Dysfonctionnement Live USB persistant
Bonjour, et bonne année :slightly_smiling:
Ma Debian Jessie 8, Gnome Shell est installée sur une clef USB en live persistant. je trimbale cette clef sur pleins de postes afin de faire découvrir Debian, ou effectuer des opérations de maintenance.
Depuis quelque temps, je n’arrive plus à explorer les disques locaux des postes, j’ai cette erreur :
Error mounting /dev/sda3 at /media/user/OS: Command-line `mount -t “ntfs” -o “uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177” “/dev/sda3” “/media/user/OS”’ exited with non-zero exit status 21: modprobe: ERROR: could not insert ‘fuse’: Unknown symbol in module, or unknown parameter (see dmesg)
ntfs-3g-mount: fuse device is missing, try ‘modprobe fuse’ as root
Quand je fais:
root:/home/user# modprobe fuse
Donc:
root:/home/user# dmesg | grep -i fuse
[ 14.336477] fuse: Unknown symbol sysfs_create_mount_point (err 0)
[ 14.336651] fuse: Unknown symbol sysfs_remove_mount_point (err 0)
[ 27.794853] fuse: Unknown symbol sysfs_create_mount_point (err 0)
[ 27.795043] fuse: Unknown symbol sysfs_remove_mount_point (err 0)
[ 1780.733711] fuse: Unknown symbol sysfs_create_mount_point (err 0)
[ 1780.733901] fuse: Unknown symbol sysfs_remove_mount_point (err 0)
[ 1784.822687] fuse: Unknown symbol sysfs_create_mount_point (err 0)
[ 1784.822878] fuse: Unknown symbol sysfs_remove_mount_point (err 0)
[ 2940.641499] fuse: Unknown symbol sysfs_create_mount_point (err 0)
[ 2940.641688] fuse: Unknown symbol sysfs_remove_mount_point (err 0)
[ 3047.580276] fuse: Unknown symbol sysfs_create_mount_point (err 0)
[ 3047.580467] fuse: Unknown symbol sysfs_remove_mount_point (err 0)
[ 3477.942258] fuse: Unknown symbol sysfs_create_mount_point (err 0)
[ 3477.942448] fuse: Unknown symbol sysfs_remove_mount_point (err 0)
[ 3641.351166] fuse: Unknown symbol sysfs_create_mount_point (err 0)
[ 3641.351357] fuse: Unknown symbol sysfs_remove_mount_point (err 0)
Je ne sais pas quoi faire :’(
Merci par avance,
Florian
