{ MOD, ‘m’, { setlayout, { “[ ]” } } },
{ MOD, ’ ', { setlayout, { NULL } } },
{ MOD, ‘h’, { setmwfact, { “-0.05” } } },
{ MOD, ‘l’, { setmwfact, { “+0.05” } } },
{ MOD, ‘.’, { toggleminimize, { NULL } } },
#ifdef CONFIG_STATUSBAR
{ MOD, ‘s’, { togglebar, { NULL } } },
#endif
#ifdef CONFIG_MOUSE
{ MOD, ‘M’, { mouse_toggle, { NULL } } },
#endif
{ MOD, ‘\n’, { zoom , { NULL } } },
{ MOD, ‘1’, { focusn, { “1” } } },
{ MOD, ‘2’, { focusn, { “2” } } },
{ MOD, ‘3’, { focusn, { “3” } } },
{ MOD, ‘4’, { focusn, { “4” } } },
{ MOD, ‘5’, { focusn, { “5” } } },
{ MOD, ‘6’, { focusn, { “6” } } },
{ MOD, ‘7’, { focusn, { “7” } } },
{ MOD, ‘8’, { focusn, { “8” } } },
{ MOD, ‘9’, { focusn, { “9” } } },
{ MOD, ‘q’, { quit, { NULL } } },
{ MOD, ‘G’, { escapekey, { NULL } } },
{ MOD, ‘r’, { redraw, { NULL } } },
{ MOD, ‘X’, { lock, { NULL } } },
{ MOD, ‘B’, { togglebell, { NULL } } },
{ MOD, KEY_PPAGE, { scrollback, { “-1” } } },
{ MOD, KEY_NPAGE, { scrollback, { “1” } } },
{ MOD, ‘?’, { create, { “man dvtm”, “dvtm help” } } },
};[/code]
cleaning
CC dvtm.c
CC madtty.c
CC -o dvtm
stripping executable
installing executable file to /usr/local/bin
installing manual page to /usr/local/share/man/man1
Réaction identique sous X ou en session tty…
Merci bien à toi
